Results 1 to 3 of 3
Thread: AFS Fault on MFD display and Headlight Range Faults codes
    Ireland
    Repairing a front damaged 2014 Passat Estate with HID lights.
    Replaced lights with new units (from Valeo) ......but have AFS fault showing on dashboard display and error codes in module 55
    Turned off AFS (in Module 09) with VCDS to see if the AFS cleared on the dashboard but still present
    Full scan below
    Any suggestions on how to correct the Headlight Range Error..........thanks Eddie
    Saturday,04,November,2017,14:55:44:31083
    VCDS Version: 17.8.0.1 (x64)
    VIN: WVWZZZ3CZFE037723   License Plate:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 55
              56 61 62 72
    VIN: WVWZZZ3CZFE037723   Mileage: 61520km-38226miles
       Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   H28 9979
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 00190012042501080000
       Shop #: WSC 47734 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018PR 003007
       ROD: EV_ECM20TDI01103L906018PR.rod
       VCID: 09136203A840290EDD-805C
       Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
       Component: J104   C2 450M VD7A 0040
       Revision: --H07---    Serial number: 00000008308248
       Coding: 0004016
       Shop #: WSC 05311 000 00001
       VCID: 79F312C330A0398ECD-802C
       Part No SW: 3AA 907 044 BQ    HW: 3AA 907 044 BQ
       Component: Climatronic   H05 0607
       Revision: 00001K02
       Coding: 061400C803
       Shop #: WSC 00015 115 00001
       VCID: 00057F279B7A68468A-8054
       Part No SW: 3AA 937 087 Q    HW: 3AA 937 087 Q
       Component: BCM PQ47 H+   422 0475
       Revision: BC422001
       Coding: 0008000000000000009800805400297423D54B88626D8560E480C7240041
       VCID: 4895A707FBCA900602-801C
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 20061  26  0612
       Coding: 00B795
       Component: RLS 120714 05  54  0403
       Coding: 0230ED
    Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
       Part No SW: 3AE 919 475 C    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0018
       Revision: --------    Serial number: 28201418801291
       Coding: 108002
       ASAM Dataset: EV_EPHVA18VW47X0000 001006
       ROD: EV_EPHVA18VW47X0000.rod
       VCID: 3F87BCDBA604D7BEB3-806A
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__108 VW10 HI   2518
       Revision: 28020000    Serial number: 003L7PEDKJNG
       Coding: 0012344
       VCID: 7CFD0BD73F920CA6D6-8028
       Subsystem 1 - Serial number: 6332MTS647581774
       Subsystem 2 - Serial number: 6342MTS687231754
       Subsystem 3 - Serial number: 6351HTS6C4AO1DKJ
       Subsystem 4 - Serial number: 6361HTS63RU72DKJ
       Part No SW: 3C9 953 501 DA    HW: 5K0 953 569 BA
       Revision: FF010042    Serial number: 20140620300828
       Coding: 1182250000
       VCID: 6BDF388B82FC9B1E4F-803E
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb
       Part No SW: 3AA 920 981 A    HW: 3AA 920 981 A
       Component: KOMBI         H03 0705
       Coding: 461F01
       Shop #: WSC 05314 115 00001
       VCID: 336FE0EB9A4C03DE47-8066
       Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1653
       Revision:   H56       Serial number: 250614F2001192
       Coding: 462007
       Shop #: WSC 05314 000 00001
       VCID: 01037A239870614E85-8054
       Part No SW: 3AA 959 433 E    HW: 3AA 959 433 E
       Component:    IMMO         048 0407
       Revision: 00048000    Serial number: VWZCZ000000000
       VCID: 3B7FC8CB7A1CCB9E9F-806E
       Revision: A1001003    Serial number: 7666445608
       Coding: 020100
       VCID: 2B5FF88B4A7C5B1E0F-807E
       Part No SW: 3C8 035 279 S    HW: 3C8 035 279 S
       Component: RNS315-EU   H80 0500
       Serial number: VWZAZ2P0387733
       Coding: 040004010400110000019002
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 3B7FC8CBB21CCB9E9F-806E
       Component: EUR_W_V6  0062
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0008827035
       Coding: 0212B7
       Shop #: WSC 05311 115 00001
       VCID: 356BDEF394381DEE69-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  005 0503
       Serial number: 00000004075443
       Coding: 010290
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 195    3501
       Revision: 00H22000
       VCID: 3973D2C37020F98E8D-806C
       Component:    KSG PQ47 ELV 048 0700
       Coding: 0191020052830E76340494157C085FCE105C04
       Component: EZE_2         H56 1653
       Coding: 00000008
       VCID: 6FE72C9BBEE4673E63-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0004
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0008835278
       Coding: 0212B6
       VCID: 3669D9FF893E16F660-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  005 0503
       Serial number: 00000004066844
       Coding: 010290
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000176151
       Coding: 0022167
       VCID: 3875D7C74B2AE08672-806C
       Component: AFS-ECU       H04 0111
       Coding: 029600000B000200
       VCID: 3777D4FB8E34EFFE7B-8062
       Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 230000
       Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 230000
    5279249 - Signal Line for Position Sensor for Right Swivel Module
              C108E 11 [137] - Short to Ground
                        Reset counter: 122
                        Mileage: 61526 km
                        Date: 2017.11.04
                        Time: 14:52:43
    5279761 - Voltage supply for Right Swivel Module Position Sensor
              C1090 11 [137] - Short to Ground
                        Reset counter: 122
                        Mileage: 61526 km
                        Date: 2017.11.04
                        Time: 14:52:44
       Component: Batt.regelung H56 1653
       Coding: 030F1859
       VCID: 71E32AE3A8D071CE75-8024
       Component: J367-BDM  H07 0180
       Serial number: 31186032061491512929
    End-------------------------(Elapsed Time: 03:23)--------------------------
    Ireland
    Update - removed bumper / headlight unit and found corrosion damage inside AFS module 3D0 941 329B on underside of H/L unit.
    Sourcing replacement ...to hopefully eliminate error codes
  3. Likes Uwe, Jack@European_Parts liked this post
    May 2017
    Also check the headlamp unit. The AFS unit is at the bottom and if there's a crack on the headlamp assembly glass, it will drop water inside and destroy the AFS unit over time. So check for cracks, holes anything on the headlamp glass. Make sure it's sealed properly.
