Results 1 to 4 of 4
Thread: Case Study: 2011 A8 with P1926 and P1927 codes
    HQ
    ST?ID=78452
    Joe calls up today, working on a 2011 A8 with a 4.2L CDRA engine, MIL on. 2 fault codes in the ECM:
    4661 - Relay for Aux Coolant Pump (J496)
    P1927 00 [104] - Open Circuit
    4663 - Relay for Aux Coolant Pump (J496)
    P1926 00 [104] - Short to Ground
    Normally any "Open Circuit" or "Short to Ground" type fault codes are simple, check the electrical paths for the item in question... fuses, terminals, wiring, the part itself. However, what caused some confusion here... the CDRA engine does not have a J496.
    So here the meat of this Case Study... slow smoked tender tasty meat..... you will may come across fault codes that have a Component Location that isn't relevant to the actual car you are working on. The more common example one might run into on V6, V8 and V10 FSI and TFSI engines are these codes:
    18726/P2294/008852 - Fuel Pressure Regulator Valve (N276): Open Circuit
    18728/P2296/008854 - Fuel Pressure Regulator Valve (N276): Short to Plus
    The V6, V8 and V10 FSI and TFSI engines most likely won't have a N276, but rather the factory repair manuals and wiring diagrams will refer to it as the N290.
    So what does one do when they run into something like this? Use the grey noodle is the starting point. With Joe's vehicle, J496 isn't referenced, but we are given a clue in the "Aux Coolant Pump", so something to do with an electrical coolant pump. Looking at the wiring diagram for the CDRA engine, I do find listed a V51 After-run coolant pump, so this is a strong candidate for the source of the fault codes.
    I can also look at other engine wiring diagrams and find one that does actually have the J496 relay and from there, I see these will power a V51 Aux Coolant Pump, so we can start connecting more dots now. Dr Peter was also able to find a test plan linking the P1926 DTC directly to the V51 on the CDRA engine, thus confirm what we suspected.
    Now this next part is my "educated" guess, but on the CDRA engine, the V51 coolant pump has 3 wires on it and I suspect that inside this unit is a relay. I'm not aware of any control module that directly operates an electrical motor, it is always a relay (mechanical or solid state) of some sort. If the J496 is built into the V51 unit, then the factory repair manual doesn't need to mentioning the J496. But from a diagnostic stand point, the ECM is saying "that relay I pull ground for has some sort of electrical path issue" and thus the P1926 and P1927 codes get flagged. I guess years ago when DTCs were being written, the J496 relay would always be a stand alone part. And when it was integrated, the wasn't a way to rewrite DTCs, so this was the best option the engineers had to explain what the problem was.
    Anyway, now the next person who runs into this issue has a Google chance of figuring it out quickly.
    Regards.
    Log-WAUAVAFDXBN018160-156867km-97472mi.txt
    Tuesday,24,October,2017,11:10:22:26935
    VCDS Version: 17.8.0.1 (x64)
    Dealer/Shop Name: PIERCE AUTO PARTS LLC
    VIN: WAUAVAFDXBN018160   License Plate: KANTOR
    Mileage: 156867km-97472mi   Repair Order:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 34 36 3B 42 46 47 52 53
              56 5F 62 6C 6D 6F 72 81 88 89 8F 90
    VIN: WAUAVAFDXBN018160   Mileage: 156867km-97472miles
    Address 01: Engine (------CDRA)       Labels:* None
       Part No SW: 4H0 907 560 C    HW: 4H0 907 560
       Component: 4.2l V8/4V    H08 0005
       Revision: N5H08---
       Coding: 0106000A290F0168
       Shop #: WSC 04940 001 00001
       ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
       ROD: EV_ECM42FSI0114H0907560C.rod
       VCID: 2A5BE0524D961E16F4-807E
                        Fault Frequency: 38
                        Mileage: 156862 km
                        Date: 2017.10.20
                        Time: 15:59:53
                        Engine speed: 770.50 /min
                        Normed load value: 24.7 %
                        Coolant temperature: 100 °C
                        Intake air temperature: 77 °C
                        Voltage terminal 30: 13.428 V
                        AFS dm: 20.6 kg/h
                        Median injection timing: 1.061 ms
                        Fault Frequency: 38
                        Mileage: 156862 km
                        Date: 2017.10.20
                        Time: 15:59:59
                        Engine speed: 643.50 /min
                        Normed load value: 33.7 %
                        Vehicle speed: 3 km/h
                        Coolant temperature: 99 °C
                        Intake air temperature: 78 °C
                        Voltage terminal 30: 13.782 V
                        AFS dm: 23.4 kg/h
                        Median injection timing: 1.173 ms
       Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
       Component: 0BK 42 FSIUSA H08 1007
       Revision: --H08---
       Coding: 000002
       Shop #: WSC 01126 444 122347
       ASAM Dataset: EV_TCMALX51011 002018
       ROD: EV_TCMALX51011.rod
       VCID: 72EB3832A5C616D68C-8026
    Address 03: ABS Brakes (J104)       Labels:. 4H0-907-379.clb
       Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
       Component: ESP PREMIUM   H10 0273
       Coding: 44E6B20022674D00E200
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremi 005006
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 3169F73E60406DCE35-8064
       Part No SW: 4H0 907 064 FD    HW: 4H0 907 064 AD
       Component: BCM2 2.0      H24 0560
       Coding: 0D872000000000000000
       Shop #: WSC 60216 001 1048576
       VCID: 70EF323AA3CA24C67A-8024
       Serial number: 2310000091550012
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00001002323092
       Coding: C018320085043201010001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 3561C32E9C2841EE69-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
       Component: Klima 3 Zonen H14 0061
       Coding: 4881202E88
       VCID: 224B087235A6C656BC-8076
    0137 - Motor for  Right Side Window Defrost Flap
              B10D8 22 [009] - Signal Amplitude Too High
                        Fault Frequency: 7
                        Reset counter: 114
                        Mileage: 156843 km
                        Date: 2017.10.20
                        Time: 12:21:26
                        Voltage terminal 30-Data: 12.2 V
                        Outside air temperature-Data: 39.50 °C
                        Interior temperature-Data: 21.60 °C
                        Defrost flap motor for right side window-Act.val.: 12828
                        Defrost flap motor for right side window-Specified value: 12828
                        Defrost flap motor for right side window-Stop open: 0
                        Defrost flap motor for right side window-Stop closed: 0
       Part No SW: 4H0 907 063 G    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0092
       Revision: 11012002    Serial number: 00000000928499
       Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
       VCID: 2C57E64A4F62002606-8078
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 110202  H32 0040
       Serial number:         110204020344
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10057163
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Serial number: 04 02 2011  00000129
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R0AAK06
       Subsystem 5 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
       Component: A31 LED Mod1L  H01 0006
       Serial number: 00000024011100010061
       Coding: 100000
       Subsystem 6 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
       Component: A27 LED Mod1R  H01 0006
       Serial number: 00000025011100010208
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA102032000000168320
       Coding: 020300
       Serial number: C6188E85000000000001
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0030
       Revision: 11001001    Serial number: 55901102300788
       Coding: 300102
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 377DC9268E24B3FE7B-8062
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H41 0041
       Revision: --------    Serial number: 003JS00126Z8
       Coding: 303143303230303030344A55304C34483053
       Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
       Serial number: 5850000R11108019EJ
       Serial number: 3575HRB40510ATOCFGL/
       Serial number: 3585HRB404T07OTS59QQ
       Serial number: 3515JRB406908IEIH8UV
       Serial number: 3525JRB406908IEICOHU
       Serial number: 3554VRB405P09GGS2P78
       Serial number: 3564VRB405R09GGSKGAN
       Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815KAS0000R
       Coding: 000434
       VCID: 326BF8326D4656D64C-8066
       Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
       Component: E221 - MFL  H06 0009
       Serial number: 26 08 2010  11042925
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4H0 920 920 C    HW: 4H0 920 920
       Component: TBenUSA------ H30 0309
       Revision: 26110011    Serial number: 658300111593028
       Coding: 0B6608011300D705020000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K.rod
       VCID: 2541136E2488316ED9-8070
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
       Component: Analoguhr D4  H05 0224
       Serial number: 1110206000022
       Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000089279
       Coding: 00C1034A00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 3365FD369A5C5FDE47-8066
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650557121
       Part No SW: 4H0 907 553 C    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0096
       Coding: 008000
       ASAM Dataset: EV_AirSuspe 003022
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2C57E64A4762002606-8078
              C10C8 00 [009] -  -
                        Reset counter: 114
                        Mileage: 156867 km
                        Date: 2017.10.24
                        Time: 10:39:50
       Revision: AA000000    Serial number: 00001002323069
       Coding: C0183B0085053201010001010101112131313333203333
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Component: SARA 6D       H02 0015
       Revision: --------    Serial number: EJ1BPA3100C4Z60
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6CD7264A87E2C02646-8038
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000112568396
       Coding: 011F1F205E0062C202000006
       Shop #: WSC 02312 785 00200
       VCID: 3B75D516BA0C979E9F-806E
       Revision: 00002001    Serial number: 0142720256
       Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0070
       Serial number: 00000000000000020821
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.028  H06 0006
       Serial number:     WOO1121146X
       Coding: 001F00
       Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
       Component: Dachelektroni  H11 0080
       Serial number: A2011000000000329881
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS009  H05 0004
       Serial number:     WOO1000BJV-
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0070
       Revision: CJ007000    Serial number: 00000000018186
       VCID: 1B3535961ACCF79E7F-804E
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0162
       Revision: --------    Serial number: 0000112947591
       VCID: 3A7BD012B536AE9684-806E
       Revision: --------    Serial number: 00000000040265
       ROD: EV_ParkiBrake_VW51.rod
       Part No SW: 4H0 035 082 A    HW: 4H0 035 082
       Component: Radio U SIRIU H51 0068
       Revision: AB001007    Serial number: 155BM0B7500622
       Coding: 020007010000000001
       VCID: 1F4D01860ED4EBBE93-804A
       Part No SW: 4H0 035 664 B    HW: 4H0 035 664
       Component: H-BN-NA       H48 0294
       Revision: --------    Serial number: 098BT0B7501334
       Coding: 020200000001F1EF45128B0E00000003F400010000000000
       VCID: 26431462518E3A76D0-8072
       Subsystem 1 - Part No: 8R0 060 884 AC
       Component: NAR 2011  0503
       Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
       Component: DU8 D4 SV NB  H46 0021
       Serial number: AUZ8ZDB1100CY3L
       Subsystem 3 - Part No SW: 4H1 919 600 D    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0063
       Serial number: 00000000029374
       Component: CD-Database  2712
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000112450683
       Coding: 010F1F20400062C202000006
       VCID: 3979CF1EB030A58E8D-806C
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H04---    Serial number: 525 PA8J11D0DG
       Coding: 1020002
       VCID: 65C1536EAC08F16E19-8030
    02203 - Audio / Video Input 1
                        Fault Status: 00101011
                        Reset counter: 153
                        Mileage: 156859 km
                        Date: 2017.10.20
                        Time: 14:54:33
                            Reverse ON
                        Count: 4
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 036100038
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B75D516B20C979E9F-806E
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000022994
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63C54D766A3C8F5EF7-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000112450712
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H05 0081
       Revision: 0L0D5012    Serial number: SN101220  0012
       ASAM Dataset: EV_GSM2x3Mono 001014
       ROD: EV_GSM2x3Mono.rod
       VCID: 2B55E556426C071E0F-807E
       Serial number: 00457303059701
       Coding: 764FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F6DF14676747B3E23-807A
       Serial number: 00456457045001
       Coding: 364FF2
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FED3146B6F43B3E63-803A
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70EF323AABCA24C67A-8024
    End-------------------------(Elapsed Time: 06:12)--------------------------
    Jef
  2. Likes NEtech, Andy, Uwe, jyoung8607 liked this post
  3. #2
    Oct 2016
    Stockholm Sweden
    A "Aux coolant pump" is normally fitted on cars with the aux heater, but sometimes not, depending on MY. I have coded some aux heaters on the 3,0 and 4,2 TDI ROW engines (Audi A6, A8, Q7) and there is a coding option in #8 or #18 for this valve to be activated or not. With this valve open the warm cooling fluid produced by the heater can circulate in the engine.
    Don´t know if this helps, but maybe a coding is messed up somewhere.
    Jan 2017
    Got a 2011 A8L 4.2 a couple weeks ago and ran into this same code. Got a new V51 pump off Amazon and since I'm an idiot, I tested it by hooking it straight to 12V battery to make sure it works before installing. It did work like a second and then not a peep. So to see what's going on and to my horror, I actually found a PCB inside the old pump. Anyhoo, just in case anyone's interested, here's a picture of what the insides of this pump looks like.
    And a link in case the embedded pic doesn't show: https://imgur.com/a/pc19v9j
  5. Likes jyoung8607, Uwe, Jef liked this post
  6. #4
    Dec 2016
    Amsterdam
    Quote Originally Posted by AndySwede View Post
    I would like to add to this that most MQB EU cars with upgraded climatronic get a residual heating function automatically. Which is in no means an auxilary heater, but every single car that has a residual heating function will have an auxilary coolant pump.
    Current:
