5F (Discover Pro Gen2) coding Comfort Telephone (Qi charger + signal booster)
MasterTommy
Amsterdam
C?ID=295586
Hey guys,
Retrofitting the Qi charger in the compartment in front of the shifter, and the two-way amplifier this connects to in the rear of the vehicle.
Both charger (5NA980611) and two-way amplifier (4N0035456) are connected as follows:
- Antenna cabling between charger, signal booster and roof aerial.
- Power from fuse 16 for both devices
- Shared ground
- Closed databus between Qi charger, signal amplifier and discover pro.
I already have the business Phone preparation which is basically a RSAP enabled carkit and a SIM card slot in de discover pro unit for a permanent internet connection. Unfortunately it doesnt have any nice stuff for when you use your phone without RSAP (which I usually do), and i couldn't order both from the factory. Thats why i'm retrofitting the basic/comfort Phone preparation as well.
Seeing as both devices i'm adding are only connected to the Discover pro and not to the gateway, the only coding I need to do (I assume) is in the 5F unit. I only found 1 bit regarding 'wireless charging availability, installed'in the experimental coding for the 5F unit. Is there anything else i need to code?
Maybe somebody has an autoscan of the 5F unit with the comfort Phone kit installed and also a Discover pro Gen 2?
Autoscan below.
Thanks!
Friday,15,September,2017,23:35:55:41109
VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4401.4
VIN: WVGZZZ5NZJW000000   License Plate: AB-123-C
Mileage: 298km-185mi   Repair Order: 12345
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C
          42 44 47 4B 52 5F 69 6C 6D 75 82 A5 BB BC CA CF D6 D7
VIN: WVGZZZ5NZJW000000   Mileage: 298km-185miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
   Part No SW: 03N 906 026 D    HW: 03N 907 309
   Component: R4 2.0l BTD   H24 3680
   Revision: A1H24---
   Coding: 01250032047605083000
   ASAM Dataset: EV_ECM20BTD01103N906026D 004005
   ROD: EV_ECM20BTD01103N906026D_004.rod
   VCID: 2C14C9DD47ABA22606-8078
Readiness: 0100 0010
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0DL 300 011 M    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2001
   Revision: 00H06V07
   VCID: 3228D7A5658FF4D64C-8066
   Revision: 00000000    Serial number: 62057000001070
   Coding: 0AEE6B9A54220B744779070762C66950D62AD0E2E046967DB86250F8C2AA4200002F641A1B13111435351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 77BE26B1CE6DD1FEBB-8022
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0451329535
   Coding: 132C2C0723
   VCID: 3E30F395A1D720B6B8-806A
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98226912
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QGM20164
   Coding: 0010000000000500818281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide_VW37.rod
   VCID: 3C34F99DB7CB32A696-8068
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000B00605887
   Coding: 0002012420241001110510020010112A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 4AD8AF45ED1F9C1614-801E
   Subsystem 2 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001721700533
   ROD: EV_BCMBOSCH_018.rod
   VCID: 095A5049A899D70EDD-805C
   Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170630  033 0372
   Serial number: 00000001706280300593
   Component: RLHS  042 0105
   Serial number: S8Y17M08D14H01M31S46
   Coding: 00A8EE
   Serial number: 000000000ZY1718333XN
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223971734394
   Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0029
   Serial number: 001607177478001
   Coding: 0A31667A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000_VW37.rod
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H02 0233
   Coding: 320067CB5CFF8728749C8145804087
   Serial number: 12071741350391
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383CE58D83F31E8672-806C
   Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
   Serial number: 003VXR33ZYC9
   Coding: 98FCC0C00C8000005C5400CF004800000065
   VCID: 0A586F45AD9FDC16D4-805E
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 5NB857705C0216R00777
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 5NB857706C0217R00515
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 35700000000B2B19A62O
   Subsystem 4 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 35800000000156842728
   Subsystem 5 - Part No SW: -----------    HW: 480 400 208 17
   Serial number: 3510001BB260B4F1B4BB
   Subsystem 6 - Part No SW: -----------    HW: 480 402 807 17
   Serial number: 3520001A524CDB11F48B
   Subsystem 7 - Part No SW: -----------    HW: 480 402 907 17
   Serial number: 3550001C322EA2B5730%
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B526D7C0386BB
   Subsystem 9 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001B526D7C0475EE
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001B526D7C04615Z
   Subsystem 11 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: I0M00000000D91C0252+
   Subsystem 12 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: I0N000000002A1C0252W
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170802501343
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 73A612A1DA15BDDE87-8026
   Part No SW: 5NA 920 791 B    HW: 5NA 920 791 B
   Component: KOMBI         407 3193
   Coding: 07A400187F88000801886B0B3401000880000000
   VCID: 42C88765D52F4456DC-8016
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 23071710800155
   Coding: 0B0500344F017300FB07225E9E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3326D2A19A95FDDE47-8066
   Serial number: 29170001574160027313
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5QA 915 181 E    HW: 5QA 915 181 E
   Serial number: 4480423804
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 F    HW: 5Q0 907 155 F
   Component: U13DCAC  H25 0780
   Serial number: 0024537
   Serial number: HA1-00020.06.17
   Coding: 0101
   ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C29C79C401736EF9-8010
   Serial number: 17000199457001
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71AA18A9A0098FCE75-8024
   Serial number: Y0006QGM20144
   Coding: 0010000000000500018281808181000000008181000000F400
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 39: Right Light (J1023)       Labels: None
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 14C002
   VCID: 3A38FF85BDFF0C9684-806E
   Serial number: 080717EG809145
   Coding: 003F1B20D200048000001000
   VCID: 43C68261CA354D5ED7-8016
   Part No SW: 5QF 909 144     HW: 5QF 909 144 _
   Component: EPS_MQB_ZFLS  506 5572
   Coding: 9307
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 075E5671BE8DA17ECB-8052
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00TYB7
   Coding: 1223060001A00A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   VCID: 6B960AC18225651E4F-803E
   Serial number: 21071710803739
   Coding: 000000050100085207104F010A0000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_VW37.rod
   VCID: 72A817A5A50FB4D68C-8026
   Serial number: 070717EG609369
   Coding: 003F1120DE00048000001000
   Part No SW: 5NA 035 022 A    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1121
   Serial number: A846G0HS006021
   Coding: 02730601000000005111010200880A101F0106E401200400DE
   VCID: 312AD8A96089CFCE35-8064
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2116065
   Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
   Component: ECE 2017  --- 0157
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0449274529
   Coding: 0100000202000000
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG016316
   Coding: 01230600A30F200000204814
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   VCID: 393AE089B8F9078E8D-806C
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31450492700000
   Coding: 0AA8
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0717
   Revision: --------
   Coding: 02230601EA42380D3F1CBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   Part No SW: 5NA 919 608 B    HW: 5NA 919 608 B
   Component: HeadupDisplay 023 0302
   Coding: 564060
   ASAM Dataset: EV_HeadUpDisplContiVW481 001015
   ROD: EV_HeadUpDisplContiVW481.rod
   VCID: 47DE9671FE0D617E0B-8012
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 29071712K20584
   Coding: 000307060000040100262347C150A90088000E200040
   ROD: EV_MFKBoschMQBB_VW36.rod
   Serial number: 120717EG908013
   Coding: 002A11200101048000001000
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Serial number: 190617EFJ09168
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
Address CA: Sunroof (J245)       Labels:* None
   Coding: 208040732602
   ROD: EV_SunRoofCONTIAU736.rod
   VCID: 3D32F499ACD13BAEA1-8068
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   VCID: 373EE6B18EED11FE7B-8062
   VCID: 16600B35E92708F640-8042
End----------(Elapsed Time: 02:34, VBatt start/end: 12.5V/12.5V)-----------
hadez16
C?ID=289891
Could you, for a better understanding, describe what does not work so far? Respectively what is the expected result after successful coding?
MasterTommy
Amsterdam
C?ID=295586
Made a temporary set-up with the charge pad hooked up to everything, coded the 5F infortainment unit with said bit, but unfortunately didnt get it to work yet.
Edit: As in; the infotainment unit doesnt give a charge notice on the screen. It should do that according to the manual.
MasterTommy
Amsterdam
C?ID=295586
Seems the new 17.10 beta added a lot of new adaptation channels in the 5F unit, a lot of which refer to wireless charging.
Does anybody have the long coding and an adaptation channel map of the 5F unit from a Tiguan with comfort telephone installed (PR-9IH or PR-9IJ)? Would have to be an admap with VCDS 17.10 unfortunately....
MasterTommy
Amsterdam
C?ID=295586
These are the adaptation channels i'd love to have a comparison from (value in bold):
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192 (this one has about 20 possible options)
IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging,not activated ,60
IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer,not activated ,60
IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off,not activated ,60
IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high,not activated ,60
IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill,not activated ,60
MasterTommy
Amsterdam
C?ID=295586
Autoscan of an MQB car with this option maybe? Should show an extra module, or at least thats what i suspect.
If i enable this one:
Module 'DE-phone charger' appears in the control unit list, which cant be reached.
This one:
Is probably the problem. Possible values include:
Comfort Can
Suspension Can
Infotainment Can
Extended Can
Flexray Bus
MIB_CAN
Kombi_CAN
Hybrid_CAN
Comfort 2 Can
CAB_01 through CAB-29
etc.
The charging unit is hooked up according to the factory diagram to pins 5 and 11 of the gray connector on the MIB2 unit.
MasterTommy
Amsterdam
C?ID=295586
Couldn't get it to work unfortunately. the 0x48_msg_bus is set up as CAB_9 on skoda's when devices are hooked up to t12g/3 and t12g/9. But I have no way of determining the correct setup of that channel when a device is hooked up to t12g/5 and t12g/11. Unfortunately there are zero autoscans to be found of MQB vehicles made with VCDS 17.10, and earlier versions dont show the necessary adaptation channels.
Tried every combination i could think of, even turning on node 0x48 in the CAN gateway, but zero effect. I also couldnt find any channel to maybe see which pins are what or diagnose all databus connections of the MIB2, and I dont even know if the charge module is supposed to be showing up on an autoscan (no communication with that module anyway).
So pulled the fuse and going to try again when there is more data available. :) Also trying ODIS next week.
GaSelle
C?ID=266649
We´re still waiting for the exciting news, MasterTommy :)
AndySwede
Stockholm Sweden
C?ID=172802
I would like to do the same retrofit on my Tiguan AD1 so the part numbers should be useful.
MasterTommy
Amsterdam
C?ID=295586
Sorry for the delay :)
Partnumbers are under group 0 in the ETKA, parts for telephone system. PR codes PR-9IH/9IJ.
In the case of a Tiguan AD, you will need:
- Center console (which has a slot for the charging interface) 5NB863241D suffix RM5 of 82V (dealer can tell you which color you have) (LHD model)
- Phone/charging interface 5NA980611
- Two-way amplifier 4N0035456 and two plastic fasteners N90536901
- Contact housing amplifier 8E0971832
- Contact housing phone interface 4B0971978B
- Contacts for both contact housings and the pins that go into the MIB unit are the same. I used the TE 963715-1 ordered from Digikey which is the original connector also used by VW. You will need a suitable crimp tool for 0,5mm contacts which can be a pain to find though. Alternatively you can used VW's repair wires which you solder onto the colored wires, you'll need 11 of those then. The dealer can tell you which repair set wire you need when looking up one of the contact housings.
- Fakra connectors, coax cable and crimp tool, or prefab cables from the ETKA with universal connectors on them.
- Fancy tape to wrap your additional wiring and to fix this to the existing loom, used some BMW tape i had laying around which is the same as the one used on the VW wiring loom. Do not use cheap isolation tape and DEFINITELY DO NOT use zipties. Most wires in the wiring loom are 0,35mm and zipties will damage these
I wanted to keep it OEM style and all factory style antenna positions were already taken (roof aerial for SOS module and both LTE antenna's behind the rear bumper for the discover pro's SIM card) so I ordered another LTE antenna 3G9035534 and made a bracket and mounted it next to the rear right antenna behind the rear bumper. I had the bumper off for retrofitting the TPMS module anyway.
Ordered some 0,5mm wire in the same colors as used OEM. Also ordered a fakra crimp tool, RTK031 coax and a shitload of color coded plugs. Not really reasonable for the one time retrofit, but i had the RNS510 in my previous car stolen a couple of times and the way most repair shops do some tearjerking job with repairing those fakra connections sucked, and i decided to get the real stuff. The tool set me back a whopping €500 but even my local dealer has asked me to pass by to perform a quality repair on a vehicle with a stolen radio two times now. So it's on its way to paying for itself hahaha. Anyway, got the tool from Quaestum, but there are also prefab cables in the ETKA (in the vehicle list, select EL = Elektrische Verbindungselemente).
Anyway, so:
- LTE antenna behind rear bumper. If you lack the premium phone kit or the SOS module, either the LTE antenna '2' (rights side behind rear bumper) is missing, or the roof aerial lacks a phone connection. In either case you can mount the LTE antenne in its OEM spot behind the bumper or swap out the roof aerial for one with a phone connection and use that.
- Amplifier behind right luggage compartment cover.
- Swap out center console (remove old one and then pull wiring before installing new one).
- Insert interface
- Between doing all this pull wiring.
Wiring:
Amplifier:
- pin 1: Power. 0,5mm red/blue to fusebox (interconnects with the same colored wire from the interface)
- pin 2: Ground. 0,5mm brown to ground (i connected it to a bundle of ground wires in the loom near the amplifier)
- pin 3: Power on signal from infortainment unit. 0,5mm yellow/red to grey connector (inside quadlock connector) on infotainment unit pin 5 (interconnects with the same colored wire from interface)
- black fakra connector on amplifier to violet fakra connector on phone interface
- violet fakra connector on amplifier to violet fakra connector on LTE antenna
Interface:
- pin 1: Power. 0,5mm red/blue to fusebox (interconnects with same colored wire from amplifier)
- pin 2: Power on signal from infotainment unit. 0,5mm yellow/red to grey connector on infotainment unit pin 5 (interconnects with same colored wire from amplifier)
- pin 3: Data/LIN bus from infotainment unit. 0,5mm yellow/blue to grey connector on infotainment unit pin 11
- pin 4: Ground. 0,5mm brown to ground (i used another bundle of ground wires near the bottom of the A-pillar)
- pin 5: No idea what it does. 0,5mm white to 73-pin plug B pin 14 on BCM (this pin is already in use if you have keyless access. in that case this goes to the Kessy control unit. Strip a piece of isolation and connect to existing wire.)
- violet fakra connector on interface to black fakra connector on amplifier
If you dont need the connection to the external antenna, you could also skip the whole amplifier and antenna part and just hook up the interface.
For the install I removed the following (and not necessarily in this order, check the manual):
- Lightswitch
- Lichtswitch panel
- Steering column housing
- Knee airbag unit
- Instrument cluster trim panel (needs to go before you can remove infortainment trim)
- Infotainment display unit trim panel
- Infotainment display (pulled the wires behind this to the fusebox)
- Infotainment control unit in storage compartment
- Dashboard storage compartment as a whole
- All floor panels on the right side from bottom A-pillar to the rear luggage compartment cover right
- Side panels of the centre console
- A/C control trim panel and the controls themselves
- Shifter trim panel
- Button unit in center console
- Rear A/C controls
- Airduct behind rear A/C controls
- Centre armrest
- Rear-right seat cushion
And a lot of other stuff i might be forgetting. I'll write up a more detailed how-to later on but no time at the moment.
Coding is pretty easy.
Unit 5F Information electronics
Coding
Experimental coding > yes
Byte 15
Activate the following bits:
- bit 0 Baseplate
- bit 1 Antenna_baseplate (or don't if you skipped the signal amplifier and antenna part)
- bit 5 Wireless_charging_availability
Exit long coding screen, check the 'soft reset' checkbox and do it.
Oh, by the way. To ross-tech i'd suggest incorporating these bits in the non-expirimental coding screen. Suggested description would be:
- Bit 0: Phone Baseplate Installed (PR-9IF/9IG/9IH/9IJ/9IK/9IL/9IN/9IP)
- Bit 1: Baseplate With Antenna (PR-9IF/9IG/9IH/9IJ/9IK/9IL/9IP)
- Bit 5: Baseplate With Wireless Charger (PR-9IH/9IJ/9IN/9IP)
So thats it, sorry for the incomplete info but i'm writing this down mostly from memory.
I'll add some pictures tomorrow.
Enjoy.
GaSelle
C?ID=266649
My Superb (3V5) came with the "signal amplifier" from the factory. Could I then just swap out the insert in the center console for a model with "signal amplifier" AND QI charging (which of course needs to be wired)?
MasterTommy
Amsterdam
C?ID=295586
I cant think of a reason why not, assuming the slot is the same. But there are enough images to be found on google.
You would need to test if the pin 5 connection to the BCM is needed, and if it is, figure out if and how plug B/pin14 is wired now (or could be wired in a full option car) and if it resembles anything like the VW’s.
GaSelle
C?ID=266649
The slot is the same, since QI charging is available as an option for MY17 (mine is MY16). My car does not have KESSY, so I would assume the slot on the BCM is free at the moment. I will keep an eye out on eBay if anything interesting shows up :)
MasterTommy
Amsterdam
C?ID=295586
If its available as an option on your car, then anything i said about wiring pinout (apart from the interface side, thats probably the same) is irrelevant and you should check the wiring diagram.
darkchina811
ITALY
C?ID=333184
I have taken inspiration from this thread and retrofitted the baseplate for the phone into my Golf, which fits into the armrest storage compartment. the concept is the same, it has the antenna amplifier but no wireless charging.
honestly I did not use the OEM antenna, instead I bought a generic 4G/LTE antenna meant to be sticked on the windshield with double sided tape. well, I am now left with a "Telephone Antenna - Electrical Failure" error when scanning the car.
I am now wondering where the problem could be. is it the baseplate? is it the amplifier? is the electronics so cool that it can somehow detect that the antenna is not the stock one?
siLc
Tallinn, Estonia
C?ID=330192
How did you code/adapt 5F for the baseplate? I have this baseplate and amplifier wired up to the 5F but no antenna connected yet (original sharkfin waiting for install). I've only coded it in 5F as a Drive2 article instructs but as there is no appropriate DTC in my unit, I'm suspicious it would rather need adaptation changes - which (if any) did you change?
darkchina811
ITALY
C?ID=333184
byte 15
bit 0 ON
bit 1 ON
no adaptations needed...
MasterTommy
Amsterdam
C?ID=295586
As far as i know, the antenna amplifier and the amplifier with QI charging fit the same slot, so if i had a car with none of these, i would go for qi charging as well...
darkchina811
ITALY
C?ID=333184
they don't, at least not in the Golf.
5G0 980 611 (antenna only) goes into the armrest, while 5NA 980 611 (also charging) should go under the forward console compartment, but not under mine. I bet the compartment is different when buying the option from the factory.
