Hey guys,
Having some trouble with an A4.
Water ingress to the CCM in the footwell, Wiring appears to be fine, Old CCM can be read when its at a certain angle but comes up with lots of codes when it does read, i am guessing these are just due to the water ingress.
Purchased a New, Sealed CCM from TPS with the same part number bar the letter on the end changed from a C to a D, i queried this and have been told it is just a super-seeded part number.
Read the original coding and the workshop number, saved both of these to the new module just by going coding then editing the figures, coding accepted.
Was advised that the Submodules 3 and 4 were missing and needed to be coded in via channel 61 and 62, this was done to match the old CCM.
The issues that i now have is that i can not get the key remotes to sync with the car, SO far i have tried:
Channel 1 factory reset on the CCM to enable the learning of the remotes.
Channel 21, Learning the keys to spaces 1 and 2.
Syncing the fobs in the door and ignition.
Checking channel 007 to see if they are synced and neither of the keys have.
Have tried this in various sequence and different ways. Also checked the old CCM if i could sync the keys and they could easily be synced withe the key in the door process.
Things i have also tried that probably would have any effect,
Disconnecting the battery for a while
Clearing codes in between
Tried forgetting the keys on the old module but didn't seem to work when i checked 007 they were both still stored. (This makes me think that i may be doing something wrong in the learning process too)
Is there part of coding in a module that i am missing? Should the module have different coding being super-seeded? What are the chances of the module Being Faulty?
Seem to have tried everything that i can find on Ross Tech but not making any progress.
Any help, suggestions or advice would be greatly appreciated.
Most recent scan
Most recent scan
VIN: WAUZZZ8E74A207693 License Plate: A9FEG
Mileage: 250380km-155578mi Repair Order: 3
VCID: 62887C23EC642B56FC-5184
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 01001
Shop #: WSC 63251
VCID: 3522F77F0D6AECEE69-4B1E
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251 000 00000
VCID: 3E30E853685C2FB6B8-5184
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 00042
Shop #: WSC 63251
VCID: 3E30E853385C2FB6B8-4B1E
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01401
Shop #: WSC 00006
VCID: 3326C967031EF2DE47-5184
WAUZZZ8E74A207693 AUZ6Z0C0461275
01039 - Coolant Temperature Sensor (G2)
01176 - Key
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
VCID: 6B9611071BAE6A1E4F-5118
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BC
Component: Komfortgerát TBF 1712
Coding: 07115
Shop #: WSC 63251
VCID: 73A60967439EB2DE87-4B1E
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0004
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0004
01559 - Drivers Door
61-00 - Won't De-Safe
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 M
Component: symphony II NP2 0410
Coding: 01001
Shop #: WSC 00512
VCID: 312AC36FFA02C0CE35-5066
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00114
Shop #: WSC 63251
VCID: 43C699A750BE425ED7-5160
End----------(Elapsed Time: 05:33, VBatt start/end: 14.1V/14.2V)-----------
