Results 1 to 4 of 4
Thread: 2007 3.0Tdi Touareg No start
    Oct 2014
    Kenya
    hello,
    I have a touareg here that came from another workshopi after body work and will not start.
    the statement from the owner is that i had been involved in a minor accident to the front end but nothing major.
    front bumper and the intercooler. the vehicle was starting properly throughout the repairs until it ran out of fuel.
    at this point the owner says the other garage added diesel and managed to start the vehicle. but after switching off
    it did not start again.
    we managed to bleed the diesel lines and am now getting a healthy 464 bar on crank. no faults are logged except the
    ones for low battery every time the battery dies. engine speed gets upto 210 rpm on crank then drops to 160rpm after a few seconds of sustained
    cranking.
    is there something im missing?
    Saturday,07,October,2017,13:44:34:58772
    VCDS Version: 17.8.0.1 (x64)
    Dealer/Shop Name: Euro Tecnik Ltd
    VIN: WVGZZZ7LZ7D015391   License Plate: KBV 377B
    Mileage: 156350km-97151mi   Repair Order: Eubert Espira
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGZZZ7LZ7D015391   Mileage: 156350km-97151miles
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 7L0 907 401 C    HW:
       Component: 3.0L V6TDI  G000AG  0030
       Revision: --H03---    Serial number: VWZ3Z0F1512826
       Coding: 0011779
       Shop #: WSC 31414 790 00001
       VCID: 2B53E54D89E0A41E0F-5164
    004499 - Fuel Pressure Sensor (G247)
                   P1193 - 001 - Open or Short to Plus - Intermittent
                        Fault Status: 00100001
                        Mileage: 156352 km
                        Torque: 0.0 Nm
                        (no units): 0.0
                        Voltage: 12.69 V
                        Pressure: 0.0 bar
                        Duty Cycle: 7.1 %
       Part No: 09D 927 750 EB
       Component: AL 750 6A           0772
       Coding: 0004200
       VCID: 72ED38296E4AB5D68C-5164
    01312 - Powertrain Data Bus
    16997 - Transmission Control Module
                P0613 - 004 - Processor Malfunction - Intermittent
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0014338
       VCID: 3D77DB1567943AAEA1-5164
       Part No SW: 3D0 909 139     HW: 5WK 484 94
       Component:    Kessy            6700
       Revision: 67006015    Serial number: VWZ3Z0F1512826
       Coding: 0000232
       VCID: 66C554795282597610-5164
    7 Faults Found:
    00189 - Control Circuit 2; Relay for Supply Voltage Terminal 50
    00087 - Terminal 30 for Starting Relevant Consumers
    00185 - Control Circuit; Relay for Supply Voltage Terminal 15
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 AL
       Component: CLIMAtronic R/L     4537
       Coding: 0000530
       VCID: 7AFD1009363ACD96C4-5148
    00532 - Supply Voltage B+
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 M
       Component:                     3003
       Coding: 0098404
       VCID: 4685B4F932427976F0-5164
    9 Faults Found:
    00967 - Left Turn Signals
    00968 - Right Turn Signals
    01117 - Generator Terminal DF Load Signal
       Part No: 3D0 909 601 F
       Component: 0C Airbag 8.4E+ H11 1151
       Coding: 0012355
       VCID: 2645147992029976D0-5164
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
       Part No: 7L6 953 549 H
       Component: Lenksäulenmodul     3401
       Coding: 0010031
       VCID: 4481AEF1047E4B66EE-5164
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 981 M
       Component: KOMBIINSTRUMENT RB8 3211
       Coding: 0007411
       VCID: 4383ADED01704C5ED7-5164
    8 Faults Found:
    02053 - Control Module for Transfer Case (J646)
    00464 - Control Module with Display for Radio and Navigation (J503)
    Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
       Part No: 7L6 815 071 D
       Component: Standheizung E1MAC
       Coding: 0000000
       VCID: 3363FD2D51D0FCDE47-5164
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70E93221604687C67A-5164
    12 Faults Found:
    00456 - Control Module for Access and Start Control (J518)
    01327 - Control Module for Parking Aid (J446)
    01207 - Control Module for Auxiliary Heater (J364)
       Part No: 0AD 927 755 AT
       Component: TRANSFERCASE        0114
       VCID: 0D174BD517B4CA2EF1-5164
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 H
       Component:      Navigation     0028
       Coding: 0000101
       VCID: 4B9385CD2920841E2F-5164
       Part No: 7L0 959 933 H
       Component: YP HSG              0400
       Coding: 0000065
       Shop #: WSC 00046 000 00000
       VCID: 418FA7E51B6C5E4EC5-4B40
       Subsystem 1 - Part No: 7L0 959 701 K
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 K
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L6 959 703
       Component: Tuersteuergeraet HL 0202
       Subsystem 4 - Part No: 7L6 959 704
       Component: Tuersteuergeraet HR 0202
       Subsystem 5 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
       Subsystem 6 - Part No: 7L6 951 171 B
       Component:    Innenraumsensor  0020
    14 Faults Found:
    00576 - Terminal 15
    01134 - Alarm Horn (H12)
    01503 - Bulb for 3rd Brake Light (M25)
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 D
       Component:        Radio        0028
       Coding: 0014452
       VCID: 3461FE3154DEFBE65E-5164
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 L
       Component: Front Wiper         4027
       Coding: 0000336
       Shop #: WSC 31414 790 376833
       Component: RLS nicht vorhanden
       Coding: 00000000
    End-------------------------(Elapsed Time: 10:11)--------------------------
    Yup G247 has either failed or there is a blown fuse/damaged wire from running dry on fuel or tugging stuff.
  3. Likes Uwe, The One liked this post
    Oct 2014
    Kenya
    the G247 fault was caused by us when checking the socket was plugged in properly. no faults are logged otherwise........
    Have you tried starting it with a battery charger connected? Maybe the crank speed is a little low and injectors are not switching on. Try scoping the injectors.
