Hello! new to the forum and with a problem i can´t find solution to by my own.
I have a 2012 Caddy that i have fitted from single H4 headlights to Touran double halogen H7,H15 headlights to.
When putting hi beam on the low beam light shuts off, on hi beam both hi and low should light together.
In adress 09 byte 18 i have changed in the scrollist to Caddy with double halogen (0C) and the code is accepted but it makes no difference on the light.
I have tried some other codes to and they get accepted but it makes no difference either.
I know it´s been done before and some caddy comes with these lights from factory but i can´t find the solution so i need some help please.
The autoscan is when i have coded it to double halogen 0C the code for the singel halogen H4 was 72.
Monday,18,September,2017,20:33:53:52348
VCDS Version: 17.8.0.1 (x64)
VIN: WV1ZZZ2KZCX098496 License Plate:
Mileage: 73590km-45726mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 15 16 17 18 19 25 42 44 46 52 56 69 77
VIN: WV1ZZZ2KZCX098496 Mileage: 73590km-45726miles
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PE HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 0871
Revision: --H43--- Serial number: 00000000000000
Coding: 00254014032400080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PE 003002
ROD: EV_ECM16TDI02103L906023DB.rod
VCID: 78C7AFBDC31F3786B2-802C
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 053 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3010
Revision: 00043014 Serial number: CU501112086836
Shop #: WSC 35110 377 08192
VCID: 37456C814681F8FE7B-8062
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 423C400D092B0302420F02ED901FC041310000
VCID: 7BCDB0B1FA291C9EDF-802E
Part No SW: 3C8 907 336 AE HW: 3C8 907 336 AE
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
ROD: EV_ClimaBasis_VW32.rod
VCID: 70D7979DAB6F6FC67A-8024
Part No SW: 5K0 937 086 P HW: 5K0 937 086 P
Component: BCM PQ35 M+ 021 0064
Revision: BD021001
Coding: 411A583A80251A69088800829400816403510C88526FA560648000000040
VCID: 41B10259D845B64EC5-8014
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 15121 26 0512
Coding: 009795
Component: RLS 201211 05 54 0403
Coding: 0230ED
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag024 H06 0013
Revision: -------- Serial number: 003HL009K1L6
Coding: 000000000000000000000000000000003234
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 35596689948D0AEE69-8060
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KLG000I5
Coding: 1882160000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76DBA185C90B41F6A0-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0788181
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 2K0 920 875 E HW: 2K0 920 875 E
Component: KOMBI H03 0607
Coding: 181801
ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
VCID: 3151529960E526CE35-8064
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 A
Component: Standheizer 043 4730
Revision: 00043000 Serial number: 09022127000000
Coding: 0031012
Shop #: WSC 35110 377 00177
VCID: 335D589152F914DE47-8066
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 141211F1002551
Coding: 357400
VCID: 3A4375B5B593E59684-806E
Component: IMMO H03 0607
VCID: 6AE385F58DB3951634-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2109
Coding: 0000112
VCID: 48A71F7D3B7F870602-801C
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 140 3301
Revision: 00H22000
VCID: 355966895C8D0AEE69-8060
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000112
VCID: 47A51C413661887E0B-8012
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2L3271553
Coding: 05000200010013
VCID: 72D39D95AD635DD68C-8026
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000164303473
Coding: 410D000100000000
VCID: 3057579D63EF2FC63A-8064
Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660213827
Coding: 0901010000010110
ASAM Dataset: EV_UHVNA A01015
ROD: UHVNA.rod
VCID: 345F5B8D9FF713E65E-8060
End-------------------------(Elapsed Time: 01:53)--------------------------
Monday,18,September,2017,22:13:36:52348
Revision: 00H31001
Revision: 00009001
Coding: 0000000002
Revision: BD021001
Coding: 009795
Coding: 0230ED
Coding: 1882160000
Coding: 820000
Coding: 181801
Coding: 0031012
Coding: 357400
Coding: 0000112
Revision: 00H22000
Coding: 0000112
ROD: UHVNA.rod
