14 reg. car was in light frontend accident,and 2 lights replaced with secondhand ones. 2 faults stored are. 5276945 positioning motor for headlight range left ,short to ground. same fault for rh light. tried brand new light but fault still exists. could someone check coding in file attached. is there anyway I can code these faults out. all wiring been checked, it was very light damage,only front bumper and lights,but damaged lights did not come with car. thanks
Friday,29,September,2017,13:22:49:42542
VCDS Version: 17.8.0.1
VIN: WVWZZZAUZFP514299 License Plate: WO14DWE
Mileage: 49732km-30902mi Repair Order: HARVEYS
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A5
VIN: WVWZZZAUZFP514299 Mileage: 49732km-30902miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22---
Coding: 01110032034505093000
Shop #: WSC 00028 028 00072
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F6DC21976BB623E23-807A
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61674000002456
Coding: 04FA8AA1242109700379060941CC2520512490C06082A4F3F440F07AC002
Shop #: WSC 00028 028 00066
VCID: 458180B1C407C86EF9-8010
Revision: 00021000 Serial number: 0338550473
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A7BE34DBDF9B79684-806E
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 13 [009] - Open Circuit
Fault Frequency: 52
Reset counter: 135
Mileage: 49732 km
Date: 2017.08.31
Time: 09:40:31
1057291 - Antenna for Keyless Entry System; Passenger Side
B1170 13 [009] - Open Circuit
Reset counter: 135
Mileage: 49732 km
Date: 2017.08.31
Time: 09:38:52
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 02120124202400011105000200101000
VCID: 73E50E69DA1306DE87-8026
Air quality sensor:
B10CD 00 [009] - -
Reset counter: 135
Mileage: 49732 km
Date: 2017.09.29
Time: 11:21:00
Voltage terminal 30: 11.1 V
CAN input signal(s) status-Back-up light: OFF
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86582506141007
Coding: 03510B66C24122FB0BA44080B11C07281800000000000000000000000000
Shop #: WSC 00020 210 01865
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: 79F93C41F87F7C8ECD-802C
Component: WWS 140614 042 0551
Serial number: 140616141856
Component: RLHS 037 0059
Serial number: S4Y14M06D26H12M59S42
Coding: 00A8EE
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141270NDT
Serial number: 00000000000030114635
Sun Roof:
Subsystem 5 - Part No SW: 5G0 959 591 HW: 7P0 959 591 C
Component: J245 PS22.018 H01 0008
Serial number: WOO29607514
Coding: 191900
Roof Blind:
Subsystem 6 - Part No SW: 5G0 959 591 HW: 7P0 959 591 C
Component: J394 PS22.018 H01 0008
Serial number: WOO2982567D
Coding: 191900
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 175
Mileage: 49732 km
Date: 2017.09.23
Time: 07:50:05
9482 - Statiionary Cornering Lamp Right
B1222 15 [009] - Open or Short to Plus
Reset counter: 135
Mileage: 49732 km
Date: 2017.08.30
Time: 10:24:29
9226 - Stationary Cornering Lamp Left
B1221 15 [009] - Open or Short to Plus
Reset counter: 135
Mileage: 49732 km
Date: 2017.08.30
Time: 10:24:29
17162 - Bulb for Left DRL and Parking Lamp
B12EA 15 [009] - Open or Short to Plus
Reset counter: 135
Mileage: 49732 km
Date: 2017.08.30
Time: 10:16:21
17418 - Bulb for Right DRL and Parking Lamp
B12EB 15 [009] - Open or Short to Plus
Reset counter: 135
Mileage: 49732 km
Date: 2017.08.30
Time: 10:16:21
204546 - Remote key 2
Reset counter: 135
Mileage: 49732 km
Date: 2017.08.30
Time: 10:32:27
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431415701295
Coding: 0131161041
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 428B9BADD529FF56DC-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 B
Component: ACC Bosch MQB H04 0304
Serial number: 16051477031169
Coding: 00000700FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001015
VCID: 387FF94583F5A58672-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR06FH8X
Shop #: WSC 00028 028 00059
VCID: 7F0DD259E65B52BEF3-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B20061441273
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B22061440150
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 806 14
Serial number: 357670000008694DFF0C
Subsystem 4 - Part No SW: ----------- HW: 480 001 306 14
Serial number: 358670000005A5ACFF0F
Subsystem 5 - Part No SW: ----------- HW: 480 401 806 14
Serial number: 3516502B71697524721+
Subsystem 6 - Part No SW: ----------- HW: 480 401 806 14
Serial number: 3526502B71697524213
Subsystem 7 - Part No SW: ----------- HW: 480 400 502 13
Serial number: 3556502AB0F53D62225E
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0155
Revision: FF028028 Serial number: 20140623500098
Coding: 0C00
ROD: EV_SMLSVALEOMQB_VW37.rod
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 951 HW: 5G1 920 951
Component: KOMBI 304 4270
Coding: 27A512106F94260001887A031400000000000000
VCID: 67DD6A399ECBFA7E2B-8032
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 17061410800453
Coding: 030100040B087300EF00025C080F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
Component: E221__MFL-DC1 H16 0038
Serial number: 27140001229390064231
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 7368553603
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000151288004
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 3467CD759F9D41E65E-8060
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000107432243
Coding: 00311220D001028000001000
VCID: 44879DB5CF3DF166EE-8010
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005771844
Coding: 0D0000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 9303
ROD: EV_SteerAssisMQB_010.rod
VCID: 418994A1D02FE44EC5-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000107450900
Coding: 00311020DE01028000801000
VCID: 43859EA9CA33F65ED7-8016
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005768547
Coding: 050000
Component: LWR-ECU 005 0080
Coding: 068E000001010000
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75E13071D46718EEA9-8020
5276945 - Positioning Motor for Headlight Range Left
C1085 11 [137] - Short to Ground
Reset counter: 135
Mileage: 49732 km
Date: 2017.09.29
Time: 12:13:17
5277201 - Positioning Motor for Headlight Range Right
C1086 11 [137] - Short to Ground
Reset counter: 135
Mileage: 49732 km
Date: 2017.09.29
Time: 12:13:17
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 10000096442
Coding: 0101010001020303020300000100010100
ROD: EV_MFKBoschAU370.rod
VCID: 3B75E649B2C38E9E9F-806E
End-------------------------(Elapsed Time: 04:34)--------------------------
