Results 1 to 3 of 3
Thread: 2012 VW Sharan steering module coding
    Jun 2017
    Please help, this i my first post.
    I have a 2012 Sharan in Denmark in Europe where the buttons on the MFSW stopped working and an Airbag light came on.
    I found another control module with the same part no. but cant seem to get it working. I keep getting a "G85 no basic setting" fault. I have spent a ton of time trying to find the correct coding, and a way to carry out the basic setting, but to no avail.
    Here are the two auto scans with the two different modules installed.
    Original module 5K0953569L
    Thursday,19,October,2017,23:10:40:54256
    VCDS Version: 17.8.0.1 (x64)
    VIN: WVWZZZ7NZCV016765   License Plate:
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 37 42 44 46 4C 4F
              52 53 56 61 62 69 6D 72 77 BE BF
    VIN: WVWZZZ7NZCV016765   Mileage: 340150km-211359miles
    BE-Slid. Door Rear Left -- Status: OK 0000
    BF-Slid. Door Rear Right -- Status: OK 0000
       Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
       Component: R4 2,0L EDC   H26 9236
       Revision: 44H26---    Serial number:
       Coding: 001D001A043401080000
       Shop #: WSC 32912 056 526860
       ASAM Dataset: EV_ECM20TDI01103L906018HJ 003007
       ROD: EV_ECM20TDI01103L906018HJ.rod
       VCID: 79F999FBF80AA28ECD-802C
    4481 - Cruise Control Switch (E45)
              P0568 00 [032] - Implausible Signal
                        Mileage: 340150 km
                        Date: 2017.10.19
                        Time: 01:54:50
                        Coolant temperature: 17 °C
                        Intake air temperature: 14 °C
                        Voltage terminal 30: 11.780 V
                        Cruise Control System (CCS): switch position-Bit 0: 192
                        Cruise Control System (CCS): status-Bit 0: 204
                        Cruise control switch-off: irreversible-Bit 0: 255
                        Cruise control switch-off: reversible-Bit 0: 255
                        Engine control module reset status-Bit 0: 0
                        Engine control module reset status-Bit 8: 0
                        Cruise control switch-off: irreversible w. brake intervention-Bit 0: 0
    4483 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                        Mileage: 340150 km
                        Date: 2017.10.19
                        Time: 01:54:50
       Part No SW: 02E 300 054 S    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2701
       Revision: 05351113    Serial number: 00001108311622
       Shop #: WSC 00020 790 00000
       VCID: 264382879134FD76D0-8072
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 N    HW: 7N0 614 109 N
       Component: J104   C3 450M VDDB 0021
       Revision: --H07---    Serial number: 00000004714339
       Coding: 0027162
       VCID: 387F5CFF4B807B8672-806C
                        Reset counter: 219
                        Mileage: 340150 km
                        Date: 2012.03.11
                        Time: 01:55:03
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.50 V
                        Bin. Bits: 00011110
                        Count: 191
                        Hex Value: 0x0000
       Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
       Component: VWKESSYPQ35GP 085 0802
       Revision: 00085000    Serial number: 0153677623
       Coding: 03100C
       Shop #: WSC 00020 999 39850
       ASAM Dataset: EV_KESSY_PQ35GP A01018
       ROD: EV_KESSY_PQ35GP.rod
       VCID: 33656BD39AE698DE47-8066
       Part No SW: 5K0 907 044 FL    HW: 5K0 907 044 FL
       Component: Clima-Sharan  H18 0204
       Revision: 00001002
       Coding: 0200104509
       Shop #: WSC 00020 999 00000
       VCID: 7AFB86F7FD0CA996C4-802E
       Slave 1:
       Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
       Component: KBT-H  004 0103
       Serial number: 20130815000000126761
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0048
       Revision: BC011001
       Coding: 40590A3B89251AC0500800C0740081E443511308476D2DF26480C720A2C1
       Shop #: WSC 00020 790 12345
       VCID: 3B7543F3BAB6509E9F-806E
       Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    110818  31  0032
       Serial number:         110825132653
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0022
       Serial number: Y11M09D03h01m34s18S1
       Coding: 0280BB
                        Reset counter: 4
                        Mileage: 340150 km
                        Date: 2012.03.11
                        Time: 02:00:15
                            Term 15 Off
                        Voltage: 11.90 V
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 7N0 919 475 A    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0012
       Revision: --------    Serial number: 28261125002238
       Coding: 118101
       ASAM Dataset: EV_EPHVA18VW4280000 001005
       ROD: EV_EPHVA18VW4280000.rod
       VCID: 397959FBB88A628E8D-806C
       Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
       Component: VW10Airbag01X H07 0013
       Serial number: 003GFPK31ZLA
       Coding: 003158
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 3E734AE7A1A445B6B8-806A
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS60CE42E1149D+
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS607A87DE149D2
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS60F50DDB149D1
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS60C3F7DE149D9
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS60E105CF14DDT
                        Mileage: 340150 km
                        Date: 2017.10.19
                        Time: 02:07:57
       Part No SW: 5K0 953 501 BM    HW: 5K0 953 569 L
       Revision: FF010040    Serial number: 20110826300250
       Coding: 1102240000
       Shop #: WSC 00020 999 12345
       VCID: 76E392C7C914CDF6A0-8022
    227339 - Windshield Wiper Switch
              B1145 13 [008] - Open Circuit
                        Reset counter: 3
              B1149 13 [008] - Open Circuit
                        Reset counter: 3
    365080 - Controls in Steering Wheel
                        Reset counter: 174
                        Mileage: 338693 km
                        Date: 2017.09.20
                        Time: 14:26:22
       Part No SW: 7N0 920 870 E    HW: 7N0 920 870 E
       Coding: 140F01
       VCID: 346768CF9FE89FE65E-8060
    12718592 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 4
                        Mileage: 340150 km
                        Date: 2017.10.19
                        Time: 02:00:14
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 C
       Component: Zuheizer        051 2730
       Revision: 00051000    Serial number: 09022126000000
       Coding: 0000041
       Shop #: WSC 14871 002 1048576
       VCID: 346768CF57E89FE65E-8060
       Part No SW: 7N0 907 530 K    HW: 1K0 907 951
       Component: J533  Gateway H40 1620
       Revision:   H40       Serial number: 010911F1000826
       Coding: 468002
       Shop #: WSC 18402 001 1048576
       VCID: 387F5CFF8B807B8672-806C
                        Reset counter: 3
                        Mileage: 340150 km
                        Date: 2012.03.11
                        Time: 02:00:13
       Component: IMMO          H03 0607
       Coding: 000007
       VCID: 6ADBB6B78DAC191634-803E
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000200154005
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E537AA771C4B53628-807A
       Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
       Component: RNS-MID       H42 1400
       Revision: AB001001    Serial number: VWZ6Z7L6060056
       Coding: 0C000400040000A000
       Shop #: WSC 00059 204 00057
       VCID: 2D517DAB74C2CE2E11-8078
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
       Component: TSG FA        H04 0400
       Revision:             Serial number: 0000119594057
       Coding: 01153E20D000411011
       VCID: 4487380FC7482F66EE-8010
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.324 1002
       Revision: 1AH03733    Serial number: 00112510085601
       Coding: 0000258
       VCID: 3C7740EF7FB857A696-8068
       Component: EZE_2         H40 1620
       Coding: 050B0500
       VCID: 6FEDA7A3BE4EFC3E63-803A
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
       Component: TSG BF        H04 0400
       Revision:             Serial number: 0000119645344
       Coding: 01153E20DE00411011
       VCID: 43853B13C246285ED7-8016
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000223613
       Coding: 0024167
       VCID: 356155CB5C9286EE69-8060
       Component: Batt.regelung H40 1620
       Coding: 030B115A
       VCID: 71E9A1DBA87AEACE75-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900520182
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 F    HW: 7N0 959 795 B
       Component: TSG HL        H03 0403
       Revision:             Serial number: 0000119652542
       Coding: 01007C200000411001
       VCID: 46832207F1741D76F0-8012
    Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
       Part No SW: 7N0 907 383     HW: 7N0 907 383
       Component: Anhaenger     H09 0101
       Revision: 3I001002    Serial number: 00000157211198
       Coding: 410C040001000000
       VCID: 73E5ABD3D266D8DE87-8026
       Part No SW: 7N0 959 107 B    HW: 7N0 959 107 A
       Component: HDSG-Modul    H11 0803
       Revision: 41011001    Serial number: 238100143
       Coding: 0733334003
       ASAM Dataset: EV_HDSGVW428 201133
       ROD: EV_HDSGVW428_VW36.rod
       VCID: 366352C789948DF660-8062
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H03 0403
       Revision:             Serial number: 0000119654210
    Address 77: Telephone        Labels: RETROFIT77.lbl
       Part No SW: KTC 364 96P     HW: KTC 364 96P
       Component: SWP:3.31.6      H24 0216
       Shop #: WSC 21977 142 74100
       VCID: 3E734AE769A445B6B8-806A
    Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
       Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
       Component: Schiebetuer_l 005 2414
       Serial number: 11333621
       ASAM Dataset: EV_AST A03704
       ROD: EV_AST.rod
       VCID: 387F5CFF83807B8672-806C
    Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
       Component: Schiebetuer_r 005 2414
       Serial number: 11333606
       ROD: EV_AST.rod
    End-------------------------(Elapsed Time: 04:16)--------------------------
    New control module with the same part no. 5K0953569L
    Thursday,19,October,2017,22:50:43:54256
              P0568 00 [047] - Implausible Signal
                        Fault Frequency: 10
                        Mileage: 340080 km
                        Date: 2017.10.17
                        Time: 22:28:50
                        Engine speed: 780.50 /min
                        Normed load value: 37.6 %
                        Coolant temperature: 55 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 14.380 V
                        Cruise control switch-off: irreversible-Bit 0: 0
                        Cruise control switch-off: irreversible w. brake intervention-Bit 0: 1
    4482 - Function Restriction due to Implausible Message(s)
              U1112 00 [032] - -
                        Mileage: 340080 km
                        Date: 2017.10.17
                        Time: 22:28:50
              U1113 00 [047] - -
                        Fault Frequency: 10
                        Mileage: 340080 km
                        Date: 2017.10.17
                        Time: 22:28:50
       Coding: 0027162
                        Fault Frequency: 11
                        Reset counter: 219
                        Mileage: 340080 km
                        Date: 2012.03.09
                        Time: 22:08:38
                        Hex Value: 0x0000
                        Voltage: 13.75 V
                        Bin. Bits: 00011110
                        Count: 191
                        Hex Value: 0x0000
                        Fault Frequency: 11
                        Reset counter: 219
                        Mileage: 340080 km
                        Date: 2012.03.09
                        Time: 22:08:38
       Coding: 03100C
    1070343 - Bulb for Ignition/Starter Switch Illumination
              B11A7 11 [008] - Short to Ground
                        Reset counter: 254
       Revision: 00001002
       Coding: 0200104509
       Slave 1:
       Revision: BC011001
       Coding: 004DBD
       Coding: 0280BB
                        Reset counter: 219
                        Mileage: 340150 km
                        Date: 2012.03.11
                        Time: 01:39:44
                        Voltage: 11.80 V
       Coding: 118101
       Coding: 003158
              B1000 1B [136] - Resistance Too High
                        Mileage: 338683 km
                        Date: 2017.09.19
                        Time: 21:36:37
       Part No SW: 5K0 953 501 BL    HW: 5K0 953 569 L
       Revision: FF010042    Serial number: 20130903101581
       Coding: 1102140000
       VCID: 75E195CBD412C6EEA9-8020
       Coding: E20000
    226838 - Turn Signal Switch
              B1144 12 [008] - Short to Plus
                        Reset counter: 4
                        Mileage: 340080 km
                        Date: 2017.10.17
                        Time: 22:27:26
    226839 - Turn Signal Switch
              B1144 11 [009] - Short to Ground
                        Reset counter: 218
                        Mileage: 340080 km
                        Date: 2017.10.17
                        Time: 22:26:53
              U108E 00 [008] - No Communications
                        Reset counter: 4
                        Mileage: 340150 km
                        Date: 2017.10.19
                        Time: 01:35:25
    1140738 - Steering angle sensor
                        Reset counter: 218
                        Mileage: 340080 km
                        Date: 2017.10.17
                        Time: 22:25:52
                        UBat: 14.40 V
                        MC1 interner Fehlercode: 0
                        MC2 interner Fehlercode: 0
       Coding: 140F01
              U1111 00 [008] - -
                        Reset counter: 3
                        Mileage: 339773 km
                        Date: 2017.10.16
                        Time: 00:11:57
       Coding: 0000041
    01444 - Under-Voltage Shut-Off (Automatic)
                000 -  -  - Intermittent
                        Reset counter: 239
                        Mileage: 339421 km
                        Date: 2012.03.02
                        Time: 07:44:21
       Coding: 468002
                        Fault Status: 00110100
                        Reset counter: 2
                        Mileage: 339773 km
                        Date: 2012.03.08
                        Time: 00:11:56
       Coding: 000007
    00862 - Antenna for GPS Navigation (R50/R52)
                        Fault Status: 00100111
                        Reset counter: 3
                        Mileage: 339004 km
                        Date: 2012.02.15
                        Time: 16:25:47
       Coding: 0000258
    02546 - Steering Limit Stop
                        Fault Status: 11100101
                        Reset counter: 219
                        (no units): 4.0
                        Voltage: 11.30 V
    00566 - Steering Assistance Operation
                        Fault Status: 11101000
                        Reset counter: 218
                        Mileage: 340080 km
                        Date: 2012.03.09
                        Time: 22:31:37
                        Hex Value: 0x7301
                        Hex Value: 0x7601
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Reset counter: 219
                        Mileage: 340150 km
                        Date: 2012.03.11
                        Time: 01:39:27
                        (no units): 4.0
                        Steering Angle: 0.00°
                            Not OK
                        (no units): 4
       Coding: 050B0500
       Coding: 0024167
                        Reset counter: 3
                        Mileage: 339004 km
                        Date: 2012.02.15
                        Time: 16:25:47
       Coding: 030B115A
       Coding: 0733334003
       ROD: EV_AST.rod
       ROD: EV_AST.rod
    These are not the same part number. Same hardware part number, yes, but what counts is the Software part number. The original is 5K0-953-501-BM, while the replacement is 5K0-953-501-BL. Have you verified that they are compatible and have the same application?
    Jun 2017
    I don't know if they are compatible, (how can i check this?) and the only difference application-wise is the new module has the cruise on the tip of the turn signal stalk (according to the coding) and is from a newer model Tiguan.
