TOURAN WILL NOT ADAPT KEYS
Danners74
C?ID=273244
Good morning. trying to adapt new remotes and the Convenience will not let me do this via adatation 01. I enter the amount of keys id like to adapt and it just keeps saying 0.
Thursday,05,October,2017,08:43:50:44004
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: Victoria Volkswagen.
Workshop Code: 210 01843 000002
Mileage: 262130km-162880mi   Repair Order:
Adaptation Channel 001:
Stored value 0
Test value 0
Remote control adaptation
  Key
  0  Count
full scan as follows
Thursday,05,October,2017,08:44:04:44004
VIN:    License Plate: TORUAN
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 69 72
VIN: WVGZZZ1TZ6W037655   Mileage: 262130km-162880miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 CD    HW: 028 101 194 5
   Component: R4 1,9L EDC G000SG  6246
   Revision: 12345678    Serial number: VWZ7Z0E2438300
   Coding: 0000072
   Shop #: WSC 01324 785 00200
   VCID: 67DA06D756C6307E2B-8032
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
                    RPM: 798 /min
                    Torque: 30.0 Nm
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00001100
                    Temperature: 56.7°C
                    (no units): 0.0
17978 - Engine Start Blocked by Immobilizer
            P1570 - 000 -  - Intermittent
                    Torque: 0.0 Nm
                    Load: 0.0 %
                    Voltage: 12.24 V
                    Bin. Bits: 00001100
                    Bin. Bits: 11000000
                    (no units): 1.0
Readiness: 0 0 0 1 1
   Revision: 00H11001
   Coding: 0021190
   Shop #: WSC 61891 133 86822
   VCID: 73E26287121ECCDE87-8026
   Part No: 1K0 820 047 DF
   Component: Climatic PQ35   090 0505
   VCID: 6BD27AE74A2E141E4F-803E
            009 - Open or Short to Ground
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000010656
   Coding: 00890F211004100000120C000000000000087B075C
   VCID: 2A5CBFE38554CD16F4-807E
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00065493
   Shop #: WSC 61891
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD0EFZER
   Coding: 0012338
   VCID: 35669C9F5CEA92EE69-8060
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76E45B93016CD9F6A0-8022
00888 - Wiper Switch for Intermittent Operation (E22)
   Part No: 1T0 920 962 A
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0002401
   Shop #: WSC 00011 067 57207
   VCID: 326CA783AD8485D64C-8066
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 H
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
   Shop #: WSC 01843 210 00002
   Revision:   H10       Serial number: 28001057080CD3
   Coding: 3D3F5340078003
   Component: IMMO            VDD 1012
   Shop #: WSC 00666 210 83946
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2302
   Coding: 0000692
   VCID: 36649B9341EC99F660-8062
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 3362A287529E8CDE47-FFFE
No Faults Found
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 01C802087F2D8405485FC61010CC
   VCID: 79FE50AF3072B68ECD-802C
   Subsystem 5 - Part No: 1K0 947 291 F
   Component: Innenraumueberw.009 4809
   Coding: 00000000
   Subsystem 7 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Part No: 1T0 959 702 B
   Coding: 0000692
   VCID: 377A969746E660FE7B-8062
   Part No: 1K0 035 186 P
   Component: Radio BVX       017 0023
   Coding: 0040400
   VCID: 3362A287529E8CDE47-8066
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0214
   Coding: 0000048
   VCID: 2F6AAEF7BEB6A83E23-807A
Address 69: Trailer        Labels: RETROFIT69.lbl
   Part No SW: 5F0 01V 000 6    HW: 8P0 907 383
   Component: TRAILER ECS
   Coding: 0000001
   Shop #: WSC 00164 211 66245
   VCID: 285845EB9B58FF06E2-807C
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
   VCID: 3068AD8BA388B7C63A-8064
End-------------------------(Elapsed Time: 02:00)--------------------------
any help would be greatly appreciated.
Danners74
C?ID=273244
Any body? its driving me crackers
Do you see anything happening in MVBs 010 or 011 when you push the buttons on the remotes?
golfi_vend
Tartu, Estonia
C?ID=195131
New from dealer? New as New/Used? Or New from eBay?
NZDubNurd
New Zealand
C?ID=230482
Did you clear the remotes in 000 first?
I had to clear mine, before I could match any in my '06 Touran - it only allowed the 2 already matched ones. I can't remember exactly what happened or not, but certainly the additional remotes wouldn't work initially.
I matched 2 used originals from the Touran, and one from a Golf R32 (that was one of the donor vehicles).
an old scan:
Monday,17,April,2017,16:22:03:42165
VCDS Version: 17.1.3.0 (x64)
Workshop Code: 123 12345 045678
VIN: WVWZZZ1KZ6W124470   License Plate:
Mileage: 71240km-44266mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W124470   Mileage: 71240km-44266miles
22-AWD -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CD    HW:
   Component: MOTRONIC ME7.1.1    7802
   Revision: --H01---    Serial number: VWZ7Z0E3138758
   Coding: 0000172
   Shop #: WSC 12345 123 45678
   VCID: 4FAD5C06DE79993920-801A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 72EBF5F26D0B94D1EF-8026
            000 -  -
01324 - Control Module for All Wheel Drive (J492)
   Part No: 1K0 907 044 BD
   Component: ClimatronicPQ35 090 0808
   VCID: 6ADBED9245DB5C1157-803E
            000 -  -
   Revision: 00H37000    Serial number: 00000005382893
   Coding: 008D0F210004100000120C000000000000097B075C
   VCID: 2A5B2D92855B9C1197-807E
   Coding: 00063445
   Shop #: WSC 01324
   Revision: 09025000    Serial number: 0038BD0H4NRK
   Coding: 0012338
   VCID: 35610EEE5CE5C3E90A-8060
            008 - Implausible Signal - MIL ON
   Coding: 0000042
   VCID: 76E3C9E2016388F1C3-8022
   Part No: 1K6 920 862 F
   Component: KOMBIINSTRUMENT VDD 4316
   Coding: 0001103
   Shop #: WSC 00070 824 83288
   VCID: 336530F65291DDD924-8066
00771 - Fuel Level Sensor (G)
            010 - Open or Short to Plus
00438 - Fuel Supply Sensor 2 (G169)
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Revision:   H10       Serial number: 2800106127113D
   Coding: BD3F0340078003
                    Fault Frequency: 24
                    Reset counter: 125
                    Mileage: 71127 km
                    Time: 15:42:18
Address 22: AWD
   Component: IMMO            VDD 4316
   Coding: 0000692
   VCID: 366309E241E3C8F103-8062
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.0   D06 1701
   VCID: 346733EA579FDAE13D-8060
02546 - Steering Limit Stop
                    Mileage: 3280 km
                    Temperature: 18.0°C
                    Voltage: 12.30 V
                    Voltage: 12.20 V
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Coding: 00C802087F2D8405485FC61010CC
   Shop #: WSC 00010 824 05318
   VCID: 79F9C2DE307DE789AE-802C
   Coding: 00000000
   Coding: 0000692
   VCID: 377D04E646E931F918-8062
   Component: Radio GR0       015 0019
   Revision: 0001503S    Serial number: VWZ2Z2F3751220
   Coding: 0040400
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2428
   Coding: 0000144
   VCID: 326B35F2AD8BD4D12F-8066
   Part No: 1K0 959 704 E
   Coding: 0000144
End-------------------------(Elapsed Time: 01:47)--------------------------
Radiosolutions
C?ID=178437
Yes clear all remotes first,then reprogram
