Results 11 to 20 of 24
Thread: Coding ABS module (Bosch 5.7)
    Sep 2017
    so i get pass login, and coding, i fallow video to a T I enter 12345 for the 2nd row codes. then i click do it. next i go login again and enter the 40168 for the steering angle calibration, and click do it, and it just go back to main ABS screen. it does not take me to calibrate. also how can i turn wheel with car off. its really hard
  2. #12
    Quote Originally Posted by Apexmaster33 View Post
    hey guys i fallowed the video provided but i am getting the these codes
    Thursday,05,October,2017,18:12:41:43295
    VCDS Version: Release 17.8.0 (x64) Running on Windows 10 x64
    Atanas D
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Control Module Part Number: 8E0 614 517 A
    Component and/or Version: 8E0614517A ABS/ESP allr
    Software Coding: ad 1726
    Work Shop Code:
    VCID: 26150809E1ED9CC7016-5216
    66-10 - Not Matched - Intermittent
    35-00 - -
    Huh?
  3. #13
    I believe these would be correct for this car (assuming it has PR code 1LT or 1LF for the brakes):
    Login: 09395
    Coding: 04495
  4. #14
    Sep 2017
    yes it is 1LF for brakes. i will try again today and let you know.
  5. #15
    Sep 2017
    Hey guys so after input login and coding I get a numbers and letters on the soft code from 00000 to ad1726 but where it says shop# I still have nothing. So I'm not sure why this is happening. Im inputting the correct valued for login and code
  6. #16
    Scratching head. Never seen or heard of "ad1726" appearing in the coding field for one of these.
  7. #17
    Budapest, Hungary
    In your autoscan, the component information is truncated.
    "Component and/or Version: 8E0614517A ABS/ESP allrad 1726" would make sense.
    Why the end of the component information is displayed in the software coding field?
  8. Likes Uwe liked this post
  9. #18
    Sep 2017
    Not sure. What to do next or try??
    What should I do?
  10. #19
    Every customer gets one free car-repair support ticket. I'm going to suggest you call us during business hours, open your free ticket, and have someone talk you through this over the phone. You'll need to to have your PC connected to the car when you call.
  11. #20
    Sep 2017
    So I was able to get the correct code under soft code now and under shop# it say wsc00000. I also calibrate steering says ok. And showing no fault code but still have ABS light on.
    Btw I also have issue w brake dash light flashing . book says it has to do with low brake fluid but I'm top up to max. I noticed with ignition when the brake light starts flashing it break connection between vsdc for a split second then it starts again
