In 001 output tests I'm stuck at the Start/Next bar. Whining sound activates under hood but never stops as I click thru the sequence of tests. There is no report of pass/fail or any change in the Start/Next bar. I believe I read outputs are done with engine off?
Related details:
Readiness looks to be set even tho I do not believe the SAI pump is functional. How can that be?
I'm awaiting a new Pressure Retention Valve which I believe to be related to 16825 and difficult starting after refuel, so the codes predate that. Cleaned the MAF per Jack as well
Related details:
Address 01: Engine Labels: 022-906-032-AXK.lbl
Control Module Part Number: 022 906 032 AF
Component and/or Version: MOTRONIC ME7.1 G 0003
Software Coding: 00003
Work Shop Code: WSC 27441
VCID: 4FA6E5278D5AAD66527-5120
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-10 - Performance too Low - Intermittent
16523 - Oxygen (Lambda) Sensor B1 S2
P0139 - 35-00 - Response too Slow
16825 - EVAP Emission Control Sys
P0441 - 35-10 - Incorrect Flow - Intermittent
Address 02: Auto Trans Labels: 01P-927-733.lbl
Control Module Part Number: 01P 927 733 CG
Component and/or Version: AG4 Getriebe 01P 4893
Software Coding: 00000
Work Shop Code: WSC 00000
VCID: 7AF064F36658D8CED59-095C
01192 - Torque Converter Lock-Up Clutch
04-10 - Mechanical Malfunction - Intermittent
Address 02: DTCs cleared
Address 01: DTCs cleared
