Hello guys,
I am trying to sort someone mess out on an Octavia 3 and need your help. Basically someone tried to code US lights on the car (with the switch in all positions) and now the DRL don't work in 0 position and Auto during daytime (they work on Auto night time) and also when indicating the relay goes twice the speed like one of the bulbs is out, but all are ok, on hazard relay works normal. Can you please help out.
Scan attached
Channel map attached
Thank you for your help
Scan attached
Wednesday,27,September,2017,22:32:13:53651
VCDS Version: 17.8.0.1 (x64)
VIN: TMBJG9NE6E0117159 License Plate: DP54154
Mileage: 151202km-93952mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 42 44 52 55 5F 69
VIN: TMBJG9NE6E0117159 Mileage: 151202km-93952miles
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 N HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6547
Revision: 84H22---
Coding: 01250012043401090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI01104L906021N 002011
ROD: EV_ECM16TDI01104L906021N_002.rod
VCID: 306F76E56BF2C0C17F-8064
Part No SW: 0CW 300 047 C HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5260
Revision: 00043014 Serial number: CU501311135854
ROD: EV_TCMDQ200021.rod
VCID: 3B7551C9B2B43399DA-806E
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 631730000000D4
Coding: 1C076291242109730078060541CC243846249000608224F000410070C002
Shop #: WSC 73430 031 00063
VCID: 4B950109E21483196A-801E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 F HW: 5E0 907 044 F
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 02010104002100011005000000100000
VCID: 285F9E8553228801A7-807C
328196 - Motor for Right Temperature Flap
B108D 71 [008] - Actuator stuck
Fault Frequency: 18
Reset counter: 89
Mileage: 147583 km
Date: 2017.07.22
Time: 11:14:39
Voltage terminal 30: 11.5 V
Outside air temperature: 23.5 °C
Interior temperature: 26.9 °C
Right temperature flap: actual value: 47
Right temperature flap: actual value: 8.0 %
Right temperature flap: specified value: 41
P1719 00 [008] - -
Reset counter: 76
Mileage: 149693 km
Date: 2017.09.12
Time: 07:00:16
Voltage terminal 30: 13.5 V
Auxiliary heater: in stages-Act.value: 1
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 Q HW: 5Q0 937 086 Q
Component: BCM PQ37BOSCH 026 0095
Revision: -------- Serial number: 86581211130488
Coding: 0C021B46424722FB47E04000001C07080000000000000000000000000000
Shop #: WSC 73430 790 12345
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_012.rod
VCID: 489F3E05F362680147-801C
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 131115 041 0570
Serial number: 131116115930
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M11D08H15M40S35S6
Coding: 02805D
8714 - Bulb for Left Fog Lamp
B121F 15 [009] - Open or Short to Plus
Fault Frequency: 7
Reset counter: 24
Mileage: 148637 km
Date: 2017.08.26
Time: 20:41:04
6410 - Bulb for Rear Right Side Turn Signal
B12D1 15 [008] - Open or Short to Plus
8970 - Bulb for Right Fog Lamp
B1220 15 [009] - Open or Short to Plus
Reset counter: 223
Mileage: 148637 km
Date: 2017.08.26
Time: 20:56:03
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831332200819
Coding: 0001050111
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_SK25.rod
VCID: 387F4EC58382188137-806C
Part No SW: 3Q0 959 655 AA HW: 3Q0 959 655 AA
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003NYPQ1GV4Y
Coding: 98FCC000000000005C5400CC000800000065
Shop #: WSC 73430 790 00000
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7DF19FD1EC20FDA9A4-8028
Belt Pretensioner left:
Component: BeltPretRevFL H35 0340
Serial number: 34169593B20111370980
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0340
Serial number: 34169592B20111370893
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 454 000 411 13
Serial number: 3576U0000007DAA02E0L
Subsystem 4 - Part No SW: ----------- HW: 454 000 111 13
Serial number: 3586U000000384902E06
Subsystem 5 - Part No SW: ----------- HW: 454 800 311 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R6D4955020000000
Subsystem 6 - Part No SW: ----------- HW: 454 800 311 13
Component: SideSensor_Pr 111 0148
Serial number: 3526REA9C3B02000000I
Subsystem 7 - Part No SW: ----------- HW: 454 801 510 13
Component: FrontSensor_D 114 0149
Serial number: 3556V6BC104020000000
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DF HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 20111304221768
Coding: 1410
ROD: EV_SMLSKLOMQB_AU37.rod
Part No SW: 5E0 920 871 D HW: 5E0 920 871 D
Component: KOMBI 333 2210
Coding: 07AD0A0829800008010A2A00000000
Shop #: WSC 73430 031 12345
VCID: 29599B814828B109B8-807C
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001264129
Coding: 030100340F087300EF00024E1C0F00010001050000000000000000000000
ROD: EV_GatewLear_010.rod
VCID: 3F8D25D9A6AC2FB9F6-806A
Subsystem 2 - Part No SW: 5E0 919 719 B HW: 5E0 919 719 B
Component: E221__MFL-PR6 H04 0120
Serial number: 000000000A0991111113
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6895131803
Address 20: High Beam Assist. (J844) Labels: 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02018F6B76765D525220343E01
VCID: 2B55618942D4A3194A-807E
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000082263148
Coding: 00150120D000048000001100
VCID: 44872A35CF4A4C61AB-8010
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000001122557
Coding: 010200
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41892321D058594980-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000083005545
VCID: 43852929CA444B5992-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000001021432
Coding: 190200
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 03CA02003F000000
Shop #: WSC 73430 790 00063
VCID: 3D715FD1ACA03DA9E4-8068
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels: 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 842 A HW: 5E0 035 842 A
Component: MU-S-D-ER 040 0421
Serial number: S7E01711130204
Coding: 03730200FF0000001111120100A800002F0000840100010002
ROD: EV_MUStd4CPASE_AU37.rod
VCID: 214983A130187949E0-8074
Subsystem 1 - Part No SW: 5E0 919 605 B HW: 5E0 919 605 B
Component: ABT_Std_Plus H50 0022
Serial number: SKZ8Z9NK600LS1
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 HW: 5Q0 907 383
Component: Anhaenger H11 0030
Revision: 6A001003 Serial number: 00000194826608
Coding: 0100000200000000
ASAM Dataset: EV_TrailFunctDemouHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: 74E7BAF5DF6ABCE1DB-8020
End-------------------------(Elapsed Time: 04:16)--------------------------
IDE00001-ENG99061-Production mode-Access control not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active
IDE00001-ENG112304-Production mode-Heckwischer not active
IDE00001-ENG98647-Production mode-Interior lighting not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active
IDE00001-ENG115731-Production mode-Virtuel_pedal not active
IDE00002-Transport mode active
IDE00820-Activating and deactivating all development messages not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 1100 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 600 ms
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active
IDE01550-Service position 166.505329 °
IDE02152-Characteristics in production mode 0 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln No
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln No
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen not active
IDE02332-Deactivate production mode 0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 40%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 40%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 40%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -0.25 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 90 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 30 °
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separate
IDE04923-ENG115774-Turn signal control-Komfortblinken active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker SMLS
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.10%
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 20.00%
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 50 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 50 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion not active
IDE04924-ENG17816-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren not active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 116
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 2
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active
IDE04927-IDE01446-Window heater-Running time of heated front window 600 s
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung 35.0 °C
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung 35.0 °C
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH Default
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme
IDE04928-ENG17832-Anti-theft device-Überwachung Innenentriegelungshebel not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active
IDE05142-ENG116621-Access control-automatisches Entriegeln active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active
IDE05142-ENG116706-Access control-Autounlock NAR not active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active
IDE05142-ENG115755-Access control-Notschließfunktion active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always
IDE05142-ENG17882-Access control-Softtouch-Betätigung senden Always
IDE05142-ENG115758-Access control-Valet Parking not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active
IDE05143-MAS02985-Writing parameter-Value 130
IDE05143-MAS04381-Writing parameter-Parameter address FE 00 00
IDE05144-Read parameter address FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 35
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 3F
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 9
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 19
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0A
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 1A
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 0C
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1C
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 0
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 0
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 minimize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 minimize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 maximize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 50
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 50
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 100
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 100
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 35
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 100
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 100
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 100
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 100
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 35
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 100
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 100
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 100
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 100
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 100
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 0
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 0
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 35
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 0
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 0
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 35
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 127
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 127
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 100
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 100
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 100
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 100
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 127
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 127
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 17
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 19
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 29
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 2A
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2E
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2F
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 3
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 4
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 5
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 6
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 0
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 0
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116100-Light configuration-Lasttyp 12 10 - allgemeine Scheinwerfer
IDE05145-ENG116119-Light configuration-Lasttyp 13 10 - allgemeine Scheinwerfer
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active
IDE05145-ENG116176-Light configuration-Lasttyp 16 8 - allgemeine Glühlampe 12W
IDE05145-ENG116195-Light configuration-Lasttyp 17 8 - allgemeine Glühlampe 12W
IDE05145-ENG116214-Light configuration-Lasttyp 18 12 - Blinkleuchten
IDE05145-ENG116233-Light configuration-Lasttyp 19 12 - Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21 34 - LED Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22 34 - LED Bremsleuchten
IDE05145-ENG116309-Light configuration-Lasttyp 23 32 - allgemeine LED bis 12W
IDE05145-ENG116328-Light configuration-Lasttyp 24 32 - allgemeine LED bis 12W
IDE05145-ENG116347-Light configuration-Lasttyp 25 18 - 2* 5W
IDE05145-ENG116366-Light configuration-Lasttyp 26 9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116385-Light configuration-Lasttyp 27 9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30 20 - 4* 5W
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8 not active
IDE05145-ENG116043-Light configuration-Lasttyp 9 not active
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 Always
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 Always
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 Always
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 10
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 8
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 8
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 8
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 8
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 8
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 8
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 8
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 27
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 28
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 8
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 45
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 46
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 47
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 48
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 8
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 8
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 0
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 0
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 20
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 20
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 22
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 23
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 9
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 9
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 9
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 10
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 30
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 10
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 9
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 10
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 0
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 0
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 3
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 5
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 30
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 0
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 0
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 30
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 30
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 30
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 30
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 30
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 30
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 30
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 0
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 0
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 0
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 20
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 20
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 0
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 0
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 0
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 3
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 4
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 20
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 30
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 30
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 0
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 0
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 20
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 20
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 20
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 30 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 1.10 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 33.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 32.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 33.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 32.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 37.50 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 36.50 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 37.50 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 36.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 41.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 40.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 41.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 40.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 70%
IDE06425-Roller test bench mode: functional not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active
IDE07007-ENG17819-A/C heater function via remote control-Anzahl zulaessiger Remotestarts 1
IDE07007-ENG17804-A/C heater function via remote control-RemoteStart Betrieb Dauer 1 min
IDE07356-Position during interval mode 25.505469 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten über Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min
IDE08542-IDE02021-Access control 2-Comfort closing active
IDE08542-IDE02022-Access control 2-Comfort opening active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen Yes
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung No
IDE08542-ENG115670-Access control 2-Komfortbedienung global active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen not active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung not active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art once
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus not active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not_active
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt not active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung Not Present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active
IDE08787-ENG17821-Auxiliary functions-Menuesteuerung Garagentoroeffner not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active
IDE09595-ENG115658-Characteristic curve-x0 0 lx
IDE09595-ENG101574-Characteristic curve-X1 2000 lx
IDE09595-ENG99557-Characteristic curve-X2 4000 lx
IDE09595-ENG102140-Characteristic curve-X3 6000 lx
IDE09595-ENG102936-Characteristic curve-X4 8000 lx
IDE09595-ENG103548-Characteristic curve-X5 10200 lx
IDE09595-ENG17883-Characteristic curve-y1_0 0
IDE09595-ENG17884-Characteristic curve-y1_1 40
IDE09595-ENG17885-Characteristic curve-y1_2 90
IDE09595-ENG17886-Characteristic curve-y1_3 140
IDE09595-ENG17887-Characteristic curve-y1_4 190
IDE09595-ENG17888-Characteristic curve-y1_5 245
IDE09595-ENG17889-Characteristic curve-y2_0 0
IDE09595-ENG17890-Characteristic curve-y2_1 60
IDE09595-ENG17891-Characteristic curve-y2_2 110
IDE09595-ENG17892-Characteristic curve-y2_3 160
IDE09595-ENG17893-Characteristic curve-y2_4 210
IDE09595-ENG17894-Characteristic curve-y2_5 255
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active
IDE09731-ENG17881-Int. light: 2nd generation-Helligkeit Türtafelbeleuchtung nicht berechnen not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel not installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed
IDE09733-ENG16335-LED bar setting values-Filterzeit Anpassung 3000 ms
IDE09733-ENG16334-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms
IDE09733-ENG17895-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s
IDE09733-ENG17896-LED bar setting values-Maximale Helligkeitsdifferenz 25
IDE09733-ENG17899-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 W/m²
IDE09733-ENG17897-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx
IDE09733-ENG17898-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx
IDE09733-ENG16333-LED bar setting values-Sperrzeit 0 s
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80%
IDE10298-Alternating park position 1 8.505486 °
IDE10299-Alternating park position 2 22.505472 °
MAS00194-tbd 5 s
MAS00194-ENG123004-tbd-p_lx_regenlichtschwelle 6000 lx
MAS00194-ENG123002-tbd-p_n_regenlichtschwelle_high 12 s
MAS00194-ENG123003-tbd-p_n_regenlichtschwelle_low 6
MAS00194-ENG123005-tbd-p_t_regenlicht 30 s
MAS01490-Energy management active
MAS05055-lower turn position 25.505469 °
MAS05056-upper turn position 166.505329 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active
ENG122934-erase_error_table 5570560
ENG122933-error_mask 0
ENG117283-Frontwaschfunktion 10
ENG99457-ENG117394-Head area heater-blower_speed 0
ENG99457-ENG98971-Head area heater-Temperature -3
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00%
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 100.00%
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00%
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 95.00%
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 80.00%
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 40.00%
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 20.00%
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 10.00%
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 5.00%
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 3.00%
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 1.00%
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 lx
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 lx
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00%
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00%
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00%
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00%
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00%
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00%
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00%
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00%
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00%
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00%
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00%
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00%
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00%
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00%
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00%
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00%
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00%
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16.00%
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16.00%
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100.00%
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100.00%
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100.00%
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6.00%
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6.00%
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100.00%
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100.00%
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100.00%
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00%
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00%
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00%
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00%
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00%
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00%
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100.00%
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100.00%
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100.00%
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100.00%
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00%
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00%
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00%
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00%
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00%
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00%
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100.00%
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100.00%
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100.00%
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100.00%
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6.00%
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6.00%
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100.00%
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100.00%
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00%
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00%
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00%
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00%
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00%
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00%
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00%
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 40
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100
ENG17433-ENG115658-InnenbeleuchtungKL 58xs min-x0 0 lx
ENG17433-ENG101574-InnenbeleuchtungKL 58xs min-X1 8 lx
ENG17433-ENG99557-InnenbeleuchtungKL 58xs min-X2 50 lx
ENG17433-ENG102140-InnenbeleuchtungKL 58xs min-X3 510 lx
ENG17433-ENG115659-InnenbeleuchtungKL 58xs min-y0 6.00%
ENG17433-ENG99777-InnenbeleuchtungKL 58xs min-Y1 6.00%
ENG17433-ENG100480-InnenbeleuchtungKL 58xs min-Y2 100.00%
ENG17433-ENG100773-InnenbeleuchtungKL 58xs min-Y3 100.00%
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 minimize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 50
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 100
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 Daytime running lights
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 Blinken links Dunkelphase
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 Blinken links Dunkelphase
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 Abbiegelicht links
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 Abbiegelicht rechts
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 17
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 35
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 8 - allgemeine Glühlampe 12W
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 19
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 3F
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 8 - allgemeine Glühlampe 12W
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 Parking light right
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 minimize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 50
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 100
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 Daytime running lights
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 Blinken rechts Dunkelphase
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 Blinken rechts Hellphase
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 9
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 Coming Home oder Leaving Home aktiv
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 Coming Home oder Leaving Home aktiv
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 34 - LED Bremsleuchten
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 32 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Coming Home oder Leaving Home aktiv
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Daytime running lights
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 32 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 Parking light right
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Coming Home oder Leaving Home aktiv
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Daytime running lights
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 100
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 18 - 2* 5W
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 Coming Home oder Leaving Home aktiv
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2E
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 0C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 9 - allgemeine Glühlampe 27W: auch H15
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 100
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2F
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1C
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 9 - allgemeine Glühlampe 27W: auch H15
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 35
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 35
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 100
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Coming Home oder Leaving Home aktiv
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 Daytime running lights
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 20 - 4* 5W
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 100
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 3
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 Ambientelicht 1
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 100
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 4
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 Ambientelicht 2
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 100
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 5
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 Ambientelicht 3
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 100
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 6
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 Ambientelicht 4
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 35
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 35
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 100
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 Parking light right
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Coming Home oder Leaving Home aktiv
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 Daytime running lights
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 127
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Coming Home oder Leaving Home aktiv
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 Daytime running lights
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 127
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 Parking light right
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Coming Home oder Leaving Home aktiv
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 Daytime running lights
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 127
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 Coming Home oder Leaving Home aktiv
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 127
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 Coming Home oder Leaving Home aktiv
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 0
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 0
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 0
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 not active
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 not active
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 not active
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 0
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 0
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 0
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 not active
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 not active
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 not active
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110.00%
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.50%
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00%
ENG122927-RLS_close_glazing 2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 9 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h
ENG122929-RLS_LIN_Communication 4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx
ENG122935-RLS_Washer_Front 15 s
ENG122926-RLS_wiper_position_parking 15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00
ENG116832-ENG122996-Wischgeschwindigkeiten-Dauerwischen Stufe 1 Zyklen pro Minute 40
ENG116832-ENG122997-Wischgeschwindigkeiten-Dauerwischen Stufe 2 Zyklen pro Minute 60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30
