Audi A6 4G Facelift 2016 Led Matrix headlights retrofit
hartar197
C?ID=20860
Hello.
I have RETROFITED the LED Matrix Lights for the A6 2016 facelift. We have an issue with the MAIN beams. These won't activate. The DRL's and Turning Signal lights work fine.
Im retrofit my Audi led matrix headlights . Original light is xenon without AFS.*
My car 09 control module number is 4H0 907 063 DH.
Original long code is Audi (A6 4G Limousine):
2600C01400349FE08181408300001D0C0F9CC30826090201000004206101150200400024030000
Copy led matrix car is (Audi A6 4G Avant):
0105C01440349FE0C1014083000018000F9CE7082E08020100000894E101130200400034030000
We have coded the*BCM*using copied Long Coding from A6 with exact specification except the LED lights are different.
Is there anyone that has an IDEA of how these LIGHTS work and if there are any Adaptions that are required to get these LED Main Beams to work?
Bruce
Near Philadelphia, PA, USA
Welcome to the forum with your first post.
For us to be able to assist, please post an AutoScan so we can see the context of what it is you are trying to do. We need the information about the car that is provided by the autoscan.
[h=3]How to post an Auto-Scan[/h]
m87a
Bosnia and Herzegovina
C?ID=156900
you can try this to see if it works
Google translated from german, kufatec guide for anyone looking, might help
Adresse 09:
Byte 00 - HEX 09
Byte 01 - HEX 07
Byte 04 - HEX 09
Byte 14 - HEX 18
Byte 15 - HEX 00
Byte 21 - Bit 0 on 0
Byte 25 - HEX 01
Byte 27 - HEX 54
Byte 28 - Bit 0, 1, 2, 3
Adresse 20 (if any):
Byte 0 - HEX 04
Adresse 85 (if any):
Byte 0 - Bit 2 auf 0
Sub bus part number LED module (at address 09):
Byte 00 - HEX 11
Adjustment in address 09:
Channel 3 - 26
Security Code: 20113
hartar197
C?ID=20860
Adresse 09:
Byte 00 - HEX 09
Byte 01 - HEX 07
Byte 04 - HEX 09
Byte 14 - HEX 18
Byte 15 - HEX 00
Byte 25 - HEX 01
Byte 27 - HEX 54
Byte 0 - HEX 04
Byte 00 - HEX 11
Channel 3 - 26
I try this yesterday,but isn`t working.
Adresse 09:
Byte 00 - HEX 09
Byte 01 - HEX 07
coding error 31.
Thursday,12,October,2017,21:19:01:41892
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ4G6GN156921   License Plate: A6 12.10.2017
Mileage: 18552km-11527mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 3B 42 44 46 52 53 55 5F 62 69
          6D 72 84 85 8F 90 AC
VIN: WAUZZZ4G6GN156921   Mileage: 18552km-11527miles
17-Instruments -- Status: Cannot be reached 0100
84-Night Vision -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BP    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1661
   Revision: 85H23---
   Coding: 0A254012242601080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021BP 002006
   ROD: EV_ECM20TDI01104L906021BP_002.rod
   VCID: 74EDACECDF188BE69E-8020
   Part No SW: 4G0 927 166 N    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0003
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 387558DC83F02F8672-806C
   Coding: 06A69E41606579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41833538D02A6E4EC5-8014
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Coding: 01A8700E000000000000
   VCID: 7BFF87D0FA46C49EDF-802E
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 12021600111583
   Coding: 34010908210000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 61C3D5B870EA0E4EE5-8034
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [009] - Signal Amplitude Too Low
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:34
                    Compressor current: actual value: 0 mA
                    Outside air temperature: 18.0 °C
                    Temperature after evaporator: 15.59 °C
                    Engine speed: 0 /min
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001292050602
   Coding: 0105C01440349FE0C1014083000018000F9CE7082E08020100000854EF01130200400034030000
   VCID: 71E3A5F8A80ABECE75-8024
   Component: WWS57X 160106  H38 0080
   Serial number:         160120102054
   Coding: 0045F7
   Serial number: 61375912
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AM    HW: 4G0 941 531 AM
   Component: E1 - LDS  H07 0044
   Serial number: 26 05 2014  00000920
   Serial number: CD49C218000000000001
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Fault Status: 01100101
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:33
00496 - Sensor for Vehicle Leveling; Front
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:34
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:38
01539 - Headlights Not Adjusted
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:51
   Revision: --------    Serial number: 003P1008LJD4
   Coding: 30333130313630323637554A304C34473053
   VCID: 3B7F47D0B2C6049E9F-806E
   Serial number: 3575HRB405H3U1OO394R
   Serial number: 3585HRB40553U1OO49BO
   Serial number: 3515JRB400E557DQ70UA
   Serial number: 3525JRB405L3HTVKN8M/
   Serial number: 3554VRB40593F0KMEO3X
   Serial number: 3564VRB400S5593QNQ78
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862PBE000LD
   Coding: 000014
   VCID: 3B7F47D0BAC6049E9F-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 18 01 2016  E0047797
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 934 D    HW: 4G8 920 934 D
   Component: TDieRdw       H11 0106
   Revision: 09001102    Serial number: 658150216596043
   Coding: 13AF0A000B410008010000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   VCID: 32616AF4658CC5D64C-8066
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002157595
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001028
   ROD: EV_GatewPkoUDS_001.rod
   Serial number: 1851869103
   Voltage stabilizer:
5080 - Front Left belt tensioner control module
          U107C 00 [009] - No communication
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:34
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 19 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
          U1101 00 [009] - Active
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:34
                    Voltage terminal 30: 12.1 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720NDSL2
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336F6FF09A96CCDE47-8066
   Component: TSG FA        H03 0511
   Coding: 011C17014000628002080002
   VCID: 47972B20F60E507E0B-8012
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:33
   Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000655919
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106_AU57.rod
   VCID: 3A7142D4BDFC3D9684-806E
   Revision: 00002001    Serial number: 0396325988
   Coding: 0100063800B930008320080428010F470000000000000000000000000000
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:33
   VCID: 46892624F1044976F0-8012
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:33
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001745175
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 316365F8608AFECE35-8064
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 03FA02202A130200
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   VCID: 366956E489E4D9F660-8062
   Coding: E01400
   Coding: E01400
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
10 Faults Found:
          U1014 00 [137] - -
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:35
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:36
5350720 - Left Matrix High Beam
          C1175 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:36
5350976 - Right Matrix High Beam
          C1176 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:36
5342449 - Output Stage for Matrix Headlamps; Left
          C1164 F1 [137] - Incorrectly Coded
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:35
5342705 - Output Stage for Matrix Headlamps; Right
          C1165 F1 [137] - Incorrectly Coded
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:35
5538082 - Temperature Sensor for Left Static Cornering Lamp
          C1171 01 [009] - Electrical Failure
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:37
5538338 - Temperature Sensor for Right Static Cornering Lamp
          C1172 01 [009] - Electrical Failure
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:37
5538083 - Static Cornering Light; Left
          C1083 F0 [009] - Current Coding Electrical Malfunction
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:37
5538339 - Static Cornering Light; Right
          C1084 F0 [009] - Current Coding Electrical Malfunction
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:37
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 044 D    HW: 4G1 035 044 D
   Component: MU-H-LN-EU    051 0389
   Serial number: A734B0GB009861
   Coding: 01750101FF0A000013110001000A00132F0006E5F1700100DF
   VCID: 204590BC3B604746AA-8074
   Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
   Component: ECE 2016  --- 0134
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Serial number: AUZ8Z9GY804CZG
   Multimedia Operating Unit:
   Serial number: 90349PBN00036
   Component: Gracenote2  --- 1012
7199 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:38
                    Voltage terminal 30: 12.5 V
                    BAP-BAP_Function_ID: 02
   Component: TSG HL        H03 0511
   Coding: 010815004000628002080002
   VCID: 49932D18E01AA60E1D-801C
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0321735575
   Coding: 0100000202000000
   Shop #: WSC 06745 128 28888
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 023400023
   Coding: 111104C021
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0511
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0107
   Serial number: 622352400201442
   Coding: 300100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X.rod
   VCID: 2C5D748C47A8932606-8078
   Camera For Night Vision System:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1423900418
4107 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:56
                    Image processor: error number-Image processor: error number 2: 00 00 00 00
                    Image processor: error number-Image processor: error number 1: 52 60 00 02
                    Voltage terminal 15: 12.30 V
                    Dynamic calibration-Dynamic calibration: yaw angle offset: 0.00 °
                    Dynamic calibration-Dynamic calibration: pitch angle offset: 0.70 °
                    Dynamic calibration: status-Dynamic calibration: pitch angle offset: 0.00 °
                    Dynamic calibration: status-Dynamic calibration: OFF
                    Dynamic calibration: status-Distance traveled with active dynamic calibration: 16512 km
                    Status of actuator test: not active
Address 85: On Board Cam. (J852)       Labels:* None
   Component: DPC-SG        H27 0081
   Coding: 60140000
   ROD: EV_OnBoardCamerDPC.rod
0552 - Control Module For Camera
          C110A 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:52
                    Outside air temperature: -41.0 °C
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 0.0 °C
0208 - invalid data record
          B2005 00 [009] -  -
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:34
                    Control Module temperature: 23.0 °C
0773 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:35
0730 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 68
                    Mileage: 18552 km
                    Date: 2017.10.12
                    Time: 21:08:35
Address 8F: Pretens. Frt Left
Address 90: Pretens. Frt Right        Labels:
   VCID: 55ABF168ACA2F2EE89-FFFE
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 160250422
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F67638076BEE83E23-807A
End-------------------------(Elapsed Time: 07:01)--------------------------
Retrofit:
- LED Matrix
- Head light leveling system (55)
- Night Vision
- On Boad Camera (85),no Lane Assist
hadez16
C?ID=289891
Dear Sir,
where are your LED modules as sub-modules in the BCM?
These are missing.
I don't know how this works for the facelift but the pre-facelift has the LED modules for both sides connected via LIN-Bus to BCM.
It does not make sense to proceed in here without having this fixed.
hartar197
C?ID=20860
Dear Sir,
These are missing.
Hello.
The headlights have LED modules. Led Matrix headlights is coded in a car where those headlights from the factory. Facelift maybe harder to coding ?
automech
C?ID=14925
In FL model lamps are connected via CAN not LIN to BCM that's first thing, then you need to have proper dataset in 09, 55 and 85 for matrix lamps, also your 55 is not coded correctly. Been there, done that. Sadly you need more than VCDS to do this retrofit.
hartar197
C?ID=20860
I have a VCDS, VCP +ODIS . If i coding with ODIS factory not "tell" me correct code. I have the option to coding the factory connection. Do you have any idea how or how to get the coding modules correctly?
spyderboyant
Australia
C?ID=65474
did you end up getting this to work?
peng shun jiang
China
C?ID=295642
Friend I can help you
d@ni3l
Romania
Hello, somebody is willing to share the codding/procedure information for this retrofit?
raf0468
C?ID=120244
here is scan of my a6 2014 which was retrofitted with the 2015 led front and rear lights, i had it done by someone as i was not capable of the task..
Q6l79xG
Monday,25,December,2017,15:57:21:29062
VIN: WAUZZZ4G8EN103926   License Plate: R15WNE 25.12,17
Mileage: 112427km-69858mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F
          62 6D 72
VIN: WAUZZZ4G8EN103926   Mileage: 112427km-69858miles
Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 Q    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0002
   Revision: 53H41---
   Coding: 12254012052601020000
   ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
   ROD: EV_ECM30TDI0114G0907401Q.rod
   VCID: 316C99676058DCCE35-8064
   Part No SW: 4G2 927 156 P    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H02 0003
   Revision: --H02---
   VCID: 3B70BB4FB214269E9F-806E
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 27A69F01E465F980DB00
   VCID: 3A7EBE4BBD2E1F9684-806E
   Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0521
   Coding: 01B93046000000000000
   VCID: 79FC6147F0A8D48ECD-802C
   Serial number: 0213000389021006
   Part No SW: 4G0 820 043 AJ    HW: 4G0 820 043 AJ
   Component: KLIMA 2 ZONEN H14 0094
   Serial number: 14121300110442
   Coding: 3622000821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 67D8373F9E1C527E2B-8032
                    Reset counter: 34
                    Mileage: 112427 km
                    Date: 2017.12.25
                    Time: 15:51:45
                    Outside air temperature: 11.0 °C
                    Temperature after evaporator: 8.92 °C
                    Engine speed: 220 /min
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Revision: 19012002    Serial number: 00000001815055
   Coding: 2600A01040349FE001810080000005040F9DC70807080301000004206000
   VCID: 6DD44517B4E0782E51-8038
   Component: WWS57X 131208  H36 0080
   Serial number:         131209210342
   Coding: 0045F7
   Serial number: 22105522
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Serial number: 09 12 2013  00000832
   Serial number: A77843E6000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Revision: 11001001    Serial number: 61061335601495
   Coding: 08C308
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 71EC5967A0D89CCE75-8024
   Revision: --------    Serial number: 003JG00G56VA
   Coding: 3032343631334E303537554A305234473053
   VCID: 3666AA7B8936FBF660-8062
   Serial number: 3575HRB40692ATKIAHUF
   Serial number: 3585HRB405P2AIFU6PNO
   Serial number: 3515JRB401E50PQ2GGPX
   Serial number: 3525JRB400O50PQ2IPG2
   Serial number: 3554VRB404V2FD2ML1C+
   Serial number: 3564VRB404V2FD2M7OB7
   Revision: 00000000    Serial number: 20140109000202
   Coding: 000035
   VCID: 306A9C636352D5C63A-8064
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658281113592037
   Coding: 23A710000B412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3F88CF5FA60C3ABEB3-806A
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001222074
   Coding: 00CD077D00
   VCID: 72EE566BA5DEA7D68C-8026
   Serial number: 3620501903
   Voltage stabilizer:
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA7207NAXX
   ROD: EV_SARA2.rod
   VCID: 3360936F9A44EEDE47-8066
   Coding: 011C16004001620002080002
   VCID: 4798D7BFF6DC727E0B-8012
   Component: RCEPS         H39 0010
   Revision: 00001000    Serial number: 0004118059
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326E966B655EE7D64C-8066
   Revision: 00002001    Serial number: 0322466267
   Coding: 013F0622A0B930008320090400010F470000000000000000000000000000
   Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
   Component: BOSE-G3-C7    H07 0160
   Revision: CJ007001    Serial number: 00000000061327
   VCID: 1D3455D704C048AE81-8048
   Coding: 011C16004401620002080002
   VCID: 4686DABBF1D66B76F0-8012
   Revision: --------    Serial number: 00000001583618
   VCID: 2D5485177C60B82E11-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Serial number: 140106-0002-002
   Coding: 1122A6101000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 192 P    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H54 0818
   Coding: 0101010101415B47082B060301020100000001
   VCID: 2F689F1F7E6CCA3E23-807A
   Subsystem 1 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464K+0D2642347
   Subsystem 2 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Serial number: 90349MLA000BH
   Coding: 010814004001620002080002
   VCID: 499CD187E0C8840E1D-801C
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 351301238
   Coding: 097205C010
   VCID: 3564AD779430F0EE69-8060
End-------------------------(Elapsed Time: 04:21)--------------------------
d@ni3l
Romania
Do you have a scan before this retrofit, to compare the differences?
Thanks.
raf0468
C?ID=120244
here is scan before retrofit...
Wednesday,23,August,2017,17:25:58:29062
VCDS Version: 17.1.3.0
VIN: WAUZZZ4G8EN103926   License Plate: RAF 23.8.17
Mileage: 107418km-66746mi   Repair Order:
Chassis Type: 4G (4G0)
          62 6D 72
VIN: WAUZZZ4G8EN103926   Mileage: 107418km-66746miles
3B-Sensor Elect. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CDUD)       Labels: 059-907-401-V2.clb
   Revision: 53H41---
   VCID: 316C99676058DCC956-8064
          U1113 00 [039] - -
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
                    Engine speed: 701.00 /min
                    Normed load value: 44.7 %
                    Coolant temperature: 30 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.800 V
                    Cruise Control System (CCS): switch position-Bit 0: 129
                    Cruise Control System (CCS): status-Bit 0: 44
                    Cruise control switch-off: irreversible-Bit 0: 255
                    Cruise control switch-off: reversible-Bit 0: 255
                    Engine control module reset status-Bit 0: 0
                    Engine control module reset status-Bit 8: 0
                    Cruise control switch-off: irreversible w. brake intervention-Bit 0: 0
          U1113 00 [039] - -
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
                    Engine speed: 703.00 /min
                    Voltage terminal 30: 13.780 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bit 0: 6
                    Active brake system error status-Bit 0: 0
                    Status of ACC/CCS acceleration interface-Bit 0: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_RUNNING
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Revision: --H02---
   ROD: EV_TCMDL501021_VW51.rod
   VCID: 3B70BB4FB2142699FC-806E
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   VCID: 3A7EBE4BBD2E1F91E7-806E
0518 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 0D
                    Uz: B2
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: B2
0803 - Function Restriction due to Implausible Message(s)
          U1112 00 [129] - -
0804 - Function Restriction due to Implausible Message(s)
          U1112 00 [129] - -
0805 - Function Restriction due to Implausible Message(s)
          U1112 00 [129] - -
   VCID: 79FC6147F0A8D489AE-802C
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-2Z.clb
   Coding: 3622000821
   VCID: 67D8373F9E1C527948-8032
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
                    Outside air temperature: 20.5 °C
                    Temperature after evaporator: 21.14 °C
                    Engine speed: 174 /min
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Coding: 2600201040349FE00181008000001D0C0F9DC70827090201000004606100
   VCID: 6DD44517B4E0782932-8038
   Coding: 0045F7
   Coding: 02006D
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101100
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:00
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Coding: 08C308
   VCID: 71EC5967A0D89CC916-8024
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   VCID: 3666AA7B8936FBF103-8062
1049093 - Databus
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:04
1049094 - Databus
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:04
1049095 - Databus
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:04
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Coding: 000035
   VCID: 306A9C636352D5C159-8064
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Coding: 33A610000B412600010000
   VCID: 3F88CF5FA60C3AB9D0-806A
   Coding: 00CD077D00
   ROD: EV_GatewPKOUDS_VW51.rod
   VCID: 72EE566BA5DEA7D1EF-8026
   Voltage stabilizer:
6655 - Sensor electronics control module
          U1077 00 [009] - No communication
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
                    Voltage terminal 30: 13.7 V
                    Voltage terminal 15: 13.8 V
                    Control Module temperature: 28 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   VCID: 4798D7BFF6DC727968-8012
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   VCID: 326E966B655EE7D12F-8066
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Coding: 013B0622A0B930008320090400010F470000000000000000000000000000
   VCID: 1D3455D704C048A9E2-8048
   VCID: 4686DABBF1D66B7193-8012
   VCID: 2D5485177C60B82972-8078
459264 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
                    Voltage terminal 30: 14.0 V
                    Internal Fault ID: 138
                    Network management state: normal
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    General Inspection Function: not active
                    Internal Parking Brake state: static
                    Status of parking brake button: Not operated
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
463616 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:03
                    Voltage terminal 30: 13.9 V
                    Internal Fault ID: 185
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
392714 - Positioning Motor for Headlight Range Left
          C1085 15 [137] - Open or Short to Plus
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:04
392970 - Positioning Motor for Headlight Range Right
          C1086 15 [137] - Open or Short to Plus
                    Reset counter: 143
                    Mileage: 107418 km
                    Date: 2017.08.21
                    Time: 19:22:04
   VCID: 2F689F1F7E6CCA3940-807A
   VCID: 499CD187E0C884097E-801C
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Coding: 097205C010
   VCID: 3564AD779430F0E90A-8060
End-------------------------(Elapsed Time: 04:17)--------------------------
torrebasetez
Spain
C?ID=354490
Hi. You could put the parts you needed to retrofit. I'd like to do it. Thank you.
raf0468
C?ID=120244
i didnt do conversion myself i just purchased lights and bumpers, there is a company called kufatec who sell the parts
d@ni3l
Romania
Raf, you buy them from kufatec? The provide install instructions.
raf0468
C?ID=120244
i didnt do the retrofit myself apart from buy front and rear lights and bumpers and install, front light needed brackets changing to accommodate new lights to fit,
the rest was done by a retrofit expert , a paid job, so have no real info to share..
when i was doing some homework in the beginning , i found that a lot of people was buying the cables and kit from kufatec and installing and coding in bcm,
i also found that bcm had to be a certain version for their kit to work,
