2010 Audi A6 Quattro 3.0 Supercharged (Fault Codes) Please Help!
Cobie90
C?ID=311736
I have replaced all o2 and manifold sensors and still getting a check engine light. Also, my headlights are brand new with brand new ballast, ignitor, and bulbs.(Fault Codes Are Below)
My air wont blow cold at all and I just recharged it yesterday! and it has a brand new ac pressure sensor switch. cause I was getting low voltage cold
P.S check out the video. can anyone tell me where the fuse/relay for ac pressure sensor and climate control
Friday,22,September,2017,17:11:53:05661
VIN: WAUKGAFB7AN036515   License Plate:
Mileage: 142070km-88278mi   Repair Order:
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
          56 5F 62 6C 72
VIN: WAUKGAFB7AN036515   Mileage: 142070km-88278miles
Address 01: Engine (CCA)       Labels: None
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0050
   Revision: --H06---    Serial number:
   Coding: 0105000A190F0120
   Shop #: WSC 08175 444 103843
   VCID: 2412E4F0D2DA9EF71F2-8070
001169 - Secondary Air Injection System: Bank 1
               P0491 - 000 - Insufficient Flow - MIL ON
                    Fault Status: 11100010
                    Mileage: 142073 km
                    Date: 2017.09.22
                    Time: 13:59:21
                    RPM: 1248 /min
                    Mass Air / Rev.: 228.9 mg/str
                    Temperature: 36.0°C
                    Bin. Bits: 00000010
                    Voltage: 12.55 V
                    Bin. Bits: 00000010
001170 - Secondary Air Injection System: Bank 2
               P0492 - 000 - Insufficient Flow - MIL ON
                    Mileage: 142073 km
                    Date: 2017.09.22
                    Time: 13:59:21
                    RPM: 1248 /min
                    Temperature: 36.0°C
                    Bin. Bits: 00000010
                    Voltage: 12.55 V
                    Bin. Bits: 00000010
Readiness: 1110 0101
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0010
   Revision: --H04---    Serial number:        4539555
   Shop #: WSC 02325 785 00200
   VCID: 2A0E0AC8B0FE488725E-807E
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6E86C6D84C9664A7B96-803A
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602501421794
   Coding: 0000007
   Shop #: WSC 02324 785 00200
   VCID: 2514F9F4D9E067FF08C-8070
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000074    Serial number: 00000030482307
   Coding: 0524326
   VCID: 1D64D114F1B0AF3F50C-8048
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 66
                    Mileage: 142073 km
                    Date: 2017.09.22
                    Time: 19:06:11
                    Voltage: 2.50 V
   Part No SW: 4F0 910 279 Q    HW: 4F0 907 279 A
   Component: ILM Fahrer      H24 0340
   Coding: 0139123
   Shop #: WSC 02335 785 00200
   VCID: 372823BC734CE56FAA0-8062
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 66
                    Mileage: 142072 km
                    Date: 2017.09.22
                    Time: 19:04:00
                    Reset counter: 66
                    Mileage: 142072 km
                    Date: 2017.09.22
                    Time: 19:04:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1574C9340580F77F98C-8040
Address 15: Airbags (J234)       Labels:| 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FA0012RDS
   Coding: 303142373034303030314A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 36362EB878C61C67B16-8062
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R0000003W4J
   Serial number: 3574SRB400009FDD0ABV
   Serial number: 3584SRB400009F94E27L
   Serial number: 3516HRB402VC0AS50SV6
   Serial number: 3526HRB402VC0AS4OKNE
   Serial number: 3554NRB40000517EBB79
   Serial number: 3564NRB4000051197E1Z
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026092900003
   Coding: 0012141
   VCID: 2708F3FCA3EC75EF3A0-8072
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H08 0144
   Revision: 00000000    Serial number: CN450YEA9
   Coding: 8BD60A050B00CF05020201
   Shop #: WSC 02391 823 56573
   VCID: 313C1DA491283B5FE44-8064
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L09A1700BA
   Coding: 000303
   VCID: 392C25844958F31F5C4-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790718207
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010017085
   Coding: 00581B00004011110000
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000102168472
   Coding: 011F57204E40410001
   VCID: 46D65E7808A68CE7216-8012
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01229654010000
   Coding: 4618269
   VCID: 353429B46940177FB8C-8060
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000041814
   Coding: 05000000
   VCID: 290CF5C4B9F8439F2C4-807C
   Part No SW: 4F0 910 274 A    HW: 4F0 907 274
   Component: J793  RKA+      H02 0100
   Revision: 00000506    Serial number: 00005061074829
   Coding: 0623301
   VCID: 221EE2E8C8CE90C76DE-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000509539
   Coding: 0002014
   VCID: 5EE69618BC36F427096-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000102131826
   VCID: 45D4597435A087FF28C-8010
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 211CEDE4CDC88BDF744-8074
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0060
   Coding: 0000026
   VCID: 698CB5C47578839FEC4-803C
   Subsystem 1 - Part No: -----------
   Component: AFS-Modul links
   Subsystem 2 - Part No: -----------
   Component: AFS-Modul rechts
02071 - Local Databus
                    Fault Status: 11100100
                    Reset counter: 66
                    Mileage: 142073 km
                    Date: 2017.09.22
                    Time: 19:04:11
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335J-097535137
   Coding: 020000010000000000
   VCID: 1D64D114FDB0AF3F50C-8048
   Part No SW: 4E0 035 664 A    HW: 4E0 035 664 A
   Component: H-BN-NA       H45 0042
   Revision: --------    Serial number: 488J/097520192
   Coding: 010200000002E1EE41000304EF6300030000
   VCID: 221EE2E8C4CE90C76DE-8076
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356JX091091752
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001422512
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
   Revision:             Serial number: 0000009496373
   Coding: 010E57204040220001
   VCID: 43D0476C3B94B9CF068-8016
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J9925BW
   Coding: 1000304
   Revision:             Serial number: 0000009496374
End----------(Elapsed Time: 01:48, VBatt start/end: 13.6V/13.6V)-----------
RTFB the TSB on 3.0 filling with carbon on the SAI combi valve pipes.
Get your PSI washer handy!
Cobie90
C?ID=311736
I'm kind of new to working on foreign cars can you tell me what you mean and also do you know where the fuse and relay are located for the climate control because I can't control my temperature at all and I have low voltage for my auto hvac. I want to locate fuses and relays to make show it's not bad
Create an account here: https://erwin.audi.com/
Spend $35 for a one-day subscription. Grab everything available for your particular car -- the site should be able to find all the applicable info based on your VIN. Some things you'll be able to save as PDFs directly. Other things you'll want to "print" to PDF files, so make sure your computer is setup to do that.
Cobie90
C?ID=311736
I can't seem to find where I can register.
Cobie90
C?ID=311736
Thanks alot
Dana
Western PA, USA
Although this reply dates back to 09-22-2017, 09:54 AM (in the original thread) I agree with Uwe on the extremely low voltage concern.
HVAC fault indicates that module saw really low supply voltage (Voltage: 5.60 V)... Since you have no low similar codes in other modules, I'd suspect a bad connection somewhere.
I can't tell you why your Headlight module is off-line, but your car's Instrument Cluster and Gateway can't talk to it either.. Check fuses first and other supply voltage connections first.
Cobie90
C?ID=311736
Cobie90
C?ID=311736
Do you know where terminal 15 is located (Fuse and Relay) so I could check and replace it!
Yup
It's in the car almost everywhere............ Please track and trace the circuit in question or component using the RTFB and WD at ERWIN.
Start reading the JPPSG and the thread has DIN specification's in it to.
A Bosch standard is color code Black for terminal 15 B+ ( Switched B+ )
"Terminal 15" is located all over the car. It's "switched power".
Cobie90
C?ID=311736
Yup
I can't find it but I have pictures saying where it is. I literally took my whole dash board down and haven't found it no where. I have screenshots of it but can't upload on here unless it have a url ��
Find in WD and use the fuse related and or component as a guide to find the tracks needed to check.
I mean seriously you either have power at the black wire when switched "ON" or not.........?
Cobie90
C?ID=311736
Thanks for the quick response and I appreciate all your advice. Can I use VCDS to check and see is it on or off?
A/C pressure switch- OEM Supplier "4H0959126B"
Yup........but is it genuine?
Vehicle Identification No.
WAUKGAFB7AN036515
Model
Audi A6 qu. 3,0
A6
Date of production
05.11.2009
Year
2010
Sales type
4F25VL
Engine Code
CCAA
Transmission Code
MCC
Axle drive
6A
Equipment
GU
Roof color
L8
Exterior color / Paint Code
L8 / Z9Y
Cobie90
C?ID=311736
WAUKGAFB7AN036515
Model
Audi A6 qu. 3,0
A6
Date of production
05.11.2009
Year
2010
Sales type
4F25VL
Engine Code
CCAA
Transmission Code
MCC
Axle drive
6A
Equipment
GU
Roof color
L8
L8 / Z9Y
Yes it's genuine I got the part from Audi itself
