Lambda or O2 sensor testing using VCDS
Djaylulu
Pennsylvania USA
C?ID=319731
I am interested in checking the performance of my O2 sensors both before and after the cat.
What series of clicks and taps do I need to get this test up and running? (in terms of measuring blocks and being able to produce a report that I can post here)
2000 VW beetle 2.0L manual trans California/Exhaust.
I deeply suspect that there may be issues or up and coming issues that are not yet being flagged by the ECU.
I am using a lot of fuel. I currently have a Throttle Body Issue and would only be testing once that is sorted out.
DJ
audiyadosir
San Francisco, CA USA
C?ID=342309
Any thoughts on tests for this, Uwe? Anyone?
Old thread, same problem...kinda. I dunno. Let me know your thoughts on what i can do other than O2 Sensor Tests?
I tested the resistance and got the 1.34 Ohms, can't tell is my multimeter is malfunctioning or if my car may be wired different or something because I get voltage from the harness, but not from the 1&5 pin as I should.
That makes me suspect the wiring harness may me mismatched with the new O2 sensor I bought that was RoadFar and it looked good. Possible the wires are crossed?
audiyadosir
C?ID=342309
Saturday,19,October,2019,00:41:50:13712
VIN: WAUGF78K49A192023   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
          52 53 55 56 62 65 67 6C 72 77
VIN: WAUGF78K49A192023   Mileage: 173810km-108000miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Revision: E1H14---
   Coding: 010C010A190F0160
   Shop #: WSC 22145 444 84529
   VCID: 79AFEEE6D95A0BCF8E9-802C
14 Faults Found:
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
          P2096 00 [104] - Too Lean
                    Mileage: 173022 km
                    Date: 2019.10.10
                    Time: 00:43:10
                    Engine speed: 1557.00 /min
                    Normed load value: 19.2 %
                    Vehicle speed: 11 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 13.617 V
                    Unlearning counter according OBD: 28
2859 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [096] - Malfunction / Open Circuit
                    Mileage: 173456 km
                    Date: 2019.10.14
                    Time: 17:59:43
                    Engine speed: 758.00 /min
                    Normed load value: 11.4 %
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 13.523 V
                    Unlearning counter according OBD: 31
2875 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0030 00 [096] - Malfunction / Open Circuit
                    Mileage: 173456 km
                    Date: 2019.10.14
                    Time: 17:53:50
                    Engine speed: 159.50 /min
                    Normed load value: 29.4 %
                    Coolant temperature: 54 °C
                    Voltage terminal 30: 11.732 V
2865 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
          P3255 00 [232] - Regulation at Upper Limit
                    Fault Frequency: 24
                    Mileage: 172950 km
                    Date: 2019.10.09
                    Time: 18:03:32
                    Engine speed: 891.50 /min
                    Vehicle speed: 12 km/h
                    Coolant temperature: 105 °C
                    Intake air temperature: 53 °C
                    Voltage terminal 30: 13.381 V
2868 - Oxygen (Lambda) Sensor B1 S1
          P3266 00 [237] - Internal Resistance Implausible
                    Fault Frequency: 24
                    Mileage: 172950 km
                    Date: 2019.10.09
                    Time: 18:02:34
                    Engine speed: 1674.50 /min
                    Normed load value: 31.8 %
                    Vehicle speed: 7 km/h
                    Coolant temperature: 100 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 13.334 V
10434 - Catalyst System; Bank 1
          P0420 00 [237] - Efficiency Below Threshold
                    Mileage: 172487 km
                    Date: 2019.10.04
                    Time: 21:19:23
                    Engine speed: 1765.50 /min
                    Normed load value: 37.3 %
                    Vehicle speed: 39 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 13.499 V
7679 - Oxygen (Lambda) Sensor B1 S1
          P0132 00 [104] - Signal too High
                    Fault Frequency: 157
                    Mileage: 172845 km
                    Date: 2019.10.08
                    Time: 14:56:32
                    Engine speed: 1043.00 /min
                    Normed load value: 7.1 %
                    Vehicle speed: 15 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 13.452 V
                    Unlearning counter according OBD: 26
7680 - Oxygen (Lambda) Sensor B1 S1
          P0131 00 [104] - Signal too Low
                    Mileage: 172936 km
                    Date: 2019.10.09
                    Time: 12:50:22
                    Engine speed: 825.50 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 81 °C
                    Intake air temperature: 37 °C
7670 - Oxygen (Lambda) Sensor B1 S1
          P0130 00 [237] - Malfunction in Circuit
                    Fault Frequency: 60
                    Mileage: 172831 km
                    Date: 2019.10.08
                    Time: 12:56:27
                    Engine speed: 2557.50 /min
                    Vehicle speed: 37 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 13.782 V
4060 - Cylinder 3
          P0303 00 [236] - Misfire Detected
                    Mileage: 173354 km
                    Date: 2019.10.13
                    Time: 13:34:47
                    Engine speed: 3198.50 /min
                    Normed load value: 88.2 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 101 °C
                    Intake air temperature: 45 °C
4063 - Cylinder 4
          P0304 00 [236] - Misfire Detected
                    Mileage: 173354 km
                    Date: 2019.10.13
                    Time: 13:35:14
                    Engine speed: 751.50 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 104 °C
4057 - Cylinder 2
          P0302 00 [236] - Misfire Detected
                    Fault Frequency: 7
                    Mileage: 172512 km
                    Date: 2019.10.04
                    Time: 23:14:47
                    Engine speed: 4269.00 /min
                    Normed load value: 94.1 %
                    Vehicle speed: 94 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 13.146 V
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [236] - -
                    Fault Frequency: 8
                    Mileage: 172512 km
                    Date: 2019.10.04
                    Time: 23:14:47
4201 - Fuel Level too Low
          P1250 00 [096] - -
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0051
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 06335 123 12345
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 363525DAA8C424B723B-8062
   Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
   Component: ESP8 quattro  H04 0210
   Coding: 150500
   VCID: 7DA7FAF6CDF237EFA21-8028
   Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
   Component: BCM2 1.1      H80 BCM2 1.1      H80 01450145
   Coding: 090200
   Shop #: WSC 06335 000 00000
   VCID: 75B7E2D6F5C26FAFEA1-8020
   Subsystem 1 - Part No: 8T0 959 754 G
   Component: FBSAUDIB8 IDG
   Subsystem 2 - Part No: 8K0 905 852 D
   Component: ELVAUDIB8
No Faults Found
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340AJ097518153
   Coding: 0001003
   Shop #: WSC 00000 000 08192
   VCID: 43D34C0EE796811F945-8016
   Subsystem 1 - Part No: 8T0 919 609 A
   Subsystem 2 - Serial number: 00000000206757
   Subsystem 3 - Serial number: 0102.12.080000000100010370ÿ
   Subsystem 4 - Serial number: 010370ÿ
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01130120090307
   Coding: 64002000
   VCID: 72BDD9CA84AC7897CF3-8026
                    Fault Status: 00100001
                    Reset counter: 69
                    Mileage: 172639 km
                    Date: 2019.10.05
                    Time: 22:13:12
                    Voltage: 13.80 V
                    Temperature: 24.0°C
                    Temperature: 17.0°C
                    Count: 12027
                    Count: 13085
                    Bin. Bits: 01000000
                    Bin. Bits: 00001011
                    Time: 255.00 s
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Revision: 05022001    Serial number: 00000000293598
   Coding: 260810091023CB010001080300003D0D4F9C460800010161000000
   Shop #: WSC 12345 123 12345
   VCID: 303913C24A200A87797-8064
   Component: WWS 130109  H06 0070
   Serial number: SWF09010135573
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10352847
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0080
   Serial number: 00000000000901091646
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
01853 - Heated Seat; Left Front (Z45)
                    Fault Status: 01101100
                    Reset counter: 39
                    Mileage: 173136 km
                    Date: 2019.10.11
                    Time: 13:20:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBI8722594
   VCID: 2A0D01AA60FC7057B73-807E
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7I0506078
   Coding: 0000100
   VCID: 313F16C64D2A038F769-8064
                    Reset counter: 36
                    Mileage: 172992 km
                    Date: 2019.10.09
                    Time: 20:23:46
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40140900804852
   Coding: 200103
   VCID: 3C2137F29668FEE7D5F-8068
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Serial number: 0039KD14RLR$
   VCID: 40D94302FA009A07897-8014
   Serial number: 5810000R08000039R4
   Serial number: 6334MSME426570164
   Serial number: 6344MSME447118122
   Serial number: 6352QSME341A2518B
   Serial number: 6362QSME3C172620B
   Serial number: 63732SME3E17302C+
   Serial number: 63832SME3E171604-
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304IA800023
   Coding: 000017
   VCID: 3D273AF68D72F7EFE21-8068
   Part No SW: 8K0 920 980 A    HW: 8K0 920 980 A
   Component: KOMBIINSTR.   H18 0224
   Revision: 00000000    Serial number: 9E17670D8
   Coding: 030511000300D705020201
   Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0095
   Revision: EB500046    Serial number: 4600E091078306
   Coding: 000303
   VCID: 4EC56D3A30D47C770BB-801A
   Component: J367-BDM  H04 0150
   Serial number: 1805B278041208
                    Reset counter: 84
                    Mileage: 173456 km
                    Date: 2019.10.14
                    Time: 17:31:00
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   Coding: 020000
   VCID: 2B0304AE6306695F4C5-807E
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001158803
   Coding: 00585300000000000000
   VCID: 77ABE8DEEFCE1DBFF8D-8022
                    Fault Frequency: 10
                    Mileage: 172807 km
                    Date: 2019.10.06
                    Time: 22:48:06
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 341AN097522836
   VCID: 38292BE2AE50D2C7317-806C
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008282729
   Coding: 011F03200F00410001
   VCID: 41DF4606F18A930F869-8014
   Component: BCM2 1.1      H80 0145
   Revision: 00002001    Serial number: 0116443622
   Coding: 016216E220F24406033002
   Component: GTO BF  H06 0040
   Serial number: 00000000000000111055
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS130  H06 0037
02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
                    Fault Status: 00101100
                    Fault Frequency: 35
                    Reset counter: 94
                    Mileage: 172138 km
                    Date: 2019.10.02
                    Time: 12:33:25
                    Reset counter: 86
                    Mileage: 173467 km
                    Date: 2019.10.15
                    Time: 10:31:40
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 AD    HW: 8T0 035 223 G
   Component: DSP STD       H08 0300
   Revision: S2600000
   Coding: 020201
   VCID: 70B9D3C28AA04A87397-8024
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008294094
   VCID: 40D94302FA809A07897-8014
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 4
                    Mileage: 171695 km
                    Date: 2019.09.25
                    Time: 01:15:32
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 00000000290993
   VCID: 323D19CA442C38970F3-8066
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 77ABE8DEE3CE1DBFF8D-8022
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Revision: 00000000    Serial number: 357AT097517255
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000008368026
   Coding: 010F01200000220001
   VCID: 44D14F12EE988627ADF-8010
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140782266448
   Coding: 0CD154
02214 - Tire Pressure Warning
                    Reset counter: 92
                    Mileage: 173630 km
                    Date: 2019.10.17
                    Time: 11:35:12
                    Bin. Bits: 00001000 00100011
                    Voltage: 13.90 V
                    Text:  17,0°C; -0,73bar;3444397030;00h; 16°C
Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000812030072
   Shop #: WSC 12336 024 394758
   VCID: 34311FD2B23836A71DF-8060
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J8Y92OH
   Coding: 1000007
   Shop #: WSC 06335 123 01234
   VCID: 372B28DEA34EDDBF38D-8062
   Revision:             Serial number: 0000008368121
   Coding: 010F01200040220001
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005076316
   Coding: 0010900
   VCID: 2809FBA27EF04247A17-807C
End----------(Elapsed Time: 02:54, VBatt start/end: 12.4V/12.4V)-----------
With this faults, there isn't any point in trying to test the B1S1 sensor with VCDS.
Is this an aftermarket sensor (Chinese Replacement Auto Part)?
audiyadosir
C?ID=342309
Not a Bosch, I’m sure of that. So just replace it and eat the loss. I gotcha.
audiyadosir
C?ID=342309
Sunday,15,December,2019,03:46:07:13712
VIN: WAUGF78K49A192023   License Plate: 6HTS825
Mileage: 178270km-110771mi   Repair Order:
Scan: 01 02 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46
          47 52 53 55 56 62 65 67 6C 72 77
VIN: WAUGF78K49A192023   Mileage: 178270km-110771miles
06-Seat Mem. Pass -- Status: Not registered 0011
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
   Revision: E1H14---
Readiness: 1010 0101
   Revision: --H04---
   Coding: 001002
   Coding: 150500
   Coding: 090200
   Subsystem 1 - Part No SW: 8T0 959 754 G    HW: 8T0 959 754 G
   Component: FBSAUDIB8 IDG  H61 0072
   Serial number: 0511000078743003
   Serial number: 0208000102844008
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Component: MEM-BFS       H05 0043
                    Reset counter: 156
                    Mileage: 177399 km
                    Date: 2019.12.05
                    Time: 04:56:44
03330 - Motor for Fore/Aft Adjustment
                    Fault Status: 00100101
                    Reset counter: 184
                    Mileage: 177399 km
                    Date: 2019.12.05
                    Time: 04:56:44
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 140
                    Mileage: 177399 km
                    Date: 2019.12.05
                    Time: 04:56:45
                    Reset counter: 140
                    Mileage: 177399 km
                    Date: 2019.12.05
                    Time: 04:56:48
02005 - Coding Pin
                    Reset counter: 141
   Coding: 0001003
02244 - Button in Control Head is Stuck
                    Reset counter: 195
                    Mileage: 178115 km
                    Date: 2019.12.14
                    Time: 00:27:26
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      010
                    Reset counter: 141
                    Mileage: 177399 km
                    Date: 2019.12.05
                    Time: 10:26:44
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
   Coding: 64002000
   Coding: 00FD11
   Coding: 025028
                    Reset counter: 150
                    Mileage: 177810 km
                    Date: 2019.12.11
                    Time: 16:00:00
                    Reset counter: 153
                    Mileage: 177927 km
                    Date: 2019.12.12
                    Time: 19:01:00
   Coding: 0000100
                    Fault Frequency: 9
                    Reset counter: 153
                    Mileage: 177954 km
                    Date: 2019.12.12
                    Time: 21:11:19
   Coding: 200103
   Coding: 000017
   Coding: 000303
                    Reset counter: 140
                    Mileage: 177399 km
                    Date: 2019.12.05
                    Time: 04:58:34
                    Reset counter: 140
                    Mileage: 177399 km
                    Date: 2019.12.05
                    Time: 04:58:38
   Revision: 00000000
   Coding: 020000
                    Reset counter: 141
                    Mileage: 177399 km
                    Date: 2019.12.05
                    Time: 05:26:32
   Revision: S2600000
   Coding: 020201
                    Reset counter: 121
                    Mileage: 175804 km
                    Date: 2019.11.16
                    Time: 22:02:39
                    Reset counter: 107
                    Mileage: 175808 km
                    Date: 2019.11.16
                    Time: 22:16:52
   Coding: 0000004
   Coding: 0CD154
                    Reset counter: 193
                    Mileage: 177938 km
                    Date: 2019.12.12
                    Time: 20:24:08
                    Voltage: 13.80 V
                    Text:  15,5°C; -0,68bar;3453386624;00h; 23°C
   Coding: 1000007
02203 - Audio / Video Input 1
                    Fault Status: 00101011
                    Reset counter: 196
                    Mileage: 178213 km
                    Date: 2019.12.14
                    Time: 23:03:44
                        Term 15 On
                        Reverse OFF
                    Count: 3
   Coding: 0010900
End----------(Elapsed Time: 02:28, VBatt start/end: 13.9V/13.8V)-----------
Color me confused, but I see no fault code(s) in 01-Engine in the above scan.
