i have a 2013 Audi Q5. the dashboard show me after 5 miles driving Transmission failure and goes in limp mode. if i stop the engine and start again everything is working fine until the distance of 5 miles is reached again. i drained out the oil and the oil in the transmission was black and the filter was dirty. i changed the oil and filter but if i drive it now then the transmission went out of the gear.
had anybody the same problems and can tell me hat is wrong????
Tuesday,31,October,2017,16:37:46:32045
VCDS Version: 17.8.0.1 (x64)
VIN: WA1LFAFP2DA050267 License Plate: CCCCCC
Mileage: 126850km-78820mi Repair Order: 111111
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56 62
6D 72 77
VIN: WA1LFAFP2DA050267 Mileage: 126850km-78820miles
Address 01: Engine (DET-CPMA) Labels:. 06H-907-115-CDN.clb
Part No SW: 8R1 907 115 B HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09---
Coding: 6A2A0013242600062000
Shop #: WSC 47056 000 1048576
ASAM Dataset: EV_ECM20TFS0118R1907115B 001006
ROD: EV_ECM20TFS0118R1907115B.rod
VCID: 3467A18A9F4642E65E-8060
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8R1 927 158 C HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1002
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002020
VCID: 3E7383A2A10A98B6B8-806A
8701 - Gear Ratio Monitoring
P0730 00 [036] - Incorrect Gear Ratio
Mileage: 126849 km
Date: 2017.10.31
Time: 16:05:39
Voltage terminal 30: 13.786 V
Engine speed: 2084 /min
Transmission input speed: 2045.00 /min
Transmission output speed: 605.00 /min
Transmission fluid temperature: 80 °C
Driving position: d
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
Current N215 Pressure control valve 1: 50.0 mA
Current N218 pressure reg.valve 4: 50.0 mA
Current N216 pressure reg.valve 2: 850.0 mA
Current N233 pressure reg.valve 5: 850.0 mA
Current N217 pressure reg.valve 3: 850.0 mA
Engine torque: 148 Nm
Current N443 pressure reg.valve 7 main pressure: 673.7 mA
M015_Time Normal Mode: 524 s
M019_Time Since Reset: 7650 ms
M014_Time Since Shift: 7650 ms
8710 - Shift Monitoring
P0780 00 [036] - Shift Error
Mileage: 126840 km
Date: 2017.10.31
Time: 15:53:19
Voltage terminal 30: 14.071 V
Engine speed: 1529 /min
Transmission input speed: 1542.00 /min
Transmission output speed: 246.00 /min
Transmission fluid temperature: 71 °C
Driving position: d
Current N215 Pressure control valve 1: 850.0 mA
Current N217 pressure reg.valve 3: 50.0 mA
Engine torque: 61 Nm
Current N443 pressure reg.valve 7 main pressure: 683.5 mA
M015_Time Normal Mode: 603 s
M014_Time Since Shift: 600 ms
12519 - Control Module Performance Implausible
P0607 00 [036] - -
Mileage: 126849 km
Date: 2017.10.31
Time: 16:05:39
Voltage terminal 30: 13.862 V
Transmission input speed: 2146.00 /min
Transmission output speed: 604.00 /min
Engine torque: 106 Nm
Accelerator position: 33 %
Engine speed: 2211 /min
Transfer speed from ESP: 21.60 km/h
Transfer speed from ESP: valid
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AL HW: 8R0 907 379 AL
Component: ESP8 quattro H09 0040
Coding: 151D1803
Shop #: WSC 06335 000 00000
VCID: 0A1B1F72A5426416D4-805E
01119 - Gear Recognition Signal
Reset counter: 111
Mileage: 126074 km
Date: 2017.10.15
Time: 18:34:08
Hex Value: 0x1B00
Hex Value: 0x4006
Hex Value: 0x1F0D
Hex Value: 0x27B2
Hex Value: 0x0000
02214 - Tire Pressure Warning
Reset counter: 111
Mileage: 126778 km
Date: 2017.10.30
Time: 10:15:13
Hex Value: 0x7500
Hex Value: 0x4006
Hex Value: 0x1221
Hex Value: 0x1FB5
Hex Value: 0x0000
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H11 0621
Coding: 0D854000000000000000
VCID: 0407314A87663266AE-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000267648011
00955 - Key 1
Reset counter: 96
Mileage: 125528 km
Date: 2017.10.10
Time: 06:18:37
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01121220120655
Coding: 6481208000
VCID: 397990BEB024BF8E8D-806C
Part No SW: 8K0 907 063 DF HW: 8K0 907 063 DF
Component: BCM1 1.0 H16 0103
Revision: 06016001 Serial number: 00000520000502
Coding: 26000091863CAFC00000480300003D0D0F1C460822090221000008004000030100000000000000
VCID: 76E35B82C1BA10F6A0-8022
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 121126 H11 0050
Serial number: 90243014121117100702
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 20801057
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000312120126
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R42XK02
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: DA094CA6000000000001
Address 15: Airbags (J234) Labels:| 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Serial number: 003GPD9133ZM
Coding: 303634313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 479DE646FED0D97E0B-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R120000AXKF
Serial number: 6334MSME75242F7DS
Serial number: 6344MSME7355477EQ
Serial number: 6352QSME68283378M
Serial number: 6362QSME7F274F50X
Serial number: 63732SME04284258W
Serial number: 63832SME38281942.
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LKT0026W
Coding: 000017
VCID: 4385F256C2E8F55ED7-8016
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 950 G HW: 8R0 920 950 G
Component: KOMBIINSTR. H07 0556
Revision: 00200000 Serial number: UWB20W4DD
Coding: 8B9622000301D705020000
VCID: 3A7B8FB2B522B49684-806E
Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0055
Revision: 1V070026 Serial number: 2641V12B298211
Coding: 80C303FF00
VCID: 489FE57AFBCED60602-801C
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000001460653144
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000045811641
Coding: 00581B00000000000000
VCID: 428BF752DDF2FC56DC-8016
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000046485417
Coding: 011D13205E00440004
VCID: 4FADCE661EA0013E43-801A
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0016059422
Coding: 100000000000
Shop #: WSC 06334 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B758AB6B2188D9E9F-806E
Revision: 00002001 Serial number: 0189465722
Coding: 0126023A20FA709584B0053200040000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000611820
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H04 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H04 0220
02912 - Bulb for Side Marker Light; Rear Right (M38)
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11101100
Reset counter: 47
Mileage: 125428 km
Date: 2017.10.09
Time: 14:00:07
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOC.clb
Part No SW: 8T1 035 223 HW: 8T1 035 223
Component: DSP Prem H05 0040
Revision: 00005001 Serial number: 94803008718201
Coding: 0203010302
VCID: 6CD779EA8FF6DA2646-8038
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000046435885
VCID: 4E93D36219AA083648-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000143586
ROD: EV_ParkiBrake_VW51.rod
VCID: 387F95BA832EA68672-806C
10613248 - Terminal 15
U1405 00 [137] - Implausible signal
Fault Frequency: 144
Reset counter: 71
Mileage: 125428 km
Date: 2017.10.09
Time: 14:00:07
Voltage terminal 30: 13.1 V
Internal Fault ID: 44
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: On
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Auto Adjust: not active
Status ParkingBrake left: Set
Status ParkingBrake right: Set
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8R1 035 186 Q HW: 8R1 035 186 Q
Component: Con3 Sirius H09 0471
Revision: 00000002 Serial number: AUZ5Z6L1830219
Coding: 040300020105850043D9070800
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000046197112
Coding: 010C13204000240004
VCID: 4683EB42F1DAC076F0-8012
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B758AB6BA188D9E9F-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000046197460
Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005293644
Coding: 0010370
VCID: 3E7383A2690A98B6B8-806A
End-------------------------(Elapsed Time: 04:00)--------------------------
