Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Coding ABS module (Bosch 5.7)
    Sep 2017
    Hello.
    I just ordered the Ross tech cable. I need some help or how to code the ABS module on my 04 A4 Quattro.
    Also with the cable is it possible to turn off the alarm or the beeping when locking/unlocking car?
    Thank you
    The first step to getting help is to post a full Auto-Scan once you get your cable. That gives important information on what module hardware & firmware is fitted to your car.
  3. Likes Uwe, Boki Ar liked this post
    Yes, both of those things should be doable on a B6 A4. I would expect it to have a Bosch 5.7 ABS, so have a look at this page and watch the video linked at the bottom.
  5. Likes Boki Ar, Ashraf6119 liked this post
  6. #4
    Sep 2017
    i read that I can do auto scan and copy the abs module, then paste it on the new one? but i already have the new module installed. I guess i can unplug the new one, and plug it on the old then do auto scan and copy.
    Codings on those Bosch 5.7 modules are short enough that Copy & Paste isn't really necessary. However, it would not be a bad idea to see what the old module's coding was. You don't need to do a full Auto-Scan for that; just [Select] -> [03-ABS] and you'll see the coding. If you'd like to save it, go to [Fault Codes] and [Save Codes] even if there aren't any. That will record all of that control module's ID data (including coding).
    Sep 2017
    Great thank you for fast reply and help.
    Sep 2017
    hi guys, I received my Cable last night. im going to try to connect today . so Do I need to connect my old ABS module and do a autoscan 1st, or can I leave my new one in the car and fallow the procedure
  10. #8
    Let's start with a scan from the car in its current condition.
  11. #9
    Sep 2017
    Thursday,05,October,2017,17:48:59:43295
    Dealer/Shop Name: Atanas D
    VIN: WAULT68E14A008323   License Plate: BFR6126
    Mileage: 278430km-173008mi   Repair Order: RO#1
              67 69 75 76 77
    VIN: WAULT68E14A008323   Mileage: 278430km-173008miles
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 L    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0010
       Coding: 0016711
       Shop #: WSC 63351 000 00000
       VCID: 3E25C0691C6D2407696-5160
    8 Faults Found:
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1
                P1116 - 004 - Open Circuit - MIL ON
                P0300 - 002 -  - Intermittent
    16687 - Cylinder 3
                P0303 - 002 - Misfire Detected - Intermittent
    16690 - Cylinder 6
                P0306 - 008 - Misfire Detected - Intermittent
    16686 - Cylinder 2
                P0302 - 002 - Misfire Detected - Intermittent
    16688 - Cylinder 4
                P0304 - 008 - Misfire Detected - Intermittent
    16689 - Cylinder 5
                P0305 - 008 - Misfire Detected - Intermittent
    16685 - Cylinder 1
                P0301 - 002 - Misfire Detected - Intermittent
    Readiness: 0110 1001
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      1726
       Coding: 00000
       VCID: 26150809E1FD9CC7016-5216
                66-10 - Not Matched - Intermittent
                35-00 -  -
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1219
       Coding: 00000
       Shop #: WSC 63351
       VCID: 6393511DD24F29EF268-513C
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       Shop #: WSC 63351
       VCID: 3537DF452C5BE75FB8C-4B00
    01502 - Bulb for Rear Fog; Left (L46)
                57-00 - Electric Circuit Failure
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 C
       Component: Airbag 8.4EP        2000
       Coding: 0010607
       VCID: 372BD54D3357154FAA0-5184
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0308
       Coding: 02041
       Shop #: WSC 63351
       VCID: 3E25C069196D2407696-4B00
       Part No: 8E0 920 950 L
       Component: KOMBI+WEGFAHRS. RB4 D36
       Coding: 03200
       Shop #: WSC 42336
       VCID: 323DE459DD35F0679DE-5160
       WAULT68E14A008323     AUZ6Z0C0185488
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       Shop #: WSC 63351
       VCID: 71BF2B5518838B7FA44-4B3C
       Part No: 8E0 959 433 BB
       Component: Komfortgerát T7B    1311
       Coding: 11788
       Shop #: WSC 63351
       VCID: 72BD24591DB5B0675DE-4B00
       Component: Tőrsteuer.FS BRM 0003
       Component: Tőrsteuer.BF BRM 0003
    10 Faults Found:
    01134 - Alarm Horn (H12)
                49-00 - No Communications
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
    01559 - Drivers Door
    01560 - Passenger Door
                59-00 - Can't Unlock
                80-00 - Single-Wire Operation
       Part No: 4Z7 907 357
       Coding: 00060
       Shop #: WSC 63351
       VCID: 0451728137318ED77F2-4B3C
                28-10 - Short to Plus - Intermittent
       Part No: 8E0 035 195 H
       Component: symphony II NP2    0260
       Coding: 01005
       Shop #: WSC 85504
       VCID: 2C01FA21FF21A697D72-5042
    00878 - Connection to Speaker Front Left
    End----(Elapsed Time: 05:55, VBatt start/end: 12.3V/12.2V. VIgn 0.0V)------
  12. #10
    Sep 2017
    hey guys i fallowed the video provided but i am getting the these codes
    Thursday,05,October,2017,18:12:41:43295
    VCDS Version: Release 17.8.0 (x64) Running on Windows 10 x64
    Atanas D
    Control Module Part Number: 8E0 614 517 A
    Component and/or Version: 8E0614517A ABS/ESP allr
    Software Coding: ad 1726
    Work Shop Code:
    VCID: 26150809E1ED9CC7016-5216
    35-00 - -
