Results 1 to 6 of 6
Thread: TOURAN WILL NOT ADAPT KEYS
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Good morning. trying to adapt new remotes and the Convenience will not let me do this via adatation 01. I enter the amount of keys id like to adapt and it just keeps saying 0.
    Thursday,05,October,2017,08:43:50:44004
    VCDS Version: 17.8.0.1 (x64)
    Dealer/Shop Name: Victoria Volkswagen.
    Workshop Code: 210 01843 000002
    Mileage: 262130km-162880mi   Repair Order:
    Adaptation Channel 001:
    Stored value 0
    Test value 0
    Remote control adaptation
      Key
      0  Count
    full scan as follows
    Thursday,05,October,2017,08:44:04:44004
    VIN:    License Plate: TORUAN
    Chassis Type: 1T (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 69 72
    VIN: WVGZZZ1TZ6W037655   Mileage: 262130km-162880miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 016 CD    HW: 028 101 194 5
       Component: R4 1,9L EDC G000SG  6246
       Revision: 12345678    Serial number: VWZ7Z0E2438300
       Coding: 0000072
       Shop #: WSC 01324 785 00200
       VCID: 67DA06D756C6307E2B-8032
    18049 - Please check DTC Memory of A/C Controller
                P1641 - 000 -
                        RPM: 798 /min
                        Torque: 30.0 Nm
                        Voltage: 14.29 V
                        Bin. Bits: 00001100
                        Temperature: 56.7°C
                        (no units): 0.0
                P1570 - 000 -  - Intermittent
                        Torque: 0.0 Nm
                        Voltage: 12.24 V
                        Bin. Bits: 00001100
                        Bin. Bits: 11000000
                        (no units): 1.0
    Readiness: 0 0 0 1 1
       Revision: 00H11001
       Coding: 0021190
       Shop #: WSC 61891 133 86822
       VCID: 73E26287121ECCDE87-8026
       Part No: 1K0 820 047 DF
       Component: Climatic PQ35   090 0505
       VCID: 6BD27AE74A2E141E4F-803E
                009 - Open or Short to Ground
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000000010656
       Coding: 00890F211004100000120C000000000000087B075C
       VCID: 2A5CBFE38554CD16F4-807E
       Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW358  012  0401
       Coding: 00065493
       Shop #: WSC 61891
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
       Component: 02 AIRBAG VW62 0506 1500
       Revision: 09025000    Serial number: 0038BD0EFZER
       Coding: 0012338
       VCID: 35669C9F5CEA92EE69-8060
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 034 0070
       Coding: 0000042
       VCID: 76E45B93016CD9F6A0-8022
    00888 - Wiper Switch for Intermittent Operation (E22)
       Part No: 1T0 920 962 A
       Component: KOMBIINSTRUMENT VDD 1012
       Coding: 0002401
       Shop #: WSC 00011 067 57207
       VCID: 326CA783AD8485D64C-8066
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 H
       Component: Zuheizer        031 1312
       Revision:        A    Serial number: 09010046
       Coding: 0000011
       Shop #: WSC 01843 210 00002
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001057080CD3
       Coding: 3D3F5340078003
       Component: IMMO            VDD 1012
       Shop #: WSC 00666 210 83946
       Part No: 1T0 959 701 B
       Component: Tuer-SG         024 2302
       Coding: 0000692
       VCID: 36649B9341EC99F660-8062
       Part No: 1K2 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: 3362A287529E8CDE47-FFFE
    No Faults Found
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AK
       Coding: 01C802087F2D8405485FC61010CC
       VCID: 79FE50AF3072B68ECD-802C
       Subsystem 5 - Part No: 1K0 947 291 F
       Component: Innenraumueberw.009 4809
       Coding: 00000000
       Subsystem 6 - Part No: 1K0 951 605 C
       Subsystem 7 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Part No: 1T0 959 702 B
       Coding: 0000692
       VCID: 377A969746E660FE7B-8062
       Part No: 1K0 035 186 P
       Component: Radio BVX       017 0023
       Coding: 0040400
       VCID: 3362A287529E8CDE47-8066
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 B
       Component: Tuersteuergeraet 06 0214
       Coding: 0000048
       VCID: 2F6AAEF7BEB6A83E23-807A
    Address 69: Trailer        Labels: RETROFIT69.lbl
       Part No SW: 5F0 01V 000 6    HW: 8P0 907 383
       Component: TRAILER ECS
       Shop #: WSC 00164 211 66245
       VCID: 285845EB9B58FF06E2-807C
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 B
       Coding: 0000048
       VCID: 3068AD8BA388B7C63A-8064
    End-------------------------(Elapsed Time: 02:00)--------------------------
    any help would be greatly appreciated.
    Jun 2016
    Any body? its driving me crackers
    Do you see anything happening in MVBs 010 or 011 when you push the buttons on the remotes?
    Tartu, Estonia
    New from dealer? New as New/Used? Or New from eBay?
    The world is my oyster...
  5. Likes Uwe liked this post
    Nov 2014
    New Zealand
    Did you clear the remotes in 000 first?
    I had to clear mine, before I could match any in my '06 Touran - it only allowed the 2 already matched ones. I can't remember exactly what happened or not, but certainly the additional remotes wouldn't work initially.
    I matched 2 used originals from the Touran, and one from a Golf R32 (that was one of the donor vehicles).
    an old scan:
    Monday,17,April,2017,16:22:03:42165
    VCDS Version: 17.1.3.0 (x64)
    Workshop Code: 123 12345 045678
    VIN: WVWZZZ1KZ6W124470   License Plate:
    Mileage: 71240km-44266mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ6W124470   Mileage: 71240km-44266miles
    22-AWD -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 022-906-032-BDB.lbl
       Part No SW: 022 906 032 CD    HW:
       Component: MOTRONIC ME7.1.1    7802
       Revision: --H01---    Serial number: VWZ7Z0E3138758
       Coding: 0000172
       Shop #: WSC 12345 123 45678
       VCID: 4FAD5C06DE79993920-801A
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
       Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
       Component: ESP 4MOTION MK60    0102
       Revision: 00H13001
       Coding: 0004738
       Shop #: WSC 01279 785 00200
       VCID: 72EBF5F26D0B94D1EF-8026
    6 Faults Found:
       Part No: 1K0 907 044 BD
       Component: ClimatronicPQ35 090 0808
       VCID: 6ADBED9245DB5C1157-803E
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Revision: 00H37000    Serial number: 00000005382893
       Coding: 008D0F210004100000120C000000000000097B075C
       VCID: 2A5B2D92855B9C1197-807E
       Coding: 00063445
       Shop #: WSC 01324
       Revision: 09025000    Serial number: 0038BD0H4NRK
       Coding: 0012338
       VCID: 35610EEE5CE5C3E90A-8060
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
       Coding: 0000042
       VCID: 76E3C9E2016388F1C3-8022
       Part No: 1K6 920 862 F
       Component: KOMBIINSTRUMENT VDD 4316
       Coding: 0001103
       Shop #: WSC 00070 824 83288
       VCID: 336530F65291DDD924-8066
    00771 - Fuel Level Sensor (G)
                010 - Open or Short to Plus
    00438 - Fuel Supply Sensor 2 (G169)
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Revision:   H10       Serial number: 2800106127113D
       Coding: BD3F0340078003
                        Fault Frequency: 24
                        Reset counter: 125
                        Mileage: 71127 km
                        Time: 15:42:18
    Address 22: AWD
       Component: IMMO            VDD 4316
       Coding: 0000692
       VCID: 366309E241E3C8F103-8062
    00943 - Heated Exterior Mirror; Driver Side (Z4)
       Part No: 1K2 909 144 K
       Component: EPS_ZFLS Kl.0   D06 1701
       VCID: 346733EA579FDAE13D-8060
    02546 - Steering Limit Stop
                        Mileage: 3280 km
                        Temperature: 18.0°C
                        Voltage: 12.30 V
                        Voltage: 12.20 V
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Coding: 00C802087F2D8405485FC61010CC
       Shop #: WSC 00010 824 05318
       VCID: 79F9C2DE307DE789AE-802C
       Coding: 00000000
       Coding: 0000692
       VCID: 377D04E646E931F918-8062
       Component: Radio GR0       015 0019
       Revision: 0001503S    Serial number: VWZ2Z2F3751220
       Coding: 0040400
       Part No: 1K0 959 703 E
       Component: Tuer-SG         021 2428
       Coding: 0000144
       VCID: 326B35F2AD8BD4D12F-8066
       Part No: 1K0 959 704 E
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:47)--------------------------
  7. Likes Uwe liked this post
    Oct 2016
    Yes clear all remotes first,then reprogram
