Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Audi A6 4G Facelift 2016 Led Matrix headlights retrofit
    Oct 2017
    Hello.
    I have RETROFITED the LED Matrix Lights for the A6 2016 facelift. We have an issue with the MAIN beams. These won't activate. The DRL's and Turning Signal lights work fine.
    Im retrofit my Audi led matrix headlights . Original light is xenon without AFS.*
    My car 09 control module number is 4H0 907 063 DH.
    Original long code is Audi (A6 4G Limousine):
    2600C01400349FE08181408300001D0C0F9CC3082609020100 0004206101150200400024030000
    Copy led matrix car is (Audi A6 4G Avant):
    0105C01440349FE0C1014083000018000F9CE7082E08020100 000894E101130200400034030000
    We have coded the*BCM*using copied Long Coding from A6 with exact specification except the LED lights are different.
    Is there anyone that has an IDEA of how these LIGHTS work and if there are any Adaptions that are required to get these LED Main Beams to work?
    Near Philadelphia, PA, USA
    Welcome to the forum with your first post.
    For us to be able to assist, please post an AutoScan so we can see the context of what it is you are trying to do. We need the information about the car that is provided by the autoscan.
    How to post an Auto-Scan
  3. Likes Uwe liked this post
    Jan 2015
    Bosnia and Herzegovina
    you can try this to see if it works
    Google translated from german, kufatec guide for anyone looking, might help
    Adresse 09:
    Byte 00 - HEX 09
    Byte 01 - HEX 07
    Byte 04 - HEX 09
    Byte 14 - HEX 18
    Byte 15 - HEX 00
    Byte 21 - Bit 0 on 0
    Byte 25 - HEX 01
    Byte 27 - HEX 54
    Byte 28 - Bit 0, 1, 2, 3
    Adresse 20 (if any):
    Byte 0 - HEX 04
    Adresse 85 (if any):
    Byte 0 - Bit 2 auf 0
    Sub bus part number LED module (at address 09):
    Byte 00 - HEX 11
    Adjustment in address 09:
    Channel 3 - 26
    Security Code: 20113
    Oct 2017
    Quote Originally Posted by m87a View Post
    Adresse 09:
    Byte 00 - HEX 09
    Byte 01 - HEX 07
    Byte 04 - HEX 09
    Byte 14 - HEX 18
    Byte 15 - HEX 00
    Byte 25 - HEX 01
    Byte 27 - HEX 54
    Byte 0 - HEX 04
    Byte 00 - HEX 11
    Channel 3 - 26
    I try this yesterday,but isn`t working.
    Adresse 09:
    Byte 00 - HEX 09
    Byte 01 - HEX 07
    coding error 31.
    Thursday,12,October,2017,21:19:01:41892
    VCDS Version: 17.8.0.1 (x64)
    VIN: WAUZZZ4G6GN156921   License Plate: A6 12.10.2017
    Mileage: 18552km-11527mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 3B 42 44 46 52 53 55 5F 62 69
              6D 72 84 85 8F 90 AC
    VIN: WAUZZZ4G6GN156921   Mileage: 18552km-11527miles
    17-Instruments -- Status: Cannot be reached 0100
    84-Night Vision -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: Cannot be reached 0100
    90-Pretens. Frt Right -- Status: Malfunction 0010
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 BP    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 1661
       Revision: 85H23---
       Coding: 0A254012242601080000
       ASAM Dataset: EV_ECM20TDI01104L906021BP 002006
       ROD: EV_ECM20TDI01104L906021BP_002.rod
       VCID: 74EDACECDF188BE69E-8020
       Part No SW: 4G0 927 166 N    HW: 0B5 927 156 K
       Component: 0B5 20 TDIRdW H03 0003
       Revision: --H03---
       Coding: 100001
       ASAM Dataset: EV_TCMDL501021 001021
       ROD: EV_TCMDL501021.rod
       VCID: 387558DC83F02F8672-806C
       Coding: 06A69E41606579829B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41833538D02A6E4EC5-8014
       Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
       Component: BCM2 2.0      H37 0572
       Coding: 01A8700E000000000000
       VCID: 7BFF87D0FA46C49EDF-802E
       Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
       Component: KLIMA 2 ZONEN H14 0112
       Serial number: 12021600111583
       Coding: 34010908210000
       ASAM Dataset: EV_AirCondiBasisUDS 003009
       ROD: EV_AirCondiBasisUDS_003.rod
       VCID: 61C3D5B870EA0E4EE5-8034
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:34
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 18.0 °C
                        Temperature after evaporator: 15.59 °C
                        Engine speed: 0 /min
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00001292050602
       Coding: 0105C01440349FE0C1014083000018000F9CE7082E08020100000854EF01130200400034030000
       VCID: 71E3A5F8A80ABECE75-8024
       Component: WWS57X 160106  H38 0080
       Serial number:         160120102054
       Coding: 0045F7
       Serial number: 61375912
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AM    HW: 4G0 941 531 AM
       Component: E1 - LDS  H07 0044
       Serial number: 26 05 2014  00000920
       Serial number: CD49C218000000000001
    03608 - Humidity Sensor in Fresh Air Intake Duct
                        Fault Status: 01100101
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:33
    00496 - Sensor for Vehicle Leveling; Front
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:34
    03725 - Control Module for Seat Belt Tensioner; Left Front
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:38
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:51
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P1008LJD4
       Coding: 30333130313630323637554A304C34473053
       VCID: 3B7F47D0B2C6049E9F-806E
       Serial number: 3575HRB405H3U1OO394R
       Serial number: 3585HRB40553U1OO49BO
       Serial number: 3515JRB400E557DQ70UA
       Serial number: 3525JRB405L3HTVKN8M/
       Serial number: 3554VRB40593F0KMEO3X
       Serial number: 3564VRB400S5593QNQ78
       Revision: C0068538    Serial number: 90862PBE000LD
       Coding: 000014
       VCID: 3B7F47D0BAC6049E9F-806E
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 18 01 2016  E0047797
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 934 D    HW: 4G8 920 934 D
       Component: TDieRdw       H11 0106
       Revision: 09001102    Serial number: 658150216596043
       Coding: 13AF0A000B410008010000
       ASAM Dataset: EV_RBD4K 004055
       ROD: EV_RBD4K.rod
       VCID: 32616AF4658CC5D64C-8066
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000002157595
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 001028
       ROD: EV_GatewPkoUDS_001.rod
       Serial number: 1851869103
       Voltage stabilizer:
    5080 - Front Left belt tensioner control module
              U107C 00 [009] - No communication
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:34
                        Voltage terminal 30: 12.2 V
                        Voltage terminal 15: 12.1 V
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
              U1101 00 [009] - Active
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:34
                        Voltage terminal 30: 12.1 V
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA720NDSL2
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 336F6FF09A96CCDE47-8066
       Coding: 011C17014000628002080002
       VCID: 47972B20F60E507E0B-8012
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:33
       Component: RCevo         H54 0202
       Revision: 00000002    Serial number: 0000655919
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106_AU57.rod
       VCID: 3A7142D4BDFC3D9684-806E
       Revision: 00002001    Serial number: 0396325988
       Coding: 0100063800B930008320080428010F470000000000000000000000000000
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:33
       VCID: 46892624F1044976F0-8012
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:33
       Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
       Component: EPB-4         H05 0017
       Revision: --------    Serial number: 00000001745175
       ASAM Dataset: EV_ParkiBrake 001029
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 316365F8608AFECE35-8064
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 03FA02202A130200
       Shop #: WSC 00046 123 12345
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
       VCID: 366956E489E4D9F660-8062
       Coding: E01400
       Coding: E01400
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
    10 Faults Found:
              U1014 00 [137] - -
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:35
    5275220 - Headlight
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:36
    5350720 - Left Matrix High Beam
              C1175 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:36
    5350976 - Right Matrix High Beam
              C1176 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:36
    5342449 - Output Stage for Matrix Headlamps; Left
              C1164 F1 [137] - Incorrectly Coded
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:35
    5342705 - Output Stage for Matrix Headlamps; Right
              C1165 F1 [137] - Incorrectly Coded
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:35
    5538082 - Temperature Sensor for Left Static Cornering Lamp
              C1171 01 [009] - Electrical Failure
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:37
    5538338 - Temperature Sensor for Right Static Cornering Lamp
              C1172 01 [009] - Electrical Failure
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:37
    5538083 - Static Cornering Light; Left
              C1083 F0 [009] - Current Coding Electrical Malfunction
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:37
    5538339 - Static Cornering Light; Right
              C1084 F0 [009] - Current Coding Electrical Malfunction
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:37
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 044 D    HW: 4G1 035 044 D
       Component: MU-H-LN-EU    051 0389
       Serial number: A734B0GB009861
       Coding: 01750101FF0A000013110001000A00132F0006E5F1700100DF
       VCID: 204590BC3B604746AA-8074
       Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
       Component: ECE 2016  --- 0134
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9GY804CZG
       Multimedia Operating Unit:
       Serial number: 90349PBN00036
       Component: Gracenote2  --- 1012
    7199 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:38
                        Voltage terminal 30: 12.5 V
                        BAP-BAP_Function_ID: 02
       Coding: 010815004000628002080002
       VCID: 49932D18E01AA60E1D-801C
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: Anhaenger     H14 0137
       Revision: 7B001001    Serial number: 0321735575
       Coding: 0100000202000000
       Shop #: WSC 06745 128 28888
       Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
       Component: HDSG-Modul    H02 0049
       Revision: 13002001    Serial number: 023400023
       Coding: 111104C021
       ASAM Dataset: EV_HDSGAu571 001022
       ROD: EV_HDSGAu571.rod
    Address 84: Night Vision (J853)       Labels:* None
       Part No SW: 4G0 907 547 A    HW: 4G0 907 547
       Component: NV-ECU-Gen3   H08 0107
       Serial number: 622352400201442
       Coding: 300100
       ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
       ROD: EV_NightVisioGen3AE4AU64X.rod
       VCID: 2C5D748C47A8932606-8078
       Camera For Night Vision System:
       Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
       Component: NV-CAM-Gen3  H03 0006
       Serial number: 623466500F1423900418
    4107 - No Basic Setting
              B2010 00 [009] -  -
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:56
                        Image processor: error number-Image processor: error number 2: 00 00 00 00
                        Image processor: error number-Image processor: error number 1: 52 60 00 02
                        Voltage terminal 15: 12.30 V
                        Dynamic calibration-Dynamic calibration: yaw angle offset: 0.00 °
                        Dynamic calibration-Dynamic calibration: pitch angle offset: 0.70 °
                        Dynamic calibration: status-Dynamic calibration: pitch angle offset: 0.00 °
                        Dynamic calibration: status-Dynamic calibration: OFF
                        Dynamic calibration: status-Distance traveled with active dynamic calibration: 16512 km
                        Status of actuator test: not active
    Address 85: On Board Cam. (J852)       Labels:* None
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 60140000
       ROD: EV_OnBoardCamerDPC.rod
    0552 - Control Module For Camera
              C110A 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:52
                        Outside air temperature: -41.0 °C
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 0.0 °C
    0208 - invalid data record
              B2005 00 [009] -  -
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:34
                        Control Module temperature: 23.0 °C
    0773 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:35
    0730 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 68
                        Mileage: 18552 km
                        Date: 2017.10.12
                        Time: 21:08:35
    Address 8F: Pretens. Frt Left
    Address 90: Pretens. Frt Right        Labels:
       VCID: 55ABF168ACA2F2EE89-FFFE
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 160250422
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F67638076BEE83E23-807A
    End-------------------------(Elapsed Time: 07:01)--------------------------
    Retrofit:
    - LED Matrix
    - Head light leveling system (55)
    - Night Vision
    - On Boad Camera (85),no Lane Assist
    Last edited by Bruce; 10-12-2017 at 03:35 PM. Reason: changed "Quote" tags to "Code" tags and fixed syntax
    Jun 2017
    Dear Sir,
    where are your LED modules as sub-modules in the BCM?
    These are missing.
    I don't know how this works for the facelift but the pre-facelift has the LED modules for both sides connected via LIN-Bus to BCM.
    It does not make sense to proceed in here without having this fixed.
  7. Likes Uwe liked this post
    Oct 2017
    Dear Sir,
    These are missing.
    Hello.
    The headlights have LED modules. Led Matrix headlights is coded in a car where those headlights from the factory. Facelift maybe harder to coding ?
    Jul 2014
    Poland
    In FL model lamps are connected via CAN not LIN to BCM that's first thing, then you need to have proper dataset in 09, 55 and 85 for matrix lamps, also your 55 is not coded correctly. Been there, done that. Sadly you need more than VCDS to do this retrofit.
    ESP OFFLINE coding for all VAG 2010->/ Certified GeKo user/ Retrofitting, Chip-tuning, Flash updates, ECU programming, key coding, clusters and many more...
  10. Likes Bogdan.audi liked this post
  11. #8
    Oct 2017
    Quote Originally Posted by automech View Post
    I have a VCDS, VCP +ODIS . If i coding with ODIS factory not "tell" me correct code. I have the option to coding the factory connection. Do you have any idea how or how to get the coding modules correctly?
  12. #9
    Jan 2016
    Australia
    Quote Originally Posted by hartar197 View Post
    did you end up getting this to work?
  13. #10
    Aug 2018
    China
    Friend I can help you
