Results 1 to 6 of 6
Thread: Lambda or O2 sensor testing using VCDS
    Oct 2017
    Pennsylvania USA
    I am interested in checking the performance of my O2 sensors both before and after the cat.
    What series of clicks and taps do I need to get this test up and running? (in terms of measuring blocks and being able to produce a report that I can post here)
    2000 VW beetle 2.0L manual trans California/Exhaust.
    I deeply suspect that there may be issues or up and coming issues that are not yet being flagged by the ECU.
    I am using a lot of fuel. I currently have a Throttle Body Issue and would only be testing once that is sorted out.
    DJ
    You may find this link handy:
    http://www.ross-tech.com/vag-com/m_blocks/index.html
    New User
    Oct 2017
    Any thoughts on tests for this, Uwe? Anyone?
    Old thread, same problem...kinda. I dunno. Let me know your thoughts on what i can do other than O2 Sensor Tests?
    I tested the resistance and got the 1.34 Ohms, can't tell is my multimeter is malfunctioning or if my car may be wired different or something because I get voltage from the harness, but not from the 1&5 pin as I should.
    That makes me suspect the wiring harness may me mismatched with the new O2 sensor I bought that was RoadFar and it looked good. Possible the wires are crossed?
    New User
    Oct 2017
    Saturday,19,October,2019,00:41:50:13712
    VIN: WAUGF78K49A192023   License Plate:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
              52 53 55 56 62 65 67 6C 72 77
    VIN: WAUGF78K49A192023   Mileage: 173810km-108000miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0001
       Revision: E1H14---
       Coding: 010C010A190F0160
       Shop #: WSC 22145 444 84529
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79AFEEE6D95A0BCF8E9-802C
    14 Faults Found:
    7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
              P2096 00 [104] - Too Lean
                        Mileage: 173022 km
                        Date: 2019.10.10
                        Time: 00:43:10
                        Engine speed: 1557.00 /min
                        Normed load value: 19.2 %
                        Vehicle speed: 11 km/h
                        Coolant temperature: 84 °C
                        Intake air temperature: 34 °C
                        Voltage terminal 30: 13.617 V
                        Unlearning counter according OBD: 28
    2859 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
              P0036 00 [096] - Malfunction / Open Circuit
                        Mileage: 173456 km
                        Date: 2019.10.14
                        Time: 17:59:43
                        Engine speed: 758.00 /min
                        Normed load value: 11.4 %
                        Intake air temperature: 30 °C
                        Voltage terminal 30: 13.523 V
                        Unlearning counter according OBD: 31
    2875 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
              P0030 00 [096] - Malfunction / Open Circuit
                        Mileage: 173456 km
                        Date: 2019.10.14
                        Time: 17:53:50
                        Engine speed: 159.50 /min
                        Normed load value: 29.4 %
                        Coolant temperature: 54 °C
                        Voltage terminal 30: 11.732 V
    2865 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
              P3255 00 [232] - Regulation at Upper Limit
                        Fault Frequency: 24
                        Mileage: 172950 km
                        Date: 2019.10.09
                        Time: 18:03:32
                        Engine speed: 891.50 /min
                        Vehicle speed: 12 km/h
                        Coolant temperature: 105 °C
                        Intake air temperature: 53 °C
                        Voltage terminal 30: 13.381 V
    2868 - Oxygen (Lambda) Sensor B1 S1
              P3266 00 [237] - Internal Resistance Implausible
                        Fault Frequency: 24
                        Mileage: 172950 km
                        Date: 2019.10.09
                        Time: 18:02:34
                        Engine speed: 1674.50 /min
                        Normed load value: 31.8 %
                        Vehicle speed: 7 km/h
                        Coolant temperature: 100 °C
                        Intake air temperature: 54 °C
                        Voltage terminal 30: 13.334 V
    10434 - Catalyst System; Bank 1
              P0420 00 [237] - Efficiency Below Threshold
                        Mileage: 172487 km
                        Date: 2019.10.04
                        Time: 21:19:23
                        Engine speed: 1765.50 /min
                        Normed load value: 37.3 %
                        Vehicle speed: 39 km/h
                        Coolant temperature: 77 °C
                        Intake air temperature: 32 °C
                        Voltage terminal 30: 13.499 V
    7679 - Oxygen (Lambda) Sensor B1 S1
              P0132 00 [104] - Signal too High
                        Fault Frequency: 157
                        Mileage: 172845 km
                        Date: 2019.10.08
                        Time: 14:56:32
                        Engine speed: 1043.00 /min
                        Normed load value: 7.1 %
                        Vehicle speed: 15 km/h
                        Coolant temperature: 89 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 13.452 V
                        Unlearning counter according OBD: 26
    7680 - Oxygen (Lambda) Sensor B1 S1
              P0131 00 [104] - Signal too Low
                        Mileage: 172936 km
                        Date: 2019.10.09
                        Time: 12:50:22
                        Engine speed: 825.50 /min
                        Normed load value: 19.6 %
                        Coolant temperature: 81 °C
                        Intake air temperature: 37 °C
    7670 - Oxygen (Lambda) Sensor B1 S1
              P0130 00 [237] - Malfunction in Circuit
                        Fault Frequency: 60
                        Mileage: 172831 km
                        Date: 2019.10.08
                        Time: 12:56:27
                        Engine speed: 2557.50 /min
                        Vehicle speed: 37 km/h
                        Coolant temperature: 92 °C
                        Intake air temperature: 35 °C
                        Voltage terminal 30: 13.782 V
    4060 - Cylinder 3
              P0303 00 [236] - Misfire Detected
                        Mileage: 173354 km
                        Date: 2019.10.13
                        Time: 13:34:47
                        Engine speed: 3198.50 /min
                        Normed load value: 88.2 %
                        Vehicle speed: 44 km/h
                        Coolant temperature: 101 °C
                        Intake air temperature: 45 °C
    4063 - Cylinder 4
              P0304 00 [236] - Misfire Detected
                        Mileage: 173354 km
                        Date: 2019.10.13
                        Time: 13:35:14
                        Engine speed: 751.50 /min
                        Normed load value: 13.3 %
                        Coolant temperature: 104 °C
    4057 - Cylinder 2
              P0302 00 [236] - Misfire Detected
                        Fault Frequency: 7
                        Mileage: 172512 km
                        Date: 2019.10.04
                        Time: 23:14:47
                        Engine speed: 4269.00 /min
                        Normed load value: 94.1 %
                        Vehicle speed: 94 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 13.146 V
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [236] - -
                        Mileage: 172512 km
                        Date: 2019.10.04
                        Time: 23:14:47
    4201 - Fuel Level too Low
              P1250 00 [096] - -
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0051
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 06335 123 12345
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 363525DAA8C424B723B-8062
       Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
       Component: ESP8 quattro  H04 0210
       Coding: 150500
       VCID: 7DA7FAF6CDF237EFA21-8028
       Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
       Component: BCM2 1.1      H80 BCM2 1.1      H80 01450145
       Coding: 090200
       Shop #: WSC 06335 000 00000
       VCID: 75B7E2D6F5C26FAFEA1-8020
       Subsystem 1 - Part No: 8T0 959 754 G
       Component: FBSAUDIB8 IDG
       Subsystem 2 - Part No: 8K0 905 852 D
       Component: ELVAUDIB8
    No Faults Found
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 340AJ097518153
       Coding: 0001003
       Shop #: WSC 00000 000 08192
       VCID: 43D34C0EE796811F945-8016
       Subsystem 1 - Part No: 8T0 919 609 A
       Component: E0380 BedienteilH08 0100
       Subsystem 2 - Serial number: 00000000206757
       Subsystem 3 - Serial number: 0102.12.080000000100010370˙
       Subsystem 4 - Serial number: 010370˙
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0150
       Revision: C1000000    Serial number: 01130120090307
       Coding: 64002000
       VCID: 72BDD9CA84AC7897CF3-8026
                        Fault Status: 00100001
                        Reset counter: 69
                        Mileage: 172639 km
                        Date: 2019.10.05
                        Time: 22:13:12
                        Voltage: 13.80 V
                        Temperature: 24.0°C
                        Temperature: 17.0°C
                        Count: 12027
                        Count: 13085
                        Bin. Bits: 01000000
                        Bin. Bits: 00001011
                        Time: 255.00 s
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000293598
       Coding: 260810091023CB010001080300003D0D4F9C460800010161000000
       VCID: 303913C24A200A87797-8064
       Component: WWS 130109  H06 0070
       Serial number: SWF09010135573
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10352847
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
       Component: E1 - LDS  H07 0080
       Serial number: 00000000000901091646
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
    01853 - Heated Seat; Left Front (Z45)
                        Reset counter: 39
                        Mileage: 173136 km
                        Date: 2019.10.11
                        Time: 13:20:00
       Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
       Component: MP3-Changer     H43 0390
       Revision: 00043003    Serial number: AUZ5ZBI8722594
       VCID: 2A0D01AA60FC7057B73-807E
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7I0506078
       Coding: 0000100
       VCID: 313F16C64D2A038F769-8064
                        Reset counter: 36
                        Mileage: 172992 km
                        Date: 2019.10.09
                        Time: 20:23:46
       Part No SW: 8K0 919 475 F    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0040
       Revision: 11001001    Serial number: 40140900804852
       Coding: 200103
       VCID: 3C2137F29668FEE7D5F-8068
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Component: AirbagVW-AU10 H27 0410
       Serial number: 0039KD14RLR$
       Coding: 303836354230303030304A55304C384B3053
       VCID: 40D94302FA009A07897-8014
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R08000039R4
       Serial number: 6334MSME426570164
       Serial number: 6344MSME447118122
       Serial number: 6352QSME341A2518B
       Serial number: 6362QSME3C172620B
       Serial number: 63732SME3E17302C+
       Serial number: 63832SME3E171604-
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90304IA800023
       Coding: 000017
       VCID: 3D273AF68D72F7EFE21-8068
       Part No SW: 8K0 920 980 A    HW: 8K0 920 980 A
       Component: KOMBIINSTR.   H18 0224
       Revision: 00000000    Serial number: 9E17670D8
       Coding: 030511000300D705020201
       Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0095
       Revision: EB500046    Serial number: 4600E091078306
       Coding: 000303
       VCID: 4EC56D3A30D47C770BB-801A
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 1805B278041208
                        Reset counter: 84
                        Mileage: 173456 km
                        Date: 2019.10.14
                        Time: 17:31:00
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0850
       Revision: 00000000
       Coding: 020000
       VCID: 2B0304AE6306695F4C5-807E
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001158803
       Coding: 00585300000000000000
       VCID: 77ABE8DEEFCE1DBFF8D-8022
                        Fault Frequency: 10
                        Mileage: 172807 km
                        Date: 2019.10.06
                        Time: 22:48:06
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
       Component: MNS US          H52 1100
       Revision: 00000000    Serial number: 341AN097522836
       VCID: 38292BE2AE50D2C7317-806C
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000008282729
       Coding: 011F03200F00410001
       VCID: 41DF4606F18A930F869-8014
       Component: BCM2 1.1      H80 0145
       Revision: 00002001    Serial number: 0116443622
       Coding: 016216E220F24406033002
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0040
       Serial number: 00000000000000111055
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS130  H06 0037
    02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
                        Fault Status: 00101100
                        Fault Frequency: 35
                        Reset counter: 94
                        Mileage: 172138 km
                        Date: 2019.10.02
                        Time: 12:33:25
                        Reset counter: 86
                        Mileage: 173467 km
                        Date: 2019.10.15
                        Time: 10:31:40
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
       Part No SW: 8T0 035 223 AD    HW: 8T0 035 223 G
       Component: DSP STD       H08 0300
       Revision: S2600000
       Coding: 020201
       VCID: 70B9D3C28AA04A87397-8024
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000008294094
       VCID: 40D94302FA809A07897-8014
                        Reset counter: 4
                        Mileage: 171695 km
                        Date: 2019.09.25
                        Time: 01:15:32
       Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
       Component: EPB Audi B8   H06 0070
       Revision: 00000003    Serial number: 00000000290993
       VCID: 323D19CA442C38970F3-8066
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06334 000 00000
       VCID: 77ABE8DEE3CE1DBFF8D-8022
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
       Revision: 00000000    Serial number: 357AT097517255
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000008368026
       Coding: 010F01200000220001
       VCID: 44D14F12EE988627ADF-8010
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140782266448
       Coding: 0CD154
    02214 - Tire Pressure Warning
                        Reset counter: 92
                        Mileage: 173630 km
                        Date: 2019.10.17
                        Time: 11:35:12
                        Bin. Bits: 00001000 00100011
                        Voltage: 13.90 V
                        Text:  17,0°C; -0,73bar;3444397030;00h; 16°C
       Component: SDS 3501 US     H46 0630
       Revision: 00000000    Serial number: 00000812030072
       Shop #: WSC 12336 024 394758
       VCID: 34311FD2B23836A71DF-8060
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J8Y92OH
       Coding: 1000007
       Shop #: WSC 06335 123 01234
       VCID: 372B28DEA34EDDBF38D-8062
       Revision:             Serial number: 0000008368121
       Coding: 010F01200040220001
       Component: Handyvorb2      H20 1130
       Revision: 00000000    Serial number: 00000005076316
       Coding: 0010900
       VCID: 2809FBA27EF04247A17-807C
    End----------(Elapsed Time: 02:54, VBatt start/end: 12.4V/12.4V)-----------
    With this faults, there isn't any point in trying to test the B1S1 sensor with VCDS.
    Is this an aftermarket sensor (Chinese Replacement Auto Part)?
    New User
    Oct 2017
    Not a Bosch, I’m sure of that. So just replace it and eat the loss. I gotcha.
