Missing coding information 2017 Tiguan AD1
MasterTommy
Amsterdam
C?ID=295586
Hey guys and girls,
Just took delivery of my new 2017 Tiguan with almost everything fitted. Original un-modified pre-changing stuff auto-scan log below.
Unfortunately, i'm missing a lot of coding information. Most control units i don't need to code. The central electronics unit and infotainment unit coding is also missing and those units i do need to change coding on.
The car is fully loaded option wise (except for aux heating and direct TPMS), unfortunately some simple stuff was left out in the ordering process (which was hard to begin with since i wanted everything on this car and over here in the Netherlands not everything is available to order for reasons unknown.
I'm trying to enable the following stuff which i have managed to in the respective control units, but not in the infotainment and central electrics:
- Traffic sign recognition (Works now, but no settings/information about it in the infotainment system because of no coding info).
- Easy entry/exit (electric seat moves back a little when opening door). Works now but same issue as above; no settings in infotainment.
- Pedestrian recognition (I have ACC/camera/everything but for some reason pedestrian recognition is not in the settings menu in the infotainment/instruments). See a few options here and there regarding this but some are parts of the experimental coding so i'd rather not touch that until its a definitive version.
- Looking to add Direct TPMS in the future, but extended CAN and central electrics is currently lacking coding info.
The first two things i'd like to get working rather sooner than later, is the missing info because the control units are unknown to ross-tech, or is there some other issue? VCDS and HEX interface HN1-003118 (maybe my interface is too old? its about 2 years old now) updated to latest software.
Thanks in advance!
Tom
AUTOSCAN:
Friday,15,September,2017,23:35:55:41109
VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4401.4
VIN: WVGZZZ5NZJW000000   License Plate: 12-345-6
Mileage: 298km-185mi   Repair Order: 12345
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C
          42 44 47 4B 52 5F 69 6C 6D 75 82 A5 BB BC CA CF D6 D7
VIN: WVGZZZ5NZJW000000   Mileage: 298km-185miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
   Part No SW: 03N 906 026 D    HW: 03N 907 309
   Component: R4 2.0l BTD   H24 3680
   Revision: A1H24---
   Coding: 01250032047605083000
   ASAM Dataset: EV_ECM20BTD01103N906026D 004005
   ROD: EV_ECM20BTD01103N906026D_004.rod
   VCID: 2C14C9DD47ABA22606-8078
Readiness: 0100 0010
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0DL 300 011 M    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2001
   Revision: 00H06V07
   ROD: EV_TCMDQ500021_001_VW36.rod
   VCID: 3228D7A5658FF4D64C-8066
   Revision: 00000000    Serial number: 62057000001070
   Coding: 0AEE6B9A54220B744779070762C66950D62AD0E2E046967DB86250F8C2AA4200002F641A1B13111435351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 77BE26B1CE6DD1FEBB-8022
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0451329535
   Coding: 132C2C0723
   VCID: 3E30F395A1D720B6B8-806A
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98226912
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QGM20164
   Coding: 0010000000000500818281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide_VW37.rod
   VCID: 3C34F99DB7CB32A696-8068
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000B00605887
   Coding: 0002012420241001110510020010112A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 4AD8AF45ED1F9C1614-801E
   Subsystem 2 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001721700533
   ROD: EV_BCMBOSCH_018.rod
   VCID: 095A5049A899D70EDD-805C
   Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170630  033 0372
   Serial number: 00000001706280300593
   Component: RLHS  042 0105
   Serial number: S8Y17M08D14H01M31S46
   Coding: 00A8EE
   Serial number: 000000000ZY1718333XN
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223971734394
   Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0029
   Serial number: 001607177478001
   Coding: 0A31667A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000_VW37.rod
   Coding: 320067CB5CFF8728749C8145804087
   Serial number: 12071741350391
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383CE58D83F31E8672-806C
   Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
   Component: AirbagVW21    005 0336
   Serial number: 003VXR33ZYC9
   Coding: 98FCC0C00C8000005C5400CF004800000065
   VCID: 0A586F45AD9FDC16D4-805E
   Belt Pretensioner left:
   Serial number: 5NB857705C0216R00777
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 5NB857706C0217R00515
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 35700000000B2B19A62O
   Subsystem 4 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 35800000000156842728
   Subsystem 5 - Part No SW: -----------    HW: 480 400 208 17
   Serial number: 3510001BB260B4F1B4BB
   Subsystem 6 - Part No SW: -----------    HW: 480 402 807 17
   Serial number: 3520001A524CDB11F48B
   Subsystem 7 - Part No SW: -----------    HW: 480 402 907 17
   Serial number: 3550001C322EA2B5730%
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B526D7C0386BB
   Subsystem 9 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001B526D7C0475EE
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001B526D7C04615Z
   Subsystem 11 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: I0M00000000D91C0252+
   Subsystem 12 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: I0N000000002A1C0252W
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170802501343
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 73A612A1DA15BDDE87-8026
   Part No SW: 5NA 920 791 B    HW: 5NA 920 791 B
   Component: KOMBI         407 3193
   Coding: 07A400187F88000801886B0B3401000880000000
   VCID: 42C88765D52F4456DC-8016
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 23071710800155
   Coding: 0B0500344F017300FB07225E9E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3326D2A19A95FDDE47-8066
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29170001574160027313
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5QA 915 181 E    HW: 5QA 915 181 E
   Serial number: 4480423804
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 F    HW: 5Q0 907 155 F
   Component: U13DCAC  H25 0780
   Serial number: 0024537
   Serial number: HA1-00020.06.17
   Coding: 0101
   ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C29C79C401736EF9-8010
   Serial number: 17000199457001
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71AA18A9A0098FCE75-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0006QGM20144
   Coding: 0010000000000500018281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 39: Right Light (J1023)       Labels: None
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 14C002
   VCID: 3A38FF85BDFF0C9684-806E
   Serial number: 080717EG809145
   Coding: 003F1B20D200048000001000
   VCID: 43C68261CA354D5ED7-8016
   Part No SW: 5QF 909 144     HW: 5QF 909 144 _
   Component: EPS_MQB_ZFLS  506 5572
   Coding: 9307
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 075E5671BE8DA17ECB-8052
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00TYB7
   Coding: 1223060001A00A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   VCID: 6B960AC18225651E4F-803E
Address 4B: Multifunc. Module (J745)       Labels:* None
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 21071710803739
   Coding: 000000050100085207104F010A0000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_VW37.rod
   VCID: 72A817A5A50FB4D68C-8026
   Serial number: 070717EG609369
   Coding: 003F1120DE00048000001000
   Part No SW: 5NA 035 022 A    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1121
   Serial number: A846G0HS006021
   Coding: 02730601000000005111010200880A101F0106E401200400DE
   VCID: 312AD8A96089CFCE35-8064
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2116065
   Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
   Component: ECE 2017  --- 0157
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0449274529
   Coding: 0100000202000000
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG016316
   Coding: 01230600A30F200000204814
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 393AE089B8F9078E8D-806C
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31450492700000
   Coding: 0AA8
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0717
   Revision: --------
   Coding: 02230601EA42380D3F1CBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW27.rod
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 5NA 919 608 B    HW: 5NA 919 608 B
   Component: HeadupDisplay 023 0302
   Coding: 564060
   ASAM Dataset: EV_HeadUpDisplContiVW481 001015
   ROD: EV_HeadUpDisplContiVW481.rod
   VCID: 47DE9671FE0D617E0B-8012
   Component: MQB_B_MFK     H08 0272
   Serial number: 29071712K20584
   Coding: 000307060000040100262347C150A90088000E200040
   ROD: EV_MFKBoschMQBB_VW36.rod
   Serial number: 120717EG908013
   Coding: 002A11200101048000001000
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Serial number: 190617EFJ09168
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
Address CA: Sunroof (J245)       Labels:* None
   Coding: 208040732602
   ROD: EV_SunRoofCONTIAU736.rod
   VCID: 3D32F499ACD13BAEA1-8068
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
   VCID: 373EE6B18EED11FE7B-8062
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16600B35E92708F640-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:34, VBatt start/end: 12.5V/12.5V)-----------
HEX-NET is fine, but data for some of the modules in this vehicle is still sparse.
MasterTommy
Amsterdam
C?ID=295586
Thats unfortunate. Anything I can do to help apart from the autoscan?
MasterTommy
Amsterdam
C?ID=295586
Regarding the missing central electronics coding info:
This thread highlights the same issue I encounter; regarding the coding showing all zero's. Unfortunately I didn't see it until now. I'll have a look through the adaptation channels as per your suggestion in that thread.
DV52
C?ID=194404
Tommy: Yes, all the old code Bits/Bytes are there in the BCM- it's just a question of finding them. Best way that I've found with these newer BCMs from MQB platform vehicles is to make your self an admap of the module, then grab yourself a large glass and pour-in a dram or two,or..... of single malt scotch. Then open the .CSV from the admap with something like MS Excel. You will find that the channel count is about 1,800-ish, so use the "find" function to locate the correct channel. The other handy thing (besides the scotch) is to have a copy of Google translate open.
PS: I have a couple of admaps of BCMs from 2017 Tiggy (Australia) in my database - if you can't find what you are looking for, then I might be able to help (at least i'll try)
MasterTommy
Amsterdam
C?ID=295586
Good tip. Already found a similar function in the adaptation menu itself, but not sure if it really displays all coding related to my search so i'll sure give that a try.
Got the traffic sign recognition working now including the menu about it in the discover pro. Did the same with the Pedestrian recognition but that kept giving a 'function not available' message so i figured i'm missing some coding somewhere. The drivers assistance module (front camera) doesnt accept me coding said option so i think thats the issue.
Also found some references to TPMS so that should be doable later on too.
Easy access is the only thing i cant find in the infotainment module adaptations. Using expiremental coding on the respective seat controllers i've managed to turn that on, but the 'display easy acces settings menu' adaptation in the discover pro unit is not there, or its using a different name or abbreviation. According to the cars manual, the should be a menu about it in the unit.
MasterTommy
Amsterdam
C?ID=295586
So, tweaked a little more.
Pedestrian assist is on my car, ejections system underneath the hood and the sensors in the bumper are all there, factory document with option codes shows it too, menu item is just not there in the discover pro. If I change the adaptation channels to show said menu, its there, but trying to change any settings results in a 'function not available at this moment' prompt. Maybe they changed something in the control unit that controls the hood system, which no longer allows you to change anything regarding the settings?
TSR is working now as i said earlier.
I have trailer assist but that also doesn't show in the menu and cant get that to show either. I can find the adaptations regarding that setting but activating them do not result in any menu changes.
Easy entry same thing (seats reclining a few centimeters when getting out), but I cant even find the right adaptation for that in the infotainment module. Its either there under a different name, or i'm missing something.
Cheers!
MasterTommy
Amsterdam
C?ID=295586
Update #3:
Pedestrian assist is probably an entry for a different model, maybe something with active pedestrian warning or something. I misread the manual, there is no menu option stated in there so i'm probably looking for something that isn't supposed to be there.
Trailer assist is something that only activates when actually connecting a trailer to the car, and there are no settings for it.
Still on the easy access mod though. I've found some 'menuesteuerung' adaptations in the central electronics module that trigger menu options on the infotainment unit. A logical assumption would be that there are other control modules that have similar adaptation channels (the seat controllers for example).
MasterTommy
Amsterdam
C?ID=295586
Back again,
Got the easy entry working including the menu options on the infotainment.
VCDS 17.10Beta added the necessary coding options.
To enable, go into long coding in unit 36 'seat memory driver' and click yes when asked if you want to use experimental coding.
Enable the following bits:
- Byte 3 bit 1 (easy_entry_front)
- Byte 9 bit 6 (easy_entry_front_over_MMI)
If you have both an electrically adjustable driver and passenger seat, additionally enable the following bits:
In control unit 36 'seat memory driver':
- Byte 6 bit 4 (easyentry_enable_passenger_over_driverMMI) If you enable this bit if you don't have an electrically adjustable passenger seat, easy entry will not work.
In control unit 06 'seat memory passenger':
Check 'soft reset' when applying the coding, and also reboot the infotainment unit. You can also turn of the ignition and lock the car for a minute.
Cheers!
TBAx
C?ID=287144
Didn‘t work on my 2017 Skoda Octavia RS. Maybe something is missing there. Could you post an Auto-Scan for comparison?
MasterTommy
Amsterdam
C?ID=295586
I will when i get back home, although i can say there are also some adaptation channels regarding the availability of memory seats in the infotainment unit that have to be set up correctly. Will post the coding for the seat controllers and a channel map of my 5F unit later today.
MasterTommy
Amsterdam
C?ID=295586
Driver side:
Coding: 001000020000150001C281808181000000008181000000F400
ROD: EV_SeatMemorDriveSide_VW37.rod
VCID: 3C34F99DB7CB32CAA01-8068
Passenger side:
Coding: 001000020000150081C281808181000000008181000000F400
Admap of the channels relevant to seat memory functions in unit 5F:
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64 (Make sure its set on the correct bus type)
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64 (Not really sure why this one isnt activated. I'll try that later and see what it does)
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64 (again, must be the correct bus type)
I vaguely remember adjusting these last 4 channels earlier, unfortunately didnt do an admap first. I'll fiddle around with them later on and see if any of these have any influence on the seat menu option.
DV52
C?ID=194404
Tommy/TBAx: Not sure if it helps, but here is an admap from a local 2017 Tiggy (RoW) with driver-side memory seat only
;SW:5Q0-959-760-B   HW:5Q0-959-760-B ---  Seat Mem. Drvr
;Component:Sitzmemory    H08 0021	 Coding:0014000000000500018281808181000000008181000000F400
;EV_SeatMemorDriveSide	2021	EV_SeatMemorDriveSide_VW37.rod
;Thursday	16	March
;VCDS Version: Beta 17.2.4 (x64)  Data version: 20170220 DS267.3
;VCID: 3C34F198B72A0FA047-8068
Adaptation Channel Description 	Setting
IDE06869-installation position	Memory seat driver side
ENG123066-vehicle_velocity_monitoring	active
Elapsed Time: 00:00
And the 5F channels are:
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	activated
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	activated
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	activated
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	Comfort data bus
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20 	not activated
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	Comfort data bus
And the code-string comparison for hex36 module is:
Name	Aussie Tiggy		Master Tommy
Byte	Hex	Binary	       Hex	Binary
0	00	00000000	00	00000000
1	14	00010100	10	00010000
2	00	00000000	00	00000000
3	00	00000000	02	00000010
4	00	00000000	00	00000000
5	00	00000000	00	00000000
6	05	00000101	15	00010101
7	00	00000000	00	00000000
8	01	00000001	81	10000001
9	82	10000010	C2	11000010
10	81	10000001	81	10000001
11	80	10000000	80	10000000
12	81	10000001	81	10000001
13	81	10000001	81	10000001
14	00	00000000	00	00000000
15	00	00000000	00	00000000
16	00	00000000	00	00000000
17	00	00000000	00	00000000
18	81	10000001	81	10000001
19	81	10000001	81	10000001
20	00	00000000	00	00000000
21	00	00000000	00	00000000
22	00	00000000	00	00000000
23	F4	11110100	F4	11110100
24	00	00000000	00	00000000
MasterTommy
Amsterdam
C?ID=295586
;Thursday	16	March
Elapsed Time: 00:00
Hey Don,
Thanks for the info!
So the adaptation channels in the 5F unit seem to be enabled by default.
The reason my coding is different:
(Note that easy access is not enabled by default and also not configurable by the user, it is described as a function in the manual though)
Byte 3 enabled bit 1 (easy acces active), changes byte 3 hex value from 00 to 02
Byte 6 enabled bit 4 (easy entry passenger over driverMMI), changes byte 6 hex value from 05 to 15
Byte 9 enabled bit 6 (easy entry front over MMI), changes byte 9 hex value from 82 to C2
Stay tuned for some trial and error regarding those adaptation channels
MasterTommy
Amsterdam
C?ID=295586
Allright, so for this to work, you definately need to enable the correct adaptation channels in the 5F unit.
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,n ot activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_hig h,activated ,60
If you have an electric passenger seat, turn these on as well:
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,activated ,64
TBAx
C?ID=287144
Thanks guys, I‘ll check my adaption maps this afternoon and may or may not find something to go after.
The car has electric seats (with memory for only driver) and the seats menu in the Car settings in the HMI is visible containing only a setting to save position by keyfob.
TBAx
C?ID=287144
Okay, I found a scan of mine at work (don't ask why) and It appears that my car has vaguely different coding. I could find following changes, that are not explained by changes MasterTommy made:
Byte 08 > Bit 7 (me: disabled)
Byte 09 > Bit 1 (me: enabled) and Bit 2 (me: disabled)
Byte 10 > Bit 0 (me: disabled)
Byte 12 > Bit 0 (me: disabled)
Byte 13 > Bit 0 (me: disabled)
Byte 23 > Bit 5 (me: disabled)
I also found that my module is version 0020, whereas MasterTommy's is 0021, part number is identical on the other hand.
MasterTommy
Amsterdam
C?ID=295586
Do you have personalization options available in your car-menu? Aka you can create 'users' and assign them a key? If not, the easy access function is part of those personalization options. I'll have to give you a lot more coding infoto enable that...
MasterTommy
Amsterdam
C?ID=295586
Let me compare that to my long coding so i can tell you what differs in mine. Ill update when i've checked.
TBAx
C?ID=287144
Nope, not there. It's done only via keyfob. BCM is coded accordingly. Do you think it is necessary to have the Account variant rather than the keyfob variant?
Here's the coding compare:
Name	Aussie Tiggy		Master Tommy		TBAx
Byte	Hex	Binary		Hex	Binary		Hex	Binary
0	00	00000000	00	00000000	00	00000000
1	14	00010100	10	00010000	10	00010000
2	00	00000000	00	00000000	00	00000000
3	00	00000000	02	00000010	00	00000000
4	00	00000000	00	00000000	00	00000000
5	00	00000000	00	00000000	00	00000000
6	05	00000101	15	00010101	05	00000101
7	00	00000000	00	00000000	00	00000000
8	01	00000001	81	10000001	01	00000001
9	82	10000010	C2	11000010	84	10000100
10	81	10000001	81	10000001	80	10000000
11	80	10000000	80	10000000	80	10000000
12	81	10000001	81	10000001	80	10000000
13	81	10000001	81	10000001	80	10000000
14	00	00000000	00	00000000	00	00000000
15	00	00000000	00	00000000	00	00000000
16	00	00000000	00	00000000	00	00000000
17	00	00000000	00	00000000	00	00000000
18	81	10000001	81	10000001	81	10000001
19	81	10000001	81	10000001	81	10000001
20	00	00000000	00	00000000	00	00000000
21	00	00000000	00	00000000	00	00000000
22	00	00000000	00	00000000	00	00000000
23	F4	11110100	F4	11110100	D4	11010100
24	00	00000000	00	00000000	00	00000000
