- Oct 17, 2017
- 8
- 3
- Saudi Arabia
- C?ID=309979
Audi A8L W12 night vision camera VCDS collaborations.
Greetings,
I hope this massage finds you all well and in great health. My name is Dr. Tariq. I am the proud owner of a 2012 Audi A8L W12. The car is fantastic! about 3-4 months ago the germanium lens on the night vision thermal camera gone completely bad so it was replaced with a new one(from a sniper rifle) . here is the thing I have a VCDS and I wanted to see if i can turn on or change the value for the pedestrian detection ( the temp. range to be exact since its hot here ) but ended up going into basic settings and running the reset all function for the camera. Now I have lost the basic setting for it see the error code:
A quick search told me that I need to re-collaborate the camera. I am living in the kingdom of Saudi Araba. so I went to the only Audi dealer in the country to try and do this only to find that they don't and will not even think of buying the tools to do the job....what a good dealer eh. so i am here trying to reverse my bad and i am here asking for help.
I wanted to see if we can code it (security access is needed) or do something to bypass this problem. I am welling to part ways with anything as long as it turns on and no triangle error pops up for me.
Many many thanks in advance.
Will Post a complete auto scan later. I only posted 84 night vision.
Greetings,
Tuesday,17,October,2017,09:38:36:43208
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WAUR4B4H9CN008772 License Plate:
Address 84: Night Vision Labels: 4H0-907-547.CLB
Control Module Part Number: 4H0 907 547 E HW: 4H0 907 547
Component and/or Version: NV-ECU-Gen1 H09 0028
Software Coding: 1200
Work Shop Code: WSC 02311 785 00200
ASAM Dataset: EV_NightVisioGen1 001002 (AU64)
ROD: EV_NightVisioGen1.rod
VCID: 313C1DC101A3D60FE44-8064
1 Faults Found:
4107 - No Basic Setting
B2010 00 [009] - -
Reset counter: 63
Mileage: 187451 km
Date: 2017.10.17
Time: 09:37:51
Voltage terminal 15: 14.0 V
Image processor: temperature: 61 °C
Adjustment malfunction: Not adjusted
