Results 11 to 20 of 34
Thread: ABS Module Coding (MK60EC1 NAR)
    Aug 2016
    The Hague, NL
    Just clear then and see if they return. If you connected all together in the proper way, the airbag light will return.
    I'd recommend to go through all the basic settings, then have a look at byte 16 bit 2, byte 17 bit 2 and byte 19 bit 1 and play around a bit to kill the light.
    Of course you'll need to reset the TPMS too by driving a bit and 'learn' the system the proper tire circumferences.
  2. #12
    Nov 2017
    Sounds good. Once my laptop finishes force updating I’ll go mess with it. The bits you’re referring to, do you mean in the airbag module or the abs module?
  3. #13
    Aug 2016
    The Hague, NL
    In the ABS module. The airbag module should be OK after you clear the DTC.
  4. #14
    Nov 2017
    Firstly, thanks for taking the time to help me out. Okay so here's where I'm at.
    I completed all basic settings listed on the Ross-Tech Wiki. The only one I couldn't complete was the basic setting for hydraulic unit disconnecting valves.
    The airbag light continues to turn on, no matter how or how many times i reset it. It also comes back on if I run an autoscan. I tried to reset the parameters for the occupancy sensor, but it says error. This issue didn't arise until I put the coding in, it has to be related or the weirdest coincidence ever.
    The TPMS light is still on but get this- every time I access the ABS module it turns off. When i exit the module, 'Ding!", it comes back on. I tried driving it around to let it relearn itself, but no luck. I drove about 5 miles.
    The ABS light is no longer flashing, but on solid. I think the BRAKE warning light has turned off, but it's hard to tell in the daytime.
    Ironically, the car seems to drive much better than before I put the "incorrect" coding into the module. The brakes are more sensitive, the steering seems tighter without a dead spot in the center, and even the engine and transmission seem to be dancing instead of fighting. No more "2nd-gear-feeling" slow starts or annoying downshifting coming out of a tight turn.
    I'm not quite sure what to make of my current situation. My car seems to have greatly improved, but my number of warning lights have doubled lol. I played around with the last few bytes on the abs module and was able to get it to accept one change- "ABS monitoring via instrument cluster".
    Here is the auto-scan from AFTER all DTCs were cleared.
    Saturday,04,November,2017,14:24:33:15250
    VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
    VIN: 3VWDX7AJ1BM006318   License Plate:
    Mileage: 211040km-131134mi   Repair Order:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
    VIN: 3VWDX7AJ1BM006318   Mileage: 211040km-131134miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 A    HW: 07K 906 055
       Component: 2,5l R5/4V      G01 9214
       Revision: T4H04---    Serial number:
       Coding: 0000075
       Shop #: WSC 25016 444 13939
       VCID: 2C01FA78BA088E47D72-8078
    005784 - Please Check DTC Memory of Steering Wheel Electronics
                   P1698 - 000 -  - Intermittent
                        Mileage: 209928 km
                        Date: 2012.03.04
                        Time: 19:37:54
                        RPM: 1286 /min
                        Load: 40.8 %
                        Speed: 11.0 km/h
                        Temperature: 54.0C
                        Temperature: 42.0C
                        Absolute Pres.: 1010.0 mbar
                        Fault Frequency: 89
                        Mileage: 209971 km
                        Date: 2012.03.06
                        Time: 13:36:12
                        RPM: 1356 /min
                        Load: 32.5 %
                        Speed: 13.0 km/h
                        Temperature: 48.0C
                        Temperature: 31.0C
    012408 - Throttle Control
                   P3078 - 000 - Airflow at Idle too Low
                        Mileage: 210631 km
                        Date: 2012.03.24
                        Time: 10:46:33
                        RPM: 683 /min
                        Load: 23.9 %
                        Temperature: 92.0C
                        Temperature: 30.0C
       Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
       Component: AQ 250 6F           1741
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 00597EC86600BA275BA-8054
       Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
       Component: ESP MK60EC1   H30 0106
       Revision: 00H30001
       Coding: B14B440C492208008D0E22E592211061A70400
       Shop #: WSC 00066 123 12345
       VCID: 74B122182EB896874F2-8020
                        Reset counter: 199
                        Mileage: 211049 km
                        Date: 2012.03.27
                        Time: 13:51:48
                        Count: 2
                        Count: 12
                        Count: 28672
                        Count: 320
                        Count: 45568
                        Count: 65024
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 199
                        Mileage: 211049 km
                        Date: 2012.03.27
                        Time: 13:51:48
                        Count: 2
                        Count: 12
                        Count: 28672
                        Count: 143
                        Count: 45568
                        Count: 65024
                        Reset counter: 199
                        Mileage: 211049 km
                        Date: 2012.03.27
                        Time: 13:51:48
                        Count: 2
                        Count: 12
                        Count: 28672
                        Count: 16390
                        Count: 45568
                        Count: 65024
       Part No SW: 5C0 820 047 L    HW: 5C0 820 047 L
       Component: J301  Klimaanlage   0102
       Revision: 2000908S    Serial number: 00000000034037
       VCID: 290F036CB5FA9B6F2C4-807C
       Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0226
       Revision: B2066001    Serial number: 03311231100025
       Coding: 73994BBE08A10B0008382000200884C400C2502E60000000300000000000
       Shop #: WSC 25807 444 59326
       VCID: 2D07F77C8D12874FC0C-8078
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3462
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3462
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.019  H08 0006
       Serial number:     WRH000061ZC
       Coding: 180000
       Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
       Serial number: 0017246
       Coding: 020000
       Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3462
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3462
       Coding: 800000
    00975 - Heated Rear Window (Z1)
                006 - Short to Plus
                        Fault Status: 01100110
                        Reset counter: 199
                        Mileage: 211049 km
                        Date: 2012.03.27
                        Time: 13:51:51
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   012 0805
       Serial number: 003END07B4B0
       Coding: 00003232
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 6FBB2D74471EB55FB20-803A
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y1000000FKL0O
       Coding: 303143
       Serial number: 3572MSME4A713552ZZZU
       Serial number: 3582MSME13486553ZZZT
       Component: S.Sens.Fahr.H  H01 ----
       Serial number: 3516KSME44526208ZZZK
       Component: S.Sens.Beif.H  H01 ----
       Serial number: 3526KSME34606208ZZZJ
       Component: F.Sens.Fahr  H01 ----
       Serial number: 3556LSME111A0708ZZZM
       Component: F.Sens.Beif  H01 ----
       Serial number: 3566LSME6D0B0408ZZZ.
    9483008 - Seat Occupied Recognition
              B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                        Reset counter: 199
                        Mileage: 211049 km
                        Date: 2017.11.04
                        Time: 14:23:46
       Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
       Component: KOMBI         H07 0406
       Coding: 170001
       Shop #: WSC 00066 123 00148
       VCID: 2B03F964B386897FDE8-807E
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 0226
       Coding: 102200
       VCID: 70B92E085AA0AAA7ABA-8024
    02078 - Media Player Position 3 (R120)
                        Reset counter: 199
                        Mileage: 211049 km
                        Date: 2012.03.27
                        Time: 13:51:53
       Component: IMMO          H07 0406
       VCID: 6A8D3C607CFC5077E5E-803E
    Address 2E: Media Player 3
       Part No SW: 5ND 035 190 A    HW: 5ND 035 190 A
       Component: RCD510USBRVC  001 0003
       Revision: -----001    Serial number: VWZ4Z3M8135616
       Coding: 05000424040006
       Shop #: WSC 00081 790 00128
       VCID: 3A2DCC204C5C20F755E-806E
    03272 - Control Module for Audio Interface
                        Reset counter: 199
                        Mileage: 211049 km
                        Date: 2012.03.27
                        Time: 13:51:47
    00856 - Radio Antenna
                        Reset counter: 199
                        Mileage: 211049 km
                        Date: 2012.03.27
                        Time: 14:23:30
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668295109
       Coding: 0A00000000010100
       Shop #: WSC 01383 790 50316
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 323DE40094ACD8B79DE-8066
    End----------(Elapsed Time: 01:34, VBatt start/end: 12.7V/12.7V)-----------
  5. #15
    Aug 2016
    The Hague, NL
    check connectors under the seat, maybe its disconnected.
    could also bue due to other modules, i.e. the ABS: http://wiki.ross-tech.com/wiki/index.php/B10B3/037043
    it looks like the abs is looking for an external TPMS module J502 but cannot find it (probably because it's not present).
    i don't know how to fix it, but maybe nostrajackass or one of the scandinavians do. this is as far as my knowledge goes for MK60EC1
    you can make the car a bit happier if you go to the CAN gateway, installation list and deselect 2E since it's not found.
  6. #16
    Nov 2017
    I checked and rechecked the connections but I haven’t checked passenger side. I’ll go look. I’ll play around with it some tonight and see what I come up with.
    I’m hoping they can help! I appreciate you getting me this far though, like I said the car feels a lot better already. Thanks again.
    2011 Jetta SEL 2.5i
  7. #17
    Aug 2016
    The Hague, NL
    no worries, i'm happy to help but i hope we can fix the last bits too. my guess is, if you manage to fix the abs coding you'll fix the airbag error too.
  8. #18
    Nov 2017
    We’ll see! I get chronic migraines so I’m bed ridden until my medication kicks in but as soon as I can, I’m going to get back on it. I’m hoping once I complete that self function test I’ll be able to get rid of it.
    2011 Jetta SEL 2.5i
  9. #19
    Aug 2016
    The Hague, NL
    As far as I'm concerned, there is no need to rush it. Take your time, it's just a car. Your health is more important.
  10. #20
    Nov 2017
    You're right, health is number 1! Car is number 2 Okay so I was able to play around and get the TPMS light to stay off, but I'm pretty sure I just turned off the TPM system, which is fine for now.
    The airbag light will not go out, no matter what I try. I think what's standing in my way is the steering angle sensor. It says "defective" and when i try to do the basic settings, the angle is stuck at 68.99 degrees when the wheel is straight. The number wont change at all, I've followed all the directions on the Wiki. Could the steering angle sensor be the problem? I think in order to get the airbag light off, I have to do the system function test for the ABS module, and in order to do that I have to do the basic setting for the steering angle sensor.
    Here's a fresh autoscan, after clearing all DTCs. I should say that earlier I had a code for the steering angle sensor but it just said "implausible signal" or similar. After doing the steering angle basic settings is when it changed to "Defective".
    Update: I got the airbag light to go off but only by turning it off manually. I don’t think this is a safe or long term solution, but it’ll do for now. Only light left on now is ABS and possibly traction control light.
    Saturday,04,November,2017,18:48:39:15250
    Scan: 01 02 03 08 09 15 17 19 25 56 77
    VIN: 3VWDX7AJ1BM006318   Mileage: 211060km-131146miles
       Coding: 0000075
                   P1698 - 000 -
                        Fault Frequency: 13
                        Mileage: 211065 km
                        Date: 2012.03.27
                        Time: 18:23:18
                        Temperature: 93.0C
                        Temperature: 66.0C
                        Absolute Pres.: 1000.0 mbar
    Readiness: 0010 0101
       Coding: 0000840
       Revision: 00H30001
       Coding: B14B440C492208008D0E22E592211061A70000
                        Reset counter: 200
                        Mileage: 211067 km
                        Date: 2012.03.27
                        Time: 18:48:06
                        Count: 2
                        Count: 12
                        Count: 12800
                        Count: 16390
                        Count: 48384
                        Count: 65280
                        Count: 255
                        Reset counter: 200
                        Mileage: 211067 km
                        Date: 2012.03.27
                        Time: 18:48:06
                        Count: 2
                        Count: 12
                        Count: 12800
                        Count: 320
                        Count: 48384
                        Count: 65280
                        Count: 255
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 200
                        Mileage: 211067 km
                        Date: 2012.03.27
                        Time: 18:48:06
                        Count: 2
                        Count: 12
                        Count: 12800
                        Count: 292
                        Count: 48384
                        Count: 65280
                        Count: 255
       Coding: 73994BBE08A10B0008382000200A84C400C2502E60000000300000000000
       Coding: 820000
       Coding: 820000
       Coding: 180000
       Coding: 020000
       Coding: 800000
       Coding: 800000
                006 - Short to Plus
                        Reset counter: 200
                        Mileage: 211067 km
                        Date: 2012.03.27
                        Time: 18:48:08
       Coding: 00003232
       Coding: 303143
                        Reset counter: 200
                        Mileage: 211067 km
                        Date: 2017.11.04
                        Time: 18:48:22
       Coding: 170000
       Coding: 102000
                        Reset counter: 200
                        Mileage: 211067 km
                        Date: 2012.03.27
                        Time: 18:48:04
       ROD: UHVNA.rod
    End----------(Elapsed Time: 01:18, VBatt start/end: 13.5V/13.6V)-----------
    2011 Jetta SEL 2.5i
