Results 1 to 6 of 6
Thread: B5 Passat ABS Issue, Input Appreciated
    Oct 2017
    South Florida
    Question B5 Passat ABS Issue, Input Appreciated
    Question...if I'm getting intermittent ABS/Brake/TC all lit (plus three beep chime), increasing in frequency over a couple months, would the ABS module be first area of focus, after physical connections? See below
    18057 - Powertrain Data Bus
    P1649 - 008 - Missing Message from ABS Controller - Intermittent
    Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
    Part No: 3B0 614 111
    Component: ABS/ASR 5.3 FRONT D00
    Coding: 00021
    Shop #: WSC 05314
    VCID: 53F381DCC2E5E2DFB68-51CE
    01203 - Electrical Connection between ABS and Instrument Cluster
    03-10 - No Signal - Intermittent
    18256 - Please check DTC Memory of Engine Controller
    P1848 - 35-10 - - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05314
    VCID: 70B92E5053B3B9C7ABA-513C
    I think so. Those Bosch 5.3 ABS modules are rather notorious...
    Oct 2017
    South Florida
    I think I'll track one down soon to install and code as needed.
    Take apart and re-solder the legs on the crummy solder joints.
    At home
    The Pros
  6. Likes Uwe liked this post
    Oct 2017
    South Florida
    ...a good idea... Most likely, I'll get a warranted refurb...and core the old one, unless I get the time to bench repair it at work.
    Oct 2017
    South Florida
    Guys, I opted to core-exchange through Cheap ABS. The major faults went away after replacement, but I did register a wheel sensor fault. The sensor was pretty oxidized and cruddy, so I cleaned it and have no brake faults, at this point I'll update as I put on a few miles.
  9. Likes Uwe, Jack@European_Parts liked this post
