Results 1 to 10 of 13
Thread: ABS CODING
Hybrid View
    Apr 2016
    ABS CODING
    Hi i have a vw golf 2010 and the abs has zero coding after ecu and clock change ive tried original coding from log but wont accept it can you help please ?ive attached original log and log after replacement clocks and ecu
    Monday,30,October,2017,12:33:50:60768
    VCDS Version: 17.8.0.1 (x64)
    VIN: WVWZZZ1KZAM666224   License Plate: JK05JLK
    Mileage: 275020km-170889mi   Repair Order:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72
    VIN: WVWZZZ1KZAM666224   Mileage: 275020km-170889miles
    01-Engine -- Status: Cannot be reached 1100
    17-Instruments -- Status: Malfunction 1010
    Address 01: Engine
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       Coding: 133B200D09280000C80D04E6901D0091310000
       Shop #: WSC 00066 000 00000
       VCID: 7AFBE7BAF5323996C4-802E
    9 Faults Found:
                        Fault Status: 00101101
                        Reset counter: 154
                        Mileage: 274919 km
                        Date: 2011.04.26
                        Time: 00:04:18
                        Count: 2
                        Count: 28928
                        Count: 8196
                        Count: 42496
                        Count: 64768
    01312 - Powertrain Data Bus
                        Reset counter: 114
                        Count: 2
                        Count: 12
                        Count: 512
                        Count: 8255
                        Count: 43008
                        Count: 256
                        Reset counter: 114
                        Mileage: 274919 km
                        Date: 2011.05.08
                        Time: 19:20:22
                        Count: 2
                        Count: 2
                        Count: 8704
                        Count: 8213
                        Count: 41728
                        Count: 65024
    01276 - ABS Hydraulic Pump (V64)
                        Fault Status: 00101100
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2011.06.09
                        Time: 00:02:46
                        Count: 2
                        Count: 20992
                        Count: 105
                        Count: 42240
                        Count: 256
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2011.06.09
                        Time: 00:08:42
                        Count: 3
                        Count: 20992
                        Count: 8233
                        Count: 40960
                        Count: 7680
                        Reset counter: 114
                        Mileage: 67843 km
                        Date: 2000.08.02
                        Time: 00:28:13
                        Count: 1536
                        Count: 153
                        Count: 39424
                        Count: 128
                        Count: 1056
                        Count: 1024
                        Count: 163
                        Count: 29186
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2011.06.09
                        Time: 00:08:42
                        Count: 3
                        Count: 2
                        Count: 20992
                        Count: 8208
                        Count: 40960
                        Count: 7680
                        Reset counter: 114
                        Mileage: 274919 km
                        Date: 2011.05.08
                        Time: 19:20:22
                        Count: 2
                        Count: 2
                        Count: 8704
                        Count: 166
                        Count: 41728
                        Count: 65024
                        Reset counter: 114
                        Mileage: 274919 km
                        Date: 2011.05.08
                        Time: 19:20:21
                        Count: 2
                        Count: 12800
                        Count: 8194
                        Count: 41984
                        Count: 65024
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000003
       Shop #: WSC 00066 000 00148
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6DD1DCE6BC7C9E2E51-8038
    13701376 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2017.10.30
                        Time: 20:47:42
    13701456 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 154
                        Date: 2017.10.27
                        Time: 03:56:33
    9481748 - High Pressure Sensor
              B10AE 14 [009] - Open or Short to Ground
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2017.10.26
                        Time: 23:49:27
       Part No SW: 5K0 937 084 B    HW: 5K0 937 084 B
       Component: BCM PQ35 B    011 0028
       Revision: BA011001
       Coding: 08180E3A902DE1C044080080040000E403700088437D8162648087000001
       VCID: 3169009668C43ACE35-8064
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 26021  21  0512
       Coding: 009795
       Component: RLS 150210 05  54  0403
       Coding: 0330AD
       Component: Innenraumuebe  004 0611
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2012.03.22
                        Time: 20:47:40
                            Term 15 On
                        Voltage: 11.80 V
                        Reset counter: 154
                            Term 15 On
                        Voltage: 12.75 V
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRA283RT
       Coding: 00003138
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B7522BEB288C09E9F-806E
       Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME6D23734EZZZ2
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME5329354EZZZ$
       Serial number: 3511HSME4107641FZZZJ
       Serial number: 3521HSME6312461FZZZK
    12670208 - No Communication with Instrument Cluster
              U0155 00 [008] - -
                        Reset counter: 154
                        Mileage: 275027 km
                        Date: 2017.10.27
                        Time: 03:56:33
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000034
       VCID: 03059A5E42F8785E97-8056
       Part No SW: 5K0 920 970 N    HW: 5K0 920 970 N
       Component: KOMBI         H13 0112
       Revision: X0013004    Serial number:
       Coding: 470B00
       ASAM Dataset: EV_KombiUDSMM9RM10 A04102
       ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
       VCID: 397938B6B8B4F28E8D-806C
    12648448 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2017.10.30
                        Time: 20:47:42
       Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
       Component: J533  Gateway   H17 0233
       Revision:   H17       Serial number: 1521J1010409DB
       Coding: E9807F06000202042003
       VCID: 6BD5D2FE4A68901E4F-803E
                        Reset counter: 154
                        Mileage: 275027 km
                        Date: 2012.03.19
                        Time: 03:56:34
                        Reset counter: 154
                        Mileage: 275027 km
                        Date: 2012.03.19
                        Time: 03:56:34
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2012.03.22
                        Time: 20:47:40
       Part No SW: 5K0 953 234     HW: 5K0 920 970 N
       Component: IMMO          H13 0112
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
       ROD: EV_ImmoUDSMM9RM10_VW21.rod
       VCID: 6ADBD7FA8D92891634-803E
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0308
       Revision: 13101005    Serial number: 0000437294
       Coding: 0202B4
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide.rod
       VCID: 275DEECE5E00747EEB-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
       Component: J389__TSG-HR  006 1401
       Serial number: 00000004641646
       Coding: 000290
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [009] - Electrical Failure
    68102 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 154
                        Mileage: 275027 km
                        Date: 2017.10.27
                        Time: 03:56:33
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 69     3001
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 31690096A8C43ACE35-8064
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 275027 km
                        Date: 2012.03.18
                        Time: 23:49:27
                        Battery Volts: 12.0 V
                            DD
                        Temperature: 15.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
                        Reset counter: 154
                        Mileage: 275027 km
                        Date: 2012.03.19
                        Time: 03:56:34
                        Voltage: 13.13 V
                            DD
                        Temperature: 19.0C
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2012.03.22
                        Time: 20:47:42
                        Voltage: 11.75 V
                            DU
                        Temperature: 6.0C
                        RPM: 1498 /min
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0308
       Revision: 15101005    Serial number: 0000353928
       Coding: 0202B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 285FEDF2531E7B06E2-807C
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
       Component: J388__TSG-HL  006 1401
       Serial number: 00000004603789
       Coding: 000290
              U1111 00 [008] - -
                        Reset counter: 154
                        Mileage: 275027 km
                        Date: 2017.10.27
                        Time: 03:56:33
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 00000000    Serial number: VWZ1Z2K8027187
       Coding: 0500040004
       VCID: 65C1A4C66C8CA66E19-8030
                        Reset counter: 154
                        Mileage: 275027 km
                        Date: 2012.03.19
                        Time: 03:56:34
    00875 - Treble Speaker Front Right (R22)
                        Fault Status: 01101011
                        Reset counter: 114
                        Mileage: 275027 km
                        Date: 2012.03.18
                        Time: 23:49:36
       Part No SW: 1K0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H17 0233
       Revision: --------    Serial number: 1521J1010409DB
       Coding: 030B085A
       VCID: 68DFADF29B9EBB0622-803C
       Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790916807
    End-------------------------(Elapsed Time: 02:54)--------------------------
    AND THIS WAS AFTER REPLACMENT CLOCKS AND ECU
    Tuesday,07,November,2017,16:54:11:60768
    VIN: WVWZZZ1KZAW113876   License Plate: JK05 AFTER ECU FIT
    Mileage: 273560km-169982mi   Repair Order:
    VIN: WVWZZZ1KZAW113876   Mileage: 273560km-169982miles
    Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 CQ    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 4971
       Revision: --------    Serial number: 00000000000000
       Coding: 00114014030500080000
       ASAM Dataset: EV_ECM16TDI02103L906023CQ 001004
       ROD: EV_ECM16TDI02103L906023CB.rod
       VCID: 77FDFE8ECE2024FEBB-8022
    7346 - Diesel Particle Filter; Differential Pressure Sensor
              P2453 00 [101] - Implausible Signal
                        Mileage: 179038 km
                        Date: 2017.10.31
                        Time: 02:22:34
                        Coolant temperature: 62 C
                        Intake air temperature: 19 C
                        Voltage terminal 30: 12.085 V
                        Environmental conditions-DIP_PF_ENVD: 482.353 hPa
                        Environmental conditions-DIP_PF_AD_ENVD: -84 hPa
                        Environmental conditions-MAF_KGH_MES_ENVD: 32.1252 mg/stroke
                        Environmental conditions-DIST_RGN_ENVD: 2550 km
                        Environmental conditions-MASS_SOOT_PF_ENVD: 0 g
                        Environmental conditions-TEG_PF_UP_ENVD: 100.391 C
                        Environmental conditions-TEG_PF_DOWN_ENVD: 92.3593 C
                        Environmental conditions-T_AST_ENVD: 0 s
                        Environmental conditions-T_ES_FCT_DIAG_ENVD: 2.2 s
                        Environmental conditions-T_INT_RGN_ACT_INI_PF_ENVD: 0 s
                        Environmental conditions-MAP_MES_ENVD: 980.251 hPa
                        Environmental conditions-FRF_STATE_RGN: 9
                        Environmental conditions-FRF_STATE_RGN_LOCK: 0
                        Environmental conditions-Coolant temperature: 62 C
                        Coolant temperature: -40 C
                        Intake air temperature: -40 C
                        Ambient air pressure: 0 mbar
                        Voltage terminal 30: 0.000 V
    Readiness: 1010 0000
       Revision: 00H30001
    03306 - Coding Not Valid
                000 -  -  - Intermittent
                        Reset counter: 114
                        Mileage: 179038 km
                        Date: 2012.03.26
                        Time: 04:35:53
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 4161
                        Count: 53504
                        Count: 256
                000 -  -
                        Reset counter: 114
                        Date: 2012.03.23
                        Time: 02:20:11
                        Count: 3
                        Count: 20992
                        Count: 195
                        Count: 43264
                        Fault Status: 01100101
                        Reset counter: 114
                        Mileage: 179038 km
                        Date: 2012.03.23
                        Time: 02:20:10
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 295
                        Count: 43264
       Revision: 00009001
       Coding: 0000000003
                        Reset counter: 114
                        Mileage: 179038 km
                        Date: 2017.10.31
                        Time: 02:20:12
       Part No SW: 1K0 937 085 D    HW: 1K0 937 085 D
       Component: BCM PQ35  B+  103 0541
       Revision: 00103 AE
       Coding: 08180E78802DE1C044080080040000E403700088437DC963648006000001
       VCID: 306F059263CE33C63A-8064
       Coding: 009795
       Coding: 0330AD
    01049 - Supply Voltage Term 50
                        Reset counter: 114
                        Mileage: 179038 km
                        Date: 2012.03.23
                        Time: 02:20:14
                            Term 15 On
                        Voltage: 12.35 V
                            Term 50 On
    02723 - Control Circuit for Power Supply Relay (Terminal 50)
                        Fault Status: 01101100
                        Reset counter: 114
                        Mileage: 179038 km
                        Date: 2012.03.23
                        Time: 02:20:14
                            Term 15 On
                        Voltage: 12.35 V
                            Term 50 On
    00332 - Control Circuit for Tank Flap
                        Fault Status: 00100111
                        Reset counter: 154
                        Mileage: 179038 km
                            Term 15 Off
                        Voltage: 12.45 V
                            Term 50 Off
       Coding: 00003138
       Coding: 0000034
       Part No SW: 5K0 920 960 J    HW: 5K0 920 960 J
       Component: KOMBI         H06 0206
       Coding: 470B00
       VCID: 346709829FD60FE65E-8060
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H06 0206
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
       Coding: 0202B4
       Slave Driver:
       Coding: 000290
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 114
                        Mileage: 179038 km
                        Date: 2017.10.31
                        Time: 02:20:18
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 154
                        Mileage: 179038 km
                        Date: 2017.10.31
                        Time: 02:20:18
       Revision: 00H17000
                        Fault Status: 11100101
                        Mileage: 179038 km
                        Date: 2012.03.23
                        Time: 02:20:21
                        Battery Volts: 12.1 V
                            DD
                        Temperature: 24.0C
                        Count: 3
                        Count: 1
                            SteerAng n.Init
       Coding: 0202B4
       Slave Passenger:
       Coding: 000290
                        Reset counter: 154
                        Mileage: 179038 km
                        Date: 2017.10.31
                        Time: 02:20:22
       Coding: 0500040004
                        Reset counter: 114
                        Mileage: 273569 km
                        Date: 2012.03.29
                        Time: 22:48:07
       Coding: 030B085A
    End-------------------------(Elapsed Time: 02:32)--------------------------
    Address 03,1K0 907 379 AJ,recoded (Long Coding),from,00000000000000000000000000000000000000,to,13422012092A00FDC80C04E590200081380000,(00066/000/00000),
    Address 03,1K0 907 379 AJ,recoded (Long Coding),from,00000000000000000000000000000000000000,to,13422012092A00FDC80C04E5902000813C0000,(00066/123/12345),
    Address 03,1K0 907 379 AJ,recoded (Long Coding),from,00000000000000000000000000000000000000,to,13422012092A00FDC80C04E590200081380000,(00066/123/12345),
    Address 03,1K0 907 379 AJ,recoded (Long Coding),from,00000000000000000000000000000000000000,to,13422012092A00FDC80C04E590200091380800,(00066/123/12345),
    Address 03,1K0 907 379 AJ,recoded (Long Coding),from,00000000000000000000000000000000000000,to,13422012092A00FDC80C04E590200081380800,(00066/123/12345),
    Aug 2016
    The Hague, NL
    please make an autoscan with the engine in there as well and tell us what you think is the original coding (there are two at the bottom)
    Also, try this code. If it's accepted, I'll tell you exactly what is wrong. 1342201209280000C80D04E6901D00813C0000
  3. Likes NZDubNurd, Uwe liked this post
    The reason the ABS module lost its coding is because the car now claims to have a different VIN than it used to, so the ABS thinks it's been installed in a different car.
    How does work during a UK MOT inspection when the VIN in the electronics doesn't match the VIN on the various data plates on the physical car? Here in the US, in areas that have mandatory emissions inspections, it would cause a considerable headache.
  5. Likes Jack@European_Parts liked this post
    Aug 2016
    The Hague, NL
    Yes exactly Uwe. The physical VIN and digital VIN don't match.
    Have the correct VIN installed in engine ecu and cluster and recode the ABS.
    I can help with that through the mail but I am far away and better to get done there in UK.
    Apr 2016
    Tanks so much for reply i will try these first thing i can change the vins in the module`s if need be and will try that to i will reply asap thanks again
    Apr 2016
    both these coding didnt work should i try changing vin in ecu and clocks back to original vin now please
  10. #8
    Aug 2016
    The Hague, NL
    you could have a try but i'm pretty sure you'll not be able to change any VINs in the engine control unit or in the immobiliser
  11. #9
    May 2017
    Why not? I thought it's the main idea when doing IMMO adaptation? It will adapt the ECU and/or instrument immobilizer to your cars VIN.
  12. #10
    Apr 2016
    hi good news all done changed the vin just in the instrument cluster dump and then recoded pump using original coding and worked perfect thanks for all the help !!!!!!!!!!!!!!
  13. Likes Jack@European_Parts, Uwe liked this post
