- Mar 23, 2016
- 25
- 14
- New Zealand
- C?ID=212507
Hi there, as title says have just replaced the front seatbelts in this 2017 Golf Mk7, after a small crash in the rear of the car.
Did the seatbelt tensioner control module reset as per the wiki regarding AirbagVW20, but get the message "Request sequence error"
Tried recoding airbag module with same coding value as mentioned in wiki, still not working. Has anyone done this successfully?
When selecting "left belt tensioner serial number" under basic settings there is no where to input a serial number (which I don't have anyway, the belts are new from oemvwshop.com)
Warning lights are off now with the new belts fitted but have the codes B1304 and B1305 (seat belt tensioner control module: not configured) as below.
Any advise appriciated
Tuesday,24,October,2017,11:49:24:18828
VCDS Version: 17.8.0.1 (x64)
VIN: WVWZZZAUZHW083306 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZHW083306 Mileage: 16580km-10302miles
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HB HW: 04E 907 309 BH
Component: R4 1.4l TFS H25 2833
Revision: R7H25---
Coding: 0125003224241D082000
ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
ROD: EV_ECM14TFS01104E906027HB.rod
VCID: 6BD5D48382CC7C1E4F-803E
CAN Converter 01:
17158 - Databus
U1123 00 [040] - Received Error Message
Mileage: 16580 km
Date: 2017.10.24
Time: 00:00:00
Coolant temperature: 23 癈
Intake air temperature: 23 癈
Voltage terminal 30: 11.756 V
Acceleration: 0.000 m/s?ding毧睱
Cruise Control System (CCS): status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 0: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16: 128
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 24: 128
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 8: 0
Drivetrain coordinator: brake fault status-Bit 0: 4
U0428 00 [040] - -
Time: 00:00:00
Voltage terminal 30: 11.826 V
Outside air temperature: 215 癈
Absolute intake pressure: 100 kPa abs
Engine torque: 0.0 Nm
Fuel level: 126.00 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Intake camshaft bank1 active operating mode-Bit 0: 0
Intake camshaft bank1 active operating mode-Bit 8: 0
Overrun cut-off-Bit 0: 0
Readiness: 0110 0001
Part No SW: 0CW 300 049 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0911
Revision: 00005026 Serial number: CU501608215814
ROD: EV_TCMDQ200021_VW26.rod
VCID: 44875F3FCFD25366EE-8010
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 92166000006251
Coding: 01FA8AA12428116F477A060041C92980512488E26082947300220078C20203
VCID: 7AFBE1C7FD96D596C4-802E
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 130
Mileage: 16580 km
Date: 2017.10.24
Time: 00:00:00
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Reset counter: 130
Mileage: 16580 km
Date: 2017.10.24
Time: 00:00:10
16413 - Display for Tire Pressure Monitoring
Reset counter: 130
Mileage: 16580 km
Date: 2017.10.24
Time: 00:00:10
Part No SW: 5G0 907 426 AJ HW: 5G0 907 426 AJ
Component: AC Manuell H03 1601
Revision: 00001K06
Coding: 00120004200100001000000000000002
ASAM Dataset: EV_ACManueBHBVW37X 004132
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 73E5CCE3DAFCA4DE87-8026
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 CJ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061624400744
Coding: 03001842C24102730BA44080B10403081000000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 020B992795469D569C-8056
Component: WWS 160812 042 0551
Serial number: 160818065519
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S6Y16M09D02H04M45S48
Coding: 00A8DD
Serial number: 000000000ZY1620216PS
Serial number: 00000000000066691401
202506 - Motor for Central Locking of Rear Trunk/Hatch
B12DD 15 [009] - Open or Short to Plus
Reset counter: 90
Mileage: 16580 km
Date: 2017.10.06
Time: 10:39:18
Revision: -------- Serial number: 39331625208704
Coding: 0031151011
VCID: 43855C23CADC545ED7-8016
1080083 - Rear Parking Aid Sensor(s)
B107B 13 [008] - Open Circuit
Reset counter: 89
Mileage: 16580 km
Date: 2017.09.29
Time: 17:08:52
13637426 - Databus
Reset counter: 130
Mileage: 16580 km
Date: 2017.10.24
Time: 00:00:00
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR224CSZ
VCID: 7F0D10D3E6B4F0BEF3-802A
Belt Pretensioner left:
Serial number: 34169677E11081750018
Coding: 333135
Belt Pretensioner right:
Serial number: 34169676E13081790140
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 909 16
Serial number: 35767000000A76584E1/
Subsystem 4 - Part No SW: ----------- HW: 480 000 809 16
Serial number: 35867000000BA2557D1/
Subsystem 5 - Part No SW: ----------- HW: 480 402 708 16
Serial number: 3516502B5218C2A361FC
Subsystem 6 - Part No SW: ----------- HW: 480 403 008 16
Serial number: 3526502C321FBE84718N
Subsystem 7 - Part No SW: ----------- HW: 480 402 008 16
Serial number: 3556502A3218C2A37075
9634901 - Control Module for Front Left Belt Tensioner
B1304 55 [009] - Not configured
Reset counter: 90
Mileage: 16580 km
Date: 2017.10.24
Time: 00:32:55
9635157 - Control Module for Front Right Belt Tensioner
B1305 55 [009] - Not configured
Reset counter: 90
Mileage: 16580 km
Date: 2017.10.24
Time: 00:32:55
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Revision: FF034034 Serial number: 20160906400863
Coding: 0410
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 3F8D50D3A63430BEB3-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 740 B HW: 5G1 920 740 B
Component: KOMBI 202 9630
Coding: 27A419082380000801082A001400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009007
ROD: EV_DashBoardJCIMQBAB_009.rod
VCID: 2541E2BB24A88A6ED9-8070
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1265
Revision: -------- Serial number: 0005331217
Coding: 030100343F085700FB00004C1C0F00010001050000000000000000000000
ROD: EV_GatewLear_013_VW37.rod
VCID: 7BF5E4C3F2ACEC9EDF-802E
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29160001631560106341
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 5361631304
197175 - Control unit for battery monitoring
U1050 00 [008] - No Communication
Reset counter: 130
Mileage: 16581 km
Date: 2017.10.24
Time: 13:58:41
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 270816EHR08324
Coding: 003002208001048000001000
VCID: 4189562BD0C0464EC5-8014
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011137245
Coding: 0D0000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 0107
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 4581423BC4E86A6EF9-8010
16272 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 95
Motor status: 00
System status: Reset
Supply voltage: 12.00 V
Temperature: 21.0 癈
KFC: 3F
KFA: 00 90
Environmental conditions: 21
uioUdNotFilt_xdu16: 12.08 V
uAdSensI_SwitchedKl30_xdu16: 12.06 V
NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
NoInitCause_RackPos_Rohwert: 00 C0
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_KMN_RACKPOS_SET: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_WHLSPDPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: activated
RP_CNTERR: activated
Component: TSG BFS 020 0041
Serial number: 270816EHM0109A
Coding: 003000208E01048000801000
VCID: 428B5927D5C65D56DC-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011440169
Coding: 150000
Part No SW: 3Q0 035 824 B HW: 3Q0 035 824 B
Component: MU-S--ER 710 0751
Coding: 02730000FF00000051510001000808001F0100D60120010003
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2C57179F4742BB2606-8078
Subsystem 1 - Part No SW: 3G0 919 605 B HW: 3G0 919 605 B
Component: ABT_Std-2 H43 4064
Serial number: VWZ6Z9S2450358
6720 - Rear View Camera
B1102 31 [008] - No Signal
Reset counter: 130
Mileage: 16580 km
Date: 2017.09.29
Time: 17:08:52
Voltage terminal 30: 14.8 V
End-------------------------(Elapsed Time: 03:58)--------------------------
