2013 Crafter abs issue
pembsv-dubs
C?ID=250431
Hi we can not access a 2013 crafter abs ecu to code the new unit to the van, we can access with an autel but can code with that system & we can access a 2010 crafter abs ecu no problem but there was a change point in 2012 on abs software has anyone got a fix for this thanks
pembsv-dubs
C?ID=250431
Mind posting an Auto-Scan so we can see what you can access?
Thursday,07,September,2017,16:31:25:30041
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 17.8.0.1
VIN: WV1ZZZ2EZD6021118   License Plate: CP62VVS
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTB)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 Q    HW: 03L 906 012 A
   Component: R4 2,0L EDC   H26 2859
   Revision: 72H26---    Serial number: VWXDZ0L1044633
   Coding: 0119401020040C080000
   Shop #: WSC 00000 555 00117
   ASAM Dataset: EV_ECM20TDI01103L906012Q 002011
   ROD: EV_ECM20TDI01103L906012Q_002.rod
   VCID: 326CBB06655A38D64C-8066
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 A    HW: 906 900 270 2
   Component: IMMO          0805  1246
   Revision: 00805000    Serial number: VWXDZ0L1044633
   Shop #: WSC 00440 210 131598
   VCID: 2546505AEC945F6ED9-8070
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55A6209A34740FEE89-8000
Address 96: LT3 Instruments
   Part No SW: 9069023301    HW: 9069019800
   ASAM Dataset: 32 791
   ROD: CRFT_KOMBI_32_791.rod
   VCID: 010E24CA907C534E85-8054
Address 99: LT3 Ign. Switch
   Part No HW: 9069002702
   Shop #: WSC 00526 289 07043
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks        Labels: None
   Component: HF-FFB        0805  1246
   Revision: 00805000    Serial number: 12345678901234
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
9023 - Central locking; emergency opening activated: msg from elect. Ign./starter switch
            Test Complete - Active/Stored
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BF25622F290399EDF-802E
Address B4: LT3 Central Elec.
   Part No SW: 9069022001    HW: 9069013100
   ASAM Dataset: 33 833
   ROD: CRFT_EZE_33_1088.rod (*)
   VCID: 7DF6583AEC8437AEE1-8028
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 060437D6B9527476B0-8052
End-------------------------(Elapsed Time: 02:48)--------------------------
milanocito
Middle East
C?ID=322802
tray lt3 like old crafter 2007-2010
