Well that was easy Your 09 is sending nine zeroes in place of its software part number. Never seen anything quite like it, where did you get it and/or did you play with its eeprom?
No the BCM doesn't store crash data, only the airbag and power steering usually do that in a Polo 6C.
If it were mine, I would indeed let the dealer try to update that module.As for the EEPROM thing, can I do something on my end to remove the additional 0 ? Would it cause trouble if I'd go to the VW dealership and try get the BCM software flashed to the latest version as Sebastian advised me ?
I surely will, as I already scheduled an appointment ... but, do you have any idea if that would solve the additional 0 it sends, as per Eric's message ?
The update process might be interesting, with a module that doesn't know its part number. My guess is, ODIS-S will fail, but you never know. If it can start the update, it should write the new part number in there and fix the issue.
I don't know the 6C well at all, but... Where is the Immo in this car? Unless I'm blind, there's no sign of it in the Auto-Scans. Does it happen to be in the BCM in this car? If so, that might be motivation for someone to have tampered with the BCM...
Since we normally get cars with as many options as possible, I'm used to seem a Kessy in the MQB cars, so the lack of a 25 never bothered me. I guess I should pay more attention to scans of cars with less equipment.I haven't seen a 25 module in any of the mqb cars (polo 6c and brothers, golf 7 and family)
It's still in the cluster, the car won't start without it
What happens if you try it without a Security Access code?Hello people!
I decided it's not worth to make another thread so I'll just leave a video about the issue I'm having, since it's related to the same car. It was always like this, so if you guys want an 1024 debug, hope you still have my old email with them, otherwise I'll just resend it because nothing changed since.
Basically I cannot generate admaps. Could it be caused by the same issue with the BCM SW part number having an additional 0 ?
Here goes my problem, https://youtu.be/AI95vJ1kncs
