JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Golf MK7.5 BCM Adaptations Help Urgent Please
Hi guys i have i a mk7 golf i have retrofitted rear tail lights from MK7.5 Facelift and also used the from 7.5 problem is 7.5 codings are all 000000's and have to enable things via adaptations. Does anyone know where the option is on for automatic transmission ?
in the mk7 the coding is byte 2 bit4 but on the 7.5 i cant tick on any bytes etc
the car i have fitted the fl on is automatic and the is from manual i need to tell it the car is auto so reverse lights work they work fine with the mk7
i have tried looking for the option in the adaptation channels but cant seem to find it
i have checked to see the pinouts in the 7.5 for reverse cant seem to find it but in the mk7 its pin 11 block c in the measuring values for
reversing light switch (discreet wire) not active in 7.5 but active in 7
i believe this is my problem as 7.5 maybe from manual car
I want to use the 7.5
ANY help please
here is admaps
;SW:5Q0-937-084-CF HW:5Q0-937-084-CF --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB M+ H34 0236 Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB 17001 EV_BCMBOSCH_017_VW27.rod
;Thursday 31 August 2017 13:35:38:00772
;VCDS Version: Release 17.8.0 Data version: 20170721 DS276.2
;VCID: 7EF659AAE1F471B6F8-802A
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01550-Service position 170.494336 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl not active 10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl not active 10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit 300 ms 10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit 300 ms 10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit 300 ms 10
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100 % 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen not active 8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1 8 s 8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2 30 s 8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer logikgesteuert 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck 0 ms 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset 0.3 ° 16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.0 %/s 16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt both sides 16
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.0 km/h 16
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.0 °C 16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.0 °C 16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.0 °C 16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 80 ° 16
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.0 km/h 16
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht 15 min 16
IDE03787-Activate left/right hand drive switch-over not active 1
IDE04927-IDE01446-Window heater-Running time of heated front window 600 s 11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.0 °C 11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.0 °C 11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer 0 s 11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt not installed 11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus not installed 11
IDE04927-ENG126845-Window heater-FSH Automatik active 11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 320 s 11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe installed 11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe not installed 11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH active 11
IDE04927-ENG141962-Window heater-Waschduesenheizung installed 11
IDE04927-ENG154810-Window heater-window heating front activation time pause 240 s 11
IDE04928-MAS01577-Anti-theft device-Parking heater not installed 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 8
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system active 8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung not active 8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder Sounder_verbaut 8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor not installed 8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet Yes 8
IDE04928-ENG142249-Anti-theft device-OBD Alarm activ 8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv) No 8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung Yes 8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 8
IDE04928-ENG142008-Anti-theft device-tilt_sensor Yes 8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm 2 sekunden verzoegerung 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-Light configuration 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 38 00 22 12 00 7F 00 00 00 00 00 00 00 00 00 06 42 00 23 13 00 7F 00 00 00 00 00 00 00 00 00 224
IDE05822-DWA Vehicle inclination sensor 100 % 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67 172
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN Heizmatten am BCM 30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe not installed 30
IDE06425-Roller test bench mode: functional not active 1
IDE06507-MAS13125-Button in center console-Function of button 1 Start-stop 8
IDE06507-MAS13129-Button in center console-Function of button 2 not coded/not installed 8
IDE06507-MAS13132-Button in center console-Function of button 3 Driving program 8
IDE06507-MAS13135-Button in center console-Function of button 4 not coded/not installed 8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED LED installed 8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich active 8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt not active 8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige active 8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik active 8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt active 8
IDE07007-ENG115720-A/C heater function via remote control-Remotestart not installed 8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung active 8
IDE07356-Position during interval mode 31.494474 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs not active 6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 255 min 6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein active 6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 9
IDE08786-ENG141956-Assistance light functions-Humidity sensor installed 9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe active 9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion not active 9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor LIN_REGEN_LICHT_SENSOR 9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor not installed 9
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80 % 19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 0 19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum 50 % 19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80 % 19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer 50 % 19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn 50 % 19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen active 19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen active 19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen active 19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen active 19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen not active 19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten active 19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM not active 19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht not installed 19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel not installed 19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel not installed 19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig not active 19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G installed 19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 19
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI not active 5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI not active 5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30 % 17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25 % 17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30 % 17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25 % 17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58 % 17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53 % 17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58 % 17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53 % 17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85 % 17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80 % 17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85 % 17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80 % 17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung not installed 17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar not installed 17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik not installed 17
IDE10298-Alternating park position 1 7.494498 ° 2
IDE10299-Alternating park position 2 29.494476 ° 2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit 1 256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach 1 256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum 0.2 256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel 1 256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher 1 256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko 1 256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd 1 256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer 0.6 256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI 0 256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2 0 256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3 0 256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4 0 256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI 0 256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2 0 256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3 0 256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4 0 256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab 1 256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf 1 256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI 0 256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay 0 256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit 100 % 256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach 100 % 256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum 70 % 256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht 100 % 256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel 100 % 256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher 100 % 256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko 100 % 256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd 100 % 256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren 96 % 256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit 100 % 256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach 100 % 256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum 70 % 256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht 100 % 256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel 100 % 256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher 100 % 256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko 100 % 256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd 100 % 256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren 96 % 256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit 100 % 256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach 100 % 256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum 70 % 256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht 100 % 256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel 100 % 256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher 100 % 256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko 100 % 256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd 100 % 256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren 96 % 256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit 100 % 256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach 100 % 256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum 70 % 256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht 100 % 256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel 100 % 256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher 100 % 256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko 100 % 256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd 100 % 256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren 96 % 256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit 100 % 256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach 100 % 256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum 70 % 256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht 100 % 256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel 100 % 256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher 100 % 256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko 100 % 256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd 100 % 256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren 96 % 256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit 100 % 256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach 100 % 256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum 0 % 256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht 100 % 256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel 100 % 256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher 100 % 256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko 100 % 256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd 100 % 256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren 0 % 256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit 100 % 256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach 100 % 256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum 70 % 256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht 100 % 256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel 100 % 256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher 100 % 256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko 100 % 256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd 100 % 256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren 96 % 256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit 100 % 256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach 100 % 256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum 127 % 256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht 100 % 256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel 100 % 256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher 100 % 256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko 100 % 256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd 100 % 256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren 127 % 256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit 126 % 256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach 126 % 256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum 126 % 256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht 0 % 256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel 126 % 256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher 126 % 256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko 126 % 256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd 126 % 256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren 126 % 256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit 100 % 256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach 100 % 256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum 127 % 256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht 100 % 256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel 100 % 256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher 100 % 256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko 100 % 256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd 100 % 256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren 127 % 256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit 100 % 256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach 100 % 256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum 126 % 256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht 100 % 256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel 100 % 256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher 100 % 256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko 100 % 256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd 100 % 256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren 126 % 256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit 100 % 256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach 100 % 256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum 70 % 256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht 100 % 256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel 100 % 256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher 100 % 256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko 100 % 256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd 100 % 256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren 96 % 256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit 100 % 256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach 100 % 256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum 70 % 256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht 100 % 256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel 100 % 256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher 100 % 256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko 100 % 256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd 100 % 256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren 96 % 256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit 100 % 256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach 100 % 256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum 70 % 256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht 100 % 256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel 100 % 256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher 100 % 256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko 100 % 256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd 100 % 256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren 96 % 256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit 100 % 256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach 100 % 256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum 70 % 256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht 100 % 256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel 100 % 256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher 100 % 256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko 100 % 256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd 100 % 256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren 96 % 256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte 200 ms 256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit 0.0 s 256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach 0.0 s 256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum 0.0 s 256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht 0.0 s 256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko 0.0 s 256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren 0.0 s 256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit 0.0 s 256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach 0.0 s 256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum 2.0 s 256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht 0.0 s 256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko 0.0 s 256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren 0.5 s 256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit 0.0 s 256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach 0.0 s 256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum 0.0 s 256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht 0.0 s 256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko 0.0 s 256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren 0.0 s 256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit 0.0 s 256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach 0.0 s 256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum 0.0 s 256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht 0.0 s 256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko 0.0 s 256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren 0.0 s 256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit 0.0 s 256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach 0.0 s 256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum 0.0 s 256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht 0.0 s 256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko 0.0 s 256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren 0.0 s 256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit 0.0 s 256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach 0.0 s 256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum 0.0 s 256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht 0.0 s 256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko 0.0 s 256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren 0.0 s 256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit 0.0 s 256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach 0.0 s 256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum 0.0 s 256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht 0.0 s 256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko 0.0 s 256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren 0.0 s 256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen 0 256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1 0 30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10 0 30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2 0 30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3 0 30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4 0 30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5 0 30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6 0 30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7 0 30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8 0 30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9 0 30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1 0 30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10 0 30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2 0 30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3 0 30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4 0 30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5 0 30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6 0 30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7 0 30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8 0 30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9 0 30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1 0 30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10 0 30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2 0 30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3 0 30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4 0 30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5 0 30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6 0 30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7 0 30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8 0 30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9 0 30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung not installed 3
IDE11944-ENG141948-Keyless access and start authorization-Kessy not installed 3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen not active 3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen active 3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung not active 3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung not active 3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin 0 30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin 0 30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin 0 30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin 0 30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin 0 30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin 0 30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin 0 30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin 0 30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin 0 30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin 0 30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin 0 30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin 0 30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin 0 30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin 0 30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin 0 30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin 0 30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin 0 30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin 0 30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin 0 30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin 0 30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin 0 30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin 0 30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin 0 30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin 0 30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin 0 30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin 0 30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin 0 30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin 0 30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin 0 30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin 0 30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung active 5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation Energy management active 5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug not installed 5
MAS01490-ENG141950-Energy management-Hybrid vehicle No 5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement not active 5
MAS01490-ENG141978-Energy management-Recuperation active 5
MAS01490-ENG142037-Energy management-Zweitbatterie not installed 5
MAS05055-lower turn position 31.494474 ° 2
MAS05056-upper turn position 170.494336 ° 2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 1200 lx 24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 2200 lx 24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 0 lx 24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 600 lx 24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 1200 lx 24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 2200 lx 24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red 00 00 24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell 2000 lx 24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway not active 24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain not active 24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity frueh 24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF not active 24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe not active 24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung 0 mV 24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke 0 lx 24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung 0 mV 24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke 0 lx 24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung 2 24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren active 4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT active 4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler not installed 4
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken not active 10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken active 10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger separte 10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing not active 10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken active 10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung active 10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10 active 10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay 50 ms 10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken not active 10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken active 10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen 3 10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken not active 10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2 not active 10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing active 10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links active 10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts active 10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken active 10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing active 10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken active 10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken active 10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz not active 10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS active 10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN active 10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf active 10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu active 10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp H7 9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze 350 km/h 9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze 350 km/h 9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag Daytime running lights 9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL 5 km/h 9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich active 9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument not active 9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut not installed 9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht active 9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active 9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO not active 9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte not active 9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit not active 9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht No 5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit 0 km/h 5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA active 5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion not active 5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe not installed 5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights not installed 18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung abschaltbar über Energiemanagement 18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung abschaltbar über Energiemanagement 18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht Aktive Begrenzung 18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten Low beam 18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus manual 18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis Driver door 18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach active 18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig Hinweis_in_LDS-Stellung_Null_und_SL 18
ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer Faktor fuer x5 Minuten 18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung 46400 lx 18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung 12 lx 18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige No 18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker FALSE 18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL Yes 18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht Yes 18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht Yes 18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung Yes 18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus Enabled 18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS) discrete 18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten klemmenabhaengig 18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module installed 18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome 10 seconds 18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung active 18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP active 18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert One-sided 18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus active 18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht active 18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit 24 s 18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte not active 18
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0 0.0 % 6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1 50.0 % 6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2 100.0 % 6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0 0.0 % 6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1 50.0 % 6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2 100.0 % 6
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP present 6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung AFS: Fernlicht ueber AFS 6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset not active 6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Not Present 6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung present 6
ENG141685-Front_wash_function 10 2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA active 6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung 800 ms 6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm active 6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf active 6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition not active 6
ENG141682-ENG141966-Front_wiper-Frontwischertyp LIN 6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer not active 6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer 0 ms 6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren Deactivating 6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay 300 ms 6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz active 6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status not active 6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung not active 6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant not active 6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube not active 6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus not active 6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube active 6
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid installed 8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid installed 8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant installed 8
ENG141645-MAS00214-HW_Verbau-Brake pad wear installed 8
ENG141645-ENG142026-HW_Verbau-Druckklappe not installed 8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv not active 8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung not installed 8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor installed 8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube installed 8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung not installed 8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer not installed 8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15 active 8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung not active 8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0 -100.00 % 30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1 -100.00 % 30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2 -100.00 % 30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3 -100.00 % 30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4 -100.00 % 30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5 -100.00 % 30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6 -100.00 % 30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7 -100 30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8 -100.00 % 30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9 -100.00 % 30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0 100.0 % 30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1 90.0 % 30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2 80.0 % 30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3 70.0 % 30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4 60.0 % 30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5 50.0 % 30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6 40.0 % 30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7 30.0 % 30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8 15.0 % 30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9 0.0 % 30
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck 26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 35 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1C 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 1C 00 80 00 00 00 00 00 00 192
ENG141662-Leuchtenkonfiguration_Sonstiges 26 00 00 41 02 00 7F 00 00 00 00 00 00 00 00 00 26 00 00 42 04 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR 1-Sensor_LWR 62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges 0 mm 62
ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4 -8.00 mm/% 62
ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn -8.00 mm/% 62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe not active 62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze 90.0 % 62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze 10.0 % 62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz 15 % 62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe 10.0 s 62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1 -8.00 mm/% 62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2 -8.00 mm/% 62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1 -8.00 mm/% 62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2 -8.00 mm/% 62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante Verbundlenkerhinterachse 62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR 0.0 % 62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf 0.00 Hz 62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung 0 62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal Negative 62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1 0 mm 62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2 0 mm 62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3 0 mm 62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4 0 mm 62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand 0 mm 62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe 0 mm 62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle 95.0 % 62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle 2.5 % 62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr 0 km/h 62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr 100 Hz 62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung 0.00 Hz 62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte BCM 62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed Rear 62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht active 62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese 20.0 % 62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart not active 62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad 0.0 %/s 62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht -100.0 % 62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut not installed 62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR 0.00 s 62
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1 not active 1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2 not active 1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3 not active 1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4 not active 1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5 not active 1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6 not active 1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ not active 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.0 % 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.0 % 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.0 % 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.0 % 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.0 % 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.0 % 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.0 % 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.0 % 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.0 % 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.0 % 12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0 -5.00 % 20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1 -5.00 % 20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2 -5.00 % 20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3 -5.00 % 20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4 -5.00 % 20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0 -5 20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1 -5 20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2 -5 20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3 -5 20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4 -5 20
ENG124714-ENG142044-OCU-DWA_push active 8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare active 8
ENG124714-OCU- not installed 8
ENG124714-ENG142261-OCU-Remote HuF Abbruch 20 km/h 8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz 3 8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1 80 s 8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3 20.0 ms 8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock Via ZV-Absicherung Light 8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar active 16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten 4 16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv active 16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion profiles_active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar active 16
ENG98831-ENG142030-Personalization-Profil_Variante Konto (v. 1.x) 16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1 active 16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2 active 16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3 not active 16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4 not active 16
ENG141646-MAS01065-Querschnitts_funktionen-Brand VW 5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll active 5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung not active 5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung not active 5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21 active 5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus Pin 31 5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben active 5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme not_installed 5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem not active 5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment Right 5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side Left 5
ENG122927-RLS_close_glazing 2.0 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system installed 10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel active 10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit 2000 ms 10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit 400 ms 10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit 0 ms 10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit 0 ms 10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit 400 ms 10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor Not available 6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor Not available 6
ENG141684-SFT271875-Slave_systems_identification-Light switch Not available 6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module Not available 6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit Not available 6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System Not available 6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn Not available 6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof Not available 6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module Not available 6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind Not available 6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender Not available 6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left Not available 6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right Not available 6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left Not available 6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left Not available 6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right Not available 6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right Not available 6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker SMLS 4
ENG116588-Sonderfunktionen- not enabled 4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1 not installed 4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen active 5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus by look command via remote control key 5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen active 5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung active 5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung active 5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel active 5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung active 5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt active 5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung active 5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron active 5
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0 0.0 lx 10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1 8.0 lx 10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2 50.0 lx 10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3 80.0 lx 10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4 100.0 lx 10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0 6 10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1 6 10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2 20 10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3 50 10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4 100 10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0 0.0 lx 10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1 8.0 lx 10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2 50.0 lx 10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3 80.0 lx 10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4 100.0 lx 10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0 6 10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1 6 10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2 20 10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3 50 10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4 100 10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0 0 ms 22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1 200 ms 22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10 2000 ms 22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2 400 ms 22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3 600 ms 22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4 800 ms 22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5 1000 ms 22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6 1200 ms 22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7 1400 ms 22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8 1600 ms 22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9 1800 ms 22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0 100.0 % 22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1 100.0 % 22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10 0.0 % 22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2 95.0 % 22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3 80.0 % 22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4 40.0 % 22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5 20.0 % 22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6 10.0 % 22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7 5.0 % 22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8 3.0 % 22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9 1.0 % 22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM 0.00 s 21
ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM 0.00 s 21
ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM 0.00 s 21
ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM 0.00 s 21
ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM 0.00 s 21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung HMI 21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen 20.0 s 21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen 3.0 s 21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe not active 21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten not_active 21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung active 21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS 2 21
ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM 0.00 s 21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert 100 % 21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl Fotosensor_Kombi 21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung Always active 21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor 0.1 21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert 6.0 % 21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0 0 22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1 50 22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10 0 22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2 100 22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3 200 22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4 253 22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5 0 22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6 0 22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7 0 22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8 0 22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9 0 22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0 0 lx 22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1 50 lx 22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10 0 lx 22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2 100 lx 22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3 200 22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4 500 22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5 0 22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6 0 lx 22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7 0 lx 22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8 0 lx 22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9 0 lx 22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0 0 ms 22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1 200 ms 22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10 2000 ms 22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2 400 ms 22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3 600 ms 22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4 800 ms 22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5 1000 ms 22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6 1200 ms 22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7 1400 ms 22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8 1600 ms 22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9 1800 ms 22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0 0.0 % 22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1 1.0 % 22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10 100.0 % 22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2 3.0 % 22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3 5.0 % 22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4 11.0 % 22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5 22.0 % 22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6 40.0 % 22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7 80.0 % 22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8 95.0 % 22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9 100.0 % 22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0 0 lx 8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1 8 lx 8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2 50 lx 8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3 500 lx 8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0 100 8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1 100 8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2 100 8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3 100 8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0 0 lx 8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1 8 lx 8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2 50 lx 8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3 510 lx 8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0 6 8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1 6 8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2 100 8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3 100 8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0 0.0 % 12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1 6.0 % 12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2 16.0 % 12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3 30.0 % 12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4 60.0 % 12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5 100.0 % 12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0 10 12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1 10 12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2 100 12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3 150 12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4 220 12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5 253 12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0 0 lx 10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1 8 lx 10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2 200 lx 10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3 300 lx 10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4 500 lx 10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0 16 10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1 16 10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2 100 10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3 100 10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4 100 10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0 0 lx 10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1 50 lx 10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2 220 lx 10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3 300 lx 10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4 500 lx 10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0 6 10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1 16 10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2 25 10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3 30 10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4 50 10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0 0 12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1 10 12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2 50 12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3 100 12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4 220 12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5 253 12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0 2.0 % 12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1 2.0 % 12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2 6.0 % 12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3 10.0 % 12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4 80.0 % 12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5 100.0 % 12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0 0 lx 8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1 8 lx 8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2 50 lx 8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3 500 lx 8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0 6 8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1 6 8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2 100 8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3 100 8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0 0 lx 8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1 8 lx 8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2 50 lx 8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3 500 lx 8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0 100 8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1 100 8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2 100 8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3 100 8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0 0.0 % 6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1 50.0 % 6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2 100.0 % 6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0 0.0 % 6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1 50.0 % 6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2 100.0 % 6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0 0 lx 12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1 10 lx 12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2 100 lx 12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3 500 lx 12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4 800 lx 12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5 1020 lx 12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0 0 12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1 20 12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2 80 12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3 180 12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4 300 12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5 500 12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1 2000 ms 10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2 3000 ms 10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3 4000 ms 10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4 5100 ms 10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0 1.0 % 10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1 5 10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2 15 10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3 40 10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4 100 10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen not active 4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen not active 4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen tilting 4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1 not installed 4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3 not installed 4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo not installed 4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule LIN 4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck not_installed 9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck active 9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv not active 9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb not active 9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close not installed 9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global active 9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen active 9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen active 9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf not active 9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen not active 9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung Always 9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden Always 9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit not installed 9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach not active 9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung active 9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy active 9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder active 9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung active 9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy active 9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder active 9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal not active 9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba not active 9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau not installed 9
ENG122979-ENG141954-Vernetzung-A/C electronics installed 8
ENG122979-ENG141968-Vernetzung-Anhaengeranschlussgeraet not installed 8
ENG122979-ENG141974-Vernetzung-Bremsen_Steuergeraet installed 8
ENG122979-ENG141953-Vernetzung-Getriebesteuergeraet not installed 8
ENG122979-ENG99457-Vernetzung-Head area heater not installed 8
ENG122979-ENG142040-Vernetzung-Kunden_spezifisches_Funktions_SG not installed 8
ENG122979-ENG141969-Vernetzung-UGDO not installed 8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB not active 7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern not active 7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein active 7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein not active 7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt not installed 7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster not installed 7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion not active 7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung active 7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion active 7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung not active 7
ENG141651-ENG141957-ZV allgemein-Radio freq. 434.42MHz 7
ENG141651-ENG141958-ZV allgemein-Tankschloss Bidirectional 7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum Freigabe_Softtouch 7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung Globale Entriegelung 7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion not installed 7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck active 3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln active 3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit not active 3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR not active 3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock adjustable 3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen active 4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash not active 4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels active 7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster not installed 7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung not active 7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen not active 7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste Yes 7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung Contact control 7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster 0.0 s 7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang No 7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel active 7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen not active 7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp 1 or 2 notch rear actuator 7
ENG141681-IDE02021-ZV Komfort-Comfort closing active 8
ENG141681-IDE02022-ZV Komfort-Comfort opening not active 8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten Yes 8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen active 8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen active 8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit 600 s 8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus active 8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen active 8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen active 8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global active 8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer not active 8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar adjustable 8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen not active 8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art once 8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus not active 8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen not active 8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen not active 8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss 2-Motorenschloesser 5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal nicht invertiert 5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite not installed 5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite not installed 5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links No 5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts No 5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter not installed 5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM Driver side 5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR No 5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer Yes 5
Elapsed Time: 02:01
Try: changing "ENG122979-ENG141953-Vernetzung-Getriebesteuergeraet" from "not installed" to "installed".
thanks mate much appreciated ill try that in the morning and let you know
thanks mate much appreciated worked spot on
thanks
Hi uwe are there any options for the cruise control on there () i am trying to deactivate it i have unticked options it in engine/clocks/gateway still showing front assist not available
Not any that are obvious to me, sorry.
