Results 1 to 8 of 8
Thread: Reductant tank heater fault
    Jun 2017
    Just scanned a 2011 VW Sharan 2.0 TDI with a MIL light on. Fault with reductant heater. Thought I'd post to see if a common fault and see if I could post a full scan correct?
    Any ideas? (I haven't looked myself yet)
    Wednesday,08,November,2017,09:35:55:60494
    VCDS Version: 17.8.0.1  HEX-NET CB: 0.4401.4
    VIN: WVWZZZ7NZBV022449   License Plate: GD11 AEZ
    Mileage: 91160km-56644mi   Repair Order:
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 52 53 56 61
              62 69 72 77
    VIN: WVWZZZ7NZBV022449   Mileage: 91160km-56644miles
    18-Aux. Heat -- Status: Malfunction 1010
       Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
       Component: R4 2,0L EDC   H24 8257
       Revision: 44H24---    Serial number:
       Coding: 001D001A042501080000
       Shop #: WSC 00020 999 00000
       ASAM Dataset: EV_ECM20TDI01103L906018HJ 003006
       ROD: EV_ECM20TDI01103L906018HJ.rod
       VCID: 79BA3082F8351C8ECD-802C
    9655 - Control Circuit for Reductant Tank Heating
              P202A 00 [237] - Open Circuit
                        Fault Frequency: 6
                        Mileage: 90731 km
                        Date: 2017.10.28
                        Time: 07:30:03
                        Engine speed: 1556.00 /min
                        Normed load value: 78.0 %
                        Vehicle speed: 74 km/h
                        Coolant temperature: 45 °C
                        Intake air temperature: 13 °C
                        Voltage terminal 30: 14.760 V
                        Outside air temperature: 11.5 °C
                        Pressure sensor for reducing agent: measured pressure: 5001 hPa
                        Sensor for reducing agent fill level: fill level: 80.36 %
                        Sensor for reducing agent tank temperature: temperature: 14.6 °C
                        Reducing agent pump: activation: 12.53 %
    Readiness: 1 1 0 0 0
       Part No SW: 02E 300 054 Q    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2602
       Revision: 05351112    Serial number: 00001011140789
       Shop #: WSC 00020 790 00000
       VCID: 240431F6E737B166CE-8070
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 L    HW: 7N0 614 109 L
       Component: J104   C3 450M VD7B 0008
       Revision: --H07---    Serial number: 00000003311122
       Coding: 0028186
       VCID: 3620FBBE41AB33F660-8062
       Part No SW: 5K0 907 044 F    HW: 5K0 907 044 F
       Component: Clima-Sharan  H11 0104
       Coding: 0000000009
       VCID: 2E10D3DE71FB0B3628-807A
       Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
       Component: BCM PQ35 B    011 0046
       Revision: BA011001
       Coding: 40180A3B8125F1C0400800C0140000E443511308426D21626480870000C1
       VCID: 3522FCB29CAD38EE69-8060
       Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    110704  31  0032
       Serial number:         110723024450
       Coding: 000D9D
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0022
       Serial number: Y10M12D13h08m31s02S1
       Coding: 0380BB
       Subsystem 3 - Part No: 7N0 951 171
       Component: DWA-Sensor 00  002 0205
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
    02382 - Sensor for Light Detection (G399)
                        Reset counter: 152
                        Mileage: 90572 km
                        Date: 2012.03.18
                        Time: 17:27:43
                            Term 15 On
                        Voltage: 14.00 V
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 7N0 919 475     HW: 7N0 919 475
       Component: PARKHILFE 8K  H04 0010
       Revision: --------    Serial number: 80231034802853
       Coding: 118101
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_EPHVA18VW4280000 001005
       ROD: EV_EPHVA18VW4280000.rod
       VCID: 78BC3586C33F0586B2-802C
       Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
       Component: VW10Airbag01K H07 0013
       Serial number: 003GFPQM2LMN
       Coding: 00314B
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 3E30E39EA19BFBB6B8-806A
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS60795F29139D/
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS60229123139D4
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS60BB741A13DDY
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS60DBA423139DU
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS608B195E139DP
       Part No SW: 5K0 953 521 BD    HW: 5K0 953 569 B
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101214200704
       Coding: 1882240000
       ASAM Dataset: EV_SMLSNGVOLWS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 6FAE0EDAB671423E63-803A
       Coding: E20000
       Part No SW: 7N0 920 970 A    HW: 7N0 920 970 A
       Coding: 440B00
       VCID: 312AC8A260C514CE35-8064
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 A
       Component: Zuheizer        051 2630
       Revision: 00051000    Serial number: 09022126000000
       Coding: 0000041
       VCID: 3228C7AEADC32FD64C-8066
    01444 - Under-Voltage Shut-Off (Automatic)
                000 -  -  - Intermittent
                        Reset counter: 159
                        Mileage: 91119 km
                        Date: 2012.03.29
                        Time: 08:52:07
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 101210F1002971
       Coding: 468003
       VCID: 312AC8A268C514CE35-8064
                        Fault Status: 00110100
                        Reset counter: 153
                        Mileage: 89960 km
                        Date: 2012.03.14
                        Time: 15:13:39
       VCID: 6A981FCE8D93A71634-803E
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669036630
       VCID: 281C25C65B1F5506E2-807C
       Part No SW: 7N0 959 793 D    HW: 7N0 959 793
       Component: TSG FA        H04 0400
       Revision:             Serial number: 0000110543322
       Coding: 011006208001411011
       VCID: 43C6926AC279965ED7-8016
       Part No: 7N0 909 144 L
       Component: EPS_ZFLS Kl. 275    3102
       Revision: 00H17000
       VCID: 3C34E9967F87E9A696-8068
       Part No SW: 7N0 959 792 D    HW: 7N0 959 792
       Component: TSG BF        H04 0400
       Revision:             Serial number: 0000109830261
       VCID: 42C8976EDD639F56DC-8016
       Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
       Component: J540 EPB4  VW-53083 0006
       Revision:   H18       Serial number: 00000000130499
       Coding: 0024067
       Part No SW: 5M0 035 186 AB    HW: 5M0 035 186 AB
       Component: Radio RCD310  016 0049
       Revision: 00000000    Serial number: VWZ1Z2K7863568
       Coding: 0100040004
       VCID: 6C9419D68F67B92646-8038
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: 71AA08A2A84554CE75-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370225881
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
       Component: TSG HL        H03 0400
       Revision:             Serial number: 0000110848287
       Coding: 010004200001411001
       VCID: 45C28C72CC4DA86EF9-8010
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Component: ConWysTrailer H07 0100
       Revision: 3A001001    Serial number: 00000132425721
       Coding: 0100000100000000
       Shop #: WSC 00007 223 174336
       VCID: 302CCDA663CF1DC63A-8064
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H03 0400
       Revision:             Serial number: 0000110848018
       Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007669025065
       Coding: 0A01000000010101
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
    End----------(Elapsed Time: 01:49, VBatt start/end: 12.0V/12.0V)-----------
  2. Likes Dana liked this post
  3. #2
    Jun 2017
    I've just spoken to TPS (Volkswagen Trade Parts) and common replacement of reductant heater £516.12 +vat and / or module £290.31 +vat.
    I will do some wiring checks later on today when I get time.
    MIL light does clear and fault is intermittent.
    My question is, can I code the module if required or does anyone know if it is plugs 'n' play?
    Fault is an intermittent open circuit / under voltage to auxiliary heater element, which TPS think is more likely module fault. Depends really on if the under voltage code is created by an actual voltage test or the fact the temperature sensor in tank doesn't warm up as expected?
    Tartu, Estonia
    Exp. Show heater fault 95%.
    The world is my oyster...
  5. Likes Jack@European_Parts, Uwe, Dana liked this post
    Change the heater and or check wiring to it if tests good..........and ultimately ECU in rare some cases as per the RTFB.
    Should just plug in if just the element purchased......
  7. Likes Dana liked this post
  8. #5
    Nov 2014
    World
    There is a heater repair kit for abt. 200 Euros, part # 7N0198970A, it is pretty easy to install, just take off the rear bumper and the inner fender liner, and unbolt and lower the tank, screw out the older heater and screw in the new one, plug it in and put everything back in place - done!
  9. Likes Jack@European_Parts, Uwe liked this post
  10. #6
    Jun 2017
    Wow, thanks guy. Shows forums are worth the time.
    Heater repair kit good number, but currently on back order 5 - 10 days. Cleared codes and driven 10 miles, so going to let customer have it back and order repair kit. Got to be worth a go at £180.91+VAT. Slightly annoyed TPS weren't forth coming with repair kit when I phoned this morning.
  11. #7
    Nov 2014
    World
    BTW, I just saw there is also a "B"-Version of this repair kit - 7N0198970B - but could not find much further information so you may want to ask your parts guy if this is the replacement part for the "A"-Version and if he got you the right part this time
  12. Likes Jack@European_Parts, Dana liked this post
  13. #8
    Jun 2017
    Apologies been a while. Just to finish tread, fitted supplied repair kit form TPS and all sorted!
  14. Likes Jack@European_Parts, Uwe liked this post
