2006 Touareg trailer module
N867LC
Texas
C?ID=199170
My T-reg came with the hitch but no module. I bought the factory module and installed it, but didn't have Vag-Com at the time to get the PCM to see the module. I've since bought Vag-Com, but can not for the life of me figure out how to get the PCM to see the module and turn the module on so I have trailer lights.
Currently the running lights "strobe" and the brake light will work, but I have no turn signals. I've not been able to see the module no matter what I've tried. I recently read that I may need the Long Hex Code Helper, and could never find how to open it until last week. I have not had the chance to try the LHCH yet.
Sunday,27,July,2014,19:45:57:14552
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVGPT77L06D054863   License Plate:
Mileage: 206580km-128362mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L06D054863   Mileage: 206580km/128362miles
   Part No SW: 070 906 016 CQ    HW: 028 101 196 2
   Component: V10 5,0L EDCG000AGMª8472
   Revision: --H02---    Serial number: VWZ3Z0E6402710
   Coding: 0060575
   Shop #: WSC 31414 000 00000
   VCID: 61C95F86BB717216F49-5140
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -  - Intermittent
                    Fault Frequency: 43
                    Mileage: 201274 km
                    Date: 2064.00.00
                    Time: 00:00:00
                    RPM: 672 /min
                    Voltage: 11.10 V
                    Bin. Bits: 00001011
                    Bin. Bits: 00000000
                    (no units): 0.0
005782 - Powertrain Data Bus
               P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
                    Fault Frequency: 43
                    Mileage: 201274 km
                    Date: 2064.00.00
                    Time: 00:00:00
                    RPM: 672 /min
                    Voltage: 11.10 V
                    Bin. Bits: 00001011
                    Bin. Bits: 00000000
                    (no units): 0.0
005120 - EGR Valve (N18)
               P1400 - 000 - Electrical Malfunction - Intermittent
                    Mileage: 206473 km
                    Date: 2064.00.00
                    Time: 00:00:00
                    RPM: 189 /min
                    Lambda: -5.9 %
                    Mass Air / Rev.: 770.0 mg/str
                    Mass Air / Rev.: 370.0 mg/str
                    Bin. Bits: 00000000
Readiness: 0 1 0 0 0
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           0856
   Revision: 00H37000    Serial number:
   Coding: 0004216
   VCID: 7F0DF9FE2DC5A4E6E2D-5140
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D71C3F6674976F6B01-515E
No Faults Found
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137     HW: 5WK 484 92
   Component: G2 Kessy            6700
   Revision: 67005614    Serial number: VWZ3Z0E6402710
   Coding: 0131304
   VCID: F0EFAAC2E09B4B9EEB7-515E
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: F7FD91DE85F51CA62AD-5140
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 T
   Component: CLIMAtronic 2+2     4222
   Coding: 0020030
   VCID: 4581AB160F993E36E81-515E
   Subsystem 1 - Part No: 7L6 907 049 E
   Component: CLIMAtronic FOND    0400
02379 - Positioning Motor for Left Side Vent (V299)
00064 - Left B-pillar/Footwell Shut-Off Flap Motor (V212)
02600 - Rear Right Temperature Flap Motor (V314)
02598 - Rear Right Upper Body Vent Motor (V316)
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3001
   Coding: 0111837
   VCID: 479DA11E35952C261AD-5140
            007 - Short to Ground
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª8472
   Coding: 0060575
   VCID: 61C95F86BB717216F49-515E
                    Fault Frequency: 43
                    Mileage: 201274 km
                    Date: 2064.00.00
                    Time: 00:00:00
                    RPM: 672 /min
                    Voltage: 11.25 V
                    Bin. Bits: 00001011
                    Bin. Bits: 00000000
                    (no units): 0.0
                    Fault Frequency: 43
                    Mileage: 201274 km
                    Date: 2064.00.00
                    Time: 00:00:00
                    RPM: 672 /min
                    Voltage: 11.25 V
                    Bin. Bits: 00001011
                    Bin. Bits: 00000000
                    (no units): 0.0
005176 - EGR Valve 2 (N213)
               P1438 - 000 - Open or Short to Ground - Intermittent
                    Mileage: 206473 km
                    Date: 2064.00.00
                    Time: 00:00:00
                    RPM: 189 /min
                    Lambda: -5.1 %
                    Mass Air / Rev.: 855.0 mg/str
                    Mass Air / Rev.: 350.0 mg/str
                    Bin. Bits: 00000000
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H02 0562
   Revision: BB38727     Serial number: 0010170?
   Coding: 0012341
   Shop #: WSC 25053 444 59338
   VCID: 285F02A298CBC35EF37-515E
   Subsystem 1 - Part No: 7L0 959 339 E
   Component: BF-Gewichtsens. 007 0009
   Part No: 7L6 953 549 H
   Component: Lenksäulenmodul     3401
   Coding: 0010032
   VCID: 4487B61204A3073EFFF-515E
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0005231
   VCID: 489FA222388B235E137-5140
02053 - Control Module for Transfer Case (J646)
01517 - Control Module for Trailer/Towing Sensor (J345)
Address 18: Aux. Heat        Labels: Redir Fail!
   Part No: 7L6 815 071 D
   Component: Standheizung E1MAC
   Coding: 0000100
   VCID: 3365E5CE510DB086565-515E
02251 - Heater Unit Locked
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: F0EFAAC2E09B4B9EEB7-5140
   Subsystem 1 - Part No: 6N0 909 901
No Faults Found
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 4581AB160F993E36E81-5140
   Subsystem 1 - Part No: 7L6 919 879 A
No Faults Found
   Part No: 0AD 927 755 AT
   Component: TRANSFERCASE        0114
   VCID: 8D11D33697690676601-5140
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: E6C3CC9AD25F952E81B-515E
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 3663DCDA427FA5AE71B-515E
01780 - Sensor for Vehicle Leveling
   VCID: F7FD91DE85F51CA62AD-515E
   Subsystem 1 - Part No: 7L0 959 760
No Faults Found
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 M
   Component:      Navigation     0047
   Coding: 0000101
   VCID: 50AF8A42C0DBEB9E4B7-515E
   Part No: 3D0 909 158
   Coding: 0000003
   VCID: E7DDC19ED5558C26BAD-515E
   Part No: 7L0 959 933 J
   Component:    HSG              5115
   Coding: 0000085
   VCID: 4385B50E01AD0006C65-4B1A
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Subsystem 4 - Part No: 7L0 959 704 D
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 E
   Component:        Radio        0047
   Coding: 0014472
   VCID: 3561DBD65F79AEB6781-515E
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C77CEF27C537FFE87F-5140
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 31414
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J670048
   Coding: 0000101
   Shop #: WSC 25053 444 85538
   VCID: F2EBA0CAEE97798E1D3-5140
03006 - Back-up Camera System not calibrated
                    Reset counter: 118
                        Invalid
                        Invalid
                        Invalid
03008 - Supply Voltage for Back-Up Camera
                    Fault Frequency: 38
                    Reset counter: 233
                        Reverse OFF
                    Count: 3
02203 - Audio / Video Input 1
                    Fault Status: 00101011
                    Reset counter: 236
                        Reverse OFF
                    Count: 3
                    Reset counter: 236
                        Reverse OFF
                    Count: 3
Address 6E: Ctrl Head Roof        Labels: 7L6-919-044.lbl
   Part No: 7L6 919 044 T
   Component: DACHDISPLAY         0539
   VCID: 489FA222388B235E137-515E
   Subsystem 1 - Part No: 7L6 919 044 T
No Faults Found
Address 76: Park Assist        Labels: 3D0-919-283.lbl
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 3979D7E673614AD69C9-5140
This is an a first-generation T'Reg. It has no Long Coding. :D
Start by going to 19-CAN Gateway and recode it with the value that's already there, 0000006. Once that's done, exit the module gracefully and then turn the ignition off for a bit and back on. This causes that Gateway to rebuild its internal list of modules that are installed based on what modules it actually finds.
Flaps10
C?ID=219700
Our Touareg came with a trailer hitch and trailer brakes. I was nothing short of dumbfounded when it popped up on the MFD to tell me to check the trailer brake lights.
Unrelated to the direct topic but the Touareg is a great vehicle. Super comfy and capable. Love the ballsy V8. The only issue on the horizon is the (well documented) hard shift from 4-5 (and occasionally 5-4). It really doesn't do it often and if you watch the shift indicator on the MFD for the pending gear change and just don't be hammering it when it happens it shifts perfectly.
We're ordering the valve body assembly on Friday. Should put it to rest.
Love the ballsy V8.
Had one of those about 10 years ago when they were brand new (we learned a lot from it). Didn't love the fuel consumption. Best we ever got was 18 and 12-15 was more typical.
The OP's V10 TDI has about the same HP as your V8 plus about 60% more torque. :cool:
N867LC
Texas
C?ID=199170
Thanks Uwe!
I'll do the graceful reset on 19-CAN gateway and post the results. Is there anything else I should do or be looking for afterwards?
Sidenote to the above: I enjoy watching people here in Texas (F350's, 3500's, etc) see me jerk a 10,000lb car trailer away like it wasn't even there with my "small" truck. Got to love that V10 torque!
Clear out all your faults after you do what I advised with the CAN gateway and then run another Auto-Scan so we can see what (if anything) is still unhappy.
N867LC
Texas
C?ID=199170
Uwe,
Here is the scan after clearing.
Friday,05,September,2014,20:39:38:14552
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
Mileage: 208820km-129754mi   Repair Order:
VIN: WVGPT77L06D054863   Mileage: 208820km/129754miles
   Coding: 0060575
   VCID: 61C95F86BB717216F43-5140
   Coding: 0004200
   VCID: 7F0DF9FE2DC5A4E6E27-5140
   Coding: 0022786
   VCID: 3D71C3F6674976F6B0B-515E
   Coding: 0131304
   VCID: F0EFAAC2E09B4B9EEBD-515E
   VCID: F7FD91DE85F51CA62A7-5140
No Faults Found
   Coding: 0020030
   VCID: 4581AB160F993E36E8B-515E
8 Faults Found:
02599 - Rear Left Temperature Flap Motor (V313)
02597 - Rear Left Upper Body Vent Motor (V315)
00362 - Rear Left Air Flap Motor (V239)
   Component:                     3001
   Coding: 0111836
   VCID: 479DA11E35952C261A7-515E
   Coding: 0060575
   VCID: 61C95F86BB717216F43-515E
   Coding: 0012341
   VCID: 285F02A298CBC35EF3D-5140
   Coding: 0010032
   VCID: 4487B61204A3073EFF5-5140
   Coding: 0005231
   VCID: 489FA222388B235E13D-5140
Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
   Coding: 0000100
   VCID: 3365E5CE510DB08656F-5140
   Coding: 0000006
   VCID: F0EFAAC2E09B4B9EEBD-5140
   VCID: 8D11D3369769067660B-515E
   Coding: 0000003
   VCID: E6C3CC9AD25F952E811-5140
   Coding: 0015521
   VCID: 3663DCDA427FA5AE711-5140
02332 - Position Sensor for Backrest Adjustment (G440)
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
01915 - Lumbar Support Height Adjustment Sensor (G374)
   Coding: 0000101
   VCID: 50AF8A42C0DBEB9E4BD-515E
   Coding: 0000003
   VCID: E7DDC19ED5558C26BA7-515E
   Component:    HSG              5115
   Coding: 0000085
   VCID: 4385B50E01AD0006C6F-4B1A
   Coding: 0014472
   VCID: 3561DBD65F79AEB678B-5140
   Coding: 0000341
   VCID: 3C77CEF27C537FFE875-5140
   Coding: 00208933
   Shop #: WSC 31414
   Coding: 0000101
   VCID: F2EBA0CAEE97798E1D9-5140
                    Reset counter: 118
                        Invalid
                        Invalid
                        Invalid
                    Fault Frequency: 59
                    Reset counter: 31
                        Reverse OFF
                    Count: 3
                    Reset counter: 22
                        Reverse OFF
                    Count: 3
                    Reset counter: 22
                        Reverse OFF
                    Count: 3
   Revision: 00900539    Serial number: 2009289.07
   VCID: 489FA222388B235E13D-515E
   VCID: 3979D7E673614AD69C3-5140
Hmm, do you have a bad connection somewhere?
   Coding: 0000006
N867LC
Texas
C?ID=199170
Hmmm...
I checked all the fuses (both modules), all good. I've looked for a way to test the modules (my Bentley CD), but not had any luck there. It may be module replacement time.
Any other ideas?
Yeah, it could be a flaky module. But it could just as easily be a bad connection somewhere. This is an 8-9 year old vehicle. Time and weather can take their toll on electrical connections. I'd pull apart, inspect, and condition all connections between the cluster (where the Gateway is located in this vehicle) and the transfer case and the trailer module before I threw money into any new modules.
N867LC
Texas
C?ID=199170
I'm ripping panels out now to check on connections and I'll pin everything I can out. This vehicle as you said is 8-9yrs old now, but it has been hangered it's entire life (no outside parking) so I'm sure if I do have any corrosion it should be minor. The truck wasn't driven hardly at all the last two years (bought a 911 4S) so it sat in the hanger more than it had in the past.
The towing module is the Westfalia that Bentley says needs to be coded. Can we do that in Vag-Com? Or should (after I check cabling) get a non-coded one?
The help and conversation is appreciated! I owe you a flight/ride in one of the other toys.
The trailer module itself doesn't show up in either of your scans. Until/unless it does, it can't be coded.
You've got a fork-tailed doctor/lawyer killer, right? I've never had a ride in one. Got a bit of time in a Mooney though, but that was a long time ago.
N867LC
Texas
C?ID=199170
Got it. I wasn't sure if we had to "turn on" the module first. I will say that these body panels and trim are so interconnected you can't just take one off...I may change the interior color, I'm that far into it now (grin).
Actually. My old Bonanza was a V35 fork-tailed doctor /lawyer killer. I upgraded to an A36 a few years go. Now I have 6 seats and air-conditioning. It is like a 200mph Touareg and I get 15mpg too, just like the egg! You can google my number (N867LC) and see the new bird.
How much does 100LL cost these days? When I was flying, you could still find it for under $2.00 a gallon sometimes. Needless to say, it's been a while.
N867LC
Texas
C?ID=199170
I remember fuel being under $2 as well. Right now 100LL is running about $4.75 - $5.50 a gallon. airnav.com can give you updated prices so I often will check there if I have to make a fuel stop.
Flaps10
C?ID=219700
Nice plane. The nicest flying plane I've ever had the pleasure of taking the controls was an A36. It had previously been owned by a higher up at Motorola. It had everything.
