My T-reg came with the hitch but no module. I bought the factory module and installed it, but didn't have Vag-Com at the time to get the PCM to see the module. I've since bought Vag-Com, but can not for the life of me figure out how to get the PCM to see the module and turn the module on so I have trailer lights.
Currently the running lights "strobe" and the brake light will work, but I have no turn signals. I've not been able to see the module no matter what I've tried. I recently read that I may need the Long Hex Code Helper, and could never find how to open it until last week. I have not had the chance to try the LHCH yet.
Sunday,27,July,2014,19:45:57:14552
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVGPT77L06D054863 License Plate:
Mileage: 206580km-128362mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L06D054863 Mileage: 206580km/128362miles
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG000AGMª8472
Revision: --H02--- Serial number: VWZ3Z0E6402710
Coding: 0060575
Shop #: WSC 31414 000 00000
VCID: 61C95F86BB717216F49-5140
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 000 - - Intermittent
Fault Frequency: 43
Mileage: 201274 km
Date: 2064.00.00
Time: 00:00:00
RPM: 672 /min
Load: 0.0 %
Voltage: 11.10 V
Bin. Bits: 00001011
Bin. Bits: 00000000
(no units): 0.0
005782 - Powertrain Data Bus
P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
Fault Frequency: 43
Mileage: 201274 km
Date: 2064.00.00
Time: 00:00:00
RPM: 672 /min
Load: 0.0 %
Voltage: 11.10 V
Bin. Bits: 00001011
Bin. Bits: 00000000
(no units): 0.0
005120 - EGR Valve (N18)
P1400 - 000 - Electrical Malfunction - Intermittent
Mileage: 206473 km
Date: 2064.00.00
Time: 00:00:00
RPM: 189 /min
Load: 0.0 %
Lambda: -5.9 %
Mass Air / Rev.: 770.0 mg/str
Mass Air / Rev.: 370.0 mg/str
Bin. Bits: 00000000
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 DP HW: 09D 927 750 DP
Component: AL 750 6A 0856
Revision: 00H37000 Serial number:
Coding: 0004216
VCID: 7F0DF9FE2DC5A4E6E2D-5140
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0022786
VCID: 3D71C3F6674976F6B01-515E
No Faults Found
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 HW: 5WK 484 92
Component: G2 Kessy 6700
Revision: 67005614 Serial number: VWZ3Z0E6402710
Coding: 0131304
VCID: F0EFAAC2E09B4B9EEB7-515E
Component: ELV XXXX
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Part No: 7L0 959 760
Component: Sitzverstellung 0701
VCID: F7FD91DE85F51CA62AD-5140
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 T
Component: CLIMAtronic 2+2 4222
Coding: 0020030
VCID: 4581AB160F993E36E81-515E
Subsystem 1 - Part No: 7L6 907 049 E
Component: CLIMAtronic FOND 0400
02379 - Positioning Motor for Left Side Vent (V299)
00064 - Left B-pillar/Footwell Shut-Off Flap Motor (V212)
02600 - Rear Right Temperature Flap Motor (V314)
02598 - Rear Right Upper Body Vent Motor (V316)
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3001
Coding: 0111837
VCID: 479DA11E35952C261AD-5140
01494 - Bulb for Parking Lamps; Left (M1)
007 - Short to Ground
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSª8472
Coding: 0060575
VCID: 61C95F86BB717216F49-515E
Fault Frequency: 43
Mileage: 201274 km
Date: 2064.00.00
Time: 00:00:00
RPM: 672 /min
Load: 0.0 %
Voltage: 11.25 V
Bin. Bits: 00001011
Bin. Bits: 00000000
(no units): 0.0
Fault Frequency: 43
Mileage: 201274 km
Date: 2064.00.00
Time: 00:00:00
RPM: 672 /min
Load: 0.0 %
Voltage: 11.25 V
Bin. Bits: 00001011
Bin. Bits: 00000000
(no units): 0.0
005176 - EGR Valve 2 (N213)
P1438 - 000 - Open or Short to Ground - Intermittent
Mileage: 206473 km
Date: 2064.00.00
Time: 00:00:00
RPM: 189 /min
Load: 0.0 %
Lambda: -5.1 %
Mass Air / Rev.: 855.0 mg/str
Mass Air / Rev.: 350.0 mg/str
Bin. Bits: 00000000
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H02 0562
Revision: BB38727 Serial number: 0010170?
Coding: 0012341
Shop #: WSC 25053 444 59338
VCID: 285F02A298CBC35EF37-515E
Subsystem 1 - Part No: 7L0 959 339 E
Component: BF-Gewichtsens. 007 0009
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010032
VCID: 4487B61204A3073EFFF-515E
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 R
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0005231
VCID: 489FA222388B235E137-5140
02053 - Control Module for Transfer Case (J646)
01517 - Control Module for Trailer/Towing Sensor (J345)
Address 18: Aux. Heat Labels: Redir Fail!
Part No: 7L6 815 071 D
Component: Standheizung E1MAC
Coding: 0000100
VCID: 3365E5CE510DB086565-515E
02251 - Heater Unit Locked
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0EFAAC2E09B4B9EEB7-5140
Subsystem 1 - Part No: 6N0 909 901
No Faults Found
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 4581AB160F993E36E81-5140
Subsystem 1 - Part No: 7L6 919 879 A
No Faults Found
Address 22: AWD Labels: None
Part No: 0AD 927 755 AT
Component: TRANSFERCASE 0114
VCID: 8D11D33697690676601-5140
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000003
VCID: E6C3CC9AD25F952E81B-515E
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 3663DCDA427FA5AE71B-515E
01780 - Sensor for Vehicle Leveling
VCID: F7FD91DE85F51CA62AD-515E
Subsystem 1 - Part No: 7L0 959 760
No Faults Found
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component: Navigation 0047
Coding: 0000101
VCID: 50AF8A42C0DBEB9E4B7-515E
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: E7DDC19ED5558C26BAD-515E
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 J
Component: HSG 5115
Coding: 0000085
VCID: 4385B50E01AD0006C65-4B1A
Subsystem 1 - Part No: 7L0 959 701 H
Subsystem 2 - Part No: 7L0 959 702 H
Subsystem 3 - Part No: 7L0 959 703 D
Subsystem 4 - Part No: 7L0 959 704 D
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Part No: 7L6 035 186 E
Component: Radio 0047
Coding: 0014472
VCID: 3561DBD65F79AEB6781-515E
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 000 376832
VCID: 3C77CEF27C537FFE87F-5140
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 31414
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J670048
Coding: 0000101
Shop #: WSC 25053 444 85538
VCID: F2EBA0CAEE97798E1D3-5140
Reset counter: 118
Invalid
Invalid
Invalid
03008 - Supply Voltage for Back-Up Camera
Fault Frequency: 38
Reset counter: 233
Term 15 On
Reverse OFF
Count: 3
02203 - Audio / Video Input 1
Fault Status: 00101011
Reset counter: 236
Term 15 On
Reverse OFF
Count: 3
Reset counter: 236
Term 15 On
Reverse OFF
Count: 3
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
VCID: 489FA222388B235E137-515E
Subsystem 1 - Part No: 7L6 919 044 T
No Faults Found
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 3979D7E673614AD69C9-5140
