Results 11 to 20 of 22
Thread: Audi A6 4G Facelift 2016 Led Matrix headlights retrofit
    Jan 2016
    Australia
    Quote Originally Posted by peng shun jiang View Post
    Friend I can help you
    If you can help, post something useful. Saying you can help, isn't useful...
  2. Likes Uwe, PetrolDave liked this post
  3. #12
    Dec 2018
    Romania
    Hello, somebody is willing to share the codding/procedure information for this retrofit?
  4. #13
    Nov 2014
    here is scan of my a6 2014 which was retrofitted with the 2015 led front and rear lights, i had it done by someone as i was not capable of the task..
    Monday,25,December,2017,15:57:21:29062
    VCDS Version: 17.8.0.1
    VIN: WAUZZZ4G8EN103926   License Plate: R15WNE 25.12,17
    Mileage: 112427km-69858mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F
              62 6D 72
    VIN: WAUZZZ4G8EN103926   Mileage: 112427km-69858miles
    Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 Q    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H41 0002
       Revision: 53H41---
       Coding: 12254012052601020000
       ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
       ROD: EV_ECM30TDI0114G0907401Q.rod
       VCID: 316C99676058DCCE35-8064
       Part No SW: 4G2 927 156 P    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H02 0003
       Revision: --H02---
       Coding: 000001
       ROD: EV_TCMDL501021.rod
       VCID: 3B70BB4FB214269E9F-806E
       Coding: 27A69F01E465F980DB00
       VCID: 3A7EBE4BBD2E1F9684-806E
       Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0521
       Coding: 01B93046000000000000
       VCID: 79FC6147F0A8D48ECD-802C
       Serial number: 0213000389021006
       Part No SW: 4G0 820 043 AJ    HW: 4G0 820 043 AJ
       Component: KLIMA 2 ZONEN H14 0094
       Serial number: 14121300110442
       Coding: 3622000821
       ASAM Dataset: EV_AirCondiBasisUDS 004002
       ROD: EV_AirCondiBasisUDS_004.rod
       VCID: 67D8373F9E1C527E2B-8032
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 34
                        Mileage: 112427 km
                        Date: 2017.12.25
                        Time: 15:51:45
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 11.0 °C
                        Temperature after evaporator: 8.92 °C
                        Engine speed: 220 /min
       Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
       Revision: 19012002    Serial number: 00000001815055
       Coding: 2600A01040349FE001810080000005040F9DC70807080301000004206000
       VCID: 6DD44517B4E0782E51-8038
       Component: WWS57X 131208  H36 0080
       Serial number:         131209210342
       Coding: 0045F7
       Serial number: 22105522
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 09 12 2013  00000832
       Serial number: A77843E6000000000001
       Revision: 11001001    Serial number: 61061335601495
       Coding: 08C308
       VCID: 71EC5967A0D89CCE75-8024
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Revision: --------    Serial number: 003JG00G56VA
       Coding: 3032343631334E303537554A305234473053
       VCID: 3666AA7B8936FBF660-8062
       Serial number: 3575HRB40692ATKIAHUF
       Serial number: 3585HRB405P2AIFU6PNO
       Serial number: 3515JRB401E50PQ2GGPX
       Serial number: 3525JRB400O50PQ2IPG2
       Serial number: 3554VRB404V2FD2ML1C+
       Serial number: 3564VRB404V2FD2M7OB7
       Revision: 00000000    Serial number: 20140109000202
       Coding: 000035
       VCID: 306A9C636352D5C63A-8064
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
       Component: MDieGb        H43 0411
       Revision: 27450259    Serial number: 658281113592037
       Coding: 23A710000B412600010000
       ASAM Dataset: EV_RBC7KMID 004048
       ROD: EV_RBC7KMID.rod
       VCID: 3F88CF5FA60C3ABEB3-806A
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001222074
       Coding: 00CD077D00
       ROD: EV_GatewPkoUDS_001.rod
       VCID: 72EE566BA5DEA7D68C-8026
       Serial number: 3620501903
       Voltage stabilizer:
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA7207NAXX
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3360936F9A44EEDE47-8066
       Coding: 011C16004001620002080002
       VCID: 4798D7BFF6DC727E0B-8012
       Component: RCEPS         H39 0010
       Revision: 00001000    Serial number: 0004118059
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 326E966B655EE7D64C-8066
       Revision: 00002001    Serial number: 0322466267
       Coding: 013F0622A0B930008320090400010F470000000000000000000000000000
       Revision: CJ007001    Serial number: 00000000061327
       VCID: 1D3455D704C048AE81-8048
       Coding: 011C16004401620002080002
       VCID: 4686DABBF1D66B76F0-8012
       Revision: --------    Serial number: 00000001583618
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 2D5485177C60B82E11-8078
       Serial number: 140106-0002-002
       Coding: 1122A6101000A300
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G0 035 192 P    HW: 4G0 035 192 F
       Component: RMC Nav Plus  H54 0818
       Coding: 0101010101415B47082B060301020100000001
       VCID: 2F689F1F7E6CCA3E23-807A
       Subsystem 1 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464K+0D2642347
       Subsystem 2 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
       Serial number: 90349MLA000BH
       VCID: 499CD187E0C8840E1D-801C
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 351301238
       Coding: 097205C010
       ROD: EV_HDSGAu571.rod
       VCID: 3564AD779430F0EE69-8060
    End-------------------------(Elapsed Time: 04:21)--------------------------
  5. #14
    Nov 2014
  6. #15
    Dec 2018
    Romania
    Do you have a scan before this retrofit, to compare the differences?
    Thanks.
  7. #16
    Nov 2014
    here is scan before retrofit...
    Wednesday,23,August,2017,17:25:58:29062
    VCDS Version: 17.1.3.0
    VIN: WAUZZZ4G8EN103926   License Plate: RAF 23.8.17
    Mileage: 107418km-66746mi   Repair Order:
    Chassis Type: 4G (4G0)
              62 6D 72
    VIN: WAUZZZ4G8EN103926   Mileage: 107418km-66746miles
    3B-Sensor Elect. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CDUD)       Labels: 059-907-401-V2.clb
       Revision: 53H41---
       VCID: 316C99676058DCC956-8064
              U1113 00 [039] - -
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
                        Engine speed: 701.00 /min
                        Normed load value: 44.7 %
                        Coolant temperature: 30 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 13.800 V
                        Cruise Control System (CCS): switch position-Bit 0: 129
                        Cruise Control System (CCS): status-Bit 0: 44
                        Cruise control switch-off: irreversible-Bit 0: 255
                        Cruise control switch-off: reversible-Bit 0: 255
                        Engine control module reset status-Bit 0: 0
                        Engine control module reset status-Bit 8: 0
                        Cruise control switch-off: irreversible w. brake intervention-Bit 0: 0
              U1113 00 [039] - -
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
                        Engine speed: 703.00 /min
                        Voltage terminal 30: 13.780 V
                        ACC target acceleration: 0.000 m/s²
                        ACC control module received status-Bit 0: 6
                        Active brake system error status-Bit 0: 0
                        Status of ACC/CCS acceleration interface-Bit 0: 0
                        Acceleration: 0.000 m/s²
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    4660 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [039] - -
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Revision: --H02---
       Coding: 000001
       ROD: EV_TCMDL501021_VW51.rod
       VCID: 3B70BB4FB2142699FC-806E
    Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
       VCID: 3A7EBE4BBD2E1F91E7-806E
    0518 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 0D
                        Uz: B2
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 08
                        Uz: B2
    0803 - Function Restriction due to Implausible Message(s)
              U1112 00 [129] - -
    0804 - Function Restriction due to Implausible Message(s)
              U1112 00 [129] - -
    0805 - Function Restriction due to Implausible Message(s)
              U1112 00 [129] - -
       VCID: 79FC6147F0A8D489AE-802C
    Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-2Z.clb
       Coding: 3622000821
       VCID: 67D8373F9E1C527948-8032
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
                        Outside air temperature: 20.5 °C
                        Temperature after evaporator: 21.14 °C
                        Engine speed: 174 /min
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       Coding: 2600201040349FE00181008000001D0C0F9DC70827090201000004606100
       VCID: 6DD44517B4E0782932-8038
       Coding: 0045F7
       Coding: 02006D
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:00
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:00
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Coding: 08C308
       VCID: 71EC5967A0D89CC916-8024
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       VCID: 3666AA7B8936FBF103-8062
    1049093 - Databus
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:04
    1049094 - Databus
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:04
    1049095 - Databus
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:04
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Coding: 000035
       VCID: 306A9C636352D5C159-8064
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Coding: 33A610000B412600010000
       VCID: 3F88CF5FA60C3AB9D0-806A
       Coding: 00CD077D00
       ROD: EV_GatewPKOUDS_VW51.rod
       VCID: 72EE566BA5DEA7D1EF-8026
       Voltage stabilizer:
    6655 - Sensor electronics control module
              U1077 00 [009] - No communication
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
                        Voltage terminal 30: 13.7 V
                        Voltage terminal 15: 13.8 V
                        Control Module temperature: 28 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       VCID: 4798D7BFF6DC727968-8012
    Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
       VCID: 326E966B655EE7D12F-8066
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Coding: 013B0622A0B930008320090400010F470000000000000000000000000000
       VCID: 1D3455D704C048A9E2-8048
       VCID: 4686DABBF1D66B7193-8012
       VCID: 2D5485177C60B82972-8078
    459264 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
                        Voltage terminal 30: 14.0 V
                        Internal Fault ID: 138
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
    463616 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:03
                        Voltage terminal 30: 13.9 V
                        Internal Fault ID: 185
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
    392714 - Positioning Motor for Headlight Range Left
              C1085 15 [137] - Open or Short to Plus
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:04
    392970 - Positioning Motor for Headlight Range Right
              C1086 15 [137] - Open or Short to Plus
                        Reset counter: 143
                        Mileage: 107418 km
                        Date: 2017.08.21
                        Time: 19:22:04
       VCID: 2F689F1F7E6CCA3940-807A
       VCID: 499CD187E0C884097E-801C
    Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
       Coding: 097205C010
       VCID: 3564AD779430F0E90A-8060
    End-------------------------(Elapsed Time: 04:17)--------------------------
  8. #17
    Sep 2018
    Spain
    Hi. You could put the parts you needed to retrofit. I'd like to do it. Thank you.
  9. #18
    Nov 2014
    i didnt do conversion myself i just purchased lights and bumpers, there is a company called kufatec who sell the parts
  10. #19
    Dec 2018
    Romania
    Raf, you buy them from kufatec? The provide install instructions.
  11. #20
    Nov 2014
    Quote Originally Posted by d@ni3l View Post
    i didnt do the retrofit myself apart from buy front and rear lights and bumpers and install, front light needed brackets changing to accommodate new lights to fit,
    the rest was done by a retrofit expert , a paid job, so have no real info to share..
    when i was doing some homework in the beginning , i found that a lot of people was buying the cables and kit from kufatec and installing and coding in bcm,
    i also found that bcm had to be a certain version for their kit to work,
