Cancel CDB Lights Control with VCDS for Mounting LED Bulbs Audi Q3 8U> 2015
walterc
Italy
C?ID=94289
Hello.
I have an Audi Q3 with Full LED lights, but I noticed that the lights mounted on the rear bumper, are W16W type.
I replaced them with Light Bulbs to Led but I have error checking back lights and rear fog lights.
With VCDS you can fool the CDB?
here is my scan:
Saturday,28,October,2017,22:11:35:54661
VCDS Version: 17.8.0.1
VIN: WAUZZZ8U2GR084074   License Plate:
Mileage: 30940km-19225mi   Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 42 44 46 52 55 56
          57 5F 62 6C 6D 72
VIN: WAUZZZ8U2GR084074   Mileage: 30940km-19225miles
Address 01: Engine (J623-DFUA)       Labels: None
   Part No SW: 04L 906 016 FL    HW: 04L 907 309 AB
   Component: R4 2.0l TDI   H20 3201
   Revision: 8EH20---
   Coding: 02250012042601083000
   Shop #: WSC 50982 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016FL 004003
   ROD: EV_ECM20TDI01104L906016FF_004.rod
   VCID: 78D0BAAEC306CE86B2-802C
   Part No SW: 0BH 300 012 Q    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5206
   Revision: 00H11V01
   VCID: 3146478A60FCDFCE35-8064
Address 03: ABS Brakes (J104)       Labels:. 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CF
   Component: ESC-EBC460iV1 H10 0013
   Serial number: A013316
   Coding: 22F124A14928E3702077440724C792C704365700508B4885
   Shop #: WSC 00049 770 00152
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 71C6878AA07C9FCE75-8024
   Revision: 00092000    Serial number: 0392607153
   Coding: 030C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: 375279928E9801FE7B-8062
   Part No SW: 8U0 820 043 F    HW: 8U0 820 043 F
   Component: E87  Klimavoll      0210
   Revision: 00H05000    Serial number: 8U0820043F
   VCID: 34484E9E57EEEAE65E-8060
Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
   Part No SW: 8X0 907 063 AB    HW: 8X0 907 063 AB
   Component: BCM PQ35  M   113 0817
   Revision: AC113817
   Coding: 46000A2FE837F3C4E01849C1218401CC57F327AA217F81FBE400879CE0C5
   Shop #: WSC 00049 770 00010
   VCID: 7CD8A6BEFF3EE2A6D6-8028
   Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 160113  H38 0090
   Serial number:         160124054245
   Coding: 0047F7
   Serial number: 61217126
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177 A
   Component: Sensor, DWA 0  005 0002
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AD    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0070
   Revision: 11001001    Serial number: 61031602305174
   Coding: A8C304
   Shop #: WSC 00049 770 00117
   ASAM Dataset: EV_EPHVA18AU21X0000 003008
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 0830CA6EB3E6BE06C2-805C
Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
   Part No SW: 8U0 959 655 D    HW: 8U0 959 655 D
   Component: AirbagVW-AU10 H10 0910
   Serial number: 003S0R0DR5L
   Coding: 304D3232333030303030554A304C38553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001010
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 48B00A6EF3667E0602-801C
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME3D637F3BZZZE
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME0D266A3BZZZ$
   Serial number: 3516KSME1F19753BZZZ+
   Serial number: 3526KSME184C093CZZZ$
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME367C503BZZZ6
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 H    HW: 5K0 953 569 AP
   Revision: FF010018    Serial number: 20160128300766
   Coding: 1114204000
   VCID: 3FA211B2A6A839BEB3-806A
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 28 10 2015  A0075262
Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 940 H    HW: 8U0 920 940 H
   Component: KOMBI_COLOUR  H02 0380
   Coding: 12DF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 3D5E6BBAACA42BAEA1-8068
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 AS    HW: 8U0 907 468 J
   Component: GAT 4CAN 2L M H13 0090
   Revision: 1R160041    Serial number: 4141R161150156
   Coding: FFCF1A5A050B0D610253
   VCID: 130AED02F2A00DDE27-8046
   Subsystem 1 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS11.403  H03 0004
   Serial number: 0000FST000R9WC800000
   Coding: 901E00
   Subsystem 2 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 43026528291491452594
   Subsystem 3 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS11.403  H03 0004
   Serial number: 0000FST000R9W0W00000
   Coding: 801E00
   Subsystem 4 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 15102100000000000043
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00004.01.16
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 52842806053AC4D66C-8006
   Component: IMMO          H02 0380
   Coding: 000007
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000011137002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H11 0415
   Coding: 011F12205C00000000
   VCID: 528428060D3AC4D66C-8006
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.377 1401
   Revision: 1BH04841    Serial number: 00160050059101
   Coding: 0000258
   VCID: 41A6174A185C4F4EC5-8014
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   Coding: 011E12201E00000000
   VCID: 5186270A083CBFCE55-8004
Address 55: Headlight Range (J745)       Labels:| 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 G    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0031
   Coding: 08AA00102B230200
   ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
   ROD: EV_HeadlRegulLEDAFSPt_AU21.rod
   VCID: 38507AAE83860E8672-806C
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02500
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02500
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E02500
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E02500
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109A.0G2526568
   Coding: 010105020100000002
   VCID: 2D7E5BFA74C4BB2E11-8078
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801302079401
   Coding: 02000000
   Part No SW: 8U1 035 670 C    HW: 8U1 035 670
   Component: H-BNT-EU      H41 1034
   Revision: --------    Serial number: 486A$0G7521706
   Coding: 0E010106000AE1EB0580137600000001000100000000000002
   VCID: 364C74968192F8F660-8062
   Subsystem 1 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
   Component: DU High AU316  H43 0018
   Serial number: AUZ8ZDFCR00FJ37
   Subsystem 2 - Part No: 8R0 060 961 G
   Component: CD-Database  6890
                    Reset counter: 252
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 22:33:05
                    Text: NGTV_DVB,H6X,M,0,0,6
03389 - Data Set Implausible
                    Reset counter: 252
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 22:33:03
                    Voltage: 12.40 V
                    Bin. Bits:      010
            000 -  -  - Intermittent
                    Reset counter: 39
                    Mileage: 30942 km
                    Date: 2017.10.28
                    Time: 18:07:18
                    Bin. Bits: 10100011 00000010
                    Bin. Bits: 00000000 00001110
                    Bin. Bits: 00000000 00000000
02387 - Telephone Mount (R126)
                    Reset counter: 252
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 22:33:14
                    Voltage: 12.40 V
03623 - Invalid Secruity/Release Code
                    Reset counter: 252
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 22:33:04
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010E12200000000000
   VCID: 4F8221721E08A93E43-801A
   Part No SW: 8U0 907 441     HW: 8U0 907 441
   Component: SG Rueckfahrkamera  0031
   Revision: --H11---    Serial number: 525 PA8JAZH15Z
   Coding: 1080015
   Shop #: WSC 02391 785 00013
   VCID: 76CCB4960112B8F6A0-8022
   Part No SW: 8U0 959 107     HW: 8U0 959 107
   Component: HDSG-Modul    H01 0549
   Revision: 15001001    Serial number: 011600882
   Coding: 183307C022
   ASAM Dataset: EV_HDSGAU316 001001
   ROD: EV_HDSGAU316.rod
   VCID: 7CD8A6BEF73EE2A6D6-8028
   Component: TSG HR        H08 0415
End-------------------------(Elapsed Time: 03:34)--------------------------
walterc
Italy
C?ID=94289
errors centr 09:
Friday,27,October,2017,22:19:47:54661
VCDS Version: Release 17.8.0 Running on Windows 7 x86
                Address 09: Cent. Elect.       Labels: 8X0-907-063.clb
Control Module Part Number: 8X0 907 063 AB    HW: 8X0 907 063 AB
  Component and/or Version: BCM PQ35  M   113 0817
           Software Coding: 46000A2FE837F3C4E01849C1218401CC57F327AA217F81FBE408879CE0C5
            Work Shop Code: WSC 00049 770 00010
03193 - Lamp 2 for Blinker; Rear Right
                    Fault Status: 00101010
                    Reset counter: 36
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 18:23:12
                        Term 15 Off
                    Voltage: 12.35 V
                        Term 50 Off
                    Fault Frequency: 9
                    Reset counter: 36
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 18:25:39
                    Voltage: 12.10 V
                        Term 50 On
                    Fault Frequency: 7
                    Reset counter: 36
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 18:28:08
                    Voltage: 12.10 V
                        Term 50 On
04021 - Rear fog lamp
                    Reset counter: 36
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 18:28:09
                    Voltage: 12.10 V
                        Term 50 On
03192 - Lamp 2 for Blinker; Rear Left
                    Reset counter: 36
                    Mileage: 30920 km
                    Date: 2017.10.27
                    Time: 18:28:14
                    Voltage: 12.05 V
                        Term 50 On
walterc
Italy
C?ID=94289
Sorry!
But do you have the solution to this problem?
Please do not open multiple threads for the same question on the same car!
This is not a "Tweak". You changed lights. So this is a Retrofit. Thread closed.
