I have a 2016 Golf 1.0 TSI where I want to enable Fatigue Detection. So far I´ve enabled the function in 19 CAN Gateway, 17 Instruments and 5F Infotainment. In the guide I found somewhere it mentions, that coding in 03 ABS is needed as well - but currently there is no labelfile for this module. I also own a 2016 Skoda Superb, which has Fatigue Detection. However, the codings can´t be compared 1:1, as the Skoda has ACC, DSG and various other features that the Golf doesn´t have. The ABS module has a slightly different P/N as well.
Has anyone enabled Fatigue Detection on a MQB car? If so, what am I missing? I´ve got the menu for Fatigue Detection in the infotainment, but it says "Function Currently Unavailable" or something similar when I try to turn the function on.
AdMap of 03 ABS has been sent to Ross-Tech, and an autoscan is attached here.
Superb ABS module:
3Q0 907 379 AB:
Coding:
1E076A9C342613720780060641C64978562CC8E0608292F51821F078C222
Tuesday,10,October,2017,22:25:13:21896
VCDS Version: 17.8.0.1
Dealer/Shop Name: N/A
Workshop Code: 001 28430 022332
VIN: WVWZZZAUZGW License Plate:
Mileage: 25852km-16063mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW060716 Mileage: 25852km-16063miles
Address 01: Engine (J623-CHZD) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 AB HW: 04C 907 309 AE
Component: R3 1.0l TFS H24 2255
Revision: W1H24---
Coding: 01190032232415086000
ASAM Dataset: EV_ECM10TFS01104C906026AB 001004
ROD: EV_ECM10TFS01104C906026AB_VW37.rod
VCID: 61E75E0D701C224EE5-8034
CAN Converter 01:
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Revision: 00000000 Serial number: 61865000004868
Coding: 01FA6AA11426296C077E060141C92580562894E06082A4F300200078C002
VCID: 7EDD0571E1A2FDB6F8-802A
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020003200100011005004000101002
VCID: 6AF539218D2A611634-803E
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0173
Serial number: 01061518802465
Coding: 00000846C2C102FB4BE44000001C07081008000000000000000000000000
Shop #: WSC 28430 001 22332
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 093766ADA86CCA0EDD-805C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150627 043 0551
Serial number: 150701181353
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M07D15H23M55S33
Coding: 90A8DD
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331519403923
Coding: 0031051001
VCID: 43ABB485CAC0505ED7-8016
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR0XGU7U
VCID: 7F23F875E6A8F4BEF3-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B09071511125
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B08071571482
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 207 15
Serial number: 35767000000CA048F41$
Subsystem 4 - Part No SW: ----------- HW: 480 000 307 15
Serial number: 358670000005A258841T
Subsystem 5 - Part No SW: ----------- HW: 480 402 906 15
Serial number: 35165029B1B7E8F3935W
Subsystem 6 - Part No SW: ----------- HW: 480 400 707 15
Serial number: 3526502BF1B7E8F5D20$
Subsystem 7 - Part No SW: ----------- HW: 480 400 107 15
Serial number: 3556502A11C52F303192
Part No SW: 5Q0 953 507 FT HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 11071504400356
Coding: 0400
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 0D3F52BDDC04D62EF1-8058
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 740 A HW: 5G1 920 740 A
Component: KOMBI 207 7640
Coding: 07A51A002380000801083A001400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_009.rod
VCID: 246917192F8E7766CE-8070
16777024 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 8
Mileage: 25852 km
Date: 2017.10.10
Time: 22:18:53
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1224
Revision: -------- Serial number: 0003724282
Coding: 030100043F085700FB00024C080F00010001000000000000000000000000
VCID: 74C92759DFEEA7E69E-8020
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 29150001416610085281
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 6261837103
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 270615BFQ1856A
Coding: 003003208000048000001000
VCID: 41A7BE8DD0DC424EC5-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006672756
Coding: 110000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0103
ROD: EV_SteerAssisMQB.rod
Component: TSG BFS 020 0041
Serial number: 020715BG114228
Coding: 003001208E00048000801000
VCID: 42A5B181D5DA5956DC-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006648106
Coding: 090000
Part No SW: 3Q0 035 819 A HW: 3Q0 035 819 A
Component: MU-S--ER 523 0627
Coding: 02730000FF0000005111000100080A001F0200C40120010001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2F43E8357648C43E23-807A
Subsystem 1 - Part No SW: 3G0 919 605 HW: 3G0 919 605
Component: ABT_Std-2 H43 4064
Serial number: VWZ6Z9R1881489
End-------------------------(Elapsed Time: 03:34)--------------------------
Superb ABS module:
3Q0 907 379 AB:
Coding:
