Octavia mk3 us lights and DRL
Claudiu
C?ID=221613
Hello guys,
I am trying to sort someone mess out on an Octavia 3 and need your help. Basically someone tried to code US lights on the car (with the switch in all positions) and now the DRL don't work in 0 position and Auto during daytime (they work on Auto night time) and also when indicating the relay goes twice the speed like one of the bulbs is out, but all are ok, on hazard relay works normal. Can you please help out.
Scan attached
Wednesday,27,September,2017,22:32:13:53651
VCDS Version: 17.8.0.1 (x64)
VIN: TMBJG9NE6E0117159   License Plate: DP54154
Mileage: 151202km-93952mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 42 44 52 55 5F 69
VIN: TMBJG9NE6E0117159   Mileage: 151202km-93952miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 6547
   Revision: 84H22---
   Coding: 01250012043401090000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM16TDI01104L906021N 002011
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 306F76E56BF2C0C17F-8064
   Part No SW: 0CW 300 047 C    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5260
   Revision: 00043014    Serial number: CU501311135854
   ROD: EV_TCMDQ200021.rod
   VCID: 3B7551C9B2B43399DA-806E
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 631730000000D4
   Coding: 1C076291242109730078060541CC243846249000608224F000410070C002
   Shop #: WSC 73430 031 00063
   VCID: 4B950109E21483196A-801E
   Part No SW: 5E0 907 044 F    HW: 5E0 907 044 F
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02010104002100011005000000100000
   VCID: 285F9E8553228801A7-807C
328196 - Motor for Right Temperature Flap
          B108D 71 [008] - Actuator stuck
                    Fault Frequency: 18
                    Reset counter: 89
                    Mileage: 147583 km
                    Date: 2017.07.22
                    Time: 11:14:39
                    Voltage terminal 30: 11.5 V
                    Outside air temperature: 23.5 °C
                    Interior temperature: 26.9 °C
                    Right temperature flap: actual value: 47
                    Right temperature flap: actual value: 8.0 %
                    Right temperature flap: specified value: 41
          P1719 00 [008] - -
                    Reset counter: 76
                    Mileage: 149693 km
                    Date: 2017.09.12
                    Time: 07:00:16
                    Voltage terminal 30: 13.5 V
                    Auxiliary heater: in stages-Act.value: 1
   Part No SW: 5Q0 937 086 Q    HW: 5Q0 937 086 Q
   Component: BCM PQ37BOSCH 026 0095
   Revision: --------    Serial number: 86581211130488
   Coding: 0C021B46424722FB47E04000001C07080000000000000000000000000000
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 489F3E05F362680147-801C
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 131115  041 0570
   Serial number:         131116115930
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M11D08H15M40S35S6
   Coding: 02805D
8714 - Bulb for Left Fog Lamp
          B121F 15 [009] - Open or Short to Plus
                    Fault Frequency: 7
                    Reset counter: 24
                    Mileage: 148637 km
                    Date: 2017.08.26
                    Time: 20:41:04
6410 - Bulb for Rear Right Side Turn Signal
          B12D1 15 [008] - Open or Short to Plus
8970 - Bulb for Right Fog Lamp
          B1220 15 [009] - Open or Short to Plus
                    Reset counter: 223
                    Mileage: 148637 km
                    Date: 2017.08.26
                    Time: 20:56:03
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831332200819
   Coding: 0001050111
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000_SK25.rod
   VCID: 387F4EC58382188137-806C
   Part No SW: 3Q0 959 655 AA    HW: 3Q0 959 655 AA
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003NYPQ1GV4Y
   Coding: 98FCC000000000005C5400CC000800000065
   Shop #: WSC 73430 790 00000
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7DF19FD1EC20FDA9A4-8028
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169593B20111370980
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169592B20111370893
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 000 411 13
   Serial number: 3576U0000007DAA02E0L
   Subsystem 4 - Part No SW: -----------    HW: 454 000 111 13
   Serial number: 3586U000000384902E06
   Subsystem 5 - Part No SW: -----------    HW: 454 800 311 13
   Serial number: 3516R6D4955020000000
   Subsystem 6 - Part No SW: -----------    HW: 454 800 311 13
   Serial number: 3526REA9C3B02000000I
   Subsystem 7 - Part No SW: -----------    HW: 454 801 510 13
   Serial number: 3556V6BC104020000000
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 20111304221768
   Coding: 1410
   ROD: EV_SMLSKLOMQB_AU37.rod
   Part No SW: 5E0 920 871 D    HW: 5E0 920 871 D
   Component: KOMBI         333 2210
   Coding: 07AD0A0829800008010A2A00000000
   Shop #: WSC 73430 031 12345
   VCID: 29599B814828B109B8-807C
   Revision: --------    Serial number: 0001264129
   Coding: 030100340F087300EF00024E1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_010.rod
   VCID: 3F8D25D9A6AC2FB9F6-806A
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000A0991111113
   Serial number: 6895131803
Address 20: High Beam Assist. (J844)       Labels: 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 02018F6B76765D525220343E01
   VCID: 2B55618942D4A3194A-807E
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000082263148
   Coding: 00150120D000048000001100
   VCID: 44872A35CF4A4C61AB-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000001122557
   Coding: 010200
   Coding: 0103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41892321D058594980-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000083005545
   VCID: 43852929CA444B5992-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000001021432
   Coding: 190200
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 03CA02003F000000
   Shop #: WSC 73430 790 00063
   VCID: 3D715FD1ACA03DA9E4-8068
   Coding: 3E0000
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels: 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 842 A    HW: 5E0 035 842 A
   Component: MU-S-D-ER     040 0421
   Serial number: S7E01711130204
   Coding: 03730200FF0000001111120100A800002F0000840100010002
   ROD: EV_MUStd4CPASE_AU37.rod
   VCID: 214983A130187949E0-8074
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H50 0022
   Serial number: SKZ8Z9NK600LS1
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383     HW: 5Q0 907 383
   Component: Anhaenger     H11 0030
   Revision: 6A001003    Serial number: 00000194826608
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctDemouHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 74E7BAF5DF6ABCE1DB-8020
End-------------------------(Elapsed Time: 04:16)--------------------------
Channel map attached
IDE00001-ENG99061-Production mode-Access control	not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active
IDE00002-Transport mode	active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	1100 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	600 ms
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active
IDE01550-Service position	166.505329 °
IDE02152-Characteristics in production mode	0 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	No
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	No
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	not active
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel	not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	40%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	40%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	40%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-0.25 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	90 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	30 °
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separate
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	SMLS
IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.10%
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	20.00%
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	50 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	50 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG17816-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus	active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	not active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	116
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	2
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active
IDE04927-IDE01446-Window heater-Running time of heated front window	600 s
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung	35.0 °C
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung	35.0 °C
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	Default
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme
IDE04928-ENG17832-Anti-theft device-Überwachung Innenentriegelungshebel	not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	not active
IDE05142-ENG116706-Access control-Autounlock NAR	not active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung	not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung	not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschließfunktion	active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Always
IDE05142-ENG17882-Access control-Softtouch-Betätigung senden	Always
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10	37
IDE05145-ENG116082-Light configuration-BAP Bitposition 11	41
IDE05145-ENG116101-Light configuration-BAP Bitposition 12	38
IDE05145-ENG116120-Light configuration-BAP Bitposition 13	42
IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0
IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0
IDE05145-ENG116177-Light configuration-BAP Bitposition 16	35
IDE05145-ENG116196-Light configuration-BAP Bitposition 17	3F
IDE05145-ENG116215-Light configuration-BAP Bitposition 18	8
IDE05145-ENG116234-Light configuration-BAP Bitposition 19	18
IDE05145-ENG115911-Light configuration-BAP Bitposition 2	48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20	9
IDE05145-ENG116272-Light configuration-BAP Bitposition 21	19
IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29
IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0A
IDE05145-ENG116329-Light configuration-BAP Bitposition 24	1A
IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28
IDE05145-ENG116367-Light configuration-BAP Bitposition 26	0C
IDE05145-ENG116386-Light configuration-BAP Bitposition 27	1C
IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B
IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B
IDE05145-ENG115930-Light configuration-BAP Bitposition 3	4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0
IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0
IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0
IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0
IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0
IDE05145-ENG115949-Light configuration-BAP Bitposition 4	3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5	44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8	0
IDE05145-ENG116044-Light configuration-BAP Bitposition 9	0
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	minimize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	minimize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	maximize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	maximize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	maximize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	maximize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	maximize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0	50
IDE05145-ENG115897-Light configuration-Dimmwert AB 1	50
IDE05145-ENG116067-Light configuration-Dimmwert AB 10	127
IDE05145-ENG116086-Light configuration-Dimmwert AB 11	127
IDE05145-ENG116105-Light configuration-Dimmwert AB 12	100
IDE05145-ENG116124-Light configuration-Dimmwert AB 13	100
IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16	100
IDE05145-ENG116200-Light configuration-Dimmwert AB 17	100
IDE05145-ENG116219-Light configuration-Dimmwert AB 18	100
IDE05145-ENG116238-Light configuration-Dimmwert AB 19	100
IDE05145-ENG115915-Light configuration-Dimmwert AB 2	35
IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23	100
IDE05145-ENG116333-Light configuration-Dimmwert AB 24	100
IDE05145-ENG116352-Light configuration-Dimmwert AB 25	100
IDE05145-ENG116371-Light configuration-Dimmwert AB 26	100
IDE05145-ENG116390-Light configuration-Dimmwert AB 27	100
IDE05145-ENG116409-Light configuration-Dimmwert AB 28	100
IDE05145-ENG116428-Light configuration-Dimmwert AB 29	100
IDE05145-ENG115934-Light configuration-Dimmwert AB 3	35
IDE05145-ENG116447-Light configuration-Dimmwert AB 30	100
IDE05145-ENG116466-Light configuration-Dimmwert AB 31	100
IDE05145-ENG116485-Light configuration-Dimmwert AB 32	100
IDE05145-ENG116504-Light configuration-Dimmwert AB 33	100
IDE05145-ENG116523-Light configuration-Dimmwert AB 34	100
IDE05145-ENG115953-Light configuration-Dimmwert AB 4	127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5	127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6	127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7	127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8	0
IDE05145-ENG116048-Light configuration-Dimmwert AB 9	0
IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2	35
IDE05145-ENG116261-Light configuration-Dimmwert CD 20	0
IDE05145-ENG116280-Light configuration-Dimmwert CD 21	0
IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23	100
IDE05145-ENG116337-Light configuration-Dimmwert CD 24	100
IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3	35
IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4	127
IDE05145-ENG115976-Light configuration-Dimmwert CD 5	127
IDE05145-ENG115995-Light configuration-Dimmwert CD 6	127
IDE05145-ENG116014-Light configuration-Dimmwert CD 7	127
IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0	100
IDE05145-ENG115905-Light configuration-Dimmwert EF 1	100
IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2	100
IDE05145-ENG116265-Light configuration-Dimmwert EF 20	0
IDE05145-ENG116284-Light configuration-Dimmwert EF 21	0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26	0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27	0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3	100
IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4	127
IDE05145-ENG115980-Light configuration-Dimmwert EF 5	127
IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	1E
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	1F
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	22
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	23
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	0
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	17
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	19
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	16
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	18
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	39
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3A
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	29
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	2A
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	2E
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	2F
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	2
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	3
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	4
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	5
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	6
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	0
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	0
IDE05145-ENG115873-Light configuration-Lasttyp 0	12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116081-Light configuration-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116100-Light configuration-Lasttyp 12	10 - allgemeine Scheinwerfer
IDE05145-ENG116119-Light configuration-Lasttyp 13	10 - allgemeine Scheinwerfer
IDE05145-ENG116138-Light configuration-Lasttyp 14	not active
IDE05145-ENG116157-Light configuration-Lasttyp 15	not active
IDE05145-ENG116176-Light configuration-Lasttyp 16	8 - allgemeine Glühlampe 12W
IDE05145-ENG116195-Light configuration-Lasttyp 17	8 - allgemeine Glühlampe 12W
IDE05145-ENG116214-Light configuration-Lasttyp 18	12 - Blinkleuchten
IDE05145-ENG116233-Light configuration-Lasttyp 19	12 - Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20	34 - LED Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21	34 - LED Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22	34 - LED Bremsleuchten
IDE05145-ENG116309-Light configuration-Lasttyp 23	32 - allgemeine LED bis 12W
IDE05145-ENG116328-Light configuration-Lasttyp 24	32 - allgemeine LED bis 12W
IDE05145-ENG116347-Light configuration-Lasttyp 25	18 - 2* 5W
IDE05145-ENG116366-Light configuration-Lasttyp 26	9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116385-Light configuration-Lasttyp 27	9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116404-Light configuration-Lasttyp 28	9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116423-Light configuration-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30	20 - 4* 5W
IDE05145-ENG116461-Light configuration-Lasttyp 31	not active
IDE05145-ENG116480-Light configuration-Lasttyp 32	not active
IDE05145-ENG116499-Light configuration-Lasttyp 33	not active
IDE05145-ENG116518-Light configuration-Lasttyp 34	not active
IDE05145-ENG115948-Light configuration-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8	not active
IDE05145-ENG116043-Light configuration-Lasttyp 9	not active
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	Always
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	Always
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	Always
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	Always
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	10
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	8
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	8
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	13
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	14
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	18
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	19
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	8
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	8
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	2
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	4
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	8
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	8
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	8
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	27
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	28
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	8
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	43
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	45
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	46
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	47
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	48
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	8
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	8
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	0
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	0
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	20
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	20
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	15
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	15
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	22
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	23
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	9
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	9
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	9
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	10
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	30
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	10
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	9
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	10
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	0
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	0
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	3
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	5
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	30
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	0
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	0
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	30
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	30
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	30
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	30
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	30
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	30
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	30
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	0
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	0
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	0
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	20
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	20
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	0
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	0
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	0
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	3
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	4
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	20
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	30
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	30
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	0
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	0
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	20
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	20
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	20
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	0
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	0
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3	0
IDE05145-ENG115979-Light configuration-Lichtfunktion F5	0
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	30 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	1.10 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	33.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	32.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	33.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	32.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	37.50 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	36.50 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	37.50 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	36.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	41.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	40.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	41.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	40.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung	not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	70%
IDE06425-Roller test bench mode: functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
IDE07007-ENG17819-A/C heater function via remote control-Anzahl zulaessiger Remotestarts	1
IDE07007-ENG17804-A/C heater function via remote control-RemoteStart Betrieb Dauer	1 min
IDE07356-Position during interval mode	25.505469 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten über Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	Yes
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	No
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	not active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel	not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	not active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	not_active
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	not active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	Not Present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active
IDE08787-ENG17821-Auxiliary functions-Menuesteuerung Garagentoroeffner	not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE09595-ENG115658-Characteristic curve-x0	0 lx
IDE09595-ENG101574-Characteristic curve-X1	2000 lx
IDE09595-ENG99557-Characteristic curve-X2	4000 lx
IDE09595-ENG102140-Characteristic curve-X3	6000 lx
IDE09595-ENG102936-Characteristic curve-X4	8000 lx
IDE09595-ENG103548-Characteristic curve-X5	10200 lx
IDE09595-ENG17883-Characteristic curve-y1_0	0
IDE09595-ENG17884-Characteristic curve-y1_1	40
IDE09595-ENG17885-Characteristic curve-y1_2	90
IDE09595-ENG17886-Characteristic curve-y1_3	140
IDE09595-ENG17887-Characteristic curve-y1_4	190
IDE09595-ENG17888-Characteristic curve-y1_5	245
IDE09595-ENG17889-Characteristic curve-y2_0	0
IDE09595-ENG17890-Characteristic curve-y2_1	60
IDE09595-ENG17891-Characteristic curve-y2_2	110
IDE09595-ENG17892-Characteristic curve-y2_3	160
IDE09595-ENG17893-Characteristic curve-y2_4	210
IDE09595-ENG17894-Characteristic curve-y2_5	255
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	not active
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	not active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG17881-Int. light: 2nd generation-Helligkeit Türtafelbeleuchtung nicht berechnen	not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed
IDE09733-ENG16335-LED bar setting values-Filterzeit Anpassung	3000 ms
IDE09733-ENG16334-LED bar setting values-Filterzeit Umgebungshelligkeit	1000 ms
IDE09733-ENG17895-LED bar setting values-Maximale Dauer fuer konstante Anzeige	0 s
IDE09733-ENG17896-LED bar setting values-Maximale Helligkeitsdifferenz	25
IDE09733-ENG17899-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor	0 W/m²
IDE09733-ENG17897-LED bar setting values-Schwellwert Plausibilisierung RLS	393210 lx
IDE09733-ENG17898-LED bar setting values-Schwellwert Plausibilisierung SLS	393210 lx
IDE09733-ENG16333-LED bar setting values-Sperrzeit	0 s
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%
IDE10298-Alternating park position 1	8.505486 °
IDE10299-Alternating park position 2	22.505472 °
MAS00194-tbd	5 s
MAS00194-ENG123004-tbd-p_lx_regenlichtschwelle	6000 lx
MAS00194-ENG123002-tbd-p_n_regenlichtschwelle_high	12 s
MAS00194-ENG123003-tbd-p_n_regenlichtschwelle_low	6
MAS00194-ENG123005-tbd-p_t_regenlicht	30 s
MAS01490-Energy management	active
MAS05055-lower turn position	25.505469 °
MAS05056-upper turn position	166.505329 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active
ENG122934-erase_error_table	5570560
ENG122933-error_mask	0
ENG117283-Frontwaschfunktion	10
ENG99457-ENG117394-Head area heater-blower_speed	0
ENG99457-ENG98971-Head area heater-Temperature	-3
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	100.00%
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	95.00%
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	80.00%
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	40.00%
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	20.00%
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	10.00%
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	5.00%
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	3.00%
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	1.00%
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500 lx
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0 lx
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16.00%
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16.00%
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100.00%
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100.00%
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100.00%
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6.00%
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6.00%
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100.00%
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100.00%
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100.00%
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	2.00%
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	2.00%
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	6.00%
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	10.00%
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	80.00%
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100.00%
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100.00%
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100.00%
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100.00%
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100.00%
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100.00%
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100.00%
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100.00%
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6.00%
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6.00%
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100.00%
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100.00%
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	40
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
ENG17433-ENG115658-InnenbeleuchtungKL 58xs min-x0	0 lx
ENG17433-ENG101574-InnenbeleuchtungKL 58xs min-X1	8 lx
ENG17433-ENG99557-InnenbeleuchtungKL 58xs min-X2	50 lx
ENG17433-ENG102140-InnenbeleuchtungKL 58xs min-X3	510 lx
ENG17433-ENG115659-InnenbeleuchtungKL 58xs min-y0	6.00%
ENG17433-ENG99777-InnenbeleuchtungKL 58xs min-Y1	6.00%
ENG17433-ENG100480-InnenbeleuchtungKL 58xs min-Y2	100.00%
ENG17433-ENG100773-InnenbeleuchtungKL 58xs min-Y3	100.00%
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	minimize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	50
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	100
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	Daytime running lights
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	Blinken links Dunkelphase
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	Blinken links Dunkelphase
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	100
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	17
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	35
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	8 - allgemeine Glühlampe 12W
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	100
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	19
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	3F
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	8 - allgemeine Glühlampe 12W
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	Parking light right
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	minimize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	50
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	100
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	Daytime running lights
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	Blinken rechts Dunkelphase
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	Blinken rechts Hellphase
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	39
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	9
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	34 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Coming Home oder Leaving Home aktiv
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3A
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	34 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Coming Home oder Leaving Home aktiv
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	34 - LED Bremsleuchten
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	100
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	100
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	32 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Coming Home oder Leaving Home aktiv
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	Daytime running lights
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	100
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	100
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	32 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Parking light right
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Coming Home oder Leaving Home aktiv
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	Daytime running lights
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	100
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	18 - 2* 5W
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	Coming Home oder Leaving Home aktiv
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2E
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	9 - allgemeine Glühlampe 27W: auch H15
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	100
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	2F
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	1C
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	9 - allgemeine Glühlampe 27W: auch H15
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	35
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	35
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	100
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Coming Home oder Leaving Home aktiv
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Daytime running lights
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	20 - 4* 5W
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	100
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	3
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	Ambientelicht 1
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	100
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	4
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	Ambientelicht 2
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	100
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	5
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	Ambientelicht 3
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	100
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	6
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	Ambientelicht 4
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	35
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	35
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	100
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	Parking light right
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Coming Home oder Leaving Home aktiv
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Daytime running lights
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	127
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Coming Home oder Leaving Home aktiv
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Daytime running lights
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	127
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	Parking light right
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Coming Home oder Leaving Home aktiv
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Daytime running lights
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	127
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	Coming Home oder Leaving Home aktiv
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	127
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	Coming Home oder Leaving Home aktiv
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	0
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	0
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	0
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	not active
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	not active
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	not active
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	0
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	0
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	0
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	not active
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	not active
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	not active
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110.00%
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.50%
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%
ENG122927-RLS_close_glazing	2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	9 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h
ENG122929-RLS_LIN_Communication	4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	500 lx
ENG122935-RLS_Washer_Front	15 s
ENG122926-RLS_wiper_position_parking	15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
ENG116832-ENG122996-Wischgeschwindigkeiten-Dauerwischen Stufe 1 Zyklen pro Minute	40
ENG116832-ENG122997-Wischgeschwindigkeiten-Dauerwischen Stufe 2 Zyklen pro Minute	60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30
Thank you for your help
DV52
C?ID=194404
Claudiu: Hi. The following changes should reinstate US Parking Light function from the two front incandescent blinkers - the values in the brackets are your existing settings:
Left Front Blinker
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 > minimize (minimize)
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 > maximize (maximize)
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 > maximize (maximize)
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 > 100 (50)
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 > 0 (0)
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 > 30 (100)
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 > 0 (0)
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 > 14 (14)
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 > 34 (34)
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 > 12 - Blinkleuchten (12 - Blinkleuchten )
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 > Always (Always )
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 > Blinken links Hellphase (Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) )
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 > not active (Daytime running lights)
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 > Blinken links Dunkelphase (Blinken links Dunkelphase )
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 > not active (not active )
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 > Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) (Blinken links Dunkelphase )
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 > not active (not active )
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 > not active (not active )
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 > not active (not active )
Right Front Blinker
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 > minimize (minimize )
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 > maximize (maximize )
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 > maximize (maximize )
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 > 100 (50)
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 > 0 (0)
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 > 30 (100)
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 > 0 (0)
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 > 15 (15)
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 > 3E (3E )
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 > 12 - Blinkleuchten ( 12 - Blinkleuchten )
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 > Always (Always )
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 > Blinken rechts Hellphase (Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) )
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 > not active (Daytime running lights )
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 > Blinken rechts Dunkelphase (Blinken rechts Dunkelphase )
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 > not active (not active )
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 > Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) (Blinken rechts Hellphase )
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 > not active (not active )
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 > not active (not active )
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 > not active (not active )
DV52
C?ID=194404
Claudiu: What side of the car is the rear fog light? It's currently set up with right-hand traffic. As you will be aware, in the UK (and here in Australia) the fog light setting should be for left-hand traffic.
So change: ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 > Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr (Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr)
DV52
C?ID=194404
Claudiu: hmm............ headlight settings look like a mess too - what sort of fittings do you have ?
Claudiu
C?ID=221613
Hi Don,
Thank you for taking the time to look over my channel map. The car is from Norway so it has fog on the right side, steering on the left. If you can help me out i will like the us lights to still be on but coded properly, at the moment when indicating the relay is working to fast and drl and us lights dont work on position 0 and Auto position during the day. Also if you can point out how to make the DRL not to dimm when ignition is on would be good. Any other problems u see please let me know what I should do to fix them. Regards
DV52
C?ID=194404
Hi Don,
Claudiu: hmm......... OK. I've changed the settings on my original reply to reinstate "US Parking Lights" - which I understand is simply turning on the blinker lamps as Parking Lights.
But a word of caution - your car appears to have incandescent blinkers on the front. Not sure if you are aware, but the lamp holders on the front blinkers aren't rated for full power dissipation. If you think about it - they don't need to be fully rated because the blinkers have what lighting engineers call a "50% duty cycle". This means that the blinker lights are off for 50% of the time when they operate as turn-signals. Without going into the technical aspects of the electrical power dissipation formula - the blinker lamp base holder only needs to be rated for 25% of full load. VW capture the cost saving in manufacture that results in the lower power dissipation rating, by under-powering the lamp holder.
Normally this isn't a problem with LED fittings, but you need to be careful for incandescent lamps. This means that your should not exceed 50% illumination when the blinker lamps are used as Parking lights. This setting is in the Dimmwert EF channel, which I have set to 30% in the table above. If you increase the illumination too high, the lamp base becomes discolored and it may start to melt!
As for the DRL problem, you didn't answer my other question - what type of HIDs does your car have fitted?
Claudiu
C?ID=221613
Hi Don,
With the settings above will the Us lights be on in all light switch positions (0, parking lights, auto and main beam)? As for the headlights they are factory fitted bixenon. I will post a pic when i’ll get some time.
Thank you
DV52
C?ID=194404
Hi Don,
Thank you
Claudiu: So ... the DRL and Parking Light is more than just opposite, these lighting functions are kind-of antithetical.
The reason why I left-off the DRL function on my suggestion for US Parking lights is because of the power limitation characteristic that I mentioned in my response; @ an illumination level of <50%, I doubt that the brightness of the indicator lamps will be visible during daylight levels. It would be different if your car had LED turn-signal lamps.
It depends on the lamp type, but a typical incandescent blinker lamp has a PWY24W fitting, which has a lumen output of around 10 lumens/watt (say). This means at 100% brightness, the lamp produces about 240 lumens. However, with a 50% Dimmwert setting, the power to the lamp is 25% of max (i.e. Power=I^2 x R), so the illumination level drops to a mere 60 lumen -this ain't much light when the lamp is competing against the sun!
But - if you are keen to have the indicators light-up (dimly) as DRLs, then add these instructions to my table in post #2
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 > Daytime Running Lights (not active )
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 >Daytime Running Lights (not active )
Also regarding your DRL problem generally (and the above tweak as well) - I've had another look at your Admap and the DRL settings on your Leuchte-sets seem OK. So I'm thinking that perhaps your problem is a classic case of the wrong choice of DRL setting (I'm guessing of course).
Not sure if you are aware, but MQB platform vehicles suffer from duplicate settings in the choice of DRL on both the Lichtfunktion adaptation channels and on the adaption channel that selects which lamp to use for the DRL activity. I have no idea why this happens, but it does occur!
Perhaps a picture is better at explaining what I mean (I produced this screenshot for another forum- so I apologize if you have seen it before):
The first picture is what VCDS reports when you select a change to any of the 280 x Lichtfunktion adaptation channels in your BCM. Notice that there are 2 x DRL entries
The second screenshot is what VCDS reports for the DRL lamp selection adaptation channel in your BCM. My guess is that this adaptation channel sets-up the power modules for the DRL/Lowbeam lamps - but I'm guessing again. Notice that there are 2 x DRL entries.
The logic-table at the bottom of my picture is what happens with various selections.
So I suspect that in your case, the combination of 2A/1B has been selected - I can't confirm this by reading your admap because there is no distinction between the entries.
Claudiu
C?ID=221613
Hi Don,
I forgot to let you know that the DRLs are working now. They were unticked from the head unit.
mabnz
New Zealand
C?ID=279595
Sorry to drag up such an old thread, but I think my question closely relates to this. I’m using my Skoda O3 in NZ, where we drive on the left. When I engage the parking light the lights on the left hand side of the car light up, which isn’t very ideal.
What settings in VCDS would I change to move this to the right hand side?
langers2k
C?ID=224085
I assume this is your 2016 Octavia? In which case, you might want to check the owners manual.
At least the UK 2016-05 manual suggests two methods:
- for one side lighting, turn off the igntion then move the indicator stalk in either the left or right position, only that side is lit up
- for two side lighting, turn the igntion on, move the light switch in the sidelight position then turn the igntion off
What happens on your Octavia?
mabnz
New Zealand
C?ID=279595
I might not have read that clearly enough :)
I've been pulling down on the stalk (which indicates left) and the left side has been lighting up, only because the icon on the stalk seems to indicate this is the way to do it. I'll try pulling up and see if the right side illuminates :)
Thanks!
