Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 07 GTI 2.0FSI Intermittent Misfire Under Boost, Now Running Poorly
    No substitution for circumventing basic mechanical tests when DTC's exist or using the RTFB as per the JPPSG.
    Looking back through my notes, I found I did not change the plugs. Plugs pictured were in the car when I got it. Gaps measure .029" - .030".
    I indeed recall a guy at dealership taking an entire engine apart and even though he installed new plugs they were bad.........I also recall a new plug failing in Santos 1.8T & which is pretty rare and it happened in front of Uwe while present too and I specifically recall Uwe paying attention to my protocol with comment as I did a compression check first before I changed or swapped the plug to move the DTC.
    I still consider not doing a compression check first an ultimate fail........
  2. #12
    Verified VCDS User GTIF's Avatar
    Jun 2016
    San Diego USA
    I will do a compression check sometime soon, as it isn't a pressing matter at the moment. I have other projects and commitments needing my attention, now that my favorite car is running well. Thanks again for your input.
    Good Thing It's Fast! '07 GTI Fahrenheit
  3. #13
    May 2016
    GTIP, good for you.
    Larimore
  4. Likes GTIF liked this post
