Results 1 to 4 of 4
Thread: Lane Assist retrofit help (2015 mk7 GTI)
    Jul 2016
    Side Assist/Blind spot retrofit help (2015 mk7 GTI)
    I need to pick your brains on this, I installed a Side Assist retrofit kit from an online supplier. everything is hooked up and coded, however I cannot get communications between some controllers. The part number for the radar sensors is different from the ones normally used on these cars, but the seller swears that they are the same... here is my autoscan after the retrofit.
    Sunday,10,September,2017,17:18:42:24044
    VCDS Version: 17.8.0.1 (x64)
    VIN: 3VW4T7AU2XXXXXXX   License Plate:
    Mileage: 52348km-32527mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
              75 A9
    VIN: 3VW4T7AU2XXXXXXXX   Mileage: 52348km-32527miles
    Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0006
       Revision: --H13---
       Coding: 091D00324424002F1000
       Shop #: WSC 00066 790 00202
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C79EA0D4756DB2606-8078
       Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4511
       Revision: 05853104    Serial number: TFK01412101379
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 2977131948A4CE0EFD-807C
    10657 - RPM Signal from ECU
              P0726 00 [002] - Implausible Signal
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 53454000000334
       Coding: 01FA6BA13427096F0080020681C32980D62C9000408194B410435050C085
       Shop #: WSC 01383 790 50316
       VCID: 47B3B5A1FEF0187E0B-8012
       Revision: 00021000    Serial number: 0356326553
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_002_VW37.rod
       VCID: 3A55DC55BD02759684-806E
       Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 00020004200100000000000010000000
       VCID: 46ADB8A5F9FA0176F0-8012
       Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86580601151384
       Coding: 00111A464041A27969E44000011407201800000000000000000000000000
       Shop #: WSC 00066 790 00206
       ROD: EV_BCMBOSCH_014.rod
       VCID: 4AB58C95EDE2E51614-801E
       Component: WWS    141205  043 0581
       Serial number:         150211015942
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S3Y14M11D26H22M52S13
       Coding: 06A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0001WOUF00000
       Coding: 181801
                        Reset counter: 161
                        Mileage: 52099 km
                        Date: 2017.09.05
                        Time: 13:10:39
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391433812357
       Coding: 0031151011
       VCID: 3D5FD749AC2C42AEA1-8068
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 14121403271837
       Coding: 01001200FE033B
       VCID: 3851C65D830E678672-806C
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM01SKSC
       VCID: 51879BF900B4D6CE55-8004
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J1500029IVO0Q
       Coding: 303131
       Subsystem 2 - Part No SW: -----------    HW: 480 000 612 14
       Serial number: 35700000000A30543210
       Subsystem 3 - Part No SW: -----------    HW: 480 000 612 14
       Serial number: 35800000000597303213
       Subsystem 4 - Part No SW: -----------    HW: 480 401 311 14
       Serial number: 3510002BB188FC11D06C
       Subsystem 5 - Part No SW: -----------    HW: 480 401 311 14
       Serial number: 35200029D188FC109327
       Subsystem 6 - Part No SW: -----------    HW: 480 402 511 14
       Serial number: 3550002B718B3A749314
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 511 14
       Serial number: 3560002B718B3A7261DA
       Revision: FF032032    Serial number: 20141218400156
       Coding: 0410
       ROD: EV_SMLSVALEOMQB_VW37.rod
       VCID: 042962AD8F46F366AE-8050
       Part No SW: 5G1 920 856     HW: 5G1 920 856
       Component: KOMBI         342 4270
       Coding: 0BAD091A2988CF0502897A091000000000000000
       VCID: 6BFB291182D81C1E4F-803E
    16777008 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
                        Reset counter: 125
                        Mileage: 52348 km
                        Date: 2017.09.10
                        Time: 17:07:47
    16776982 - Databus
                        Reset counter: 125
                        Mileage: 52348 km
                        Date: 2017.09.10
                        Time: 17:07:44
       Revision: --------    Serial number: 16011510000552
       Coding: 0101000820085900FF00002A1C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07029
       ROD: EV_GatewConti_011.rod
       VCID: 72C53475A5F2CDD68C-8026
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29140002882510035044
       Coding: 29FFFF
       Revision: 00000000    Serial number: 15000015223004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_004_VW37.rod
       VCID: 3449F26D9F6683E65E-8060
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 5QD 907 686     HW: 5QD 907 686
       Component: HRE_Master    H12 0071
       Serial number: 6055910562
       Coding: 02011103
       ROD: EV_HREntryHella_VW32.rod
       VCID: 0E3D4085D10A893608-805A
       Lane Change Assistant 2:
    341261 - Databus
                        Reset counter: 125
                        Mileage: 52348 km
                        Date: 2017.09.10
                        Time: 17:08:25
       Serial number: 12011506050B9W
       Coding: 003F1320D000040000000000
       VCID: 40A1AEBDDBDE2F46CA-8014
       Serial number: 00000000000000594835
       Coding: 011000
       Coding: 9302
       ROD: EV_SteerAssisMQB.rod
       VCID: 3753C5618E1068FE7B-8062
    23552 - Databus
                        Reset counter: 125
                        Mileage: 52348 km
                        Date: 2017.09.10
                        Time: 17:08:41
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 13.25 V
                        Temperature: 42.0 °C
                        KFC: 5C
                        KFA: 00 00
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 13.34 V
                        uAdSensI_SwitchedKl30_xdu16: 13.34 V
    21760 - Databus
                        Reset counter: 125
                        Mileage: 52348 km
                        Date: 2017.09.10
                        Time: 17:08:41
                        Motor status: 01
                        KFC: 55
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 13.22 V
                        uAdSensI_SwitchedKl30_xdu16: 13.21 V
       Part No SW: 5G0 035 456     HW: 5G0 035 456
       Component: MIB_lite_amp  H40 0060
       Serial number: VWZ8Z1EC4023K5U
       Coding: 22000000AAAAAA0000
       ASAM Dataset: EV_AMPMst12C1ALPI 001007
       ROD: EV_AMPMst12C1ALPI.rod
       VCID: 63EB41316A08545EF7-8036
       Serial number: 3001150605063O
       Coding: 003F1320DC00040000000000
       VCID: 3FA3AD41A62050BEB3-806A
       Serial number: 00000000000000432560
       Coding: 091000
       Coding: 021A01010B000400
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B00401151412
       Coding: 027300000000000021220002001800001F0203340100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 64E9422D6F0653660E-8030
              B11CF 53 [009] - Deactivated
                        Reset counter: 126
                        Mileage: 52348 km
                        Date: 2017.09.10
                        Time: 17:09:11
                        Voltage terminal 30: 13.2 V
    6665 - No Communcation  with Front Display/Control Module
              U0257 00 [009] - -
                        Reset counter: 126
                        Mileage: 52348 km
                        Date: 2017.09.10
                        Time: 17:12:08
    6691 - Data Bus for Control/Display
              U10AD 00 [009] - No Communications
                        Reset counter: 126
                        Mileage: 52348 km
                        Date: 2017.09.10
                        Time: 17:09:15
       Component: OCULowMQBUS   007 0564
       Coding: 02730002C2823A017F1E06000000
       Shop #: WSC 00066 790 00123
       ROD: EV_OCULowMQB_VW37.rod
       VCID: 43ABA1B1CAC8345ED7-8016
    0036 - Databus
                        Reset counter: 164
    13633792 - Databus
                        Reset counter: 164
    9457171 - Audio signal output 1
              B14F1 13 [009] - Open Circuit
                        Reset counter: 108
                        Mileage: 51999 km
                        Date: 2017.09.02
                        Time: 20:05:55
    7170 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 150
                        Mileage: 52004 km
                        Date: 2017.09.04
                        Time: 10:25:24
       Serial number: 141125201646
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
    End-------------------------(Elapsed Time: 04:18)--------------------------
    Address 3C: DTCs cleared
    Address 5F,5G0 035 844 ,channel IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,adapted from,Databus extended ,to,Terminal 15 ,
    Address 5F: DTCs cleared
    Address 5F,5G0 035 844 ,channel IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,adapted from,Terminal 15 ,to,Databus extended ,
    Aug 2016
    The Hague, NL
    Looks like an Aliexpress kit?
    Feb 2017
    Where's the A5 module?
    Jul 2016
    Quote Originally Posted by ibis_white View Post
    My bad, it's Side Assist/Lane change/Blind Spot Monitoring. VW calls it so many names...
