Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: ABS Module Coding (MK60EC1 NAR)
  1. #31
    May 2017
    The steering wheel DTC could be your coding. You mentioned that you had the voice command button coded to mute? That could be one reason.
  2. #32
    Enable what is supposed to be present, code it.......... and ADP all needed ecu's.
  3. #33
    United States
    Quote Originally Posted by Nomad View Post
    I’ve tried that before (holding the reset button in glovebox) but nothing happens. No ding, no light, nothing. Should I go ahead and change A7 to 05 in the long coding?
    Make sure you attempted to reset it with the key on, engine off. Some cars are stubborn if you try to do it at idle. Another option is Basic Settings 042 reset and it doesn't matter if the engine is running or not in my experience.
  4. Likes Jack@European_Parts, downtime, Uwe liked this post
  5. #34
    Nov 2017
    Okay so I changed the long code as suggested (coding accepted), and now I get a new fault in the ABS module: “02186 - Engine <-> ADR interface”. The box for TPMS Installed is still checked in the ABS long code helper.
    I will post a scan when the WiFi starts working.
    2011 Jetta SEL 2.5i
