Results 1 to 9 of 9
Thread: VW Passat 3.2 FSI - Idle speed tweak. Need some help.
    Sep 2017
    Norway
    Hey all!
    What a first post this is going to be. Somewhat scared and excited
    I'm from a relative shameful background.
    Myself, as I think quite a few people don't care to admit, started out with a eBay-version of the VCDS-interface.
    Lately, I've come to realise that I'm not actually a thief, and acknowledged the fact that people have worked tirelessly to develop both hardware and software (Even though the seller swore it was a genuine verison). So, I bought the new HEX-V2 directly from Ross-Tech. It is reasonably priced, and I wanted to "repent" my sins. Despite this (Which I actually didn't have to share with you, but honesty lasts longer, I'm lead to believe), I hope you'll welcome me in reaching me a hand on this one.
    So hey, here I am.
    When I had the chinese version, I think the software was limited to ver. 14.1 - I've done several mods on my car, and one which I did was to enter the engine module 01, and change the idle speed from the adaption menu.
    Now, I get sporadic air-flow errors whilst idling, and sometimes clutch engagement from standstill seems "edgy", so I want to change the idle speed back. It was 800rpm to begin with, and I changed it to 600rpm. Don't ask me why - Because I honestly don't know.
    Anyway, I tried changing the idle speed back to normal, but now when I open Engine 01 -> Adaption -> Idle speed, it says I need a security access code.
    I can't remember if I ever entered that on the 14.1 version, but I'm used to a pop-up showing the corresponding security access codes. This pop up does not show on the latest version.
    I tried code 12233, and the engine control module locked up. How do I find the appropriate code?
    The car is a 2010 VW Passat 3.2FSI (AXZ engine code).
    All help will be very appreciated, thanks!
    Tuesday,12,September,2017,19:43:44:12369
    VIN: WVWZZZ3CZAE057230   License Plate:
    Chassis Type: 3C-N/A (3C0)
    Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 36 42 44 46 52 53 55
              62 65 72
    VIN: WVWZZZ3CZAE057230   Mileage: 270490km-168074miles
    10-Park/Steer Assist -- Status: Not registered 0001
    Address 01: Engine (AXZ)       Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 906 032 HB    HW: 03H 906 032 AB
       Component: P3.2-FSI-EU4    G   4845
       Revision: 5GH04---    Serial number: VWZCZ000000000
       Coding: 0000175
       Shop #: WSC 05311 000 00000
       VCID: 698CB511257AE75FEC4-803C
    000807 - Knock Sensor 1 (G61)
                   P0327 - 002 - Signal too Low - Intermittent
                        Mileage: 268402 km
                        Date: 2011.12.03
                        Time: 23:54:26
                        RPM: 2602 /min
                        Load: 73.3 %
                        Speed: 35.0 km/h
                        Temperature: 85.0C
                        Temperature: 24.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.843 V
    012408 - Throttle Control
                   P3078 - 002 - Airflow at Idle too Low - Intermittent
                        Mileage: 269536 km
                        Date: 2011.12.25
                        Time: 21:26:37
                        RPM: 621 /min
                        Load: 24.3 %
                        Temperature: 88.0C
                        Temperature: 23.0C
                        Voltage: 13.208 V
       Part No SW: 02E 300 011 DA    HW: 02E 927 770 AM
       Component: GSG DSG AG6     531 1982
       Revision: 06253104    Serial number: 00001509260786
       Shop #: WSC 04940 001 00001
       VCID: 51FC7DF1ADEA3F9F844-8004
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --025---    Serial number: 00000795617354
       Coding: 0000395
       VCID: 629EA23DD84CB4072DE-8036
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 EB    HW: 3C0 907 044 EB
       Component: ClimatronicPQ46 133 1010
       Revision: 00133026    Serial number: 00000000000000
       VCID: 6594B921C962C33FC8C-8030
       Revision: 00H54000    Serial number: 00000003327726
       Coding: F78E8B07500214001F00325A32000000801B354364400100000000000000
       Shop #: WSC 00027 218 80666
       VCID: 3330177937366D8F968-8066
       Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
       Component: Wischer 140709 006  0208
       Coding: 00049045
       Shop #: WSC 00027
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     160909 046  0204
       Coding: 00131149
       Shop #: WSC 00027
       Part No SW: 3C8 919 475 A    HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0009
       Revision: --------    Serial number: 08720924603904
       Coding: 100102
       Shop #: WSC 05314 000 00000
       VCID: 323E127DC42C64879DE-8066
       Component: DAEMPFUNGS-SG H07 0070
       Revision: 00000000    Serial number: 15090903270001
       Coding: 010180
       VCID: 2708F329FFEE112F3A0-8072
       Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
       Component: J234__025 VW10 HI   1916
       Revision: 20013000    Serial number: 003E1PKCQE3W
       Coding: 0012853
       VCID: 42DE42BD788CD4070DE-8016
       Subsystem 1 - Serial number: 6332MTS628722449
       Subsystem 2 - Serial number: 6342MTS680052369
       Subsystem 3 - Serial number: 6351HTS6PM8N09KJ
       Subsystem 4 - Serial number: 6361HTS61P4119KJ
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C9953507CN
       Coding: 0001612
       VCID: 74B2D46572B82AB74F2-8020
       Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6   H07 0022
       Coding: 00000227
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb
       Part No SW: 3C8 920 880 F    HW: 3C8 920 880 F
       Component: KOMBI         H03 0132
       Coding: 161F00
       VCID: 2F381B09D79E496FF20-807A
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P099290305
       Coding: FD8BFF07000002002002
       Shop #: WSC 00027 218 81049
       VCID: 2A0E0A1DE0FC2C4725E-807E
                        Reset counter: 195
                        Mileage: 270492 km
                        Date: 2012.02.03
                        Time: 19:34:37
       Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
       Component: Haldex 4Motion      4013
       Coding: 0000005
       VCID: 44D244A56298DA373F2-8010
       Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 00040 218 58589
       VCID: 75B4E96179C233BF78C-8020
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
       Component: Sitzverstellung     1101
       Revision: 00005000    Serial number: 00000000000000
       VCID: 2F381B09DB1E496FF20-807A
       Part No SW: 1K0 959 701 AS    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1501
       Revision: 71009005    Serial number: 00000876798916
       Coding: 0004599
       VCID: 7F580B494BFE79EF220-802A
       Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.318 1202
       Revision: 1BH04737    Serial number: 00131890007201
       Coding: 0000258
       Shop #: WSC 00610 218 138159
       VCID: 3FD84B490B7EB9EF620-806A
       Component:    KSG PQ46 RDK 052 0412
       Coding: 0091020051034E7630041F1F700ACFCE705801
       Subsystem 1 - Part No: 1K8 951 605
       Component: LIN BACKUP HORN H09 9002
       Part No SW: 1K0 959 702 AS    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1501
       Revision: 71009005    Serial number: 00000759198910
       Coding: 0004598
       VCID: 005A88B5360006175BA-8054
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000034334
       Coding: 0000057
       VCID: 2C020C05EA083277D72-8078
       Component: AFS-Steuergeraet    0142
       Coding: 2346177
       VCID: 3432146532386AB78F2-8060
       Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000035
       Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Coding: 00000035
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000001085550
       Coding: 0000208
       VCID: 70BAD87506A01697ABA-8024
       Component:    RDK              0453
       Coding: 0161211
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000001083423
       Coding: 0000208
       VCID: 71BCDD710DAA1F9FA44-8024
    End----------(Elapsed Time: 01:32, VBatt start/end: 12.3V/12.3V)-----------
  2. Likes Uwe, Eric liked this post
  3. #2
    Welcome.
    An Auto-Scan is relevant, so people can see exactly what ECU you have.
  4. Likes 4pekatt liked this post
  5. #3
    Sep 2017
    Norway
    Welcome.
    Alright boss, I'll update this as soon as I'm back home. ~2 hours and it's done
  6. #4
    Sep 2017
    Norway
    OP updated with auto-scan.
    This is what I struggle with.
    First, I get into the engine control module, and press "Adaption".
    From there, I choose "Idle Speed Adjustment"
    Which leaves this error message.
    As stated in OP I do not know the security code, and the pop-up that usually shows the corresponding security codes does not show.
    Hmm... I went back and looked at the older versions, 12.12 and 14.10 and I don't see where a security access for that has ever been documented, nor do I know one. Yet you say you changed the channel at some point? I'm scratching my head, wondering how that's possible without one.
    Would you mind having a look at MVB 056 while the engine is idling? That will show both the actual idle speed and the currently specified speed.
    Sep 2017
    Norway
    Absolutely.
    Measuring group 056 says:
    Engine speed actual: 640 / 650rpm
    Engine speed specified: 650rpm
    Idle regulator: -0,6%
    Operation condition: 000101
    When you ask that question, I start to second guess myself.
    Not about the idle adjustment, because I remember that clear as day.
    But, if I did it from the adaption menu, I'm not sure.
    OK, so your engine is idling at the "specified" speed.
    I can't think of any way to do the idle adjustment other than via Adaptation. And it's not VCDS demanding a security access; that's the ECU itself.
  10. #8
    Sep 2017
    Norway
    Hmm.
    So there's no way I did that adaption from VCDS back then?
    How on earth did I do it? I sometimes hate my goldfish-like memory..
  11. #9
    Quote Originally Posted by 4pekatt View Post
    Well, it is possible you found one somewhere on the 'net that we don't know about.
