Thanks for taking the time to read my post.
I have a 2011 Octavia RS TDI 170 (CEGA engine code)
The car has been so far been faultless in my ownership but I now have a niggling electrical fault that I cannot seem to get to the bottom of.
While travelling at speed on a motorway a few weeks ago I noticed the power steering (electric on this vehicle) felt like it was failing, steering went heavy then light then heavy and light again a few times.
The following day I also noticed that when pulling up at lights the car was idling high at just over 1000rpm.
Over the last 4 weeks I've been more aware of this and it's completely random, often the car idles higher than normal and the fans in the engine bar are running full, when the car is like this (and only then) then I get the intermittent power steering issue.
If I turn off the engine and restart then it's fine for a short while but soon comes back to this situation.
I've scanned the car and the only fault is shown below
If I clear the code then as soon as I notice the "situation" (car idling high again, fans running and intermittent flaky power steering) again, scan shows above code is present again, so it's definitely triggering my symptoms.
My car has a DPF but its not related to that, the high idle and fans you would expect during a regen but the car is not regenerating when this happens.
So far I've done the following myself
Battery professionally tested twice - OK
Alternator and output tested - OK
Continuity between alternator and battery - OK
Continuity between battery and fuse box - OK
Battery negative/earth cable continuity (also cleaned up connections) - OK
Battery terminals cleaned up - OK
Fuses in fusebox tested, removed and re-inserted a few times - OK
I've thus far drawn a blank and any advice or suggestions would be HUGELY appreciated.
Below is a full scan for information.
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 48000AB8E049B1C040080080110011E4437000AE726D8160808440040040
Shop #: WSC 73430 790 00085
VCID: 387F050D8BA4B98672-806C
Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 10121 26 0601
Coding: 00D7B7
Component: RLS 201210 05 54 0403
Coding: 0730ED
Subsystem 3 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
01598 - Drive Battery Voltage
Fault Status: 00101011
Fault Frequency: 24
Reset counter: 51
Mileage: 137041 km
Date: 2012.01.24
Time: 11:31:03
Voltage: 14.00 V
Term 50 Off
Wednesday,13,September,2017,18:29:19:63282
VCDS Version: 17.8.0.1 (x64)
VIN: TMBEH21Z2B2093411 License Plate: Y12 MCS
Mileage: 137820km-85637mi Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
VIN: TMBEH21Z2B2093411 Mileage: 137820km-85637miles
Address 01: Engine (CEG) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 RE HW: 03L 906 022 GA
Component: R4 2,0L EDC G000AG 5752
Revision: 13H14--- Serial number:
Coding: 0001078
Shop #: WSC 14387 792 427814
VCID: 79F9C009302E608ECD-802C
Part No SW: 02E 300 054 H HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2601
Revision: 05351112 Serial number: 00001011221285
VCID: 1B35FA81DA52F29E7F-804E
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 163B601C092B00FD680F06E5901A0082340800
VCID: 75E1CC39DC3604EEA9-8020
Part No SW: 3T0 907 044 BD HW: 3T0 907 044 BD
Component: Climatronic H16 0402
Revision: 00006001
Coding: 0000000002
VCID: 75E1CC39D43604EEA9-8020
Revision: 00103 AD
Coding: 00D7B7
Coding: 0730ED
Fault Frequency: 24
Reset counter: 51
Mileage: 137041 km
Date: 2012.01.24
Time: 11:31:03
Voltage: 14.00 V
Term 50 Off
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC21XWK7
Coding: 0020788
VCID: 3D71141964869CAEA1-8068
Subsystem 1 - Serial number: 6332MSME5A7232718
Subsystem 2 - Serial number: 6342MSME5B0108300
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101222100936
Coding: 189A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EF3D315E10047B6F8-802A
Subsystem 1 - Part No SW: 3T0 959 537 A HW: 3T0 959 537 A Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 830000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 943 N HW: 1Z0 920 943 N
Component: KOMBI H20 0420
Coding: 710E01
Shop #: WSC 73430 031 00085
VCID: 448761FDCF6CED66EE-8010
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 181210F6000350
Coding: 351303
VCID: 306F3D2D63D461C63A-8064
Component: IMMO H20 0420
VCID: 6ADBEF458D88DB1634-803E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3T0 035 680 G HW: 3T0 035 680 A
Component: RNS-MID H42 5238
Revision: AB001001 Serial number: SKZ6Z7L8003034
Coding: 04000402000100810000
Shop #: WSC 20068 576 98712
VCID: 3467313D97CC5DE65E-8060
Subsystem 1 - Part No: 3T0 051 859 AL
Component: EU West V13 8348
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2120
Coding: 0000756
VCID: 489F75CD3B44C90602-801C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 3467313D57CC5DE65E-8060
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 479D76F1365AC67E0B-8012
Component: AFS-Steuergeraet 0148
Coding: 1507610
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000023
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000023
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012565
VCID: 326B3725ADD853D64C-8066
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3365322152C25ADE47-8066
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 5N0 035 730 D HW: 5N0 035 730 D
Component: Telefon 009 0511
Revision: -------- Serial number: 35909603086523
Coding: 020100000100010000000000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_A01.rod
VCID: 2959D049480E100EFD-807C
End-------------------------(Elapsed Time: 02:27)--------------------------
