Steps to read DPF status using VCDS
In My Garage
Canada
C?ID=197853
I tried, but as usual, "search" here and on the usual VW TDI forums did not come up with anything.
Is there a procedure anywhere on how to use the VCDS to read the Diesel Particulate Filter status with regard to how much it is clogged?
TIA!
This varies a great deal by engine, ECU, etc. Please post an Auto-Scan so people can see exactly what you've got.
In My Garage
Canada
C?ID=197853
I have a 2013 Jetta with the CJAA engine.
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 HE HW: 03L 907 309 AA
Component: R4 2,0L EDC G000SG 4819
Revision: 12H15--- Serial number:
Coding: 0050072
Keithuk
Stoke on Trent, England
C?ID=122432
I checked mine last year.
In My Garage
Canada
C?ID=197853
Thanks Keith, but I do not want to "start a regeneration".
I was just curious what my numbers are.
I did not get to that screen, but I did get to an Advanced Measuring Values screen and came across various data such as oil ash volume: 0 ml.
I'll check this more out in the next few days.
Keithuk
C?ID=122432
That doesn't start a regeneration it just shows when it was last done and what the ash & carbon figures are so you can tell how full its getting.
jonixins
Latvia
C?ID=151647
A lot of cases too high carbon mass does not mean that filter must be replaced.
The main data is filter pressure in different loads/situations while driving.
prako
Zagreb Cro
C?ID=116509
TIA!
Go to 01 Engine/08 Measuring Blocks/ open chanel 108
mikeme
Alexandria/fairfax county VA
C?ID=99408
http://forums.tdiclub.com/showthread.php?t=324067
Some good info here.
look above and below number of measuring block too. look for an pay attention to blocks which are labeled soot vs Ash. the regen turns soot to ash. soot should build up, and reduce as the regens happen. the ash load increases, but only changes every 8-10,000 miles or so.
