Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Retrofit Active Info Display on Passat B8
    Verified VCDS User @DRI@N's Avatar
    Nov 2017
    Romania
    Look for the thread initiated by our colleague "bbusato" .
    He explain how made the AID retrofit on his car Vw Golf and in his thread you found attached pictures from VCDS .
    But you need to know that for removal Component Protection and mating keys with Immo is necessary VAS-ODIS .
    I am NEW here and unfurtunately I don't have permision to attache pictures .
  2. #12
    Quote Originally Posted by @DRI@N View Post
    Please see: How to Post Pictures.
  3. #13
    Unverified
    Apr 2019
    Bosnia and Herzegovina
    Hello! I am new to the forum! Please share some experiences with Active Info Display Passat B8 with me. Passat B8 is the 2015 production, it was my ordinary instrument clock, I purchased an AID a month ago and it was built by the man who sold it to me, everything works on the AID. it just does not show the maps on the AID. Please for help, Passat has MIB discover media II. I also built a cable optical that goes from MIB devices to digital cockpit! Please if you have suggestions to answer me on the forum?
  4. #14
    Unverified
    Apr 2019
    Last edited by Uwe; 04-19-2019 at 02:56 PM. Reason: IMG -> URL (since it's an album, not a single image)
  5. #15
    Mar 2016
    Slovenia
    Today i made retrofit to AID in my Passat B8. I have some errors and i have no solution. Please see AutoScan. Car work prfect, only full Navigation is not on AID....
    And when i give ignition, instrument cluster beep 5 times. i dont know for what ..
    Wednesday,15,May,2019,10:19:19:34340
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ3CZFE447826   License Plate: PO INSTALACIJI
    Mileage: 59666km-37074mi   Repair Order:
    Chassis Type  3C-VW48 (5Q0)
    Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 65 6C BB
              BC CA
    VIN: WVWZZZ3CZFE447826   Mileage: 59666km-37074miles
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H21 1989
       Revision: B5H21---
       Coding: 01190012034405083000
       Shop #: WSC 29121 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
       ROD: EV_ECM20TDI01104L906026FK.rod
       VCID: 7F0B74BAE67B58B2A4-802A
       Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
       Component: ESC           H42 0609
       Revision: 00000000    Serial number: 63534000003493
       Coding: 0EEC6A8F34240B73077F060241C94970562CD0E0608292F11460F0084009
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       VCID: 3D774EB2ACF78AA2F6-8068
    8299 - Databus
                        Reset counter: 252
                        Date: 2019.05.15
                        Time: 09:55:06
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0357395923
       Coding: 000F3E0603
       Shop #: WSC 05311 115 00300
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77FB9C9ACE4B60F2EC-8022
       Part No SW: 5G1 907 044     HW: 5G1 907 044
       Revision: 00001K10
       Coding: 11020114202100012015504C00101802
       VCID: 65C7C6D264E7E2624E-8030
       Air quality sensor:
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86580301151324
       Coding: 00910C46C24102FF43C0400400180708189E000000000000000000000000
       Shop #: WSC 12345 123 61029
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7DF78EB2EC774AA2B6-8028
       Component: WWS    141213  042 0607
       Serial number:         141219085831
       Component: RLHS  037 0059
       Serial number: S3Y16M05D12H12M50S47
       Coding: 028877
       Serial number: 07 11 2014  00000968
       Sun Roof:
       Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0053
       Revision: --------    Serial number: 39311500205593
       Coding: 0071151001
       Shop #: WSC 05311 115 00093
       ROD: EV_EPHVA18AU3700000_002_VW48.rod
       VCID: 40893746DB05E74A9D-8014
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0130
       Coding: 2A40600110FFC428949C804C
       ASAM Dataset: EV_ACCBOSCHVW48X 001007
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3363688A9AB34CD210-8066
       Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R2P06CC89
       Coding: 88CCC000000000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 020DFD4E9589355ACB-8056
       Subsystem 1 - Part No SW: -----------    HW: 454 000 401 15
       Serial number: 3576U000000E8C70721G
       Subsystem 2 - Part No SW: -----------    HW: 454 000 301 15
       Serial number: 3586U000000972707211
       Subsystem 3 - Part No SW: -----------    HW: 454 800 701 15
       Serial number: 3516RA0E68E05000000D
       Subsystem 4 - Part No SW: -----------    HW: 454 800 801 15
       Serial number: 3526RE8348B05000000A
       Subsystem 5 - Part No SW: -----------    HW: 454 800 301 15
       Serial number: 3556V36124A05000000
       Part No SW: 5Q0 953 569 B    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0205
       Revision: --------    Serial number: 20160203500079
       Coding: 0400
       Shop #: WSC 46287 002 1048576
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
       ROD: EV_SMLSVALEOMQBLRH.rod
       Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
       Component: KOMBI         405 2170
       Coding: 0BA509902E00000801886F251000000000000000
       ROD: EV_DashBoardVDDMQBAB_VW48.rod
       VCID: 28598FE653753F0AB5-807C
    10485826 - Internal Control Module Memory Check Sum Error
              B2000 41 [009] - General checksum failure
                        Mileage: 40034 km
                        Date: 2018.02.11
                        Time: 15:12:23
    16776996 - Databus
                        Reset counter: 252
                        Mileage: 59666 km
                        Date: 2019.05.15
                        Time: 09:54:41
    16777034 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 37
                        Mileage: 59666 km
                        Date: 2019.05.15
                        Time: 09:54:44
       Revision: --------    Serial number: 19121410803720
       Coding: 030300044F087300FF00025A080F00010001070000000000000000000000
       ROD: EV_GatewConti_011_VW48.rod
       VCID: 72EDAD8EA52905DADB-8026
       Serial number: 29160000008240116013
       Coding: 2C0000
       Serial number: 2895365303
       Analog clock:
       Component: Analoguhr  111 1004
       Serial number: 1712201400010411
       Serial number: 14000315613005
       Coding: 0000000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71EFA282A02F3EC222-8024
       Serial number: 221214BLL01893
       Coding: 003F1B205400020000001000
       VCID: 428D3D4ED509F55A8B-8016
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    203 2033
       Revision: 00000000    Serial number: 0000114805
       Coding: 01000010005000
       Shop #: WSC 00015 115 00300
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       VCID: 3B7340AAB2E38492C8-806E
       Serial number: 161214BLG08549
       Coding: 003F1120D400020000001000
       VCID: 418F3242D00FEE4292-8014
       Coding: 039A00000F200200
       Shop #: WSC 64272 001 1048576
       VCID: 3F8B34BAA6FB98B2E4-806A
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
       Coding: E02400
       Component: LeiMo rechts  H02 0003
       Coding: E02400
       Part No SW: 3Q0 035 864     HW: 3Q0 035 864
       Component: MU-S-N-ER     H10 0140
       Serial number: VWZAZ2P8504048
       Coding: 02840101FF0000001111000100090A001F01008401200100CD
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 6ED5B9FEB111213A3F-803A
       Component: ABT_High  H42 0022
       Serial number: VWZ8Z9M2300ME3
       Subsystem 2 - Part No SW: V03 825 254 A    HW: -----------
       Component: ECE DL1 19/20  --- 1115
       Serial number: 30000000005415
       ROD: EV_RDKBERU30_006_VW48.rod
       VCID: 34616B969FBD4BEA09-8060
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H07 0100
       Coding: 0184010142002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
       Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0028
       Serial number: 181214BLH19573
       Coding: 000E01200100020000001000
       VCID: 44813B56CF1DFB6AB9-8010
       Component: TSG HBFS      020 0028
       Serial number: 181214BLH19576
    Address CA: Sunroof
    Interface not compatible.
    End-------------------------(Elapsed Time: 05:08)--------------------------
    Tnx
  6. #16
    Nov 2017
    Romania
    Hello colleagues,
    I need a little help from you.
    After I made retrofit to the AID, I observe that I don't receive information about AdBlue RANGE, as in the picture below :
    https://imgur.com/MM5FN01
    Is possible to tell me what ADAPTATION to made with VCDS that to show me the AID this information ???
    Thanks,
    Best regards .
  7. #17
    We'll need to see a full unedited VCDS Auto-Scan so we can see what car you have, what modules are fitted and what their hardware & software versions are.
  8. #18
    Nov 2017
    Romania
    @PetrolDave
    You can see below complete VCDS log :
    Tuesday,16,July,2019,12:36:45:62612
    VIN: WVWZZZ3CZFE400297   License Plate: GL-08-RMN
    Mileage: 63191km-39265mi   Repair Order:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 47
              52 55 5F 69 6C 6D A5 BB BC CA CF
    VIN: WVWZZZ3CZFE400297   Mileage: 63191km-39265miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
       Part No SW: 03N 906 026     HW: 03N 907 309
       Component: R4 2,0L EDC   X22 0948
       Revision: A1X22---
       Coding: 01250032047605083000
       Shop #: WSC 08601 003 1048576
       ASAM Dataset: EV_ECM20BTD01103N906026 001008
       ROD: EV_ECM20BTD01103N906026.rod
       VCID: 688AB06D52FC9207629-803C
       Part No SW: 0DL 300 011     HW: 0BH 927 711 F
       Component: GSG DQ500     H10 4701
       Revision: 00H10V01
       VCID: 6594B959A5EE8F6F59F-8030
       Part No SW: 3Q0 907 379 H    HW: 3Q0 907 379 H
       Component: ESC           H34 0906
       Revision: 00000000    Serial number: 42044000000257
       Coding: 0EEC6B8F54200B6C0779070941CA6970D62AD0E0E08296F5B86250F8CAA9
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034001
       VCID: 3FD84B3167F2F5BFF33-806A
       Part No SW: 3Q0 959 435 A    HW: 3Q0 959 435 A
       Component: VWKESSYMQB    033 0523
       Revision: 00033000    Serial number: 0338858352
       Coding: 0F00000703
       Shop #: WSC 05311 115 00084
       VCID: 382A202D42DCC287329-806C
       Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
       Component: GEB.F.Heckoef  H17 0812
       Serial number: ;8000020
       Part No SW: 5G1 907 044 B    HW: 5G1 907 044 B
       Revision: 00001K10
       Coding: 11020114202100012115504E00101102
       Shop #: WSC 00015 115 08193
       ROD: EV_ACClimaBHBVW37X_003_VW48.rod
       VCID: 2708F3519F625D7FAB3-8072
       Air quality sensor:
       Part No SW: 5Q0 937 086 G    HW: 5Q0 937 086 G
       Component: BCM PQ37BOSCH 028 0112
       Revision: --------    Serial number: 86582307141678
       Coding: 00959E66C2410AFF13844084B118172C1880000000000000000000000000
       ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
       ROD: EV_BCMBOSCH_013.rod
       VCID: 3E26363560F8FCB7F85-806A
       Component: WWS    140725  042 0607
       Serial number:         140728125216
       Serial number: S4Y14M07D22H06M13S09
       Coding: 06A8DD
       Serial number: 21 05 2014  00000097
       Serial number: 000000000ZY1416304FJ
       Serial number: 00000000000030345385
       Seat Backrest Fan 1 Front Left:
       Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Component: SysNameFanLin  012 X025
       Serial number: ESE0001317
       Seat Cushion Fan 1 Front Left:
       Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0002060
       Seat Backrest Fan 1 Front Right:
       Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0000985
       Seat Cushion Fan 1 Front Right:
       Subsystem 10 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0002055
       Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
       Component: PLA 3.0 12KH08 0013
       Serial number: ATW-00107.08.14
       Coding: 0471267151
       Shop #: WSC 05311 123 08193
       ASAM Dataset: EV_EPHVA2CAU3700000 008017
       ROD: EV_EPHVA2CAU3700000_008.rod
       Component: ACC Bosch MQB H04 0128
       Coding: 326167DB14FFC728949C804C
       Shop #: WSC 05311 115 00171
       VCID: 333017015BBA21DF07B-8066
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H15 0115
       Serial number: 15071441350001
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 76B6EE15084874F7E05-8022
       Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
       Revision: --------    Serial number: 003R1PFWE7B6
       Coding: 98FCC0C0008000005C5400CC000800000065
       VCID: 015C8DC95186434FC57-8054
       Belt Pretensioner left:
       Component: BeltPretRevFL  105 1032
       Serial number: 3G1857705E0226O00499
       Coding: 80000A
       Belt Pretensioner right:
       Component: BeltPretRevFR  105 1032
       Serial number: 3G1857706E0223O00099
       Coding: 80000A
       Subsystem 3 - Part No SW: -----------    HW: 454 001 107 14
       Serial number: 3576U000000574C46014
       Subsystem 4 - Part No SW: -----------    HW: 454 001 107 14
       Serial number: 3586U000000295C46015
       Subsystem 5 - Part No SW: -----------    HW: 454 801 407 14
       Serial number: 3516R0B8E2C040000007
       Subsystem 6 - Part No SW: -----------    HW: 454 801 407 14
       Serial number: 3526R23812C04000000W
       Subsystem 7 - Part No SW: -----------    HW: 454 800 107 14
       Serial number: 3556V12A00304000000R
       Part No SW: 3Q0 953 521 AL    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0185
       Revision: FF033033    Serial number: 20140731500365
       Coding: 0810
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
       VCID: 7AAEFA253C50109784D-802E
       Part No SW: 3G0 920 798 A    HW: 3G0 920 798 A
       Component: KOMBI         F15 0460
       Coding: 00B40019FFAC000801897E2B7403000000000000
       Shop #: WSC 00046 123 12345
       ASAM Dataset: EV_DashBoardVDDMQBAB 009041
       VCID: 2E060675B0980C37685-807A
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 16081410801367
       Coding: 0B0300344F017300FF00025E9C0F00010001070000000000000000000000
       ASAM Dataset: EV_GatewConti 011017
       ROD: EV_GatewConti_011.rod
       VCID: 42DE42C5140098579CD-8016
       Component: E221__MFL-DC1  H16 0038
       Serial number: 29140001517680084292
       Coding: 2FFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 3792203703
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
       Component: WECHSELRICHTE  H54 0033
       Serial number: 0000652
       Analog clock:
       Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Serial number: 1607201400010091
       Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7081
       Serial number: HA1-00022.03.14
       Coding: 0301
       ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
       VCID: 46D65ED53828A477B05-8012
       Serial number: 14000082601003
       Coding: 0800000000000000
       VCID: 71BCDD09612653CF357-8024
    Address 36: Seat Mem. Drvr (J810)       Labels:* None
       Part No SW: 3Q0 959 760 A    HW: 3Q0 959 760 A
       Component: Sitzmemory    H03 0011
       Serial number: Y0006NGU10039
       Coding: 001010020000010081A080808080000000008181000000F4
       ASAM Dataset: EV_SeatMemorDriveSide 001015
       ROD: EV_SeatMemorDriveSide_001.rod
       VCID: 392C252979D6DB8FCD7-806C
       Part No SW: 3Q0 907 566 A    HW: 3Q0 907 566
       Component: MRR1Rear      H15 0227
       Revision: --------
       Coding: 14C002
       Shop #: WSC 38071 001 104857
       VCID: 36362E1548C834F7205-8062
       Serial number: 03071406070479
       Coding: 003F1A20D200028000001000
       Coding: 9703
       Shop #: WSC 12345 123 12345
       VCID: 372823114FC2CDFF3B3-8062
    Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
       Part No SW: 3Q0 035 466 B    HW: 3Q0 035 466 B
       Component: MIB2_amp_P_VW H40 0170
       Revision: 00000001    Serial number: VWZ8Z1EAT00087
       Coding: 1284010001AA0A2AAA0000000000
       ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
       ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
       Serial number: 06081404081132
       Coding: 003F1020DE00028200001000
       VCID: 41DC4DC91106834F857-8014
       Coding: 03A203004F210200
       Coding: E02400
       Coding: E02400
       Coding: E02400
       Coding: E02400
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 044     HW: 3G0 035 044
       Component: MU-H-TN-EU    H33 0199
       Serial number: A293G0EB001148
       Coding: 028401010000000011110002000808101F0100A4012080009F
       VCID: 5AEE9AA59C903097E4D-800E
       Component: ABT_High  H61 0031
       Serial number: VWZ8Z9PS100J72
       Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Component: Gracenote2  --- 1008
       Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
       Component: Anhaenger     H14 0137
       Revision: 8A001001    Serial number: 0343446109
       Coding: 0100000202000000
    Address 6C: Back-up Cam. (J123)       Labels:* None
       Part No SW: 5Q0 907 556     HW: 5Q0 907 556
       Component: TopView       H11 0328
       Serial number: C854706JG000107
       Coding: 01840101E70F200000204814
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003011
       ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
       Part No SW: 5Q0 959 107 H    HW: 5Q0 959 107
       Component: HDSG-Modul    H11 0253
       Revision: --------    Serial number: 29486950100000
       Coding: 0108
       Shop #: WSC 44873 002 1048576
       VCID: 3D2431396DFEE7AFE1F-8068
       Part No SW: 3Q0 980 653 C    HW: 3Q0 980 653
       Component: MQB_B_MFK     H07 0061
       Serial number: 13081411P10083
       Coding: 00040801000004010022234FC040A100980086200040
       Serial number: 06081402091458
       Coding: 000E10200100028000001000
       VCID: 44D244DD0E149667AE1-8010
       Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
       Component: TSG HBFS      020 0025
       Serial number: 10071403110759
       Part No SW: 4M0 907 594 C    HW: 4M0 907 594
       Component: SAD_STG_1     009 0002
       Coding: 608000748101
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       Part No SW: 3Q0 907 590 A    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
    End----(Elapsed Time: 02:59, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    If software update is required please tell me where I need to go to make updates!
    Because Vw dealer in Romania told me when I installed AID in car, this car don't have any software update !
    Thanks.
    Best regards .
