Audi A3 8p1 2004 1.9 tdi
Glow plugs are new Bosch. After ignition on orange glow led lights very short on cold temperatures below 5.
VCDS: no fault codes, ignition on ->mvb 12 = status: no pre-glow, pre-glow period: 0 seconds.
How to log mvb 12 from ignition off to ignition on? I ask this because if I turn off ignition there is no
signal to controller anymore! I think that there is no ecu output to glow plug controller, but don't know why.
I must test ECT sensor, pre-glow period at cold temperatures, ecu maps... ??
Monday,23,October,2017,17:08:09:64639
VCDS Version: 17.8.0.1
VIN: WAUZZZ8P24A123573 License Plate:
Mileage: 144080km-89527mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P24A123573 Mileage: 144080km-89527miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 J HW: 028 101 138 3
Component: R4 1,9L EDC 0000SG 5497
Revision: 12345678 Serial number: AUX7Z0D0FN705J
Coding: 0000071
Shop #: WSC 00066 001 57865
VCID: 2A5CCF9A85035616F4-807E
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021125
Shop #: WSC 06435 000 00000
VCID: 3A7CFFDA75A3E69684-806E
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 023014 Serial number: 8P0820043D
VCID: 2D56C486B4ED412E11-8078
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 205
Mileage: 144081 km
Date: 2017.06.23
Time: 17:05:19
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000391470
Coding: 03884F1082141000000000000000000000
Shop #: WSC 03016 425 62869
VCID: 3B72FADE7A99DF9E9F-806E
Subsystem 1 - Part No: 8P1 955 119 A Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 03016
010 - Open or Short to Plus
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 E HW: 8P0 959 655 E
Component: Airbag 8.4EDmin H00 0130
Coding: 0010102
VCID: 448081220767A066EE-8010
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
VCID: 6FEA1E8E7E61733E63-803A
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 900 D HW: 8P0 920 900 D
Component: KOMBIINSTR. VDO H27 0110
Revision: D08 Serial number: 1240DD08012463
Coding: 0004103
Shop #: WSC 07136 298 179329
VCID: 3068DDF2A3DF2CC63A-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103C04A4A7
Coding: 3D0F0B42070100
VCID: 26443BAA911B7276D0-8072
01304 - Radio
Fault Frequency: 141
Reset counter: 205
Mileage: 143608 km
Date: 2017.06.21
Time: 08:32:49
Revision: D08 Serial number: AUX7Z0D0FN705J
01176 - Key
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000016
VCID: 397EE0D670A5ED8E8D-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V1.clb
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.9 1202
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 008800186D288505484A016000
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001053989
VCID: 70E81DF2635F6CC67A-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000016
Address 56: Radio
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
VCID: 2B52CA9E8AF94F1E0F-807E
014 - Defective
End-------------------------(Elapsed Time: 01:38)--------------------------
