B5 Passat ABS Issue, Input Appreciated
305illest
South Florida
C?ID=318521
Question...if I'm getting intermittent ABS/Brake/TC all lit (plus three beep chime), increasing in frequency over a couple months, would the ABS module be first area of focus, after physical connections? See below
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00021
Shop #: WSC 05314
VCID: 53F381DCC2E5E2DFB68-51CE
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - Intermittent
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 05314
VCID: 70B92E5053B3B9C7ABA-513C
01316 - ABS Control Module
I think so. Those Bosch 5.3 ABS modules are rather notorious...
305illest
South Florida
C?ID=318521
I think I'll track one down soon to install and code as needed.
Take apart and re-solder the legs on the crummy solder joints.
At home
The Pros
305illest
South Florida
C?ID=318521
...a good idea... Most likely, I'll get a warranted refurb...and core the old one, unless I get the time to bench repair it at work.
305illest
South Florida
C?ID=318521
Guys, I opted to core-exchange through Cheap ABS. The major faults went away after replacement, but I did register a wheel sensor fault. The sensor was pretty oxidized and cruddy, so I cleaned it and have no brake faults, at this point:) I'll update as I put on a few miles.
