Results 1 to 3 of 3
Thread: Audi s8 2007
    Mar 2018
    Saudi Arabia
    Audi s8 2007
    i have got this fault , and the engine work not in normal
     Wednesday,04,April,2018,19:32:09:21591
    VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WAUPN44E17N005716   License Plate:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 0E 11 31 15 16 17 19 1D 1E 25 28 34
              36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77
    VIN: WAUPN44E17N005716   Mileage: 90360km-56147miles
    0E-Media Player 1 -- Status: Cannot be reached 1100
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
    1D-Driver Ident. -- Status: OK 0000
    34-Level Control -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    65-Tire Pressure -- Status: Cannot be reached 1100
       Part No SW: 4E0 910 552 B    HW: 4E0 907 552
       Component: 5.2L V10/4V FSI    0050
       Revision: 5AH11---    Serial number: AUX3Z0F6700015
       Coding: 01060000190F0160
       Shop #: WSC 00010 724 71062
       VCID: 211F18635DCCAF7F5D6-8074
    20 Faults Found:
    000275 - Intake Air Temp. Sensor (G42)
                   P0113 - 002 - Signal too High - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:35:26
                        Load: 0.0 %
                        Temperature: 50.0C
                        Temperature: -40.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 10.795 V
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 002 - Signal too Low - MIL ON
                        Fault Status: 11100010
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:35:34
                        RPM: 123 /min
                        Load: 55.3 %
                        Temperature: 51.0C
                        Temperature: -40.0C
                        Voltage: 7.620 V
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 004 - Open Circuit - Intermittent - MIL ON
                        Fault Status: 10100100
                        Fault Frequency: 24
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:35:35
                        RPM: 1785 /min
                        Load: 16.5 %
                        Temperature: 61.0C
                        Temperature: -40.0C
                        Voltage: 11.049 V
    005173 - Secondary Air Pump Relay (J299)
                   P1435 - 002 - Short to Ground - MIL ON
                        Fault Frequency: 24
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:35:35
                        RPM: 2341 /min
                        Load: 24.3 %
                        Temperature: 51.0C
                        Temperature: -40.0C
                        Voltage: 10.287 V
    005153 - Secondary Air Injection Solenoid Valve (N112)
                   P1421 - 002 - Short to Ground - MIL ON
                        Fault Frequency: 25
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:35:35
                        RPM: 2341 /min
                        Load: 24.3 %
                        Temperature: 51.0C
                        Temperature: -40.0C
                        Voltage: 10.287 V
    001112 - Evap System Purge Control Valve (N80)
                   P0458 - 002 - Short to Ground - MIL ON
                        Fault Frequency: 46
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:35:35
                        RPM: 2412 /min
                        Load: 20.4 %
                        Temperature: 51.0C
                        Temperature: -40.0C
                        Voltage: 10.287 V
    000406 - Engine Oil Temp. Sensor (G8)
                   P0196 - 004 - Implausible Signal - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:37:08
                        Load: 0.0 %
                        Temperature: 32.0C
                        Temperature: 33.0C
                        Voltage: 10.668 V
    005464 - Throttle Actuator (G186)
                   P1558 - 002 - Electrical Malfunction - Intermittent
                        Mileage: 90362 km
                        Load: 0.0 %
                        Temperature: 29.0C
                        Temperature: 30.0C
                        Voltage: 11.811 V
    049429 - Second (Slave) Engine Control Module
                   U0115 - 008 - No Communication - Intermittent
                        Load: 0.0 %
                        Temperature: 33.0C
                        Temperature: 32.0C
                        Voltage: 10.922 V
    000080 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
                   P0050 - 004 - Malfunction / Open Circuit - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 00:03:09
                        RPM: 819 /min
                        Load: 89.8 %
                        Temperature: 39.0C
                        Temperature: 33.0C
                        Voltage: 11.811 V
    000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
                   P0057 - 002 - Short to Ground - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 00:04:18
                        RPM: 495 /min
                        Load: 70.2 %
                        Temperature: 63.0C
                        Temperature: -40.0C
                        Voltage: 11.430 V
    000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
                   P0031 - 002 - Short to Ground - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 00:04:21
                        RPM: 568 /min
                        Load: 56.8 %
                        Temperature: 63.0C
                        Temperature: -40.0C
                        Voltage: 12.319 V
    000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                   P0037 - 002 - Short to Ground - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 00:07:34
                        RPM: 692 /min
                        Load: 32.5 %
                        Temperature: 76.0C
                        Temperature: -40.0C
                        Voltage: 12.827 V
    000546 - Angle Sensor 2 for Throttle (G188)
                   P0222 - 002 - Signal Too Low - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.15
                        Time: 00:54:28
                        RPM: 581 /min
                        Load: 52.1 %
                        Temperature: 69.0C
                        Temperature: 35.0C
                        Voltage: 11.049 V
    000290 - Throttle Position Sensor (G69)
                   P0122 - 002 - Signal too Low - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.15
                        Time: 00:54:29
                        RPM: 581 /min
                        Load: 54.5 %
                        Temperature: 69.0C
                        Temperature: 35.0C
                        Voltage: 12.192 V
    000835 - Camshaft Position Sensor (G40)
                   P0343 - 001 - Signal too High - Intermittent
                        Fault Status: 00100001
                        Fault Frequency: 6
                        Mileage: 90362 km
                        Date: 2018.03.15
                        Time: 00:58:38
                        RPM: 1090 /min
                        Load: 37.6 %
                        Temperature: 86.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
                   P1653 - 008 -
                        Fault Status: 01101000
                        Fault Frequency: 42
                        Mileage: 90362 km
                        Date: 2018.03.15
                        Time: 01:01:35
                        Load: 0.0 %
                        Temperature: 32.0C
                        Temperature: 32.0C
                        Voltage: 11.430 V
    000872 - Camshaft Position Sensor B Bank 1 (G300)
                   P0368 - 001 - Signal too High - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.15
                        Time: 01:01:55
                        RPM: 3173 /min
                        Load: 20.4 %
                        Temperature: 85.0C
                        Temperature: 36.0C
                        Voltage: 11.557 V
    005416 - Camshaft Timing Adj. Bank1 (N205)
                   P1528 - 004 - Open Circuit - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.15
                        Time: 01:07:35
                        RPM: 594 /min
                        Load: 35.7 %
                        Temperature: 90.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
    008756 - Oxygen (Lambda) Sensor B2 S1
                   P2234 - 004 - Signal Shorted to Heater Circuit
                        Mileage: 90362 km
                        Date: 2018.03.24
                        Time: 00:13:59
                        RPM: 1873 /min
                        Load: 31.4 %
                        Temperature: 68.0C
                        Temperature: 39.0C
                        Voltage: 12.192 V
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 09E-927-156.lbl
       Part No SW: 4E1 910 156 K    HW: 09E 927 156 B
       Component: AG6 09E 5,2 FSI RdW 0020
       Revision: --H01---    Serial number:        0089912
       Coding: 0000001
       Shop #: WSC 02313 785 00200
       VCID: 2B03FA4B2F00752FF7A-807E
    006231 - Load Signal
                   P1857 - 001 - Error Message from ECU
                        Fault Status: 01100001
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:30
                        (no units): 30.0
                        (no units): 145.0
                        Temperature: 34.0C
                        T.B. Angle: 0.0
    049458 - Ride Level Control Module
                   U0132 - 000 - No Communications
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:44:31
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
       Component: ESP 5.7 allrad  H46 0500
       Coding: 0001927
       Shop #: WSC 02313 000 00000
       VCID: 2411117742DEBA57360-8070
    18265 - Load Signal
                P1857 - 000 - Error Message from ECU
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 L
       Component:     FBS AUDID3  H10 0190
       Revision: 01904910    Serial number: AUX3Z0F6700015
       Coding: 0410624
       Shop #: WSC 02311 785 00200
       VCID: 58E975874E162EB76A8-800C
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Fault Frequency: 0
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:48:28
    Address 06: Seat Mem. Pass        Labels: None
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H07  0060
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 4063328
       Shop #: WSC 02316 823 51787
       VCID: 2313126B47D0BD6F4FA-8076
    01915 - Lumbar Support Height Adjustment Sensor (G374)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 111
                        Mileage: 95740 km
                        Date: 2012.11.25
                        Time: 11:08:05
    Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
       Part No SW: 4E0 910 731 G    HW: 4E0 035 729 A
       Component: Interfacebox    H43 2830
       Revision: 00000000    Serial number: 300GI067570209
       Coding: 0000006
       VCID: 25170C7349E4435F21E-8070
       Component: E0380 BedienteilH03 0040
       Subsystem 2 - Serial number: 00000000018025
       Subsystem 3 - Serial number: 0102.08.060000000100010077
       Subsystem 4 - Serial number: 010077
       Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
       Component: KLIMAAUTOMAT    017 0450
       Revision: 00000032    Serial number: 00000000103009
       Coding: 0041465
       VCID: 1C6129977AAE82978E0-8048
    13 Faults Found:
    01855 - Temperature Sensor for Heated Seat; Left Front (G344)
                        Reset counter: 182
                        Mileage: 80596 km
                        Date: 2017.10.29
                        Time: 10:44:13
                        Temperature: 38.0C
    01856 - Temperature Sensor for Heated Seat; Front Right (G345)
                        Reset counter: 182
                        Mileage: 80596 km
                        Date: 2017.10.29
                        Time: 10:44:13
                        Temperature: 38.0C
                        Fault Status: 00101010
                        Reset counter: 146
                        Mileage: 90362 km
                        Date: 2018.03.08
                        Time: 00:00:07
                000 -  -  - Intermittent
                        Reset counter: 146
                        Mileage: 90344 km
                        Date: 2018.03.07
                        Time: 00:00:15
                        Bin. Bits: 00011111
    01853 - Heated Seat; Left Front (Z45)
                        Fault Status: 00101011
                        Fault Frequency: 13
                        Reset counter: 149
                        Mileage: 87102 km
                        Date: 2018.01.27
                        Time: 00:01:00
                        Temperature: 23.0C
                        Reset counter: 146
                        Mileage: 90361 km
                        Date: 2018.03.07
                        Time: 20:43:21
    00455 - Control Module for Access and Start Control; Comfort CAN (J518)
                        Reset counter: 146
                        Mileage: 90361 km
                        Date: 2018.03.07
                        Time: 20:47:16
                        Bin. Bits: 00011000
                        Reset counter: 146
                        Mileage: 90361 km
                        Date: 2018.03.07
                        Time: 20:47:16
    00565 - Rear A/C Control Head (Climatronic) (E265)
                        Reset counter: 148
                        Mileage: 90361 km
                        Date: 2018.03.07
                        Time: 20:47:17
                        Reset counter: 146
                        Mileage: 90361 km
                        Date: 2018.03.07
                        Time: 20:47:17
                        Voltage: 11.90 V
    01854 - Heated Seat; Front Right (Z46)
                        Fault Frequency: 6
                        Reset counter: 149
                        Mileage: 90361 km
                        Date: 2018.03.07
                        Time: 20:47:28
                        Temperature: 30.0C
                        Reset counter: 146
                        Mileage: 90361 km
                        Date: 2018.03.07
                        Time: 20:47:34
                        Bin. Bits: 00011000
                        Reset counter: 146
                        Mileage: 90361 km
                        Date: 2018.03.07
                        Time: 20:48:26
                        Temperature: 31.0C
    Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
       Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
       Component: ILM Fahrer      H15 0230
       Coding: 0133001
       VCID: 3635DB3FE44238C7984-8062
       Subsystem 1 - Part No: 4E1 910 113 C
       Component: Wischer WWS D3  H60 0420
       Coding: 00000036
       Shop #: WSC 02313
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00141886
       Shop #: WSC 02313
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:38:03
    01498 - Bulb for Parking Lamps; Right (M3)
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:37:59
    00908 - Control Module for Wiper Motor
                        Fault Frequency: 10
                        Reset counter: 150
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:34:39
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:38:00
                        Fault Frequency: 10
                        Reset counter: 150
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 03:34:39
    Address 0E: Media Player 1
    18 Faults Found:
                   P1653 - 008 -
                        Fault Frequency: 155
                        Mileage: 90362 km
                        Date: 2018.03.08
                        Time: 00:35:08
                        Load: 0.0 %
                        Temperature: 32.0C
                        Temperature: 32.0C
                        Voltage: 11.557 V
    012322 - Valve for Exhaust Flap 2 (N322)
                   P3022 - 002 - Short to Ground
                        Fault Frequency: 26
                        Mileage: 90362 km
                        Date: 2018.03.08
                        Time: 00:35:26
                        RPM: 187 /min
                        Load: 54.5 %
                        Temperature: 50.0C
                        Temperature: -40.0C
                        Voltage: 10.287 V
    005490 - Left Engine Mount Solenoid Valve (N144)
                   P1572 - 002 - Short to Ground
                        Fault Frequency: 32
                        Mileage: 90362 km
                        Date: 2018.03.08
                        Time: 00:35:26
                        RPM: 187 /min
                        Load: 54.5 %
                        Temperature: 50.0C
                        Temperature: -40.0C
                        Voltage: 10.287 V
    004763 - Fuel Pressure Regulator Valve; Bank 2 (N276)
                   P129B - 004 - Open Circuit - Intermittent - MIL ON
                        Fault Frequency: 54
                        Mileage: 90362 km
                        Date: 2018.03.08
                        Time: 00:35:26
                        RPM: 191 /min
                        Load: 54.5 %
                        Temperature: 50.0C
                        Temperature: -40.0C
                        Voltage: 10.287 V
    000268 - Mass Air Flow Sensor (G246)
                   P010C - 002 - Signal too Low - MIL ON
                        Mileage: 90362 km
                        Date: 2018.03.08
                        Time: 00:35:26
                        RPM: 193 /min
                        Load: 54.5 %
                        Temperature: 50.0C
                        Temperature: -40.0C
                        Voltage: 10.287 V
    012850 - Oxygen (Lambda) Sensor B4 S1; Heating Circuit
                   P3232 - 004 - Open - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.09
                        Time: 02:34:20
                        RPM: 695 /min
                        Load: 94.9 %
                        Temperature: 39.0C
                        Temperature: 33.0C
                        Voltage: 11.684 V
    012869 - Oxygen (Lambda) Sensor B4 S2; Heating Circuit
                   P3245 - 002 - Short to Ground - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.09
                        Time: 02:35:48
                        RPM: 461 /min
                        Load: 65.9 %
                        Temperature: 60.0C
                        Temperature: -40.0C
                        Voltage: 11.684 V
    012802 - Oxygen (Lambda) Sensor B3 S1; Heating Circuit
                   P3202 - 004 - Open - MIL ON
                        Fault Status: 11100100
                        Mileage: 90362 km
                        Date: 2018.03.09
                        Time: 02:37:13
                        RPM: 477 /min
                        Load: 54.1 %
                        Temperature: 53.0C
                        Temperature: -40.0C
                        Voltage: 11.684 V
                        Mileage: 90362 km
                        Date: 2018.03.09
                        Time: 07:16:25
                        Load: 0.0 %
                        Temperature: 32.0C
                        Temperature: 33.0C
                        Voltage: 10.922 V
    000840 - Camshaft Position Sensor (G163)
                   P0348 - 001 - Short to Plus - Intermittent
                        Fault Frequency: 6
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 02:29:43
                        RPM: 1043 /min
                        Load: 37.2 %
                        Temperature: 86.0C
                        Temperature: -40.0C
                        Voltage: 12.827 V
    005430 - Camshaft Timing Adj. Bank2 (N208)
                   P1536 - 004 - Open Circuit - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 02:42:23
                        RPM: 550 /min
                        Load: 52.5 %
                        Temperature: 90.0C
                        Temperature: -40.0C
                        Voltage: 12.573 V
    012326 - Angle Sensor 1 for Throttle Drive 2 (G297)
                   P3026 - 002 - Signal too Small - Intermittent - MIL ON
                        Fault Status: 10100010
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 02:56:25
                        RPM: 652 /min
                        Load: 78.4 %
                        Temperature: 37.0C
                        Temperature: -40.0C
                        Voltage: 12.192 V
    012329 - Angle Sensor 2 for Throttle Drive 2 (G298)
                   P3029 - 002 - Signal too Small - Intermittent - MIL ON
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 02:56:25
                        RPM: 427 /min
                        Load: 85.5 %
                        Temperature: 36.0C
                        Temperature: -40.0C
                        Voltage: 12.446 V
    012821 - Oxygen (Lambda) Sensor B3 S2; Heating Circuit
                   P3215 - 002 - Short to Ground - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.13
                        Time: 00:07:32
                        RPM: 709 /min
                        Load: 37.2 %
                        Temperature: 76.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
    012337 - Throttle Drive 2 (G296)
                   P3031 - 002 - Electrical Malfunction - Intermittent
                        Mileage: 90362 km
                        Load: 0.0 %
                        Temperature: 60.0C
                        Temperature: 35.0C
                        Voltage: 11.430 V
    000915 - Camshaft Position Sensor (G301)
                   P0393 - 001 - Signal too High - MIL ON
                        Fault Status: 11100001
                        Mileage: 90362 km
                        Date: 2018.03.15
                        Time: 00:59:54
                        RPM: 643 /min
                        Load: 53.7 %
                        Temperature: 81.0C
                        Temperature: 36.0C
                        Voltage: 12.065 V
    049408 - No Communication with Engine Control Module (SAE ECM/PCM)
                   U0100 - 008 -  - Intermittent
                        Mileage: 90362 km
                        Date: 2018.03.15
                        Time: 01:02:29
                        RPM: 570 /min
                        Load: 43.5 %
                        Temperature: 41.0C
                        Temperature: 33.0C
                        Voltage: 11.303 V
    053248 - No Communication with Comfort System Control Module (J393)
                   U1000 - 002 -  - Intermittent
                        Mileage: 90362 km
                        Load: 0.0 %
                        Temperature: 33.0C
                        Temperature: 32.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    Address 15: Airbags        Labels: 4E0-910-655-94.lbl
       Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
       Component:    Airbag 9.41  H13 3710
       Revision: 91H13371    Serial number: 0037P000NNFA
       Coding: 0431707
       VCID: 270B067B33E8514F132-8072
       Subsystem 1 - Serial number: 63328RB40170CCD2P
       Subsystem 2 - Serial number: 63428RB40170D838J
       Subsystem 3 - Serial number: 63528RB40170D05FL
       Subsystem 4 - Serial number: 63628RB40170D5C0J
       Subsystem 5 - Serial number: 63729RB401663084B
       Subsystem 6 - Serial number: 63829RB4016630FFU
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:29
    00591 - Seat Belt Switch; Driver (E24)
                        Fault Status: 11101010
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:31
    00592 - Seat Belt Switch; Passenger (E25)
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:31
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549
       Component: Lenksulenmodul H14 0040
       Coding: 0012141
       VCID: 65974C730964835FE1E-8030
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 901 D    HW: 4E0 920 901 D
       Component: KOMBIINSTR. VDO H82 0520
       Revision: D03         Serial number: AUDID3F6000528
       Coding: 0032613
       Shop #: WSC 00010 724 57846
    Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
       Part No SW: 4E0 910 468 B    HW: 4E0 907 468 E
       Component: Gateway         H11 0090
       Revision: 11          Serial number: 2000306627805A
       Coding: FCFFFFDD3B7504
       Shop #: WSC 00010 724 82219
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:32
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:32
    02076 - Media Player Position 1 (R118)
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:44:27
    01310 - Level Control System Control Module (J197)
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:44:32
    Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
       Part No SW: 4E0 910 218 A    HW: 4E1 905 218 B
       Component: FPI_1           H01 0020
       Revision: 01000102    Serial number: 03082006065850
       VCID: 1F1B1E9B6BB8998F6B2-804A
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBF8167283
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0410624
       XXXXXXXXXXX ELV                 XXXX
                        Fault Frequency: 0
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:48:28
    Address 28: HVAC, Rear        Labels: None
       Part No SW: 4E0 910 158     HW: 4E0 919 158 C
       Component: KLIMA-STG. FOND 017 0230
       Revision: 00000019    Serial number: 00000000044293
       Coding: 0000000
       VCID: 619F58631D4CEF7F1D6-8034
    8 Faults Found:
    00458 - Control Module for Battery Monitoring (J367)
    00532 - Supply Voltage B+
    Address 34: Level Control
       Component: Sitzmemory FS  H07  0060
       Coding: 4063342
                        Reset counter: 111
                        Mileage: 95740 km
                        Date: 2012.11.25
                        Time: 10:26:30
       Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 D
       Component: MNS ECE         H48 0850
       Revision: 00000000    Serial number: 364G/067583496
       VCID: 3B23CA0BDF60E5AF67A-806E
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Component: Dachknoten D3   H05 0090
       Serial number: 00000618800055
       Coding: 0003286
       VCID: 1D67249361B48B9F79E-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 801 B
       Component: Trsteuer.FS BRM003 0100
       Coding: 0032621
       VCID: 20191D6756C6A677528-8074
    00913 - Window Regulator Switch; Front Right Driver (E81)
                        Reset counter: 116
                        Mileage: 88608 km
                        Date: 2018.02.11
                        Time: 08:29:12
    01482 - Motors for Central Locking
                        Fault Status: 00100111
                        Reset counter: 116
                        Mileage: 88608 km
                        Date: 2018.02.11
                        Time: 08:29:00
    02117 - Motor for Mirror Folding
                        Fault Frequency: 0
                        Reset counter: 139
                        Mileage: 89648 km
                        Date: 2018.02.24
                        Time: 03:38:32
                        Fault Frequency: 0
                        Reset counter: 147
                        Mileage: 90352 km
                        Date: 2018.03.07
                        Time: 20:47:28
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
       Component: Komfortgeraet   H07 0010
       Revision: 00100007    Serial number:  W040607240143
       Coding: 0004712
       VCID: 2A0DFF4F20FA6C270CC-807E
       Component: Heckdeckel   P14H06 0070
    02199 - Bulb for Tail Light 2; Right (M50)
                        Reset counter: 111
                        Mileage: 80594 km
                        Date: 2011.12.24
                        Time: 00:00:23
    01505 - Bulb for Blinkers; Rear Right (M8)
                        Reset counter: 111
                        Mileage: 80594 km
                        Date: 2011.12.24
                        Time: 00:11:35
    01134 - Alarm Horn (H12)
                        Fault Status: 01101100
                        Reset counter: 111
                        Mileage: 80594 km
                        Date: 2011.07.21
                        Time: 05:40:43
    Address 47: Sound System        Labels: None
       Part No SW: 4E0 910 466 A    HW: 4E0 035 466
       Component: BO_D3           H06 0170
       Revision: 12S00002    Serial number: 01807060004203
       Coding: 0000026
       Subsystem 1 - Part No: 4E0 910 465 A
       Component: BO_D3_SLAVE     H31 0100
       Subsystem 2 - Serial number: 01107060001911
       Subsystem 3 - Serial number: 0211.07.060000000100030003
       Subsystem 4 - Serial number: 030003
    00876 - Treble Speaker Rear Left (R14)
                        Fault Status: 01101011
                        Reset counter: 111
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:27
                        Voltage: 11.20 V
                        Temperature: 40.0C
                        Bin. Bits: 00000100
                        Voltage: 11.50 V
                        Temperature: 44.0C
    03016 - Motor for Front Right Treble Speaker (V345)
                        Reset counter: 193
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:44:25
                        Voltage: 11.20 V
                        Temperature: 41.0C
                        Bin. Bits: 00000100
                        Voltage: 11.50 V
                        Temperature: 45.0C
                        Reset counter: 193
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:44:25
                        Voltage: 11.20 V
                        Temperature: 41.0C
                        Bin. Bits: 00000100
                        Voltage: 11.50 V
                        Temperature: 45.0C
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H09 0040
       Revision:             Serial number: 00000000056859
       Coding: 0010101
       VCID: 1E65239F6CB29087604-804A
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
       Component: Trsteuer.BF BRM003 0100
       Coding: 0032621
    02124 - Exterior Door Handle Switch
                        Fault Frequency: 0
                        Reset counter: 0
                        Fault Frequency: 0
                        Reset counter: 147
                        Mileage: 90352 km
                        Date: 2018.03.07
                        Time: 20:47:40
    01964 - Control Module for Seat & Steering Column Memory (J136)
                        Fault Frequency: 0
                        Reset counter: 147
                        Mileage: 90352 km
                        Date: 2018.03.07
                        Time: 20:47:40
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
       Component: EPB  A4EC0230   H03 0230
       Revision: --H03---
       Coding: 0000731
       Shop #: WSC 00010 724 60324
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 14
                        Reset counter: 111
                        Date: 2018.03.24
                        Time: 00:00:00
                        Voltage: 10.25 V
                        Count: 220
    02596 - Rear Brake Pads Worn
                        Fault Status: 01111000
                        Reset counter: 110
                        Voltage: 10.35 V
                        Count: 61
    Address 55: Headlight Range
       Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
       Component: TUNER EU/US/RDW H42 0570
       Revision: 00000000    Serial number: 396GP067544002
       Coding: 0000001
                        Fault Frequency: 11
                        Reset counter: 151
                        Mileage: 90362 km
                        Date: 2018.03.08
                        Time: 20:01:44
                        Fault Frequency: 60
                        Reset counter: 151
                        Mileage: 90362 km
                        Date: 2018.03.08
                        Time: 19:57:25
    Address 57: TV Tuner        Labels: 4E0-910-146.clb
       Part No SW: 4E0 910 146 E    HW: 4E0 919 146 C
       Component: TV analog TUNER H15 0270
       Revision: 00000050    Serial number: 00000000043250
       Coding: 0000001
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H12 0550
       Revision: 00000000    Serial number: 00000000015032
       Shop #: WSC 00010 724 56672
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  2607280285
       Coding: 344530393135313035412056413032363037323830323835
       Shop #: WSC 00000 128 00289
    02273 - Quiescent Current Stage 2
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:33
    02276 - Quiescent Current Stage 5
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:43:43
    02272 - Quiescent Current Stage 1
                        Mileage: 90368 km
                        Date: 2018.03.24
                        Time: 22:48:18
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
       Component: Trsteuer.HL BRM003 0100
       Coding: 0032621
                        Fault Frequency: 0
                        Reset counter: 147
                        Mileage: 90352 km
                        Date: 2018.03.07
                        Time: 20:47:28
                        Fault Frequency: 0
                        Reset counter: 150
                        Mileage: 90352 km
                        Date: 2018.03.24
                        Time: 21:11:50
    Address 65: Tire Pressure
    Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H45 0630
       Revision: 00000000    Serial number: 00000607210104
       Shop #: WSC 12336 024 394758
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
       Component: Trsteuer.HR BRM003 0100
       Coding: 0032621
                        Fault Frequency: 0
                        Reset counter: 147
                        Mileage: 90352 km
                        Date: 2018.03.07
                        Time: 20:47:40
                        Fault Frequency: 0
                        Reset counter: 147
                        Mileage: 90352 km
                        Date: 2018.03.07
                        Time: 20:47:40
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
       Component: Parkhilfe 8-Kan H12 0040
       Revision: 00H12000    Serial number: 08720620602863
       Coding: 0301008
    Address 77: Telephone        Labels: 4E0-910-333.lbl
       Part No SW: 4E0 910 333 F    HW: 4E0 862 333 C
       Component: TELEFONMODUL EU     0770
       Revision: 00000008    Serial number: T2AUDX0806JPNK
       Coding: 0000004
       VCID: 221D176F58CAB46744C-8076
    End----(Elapsed Time: 02:22, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
    Oct 2014
    Arandjelovac, Serbia
    Pay attention to the battery. VBatt start/end: 11.2V/11.2V. VIgn 11.2V)
    Apr 2016
    United Kingdom
    Poor car :-( What's the history?
    As a first step get a charged / new battery in and coded. Clear all faults and see what returns.
  5. Likes Jack@European_Parts, Uwe, Boki Ar liked this post
