Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: ABS Module Coding (MK60EC1 NAR)
    Nov 2017
    ABS Module Coding Request (MK60EC1 NAR)
    First, I'd like to start by saying this is my first post. If I have done something wrong, I apologize and hope someone will point it out so I know for the future.
    To make a long story short, I purchased a used 2011 Jetta SEL and a few weeks later, noticed the ABS and BRAKE warning lights flashing. Turns out, someone opened the gauge cluster and covered up the lights. I recently got VCDS and the cable, and have discovered the ABS module on the car is not programmed. The long code is all 0's. I'm really hoping someone can help me out. The ABS module's p/n is 1KO 907 379 BC but I don't know if this is the original module on the car, or if it was replaced and never coded.
    The applicable codes from the tag by the spare tire are 1ZP 2UA 7K6 I THINK. I can post any others needed, but there are over 40.
    The VIN is 3VWDX7AJ1BM006318
    Engine code is CBT automatic transmission code is MAN -Not sure if necessary, just want to be thorough.
    I hope someone can help and sorry if I've created this post incorrectly!
    Friday,03,November,2017,13:24:19:15250
    VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
    VIN: 3VWDX7AJ1BM006318   License Plate:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
    VIN: 3VWDX7AJ1BM006318   Mileage: 211010km-131115miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 A    HW: 07K 906 055
       Component: 2,5l R5/4V      G01 9214
       Revision: T4H04---    Serial number:
       Coding: 0000075
       Shop #: WSC 25016 444 13939
       VCID: 2C01FA78BA088E47D72-8078
    005784 - Please Check DTC Memory of Steering Wheel Electronics
                   P1698 - 000 -  - Intermittent
                        Mileage: 209928 km
                        Date: 2012.03.03
                        Time: 19:37:54
                        RPM: 1286 /min
                        Load: 40.8 %
                        Speed: 11.0 km/h
                        Temperature: 54.0C
                        Temperature: 42.0C
                        Absolute Pres.: 1010.0 mbar
                        Fault Frequency: 85
                        Mileage: 209971 km
                        Date: 2012.03.05
                        Time: 13:36:12
                        RPM: 1356 /min
                        Load: 32.5 %
                        Speed: 13.0 km/h
                        Temperature: 48.0C
                        Temperature: 31.0C
    012408 - Throttle Control
                   P3078 - 000 - Airflow at Idle too Low - Intermittent
                        Mileage: 210631 km
                        Date: 2012.03.23
                        Time: 10:46:33
                        RPM: 683 /min
                        Load: 23.9 %
                        Temperature: 92.0C
                        Temperature: 30.0C
       Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
       Component: AQ 250 6F           1741
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 00597EC86600BA275BA-8054
       Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
       Component: ESP MK60EC1   H30 0106
       Revision: 00H30001
       VCID: 74B122182EB896874F2-8020
                        Reset counter: 196
                        Date: 2012.03.26
                        Time: 13:22:20
                        Count: 3
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 44032
                        Fault Status: 01100101
                        Reset counter: 196
                        Mileage: 211011 km
                        Date: 2012.03.26
                        Time: 13:21:54
                        Count: 3
                        Count: 12
                        Count: 28672
                        Count: 295
                        Count: 44032
       Part No SW: 5C0 820 047 L    HW: 5C0 820 047 L
       Component: J301  Klimaanlage   0102
       Revision: 2000908S    Serial number: 00000000034037
       VCID: 290F036CB5FA9B6F2C4-807C
    03934 - Control Circuit for Seat Heating; Rear
                        Fault Status: 00111011
                        Reset counter: 225
                        Mileage: 210624 km
                        Date: 2012.03.22
                        Time: 21:07:01
       Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0226
       Revision: B2066001    Serial number: 03311231100025
       Coding: 73994BBE08A10B0008382000200884C400C2502E60000000300000000000
       Shop #: WSC 25807 444 59326
       VCID: 2D07F77C8D12874FC0C-8078
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3462
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3462
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.019  H08 0006
       Serial number:     WRH000061ZC
       Coding: 180000
       Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
       Serial number: 0017246
       Coding: 020000
       Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3462
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3462
       Coding: 800000
    00975 - Heated Rear Window (Z1)
                006 - Short to Plus
                        Fault Status: 01100110
                        Reset counter: 196
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   012 0805
       Serial number: 003END07B4B0
       Coding: 00003232
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 6FBB2D74471EB55FB20-803A
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y1000000FKL0O
       Coding: 303143
       Serial number: 3572MSME4A713552ZZZU
       Serial number: 3582MSME13486553ZZZT
       Component: S.Sens.Fahr.H  H01 ----
       Serial number: 3516KSME44526208ZZZK
       Component: S.Sens.Beif.H  H01 ----
       Serial number: 3526KSME34606208ZZZJ
       Component: F.Sens.Fahr  H01 ----
       Serial number: 3556LSME111A0708ZZZM
       Component: F.Sens.Beif  H01 ----
       Serial number: 3566LSME6D0B0408ZZZ.
       Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
       Component: KOMBI         H07 0406
       Coding: 470001
       Shop #: WSC 00066 123 00148
       VCID: 2B03F964B386897FDE8-807E
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 0226
       Coding: 102200
       VCID: 70B92E085AA0AAA7ABA-8024
    02078 - Media Player Position 3 (R120)
                        Reset counter: 99
                        Mileage: 180854 km
                        Date: 2011.01.31
                        Time: 00:26:20
       Component: IMMO          H07 0406
       VCID: 6A8D3C607CFC5077E5E-803E
    Address 2E: Media Player 3
       Part No SW: 5ND 035 190 A    HW: 5ND 035 190 A
       Component: RCD510USBRVC  001 0003
       Revision: -----001    Serial number: VWZ4Z3M8135616
       Coding: 05000424040006
       Shop #: WSC 00081 790 00128
       VCID: 3A2DCC204C5C20F755E-806E
                        Fault Status: 00101011
                        Reset counter: 220
                        Mileage: 207446 km
                        Date: 2012.01.29
                        Time: 07:00:33
                        Reset counter: 196
                        Mileage: 211011 km
                        Date: 2012.03.26
                        Time: 12:13:08
                        Reset counter: 196
                        Mileage: 211011 km
                        Date: 2012.03.26
                        Time: 12:13:08
    00856 - Radio Antenna
                        Reset counter: 196
    03272 - Control Module for Audio Interface
                        Reset counter: 99
                        Mileage: 181499 km
                        Date: 2011.02.10
                        Time: 18:23:56
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668295109
       Coding: 0A00000000010100
       Shop #: WSC 01383 790 50316
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 323DE40094ACD8B79DE-8066
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/13.9V)-----------
    Revision: 00H30001
    Coding: 0000000009220000000E00E590210000000000 LHD stripped VIN
    Coding:
    OP find scans of the net that have similar attributes and post them here.
  3. Likes Nomad liked this post
    Nov 2017
    Thanks Jack. Found some donor coding last night from two different VINs that were different by 2 or 3 digits. Donor codes are as follows:
    B14B400C492708FB8D1102E7921C1061A70000
    B1004400490008008D00220092001061A70000
    B14B440C492308FB8D1422EA92191061A70000
    How do i find the size of my brakes? I have disc in the front and drums in the back.
  6. #4
    Aug 2016
    The Hague, NL
    If you are confident that the donor cars are very similar (engine, chassis, market, ESP button, TPMS, etc...) try the codes:
    B14B440C492208008D0E22E592211061A70000
    B1004400492208008D0E22E592211061A70000
  7. Likes Nomad, Uwe, Jack@European_Parts, Dana liked this post
  8. #5
    Nov 2017
    Thanks! I'll give them a try right now and report back. I wish I could wrap my head around how to calculate these codes.
  9. #6
    Nov 2017
    OHMYGOD! IT WORKED!! The module accepted the first code you suggested! Thank you so much! Is there anything i need to do from here to insure everything functions properly? I know i have to do the steering angle setup now, right?
  10. Likes Jack@European_Parts, Dana liked this post
  11. #7
    Nov 2017
    Okay so maybe i spoke too soon... The TPMS light keeps coming on and going off, sometimes flashing. The airbag light is also coming on and off, both accompanied by a "ding". Ill post an autoscan.
  12. #8
    Nov 2017
    Saturday,04,November,2017,11:36:24:15250
    VIN: 3VWDX7AJ1BM006318   Mileage: 211040km-131134miles
       Coding: 0000075
                   P1698 - 000 -
                        Mileage: 209928 km
                        Date: 2012.03.04
                        Time: 19:37:54
                        RPM: 1286 /min
                        Load: 40.8 %
                        Speed: 11.0 km/h
                        Temperature: 54.0C
                        Temperature: 42.0C
                        Fault Frequency: 88
                        Mileage: 209971 km
                        Date: 2012.03.06
                        Time: 13:36:12
                        RPM: 1356 /min
                        Load: 32.5 %
                        Speed: 13.0 km/h
                        Temperature: 48.0C
                        Temperature: 31.0C
                        Mileage: 210631 km
                        Date: 2012.03.24
                        Time: 10:46:33
                        RPM: 683 /min
                        Load: 23.9 %
                        Temperature: 92.0C
                        Temperature: 30.0C
       Coding: 0000840
       Revision: 00H30001
       Coding: B14B440C492208008D0E22E592211061A70000
       Shop #: WSC 00066 123 12345
    6 Faults Found:
    03306 - Coding Not Valid
                000 -  -  - Intermittent
                        Reset counter: 199
                        Mileage: 211025 km
                        Date: 2012.03.27
                        Time: 08:48:22
                        Count: 3
                        Count: 12
                        Count: 28672
                        Count: 4161
                        Count: 45056
                        Reset counter: 196
                        Date: 2012.03.27
                        Time: 13:22:20
                        Count: 3
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 44032
                        Reset counter: 198
                        Mileage: 211025 km
                        Date: 2012.03.27
                        Time: 07:25:09
                        Count: 3
                        Count: 12
                        Count: 28672
                        Count: 320
                        Count: 45056
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 198
                        Mileage: 211011 km
                        Date: 2012.03.27
                        Time: 14:13:52
                        Count: 16386
                        Count: 4
                        Count: 12800
                        Count: 292
                        Count: 50178
                        Count: 1536
                        Reset counter: 199
                        Mileage: 211040 km
                        Date: 2012.03.27
                        Time: 11:26:10
                        Count: 16391
                        Count: 4
                        Count: 12800
                        Count: 212
                        Count: 48897
                        Count: 254
                        Count: 1023
                        Count: 512
                        Reset counter: 196
                        Mileage: 211040 km
                        Date: 2012.03.27
                        Time: 11:26:10
                        Count: 16391
                        Count: 4
                        Count: 12800
                        Count: 295
                        Count: 48897
                        Count: 254
                        Count: 1023
                        Count: 512
                        Reset counter: 225
                        Mileage: 210624 km
                        Date: 2012.03.23
                        Time: 21:07:01
       Coding: 820000
       Coding: 820000
       Coding: 180000
       Coding: 020000
       Coding: 800000
       Coding: 800000
                006 - Short to Plus
                        Reset counter: 199
       Coding: 00003232
       Coding: 303143
    9483008 - Seat Occupied Recognition
              B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                        Reset counter: 199
                        Mileage: 211040 km
                        Date: 2017.11.04
                        Time: 11:27:04
       Coding: 170001
       Coding: 102200
                        Reset counter: 99
                        Mileage: 180854 km
                        Date: 2011.02.01
                        Time: 00:26:20
                        Reset counter: 220
                        Mileage: 207446 km
                        Date: 2012.01.30
                        Time: 07:00:33
                        Reset counter: 196
                        Mileage: 211011 km
                        Date: 2012.03.27
                        Time: 12:13:08
                        Reset counter: 196
                        Mileage: 211011 km
                        Date: 2012.03.27
                        Time: 12:13:08
                        Reset counter: 198
                        Reset counter: 99
                        Mileage: 181499 km
                        Date: 2011.02.11
                        Time: 18:23:56
       ROD: UHVNA.rod
    End----------(Elapsed Time: 01:34, VBatt start/end: 13.7V/13.7V)-----------
  13. Likes Uwe liked this post
  14. #9
    Aug 2016
    The Hague, NL
    It would be good to clear all DTCs and make a scan. This way we can see the ones that persist.
    At first glance, the error in the airbag is not related to the ABS coding.
    You'll need to do at least a basic setting of all the sensors (G85, lateral acceleration sender, maybe some more).
    The wiki site is a bit messy but I'm sure its readable. http://wiki.ross-tech.com/wiki/index...cs_(MK60EC1%29
    Let's try again after basic settings. Does the car have a TPMS reset button somewhere?
  15. Likes Uwe, Jack@European_Parts, Nomad liked this post
  16. #10
    Nov 2017
    Once my laptop gets its life together I’ll clear the codes and re scan. I have a feeling I caused the airbag code when I was trying to fix the seat heater... woops. Is there a way to clear that or will it go off when I erase the DTCs?
    There is a TP reset button in the glovebox. I tried resetting it a couple times but the light wouldn’t go out. The ABS light is on also but it’s been covered up inside the cluster so it’s hard to say for sure what other lights may be on.
  17. Likes Jack@European_Parts liked this post
