Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 2002 a4 instrument panel can not code
    Even more reason for upload/download or set to virgin to ease the pain.
  2. Likes Jetta ,97 liked this post
  3. #12
    Dallas (McKinney) ,TX ,USA
    100% Agree with Jack , Audi A4 even with know SKC(Pin) not possible to program if is in used mode , Need to be set to Virgin mode to be able to program it with VCDS .
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  4. Likes Uwe, Jack@European_Parts liked this post
  5. #13
    Feb 2017
    cluster thatcar will not run with
    Wednesday,08,November,2017,18:13:55:36215
    VIN: WAULC68E22A288797   License Plate:
    Mileage: 355490km-220891mi   Repair Order: 02a4 doner cluster
              67 69 75 76 77
    VIN: WAULC68E22A288797   Mileage: 355490km-220891miles
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 D    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0003
       Coding: 0016711
       Shop #: WSC 63351 000 00000
       VCID: 36362C1CD45FAAC7B16-5160
    17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
                P1347 - 001 - Incor. Correl.
    19761 - B2
                P3305 - 002 - Exhaust Cam Pos. Sensor (G301) / Crank Pos. Sensor (G28) Incorr. Correl.
    17947 - Clutch Pedal Switch (F36)
                P1539 - 004 - Implausible Signal
                P1570 - 008 -
    Readiness: 0000 1101
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      1726
       Coding: 04495
       VCID: 2616FC5C01FFDA47016-5216
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1319
       Coding: 00000
       Shop #: WSC 63351
       VCID: 6390A548324D6F6F268-5160
    8 Faults Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    01273 - Fresh Air Blower (V2)
                53-10 - Supply Voltage Too Low - Intermittent
    00532 - Supply Voltage B+
                27-00 - Implausible Signal
                49-00 - No Communications
    01794 - Control Module - Incorrect Chassis (VIN) Number
                35-10 -  -  - Intermittent
       Part No: 8E0 907 279 E
       Component: int. Lastmodul  USA 0305
       Coding: 00003
       Shop #: WSC 63351
       VCID: 34321614C723B8D78F2-4B1E
    01800 - Light Switch (E1)
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 A
       Component: Airbag 8.4E         4000
       Coding: 0010607
       VCID: 35342B10C959A1DFB8C-5160
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0601
       Coding: 00041
       Shop #: WSC 06335
       VCID: 41DC4FC088911D7F144-4B00
       Part No: 8E0 920 950 H
       Component: KOMBI+WEGFAHRS. RB4 D26
       Coding: 01202
       Shop #: WSC 19404
       VCID: 2E06047C290F9207F96-5184
       WAULC68E22A288797     AUZ6Z0B0059370
    01177 - Engine Control Unit
                65-10 - Unauthorized - Intermittent
    01176 - Key
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0504
       Coding: 00001
       VCID: 6B80CD68DA9D272F9E8-5118
       Part No: 8E0 959 433 T
       Component: Komfortgerát T5B    0617
       Coding: 11788
       Shop #: WSC 63351
       VCID: 42DE40CC8D9706670DE-4B1E
       Component: Tőrsteuer.FS BRM 0706
       Component: Tőrsteuer.BF BRM 0002
                35-00 -  -
    01561 - Rear left door
       Part No: 8E0 035 195 A
       Component: symphony II NP2    0006
       Coding: 00201
       VCID: 2514FB507CC9D15F08C-4E62
                36-00 - Open Circuit
    End----------(Elapsed Time: 05:35, VBatt start/end: 12.1V/12.0V)-----------
  6. Likes Jetta ,97 liked this post
  7. #14
    Feb 2017
    Wednesday,08,November,2017,17:37:49:36215
    VIN: WAULT68EX2A151669   License Plate:
    Mileage: 330710km-205493mi   Repair Order: 02 a4 stock cluter
              67 69 75 76 77
    VIN: WAULT68EX2A151669   Mileage: 330710km-205493miles
       Coding: 0016711
    19761 - B2
       Coding: 04495
       VCID: 2616FC5C01FFDA47016-51F2
       Coding: 00000
       Shop #: WSC 63351
    7 Faults Found:
                35-00 -  -
       Coding: 00003
       Shop #: WSC 63351
       Coding: 0010607
       Coding: 00041
       Shop #: WSC 06335
       VCID: 41DC4FC088911D7F144-4B1E
       Component: KOMBI+WEGFAHRS. RB4 D25
       Coding: 03200
       Shop #: WSC 00001
       WAULT68EX2A151669     AUZ6Z0A0288577
    01176 - Key
       Coding: 00001
       Coding: 11788
       Shop #: WSC 63351
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0002
       Component: Tőrsteuer.HR BRM 0002
                35-00 -  -
       Coding: 00201
       VCID: 2514FB507CC9D15F08C-4E84
    End----------(Elapsed Time: 06:03, VBatt start/end: 12.4V/12.3V)-----------
              67 69 75 76 77
       Coding: 0016711
    19761 - B2
       Coding: 04495
       Coding: 00000
       Shop #: WSC 63351
    8 Faults Found:
       Coding: 00003
       Shop #: WSC 63351
       Coding: 0010607
       Coding: 00041
       Shop #: WSC 06335
       Coding: 01202
       Shop #: WSC 19404
    01176 - Key
       Coding: 00001
       Coding: 11788
       Shop #: WSC 63351
                35-00 -  -
       Coding: 00201
    End----------(Elapsed Time: 06:18, VBatt start/end: 12.2V/12.2V)-----------
              67 69 75 76 77
       Coding: 0016711
    19761 - B2
       Coding: 04495
       Coding: 00000
       Shop #: WSC 63351
    8 Faults Found:
       Coding: 00003
       Shop #: WSC 63351
       VCID: 34321614C723B8D78F2-4B00
       Coding: 0010607
       Coding: 00041
       Shop #: WSC 06335
       Coding: 01202
       Shop #: WSC 19404
    01176 - Key
       Coding: 00001
       Coding: 11788
       Shop #: WSC 63351
       VCID: 42DE40CC8D9706670DE-4B00
                35-00 -  -
       Coding: 00201
    End----------(Elapsed Time: 05:57, VBatt start/end: 12.1V/12.1V)-----------
  8. Likes Jetta ,97 liked this post
  9. #15
    I would have a look at the key coil and twisted pair that feed it from the cluster............Use WD and test the tracks.
  10. #16
    Feb 2017
    And this would be why i have Immobilizer codes in everything
  11. #17
    It is not a coil , it is cluster 100%, I have run in this problem to many times. Audi A4 has this problem with 8E0 920 950 H , cluster .
    Since your replacement cluster is same part number will happen again in future.
    You need to find update version 8E0 920 950 P.
    Please use Quote CODE tags around Auto Scan to not make post mile long.
    Also write which one is original , and which auto scan is with replacement cluster, this way we know what is what.
    Immobilizer/ECU
  12. Likes Uwe liked this post
  13. #18
    Feb 2017
    The clusters are labeled in the repair order field stock and Doner
  14. #19
    Yup could be...............
    It would be foolish to not test what I stated & just because Marin is cock sure of a part # or firmware update.
    What he isn't telling you is that the software just makes it ignore the weak signal to a lesser degree because indeed there can be an issue with the wiring or key coil.
    An easy way to see is to change the resistance value of the coil or repair wiring if found damaged in pinch point.
    Another test critical of load & which many negate or fail to understand how to test a track/component.
  15. #20
    Quote Originally Posted by Justin02071978 View Post
    Ok, I see now .Thanks
    Just Put Wrap Quote around Auto scan , so it will make much shorter that post . That is on top when you make post , last symbol.
    Immobilizer/ECU
