Support for Polo 6C
EduardJS
Romania
C?ID=307521
Hello guys!
I've seen this quite a few times, reading up the forum but ... I think it's for the best to just open a new thread.
Unfortunately, every time I try opening the Long Coding Helper, I get the following:
I have to accept the Experimental coding in order to see some parameters, most of them are not correctly translated, or translated at all.
Either way, I found the headlight washer system Bit, checked it, saved it, coding accepted.
Wiring is all done, everything is ok, problem is, BCM is just not triggering the washer system relay (J39) .. ( washer fluid level sensor installed, works fine -- enough fluid in the tank ), holding down the windshield washer for more than 3 seconds, with the headlights on, even engine running, nothing happening.
Connected the relay GND and BCM wire to trigger the switch, works fine, which leaves me with "faulty coding".
Seems like the BCM simply does not want to send current down the washer system wire.
I've sent an Autoscan and the channels admap / measuring values here, at support@rt, last week .. received a confirmation reply.
Saturday,09,September,2017,19:05:08:58812
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: WVWZZZ6RZFYXXXXXX   License Plate:
Mileage: 28624km-17786mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY146290   Mileage: 28624km-17786miles
Address 01: Engine (J000-CUSA)       Labels:. 04B-907-445-V1.clb
   Part No SW: 04B 906 027     HW: 04B 907 445
   Component: R3 1,4 DCM6.2 H07 8205
   Revision: 21003001
   Coding: 01114012432401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TDI03004B906027 003019
   ROD: EV_ECM14TDI03004B906027B.rod
   VCID: 5EE697A3B0B9CE37096-800A
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08503245140827
   Coding: 21DD2485892733C6091610720051842491CC90080007C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   VCID: 333016176BBB335F968-8066
Address 08: Auto HVAC (J65)       Labels:* None
   Part No SW: 6C0 819 045 C    HW: 6C0 819 045 C
   Component: Heizung       H02 0103
   Serial number:  1405291B-1136
   Coding: 201000000000000200
   ASAM Dataset: EV_HZGManueHMMValeoPQ26 001001
   ROD: EV_HZGManueHMMValeoPQ26.rod
   VCID: 2708F247AF634FFF3A0-8072
   Part No HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0047
   Serial number: 009458017422
   Coding: 000008404253005B4B844000400F078800005B0251010000000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_BCMA0_004_VW26.rod
   VCID: 55F4888FC58F0D6F58C-8000
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU001091442441673
   Coding: 0400A0
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU003091442468341
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU009091442525731
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU010091442532611
   Coding: 1400A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag00Z 001 0330
   Revision: --------    Serial number: 003LM004MBGD
   Coding: 88C0C000000000005C000000000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 313C1C1F91A7014FE44-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 820 308 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00BB15739C1930N
   Subsystem 2 - Part No SW: -----------    HW: 410 820 308 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00062837AA1D2AO
   Subsystem 3 - Part No SW: -----------    HW: 442 150 609 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00C31725223B22Z
   Subsystem 4 - Part No SW: -----------    HW: 442 150 609 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C31725220B17.
   Part No SW: 6C0 920 741 A    HW: 6C0 920 741 A
   Component: KOMBI         211 0290
   Coding: 472509002180000800083A001000000000000000
   VCID: 211CEC5FC147B1CF744-8074
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0047
   Revision: --------    Serial number: 009458017422
   Coding: 030100044F0A590071000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 6594B84F95EF9DEFC8C-8030
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2411422172402137AD1B
   Coding: 280000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61247G58362821697892
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PE9J0052
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 323E131394A13A579DE-8066
   Part No SW: 6C0 035 869 B    HW: 6C0 035 869 B
   Component: MU-E--ER      820 6220
   Serial number: 26081400010666
   Coding: 02620000BE00000041110001000000001F0004840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   VCID: 2A0E0B73BC71729725E-807E
End----------(Elapsed Time: 00:41, VBatt start/end: 12.1V/12.1V)-----------
Any idea ... any other advice ? I'm just trying to split the wire and measure it with a voltmeter, see if there's anything at all flowing through that wire while washing the windscreen.
I'm coming my original post here ( more detailed ): https://uk-polos.net/viewtopic.php?f=56&t=70119&start=30
Please advise .. when can I expect my BCM to be supported by VCDS, given it's around for 3 years now ..
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Interesting case. This module should have been covered since 2015 and looking at past Auto-Scan's from other customers, it was in fact covered.
Looking closer at your Auto-Scan, there is a communication error which results in VCDS not reading the software part number from this specific control module and only the hardware part number is read. Due to that error, VCDS isn't able to match the proper label file and instead offers the experimental coding info instead. So to sum this up, the communication error is the reason for you not seeing what you need to see and that needs to be addressed.
This is what you should see...
   Part No SW: 6C0 937 089     HW: 6C0 937 089
...while yours shows...
...and now the question is, has this always been the case for you (got any older Auto-Scans to double check?)?
EduardJS
Romania
C?ID=307521
Hello Sebastian and thanks for the fast reply. Sorry for being late, wasn't around today.
To answer your question, yes, it has always been the same. At first, I bought some aftermarket vcds cable, didn't have any idea what Ross Tech is, or anything. Here is a scan from 2 months ago, with the aftermarket cable:
Chassis Type: 6R (6C0)
Mileage: 27512km-17095miles
Address 01: Engine (J000-CUSA)       Labels: 04B-907-445-V1.clb
   Revision: 21003001
   ROD: EV_ECM14TDI03004B997027B.rod
   VCID: 5EB3F85D41E606B1BB-800A
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   VCID: 336579E99AE4FBD924-8066
Address 08: Auto HVAC (J65)       Labels: None
   ROD: EV_HZGManueHMMValeoPQ26_VW26.rod
   VCID: 275D9DB95E3C877988-8072
   Coding: 000008404253005B4B8440004007038800005B0251010000000000000000
   VCID: 55A1E77134D0C5E9EA-8000
   Coding: 0400A0
   Coding: 1400A0
   Coding: 0400A0
   Coding: 1400A0
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   VCID: 316973E160F8C9C956-8064
   VCID: 214983A130187949C6-8074
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   VCID: 65C1D7B164B055697A-8030
   Coding: 280000
197175 - Control unit for battery monitoring
          U1050 00 [008] - No Communication
                    Fault Frequency: 47
                    Reset counter: 14
                    Mileage: 27320 km
                    Date: 2017.06.26
                    Time: 00:00:02
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: OFF
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Coding: 0007
   VCID: 326B7CED65FEF2D12F-8066
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-ENT2.clb
   VCID: 2A5B648D4D2EBA1197-807E
So, when I tried coding it the first time ... I saw the same error ... then I've looked around .. did some research, found out about Ross-Tech and I thought to myself, it's something with the cable not being OEM. That's when I decided to order a HEX-NET V2.
Sad was the moment when I saw the same error.
One thing to mention is that when I try and do the channel adaptation maps, and type in 09 address, there's always this error
Don't know if it matters, but I click OK, it shows an empty adaptation map channel, where you can either hit add to log or go back, and it cancel's the mapping.
Not sure if it's related, I could make a screen recording if it helps, let me know :)
Please advise
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I have seen cases, where non-genuine VCDS hardware caused modules to crash due to communication irregularities, in most cases a power cycle fixed this while in more rare scenarios a full power down was required. What I would do is make sure the module is completely offline by pulling all its fuses (I am not a fan of removing the battery entirely, so go with the fuses first). Leave it offline for at least 15 minutes and then put them back in and try again. In addition, if this was my car I'd talk to my VW dealer and have them update that module. Per TPI 2043247 there is an update which should bump your module from 6C0-937-089-A @ 0047 to 6C0-937-089-D @ 0094 which is IMO definitely worth doing considering how many troubles those BCMs used to have.
EduardJS
Romania
C?ID=307521
I think the battery's been unplugged quite a few times now, working on AFS / BiXenon, for even more than 15 minutes, I'll just leave it unplugged again tomorrow, for more time this round, see how that turns up.
Regarding that upgrade, do you know what it involves ? I'm new to all of this, just got used to electric schemas, BCM, CAN Bus and coding stuff. That TPI thing is over my head ... what exactly do I need to ask them ? Guess it's a software update ?
If so, could I do it myself ? Tried googling it up, since I don't have any VW dealership anywhere near I live .. :(
EduardJS
Romania
C?ID=307521
Found a VW dealership ~250km from my place. Will try scheduling an appointment there, is there anything else I could do or try meanwhile ?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
We could do some debugging on our end to ensure the HEX-V2/HEX-NET works properly and doesn't "miss" the part number, though I would leave that decision to Uwe/Eric. I don't see anything right now which you could do in the meanwhile.
iichel
Netherlands, eastern part
C?ID=284912
I'm currently having a courtesy car and the byte 13 bit 4 is enabled. It goes on the fifth cycle, with headlights on.
EduardJS
Romania
C?ID=307521
Guess then I'll just have to wait until they get me that upgrade. Do you think that would fix this issue though ? Otherwise, only workaround I could think of is to find someone that has my particular BCM and ask him to send me some screenshots with each byte page.
EduardJS
Romania
C?ID=307521
Hey. Yes, it's connected to T46b ( middle connector ) / slot 34 ( double checked ). Regarding the admap ... I'm not sure what I'm looking at.. trying to grasp what adaptation maps are as well
iichel
C?ID=284912
It's just a big long list of all the adaptation channels and their values. MQB platform has a lot of them...
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I've added a workaround for the missing sw part number, which should show you coding details. Contact me directly via email please (see signature for address), so I can send you the updated data version.
EduardJS
Romania
C?ID=307521
Iuhuu, sounds promising, sent you an email :)
iichel
C?ID=284912
So, check any adaptation channel with SRA in it (SRA = Schweinwerfer Reininungs Anlage, headlight washer installation in the beautiful German language). See if the settings in the reference scan match your settings.
EduardJS
Romania
C?ID=307521
Oh, that's why I wasn't finding it .. was just searching for washer related entries ... OK, great, thanks!
EduardJS
Romania
C?ID=307521
@Sebastian, good news and bad news. Address 08 ( Auto HVAC ) module works fine now, it is being recognised after doing the update you sent me, so that's amazing, you're onto something here. Bad part is, BCM is still not being recognised, same thing happens.
@iichel, big thanks for the adaptation map! After doing the same settings for the SRA related entries, everything works fine now :) ! God, feeling relieved now.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Interesting, let's see what Uwe/Eric have to say about possible debugging this case further.
