Results 1 to 10 of 20
Thread: MK6 GLI OEM bi-xenon retrofit - coding or bridge or something else?
    Apr 2015
    Unhappy MK6 GLI OEM bi-xenon retrofit - coding or bridge or something else?
    Hey folks. Some idiot crashed into my car ('12 Jetta GLI) while it was parked and among other things I had to replace the headlights. I got OEM bi-xenons and had the repair shop install them. I purchased Kufatec adapters for 10 to 12 pin halogen to xenon which have enabled me to turn on the lights and activate the high beam shutter. Unfortunately no matter how I code with VCDS I can't get the LED DRLs to come on and I'm getting a bunch of bulb out warnings. I did not install any of the AFS/leveling components at this time. Right now I just want to get the DRLs to work and remove the error warnings.
    I know there are many postings on this topic. I have read through all the threads I could find but thus far haven't found a solution. Some posts indicated that it may be necessary to create a bridge between two of the pins on the harness to provide power to the DRLs but I'm not sure how to do that nor do I wish to damage anything. I'm also not sure that is the correct solution.
    I've been through coding nightmares before and I know how finicky it can be... hoping an expert might be able to offer recommendation. I previously very brilliantly bricked my BCM while doing a different xenon retrofit of aftermarket assemblies. I am very wary about messing with byte 18 now.
    I enabled all the appropriate bits in VCDS, tried different combinations, changed the region setting for the lights, etc. to no avail.
    Do I need to make further coding changes or do I need to perhaps bridge pins 10 and 12 as mentioned in some other threads? If so, how do I do that? I don't want to fry the electrics.
    Here is my scan. Some of the lights errors are old but still in computer while some errors remain active and are related to the retrofit problem.
    Tuesday,05,September,2017,15:01:51:48450
    VCDS Version: 17.8.0.1
    VIN: 3VW4A7AJ3CM048038   License Plate: 090517
    Mileage: 110850km-68878mi   Repair Order:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 4F 52 56 62
              72 77
    VIN: 3VW4A7AJ3CM048038   Mileage: 110850km-68878miles
    Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
       Part No SW: 06J 997 029 E    HW: 06J 907 309 B
       Component: MED17.5.2 TFSI 2 03 1510
       Revision: PAH04---    Serial number:
       Coding: 040301081C070160
       Shop #: WSC 04881 002 1048576
       VCID: 3957C43E70E4D08E8D-806C
       Part No SW: 02E 300 057 B    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2730
       Revision: 05351113    Serial number: 00001103201160
       VCID: 181121BA2B2EE98652-804C
       Revision: 00H31001
       Coding: A14B600C49260002850B06E792210041A70800
       VCID: 7BDB1E36FA58229EDF-802E
    02214 - Tire Pressure Warning
                        Reset counter: 183
                        Mileage: 110220 km
                        Date: 2011.11.06
                        Time: 16:25:35
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 48897
                        Count: 251
    Address 08: Auto HVAC
       Part No SW: 5K0 937 086 L    HW: 5K0 937 086 L
       Component: BCM PQ35 M    011 0048
       Revision: BJ011001
       Coding: 2F200ABAE02F06C480080000250009E8456C008841A08D22E48C00040040
       Shop #: WSC 64979 001 104857
       VCID: 3D5FD02EA4CCECAEA1-8068
       Component: RLS 200914 05  54  0403
       Coding: 0330AD
    25 Faults Found:
                        Fault Status: 00100111
                        Reset counter: 213
                        Mileage: 110810 km
                        Date: 2012.01.27
                        Time: 13:22:60
                        Voltage: 13.70 V
                        Fault Status: 00101010
                        Reset counter: 213
                        Mileage: 110766 km
                        Date: 2011.12.16
                        Time: 10:34:27
                        Voltage: 12.70 V
                        Reset counter: 213
                        Mileage: 110810 km
                        Date: 2012.01.27
                        Time: 13:22:60
                        Voltage: 13.70 V
                        Reset counter: 213
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 10:51:59
                        Voltage: 11.85 V
    00984 - Left Tail Light (M4)
                        Reset counter: 213
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 13:37:58
                        Voltage: 11.75 V
    00985 - Right Tail Light (M2)
                        Fault Frequency: 10
                        Reset counter: 213
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 13:37:58
                        Voltage: 11.75 V
                        Fault Frequency: 10
                        Reset counter: 213
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 13:38:47
                        Voltage: 11.70 V
                        Reset counter: 213
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 13:38:47
                        Voltage: 11.70 V
                        Reset counter: 213
                        Mileage: 110767 km
                        Date: 2011.12.23
                        Time: 07:56:18
                        Voltage: 13.85 V
                        Fault Status: 01101010
                        Reset counter: 162
                        Mileage: 110766 km
                        Date: 2011.12.16
                        Time: 10:34:26
                        Voltage: 11.80 V
                        Reset counter: 209
                        Mileage: 110766 km
                        Date: 2011.12.16
                        Time: 09:37:38
                        Voltage: 12.35 V
                        Reset counter: 213
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 13:12:06
                        Voltage: 11.80 V
                        Reset counter: 166
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 12:13:15
                        Voltage: 11.75 V
                        Reset counter: 206
                        Mileage: 110766 km
                        Date: 2011.12.16
                        Time: 10:34:26
                        Voltage: 11.80 V
    01502 - Bulb for Rear Fog; Left (L46)
                        Reset counter: 166
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 13:37:50
                        Voltage: 11.65 V
                        Reset counter: 208
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 16:30:46
                            Term 15 Off
                        Voltage: 12.05 V
                        Fault Frequency: 60
                        Reset counter: 213
                        Mileage: 106728 km
                        Date: 2017.05.11
                        Time: 13:26:26
                        Voltage: 12.05 V
                        Reset counter: 203
                        Mileage: 110767 km
                        Date: 2011.12.23
                        Time: 07:56:11
                        Voltage: 11.40 V
                        Fault Frequency: 19
                        Reset counter: 167
                        Mileage: 110766 km
                        Date: 2011.12.16
                        Time: 09:51:52
                            Term 15 Off
                        Voltage: 12.35 V
                        Fault Frequency: 21
                        Reset counter: 173
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 12:13:19
                        Voltage: 11.85 V
                        Reset counter: 162
                        Mileage: 110766 km
                        Date: 2011.12.16
                        Time: 10:34:30
                        Voltage: 13.75 V
                        Reset counter: 166
                        Mileage: 110769 km
                        Date: 2012.01.21
                        Time: 12:13:15
                        Voltage: 11.70 V
    02896 - Control Circuit for LED Module for DRL and Parking Light; Left
                        Reset counter: 173
                        Mileage: 110810 km
                        Date: 2012.01.27
                        Time: 14:15:40
                        Voltage: 13.10 V
    02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                        Reset counter: 173
                        Mileage: 110810 km
                        Date: 2012.01.27
                        Time: 14:15:40
                        Voltage: 13.10 V
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 173
                        Mileage: 110810 km
                        Date: 2012.01.27
                        Time: 14:15:40
                        Voltage: 13.00 V
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   013 0807
       Serial number: 003GTM01SU44
       Coding: 00003937
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3449F50A9F862DE65E-8060
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y1100007C8F0B
       Coding: 303245
       Serial number: 3572MSME192B1262ZZZR
       Serial number: 3582MSME772C7161ZZZ.
       Serial number: 3516KSME291F5012ZZZO
       Serial number: 3526KSME39265312ZZZL
       Serial number: 3556LSME09211712ZZZH
       Serial number: 3566LSME6F5A3212ZZZ$
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20110614300276
       Coding: 089A140000
       Shop #: WSC 00066 000 00187
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76CD0F02C97A7FF6A0-8022
       Component: E221__MFL-TAS  H06 0010
       Coding: 830000
       Part No SW: 5C6 920 971 B    HW: 5C6 920 971 B
       Coding: 271E01
       Shop #: WSC 00066 000 00118
       VCID: 2C79ED6A47B6752606-8078
       Part No SW: 7N0 907 530 K    HW: 1K0 907 951
       Component: J533  Gateway H40 1620
       Revision:   H40       Serial number: 06091101290627
       Coding: 351002
       Shop #: WSC 64979 001 1048576
       VCID: 3851C13A8BEEC98672-806C
       Part No SW: 561 919 965     HW: 561 919 965
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1829227R046005
       VCID: 63EB4656A2E8FA5EF7-8036
       VCID: 6AF52B728DC2AB1634-803E
       Revision: A1001003    Serial number: 7660408300
       VCID: 2977147E4044600EFD-807C
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 70     3201
       Revision: 00H20000
       VCID: 3449F50A57862DE65E-8060
       Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
       Component: KonzernAmp10K 0362
       Revision: --------    Serial number: BP225319948226
       VCID: 3041F91A6B9E11C63A-8064
       Component: EZE_2         H40 1620
       Coding: 01030100
       VCID: 6FC33A66BE204E3E63-803A
       Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.019  H08 0006
       Serial number:     WRH0002SAFP
       Coding: 180000
       Revision: 15110009    Serial number: 0003299509
       Coding: 0004B4
       Shop #: WSC 01383 790 50316
       VCID: 5C997DAA5796C5A6B6-8008
       Slave Passenger:
       Component: J389__TSG-HR  006 1508
       Serial number: 00000006033705
       Coding: 000490
       Part No SW: 1K0 035 180 AD    HW: 1K0 035 180 AD
       Component: Radio Prem-8  H04 0018
       Revision: -----17S    Serial number: VWZ4Z7L3192332
       Coding: 0102000001
       Shop #: WSC 00066 123 12345
       VCID: 62E543527DF2F356FC-8036
                        Reset counter: 60
                        Mileage: 90572 km
                        Date: 2016.01.22
                        Time: 16:25:50
       Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007660558605
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 354FC80E94FC34EE69-8060
    End-------------------------(Elapsed Time: 02:22)--------------------------
    Thoughts? Any help is very much appreciated! :beer:
    Apr 2015
    I'm sorry I forgot to mention that I also have OEM LED tail lights installed, in case that affects the coding requirement, particularly for byte 18. These tail lights have worked fine for two years with my current coding. Don't want to mess that up either!
    Apr 2015
    Oh, apologies but I just thought of yet another detail that may or may not be relevant. I am using a euro headlight switch and I previously retrofitted rain and light sensors without issue.
    Jan 2015
    Bosnia and Herzegovina
    you will have to play with byte 18 to get everything to work as is
    Apr 2015
    Quote Originally Posted by m87a View Post
    I assumed that would likely be part of the solution, however because of my experience bricking the BCM last time I tried a bunch of different settings for 18, I am hesitant to do too much with it until I find better guidance. I already did try a couple different settings with no success.
    Apr 2015
    Alright, so here is where I stand:
    2012 Jetta GLI Autobahn halogens
    Working correctly and installed a while ago:
    Retrofitted LED tails w/ no fogs
    Retrofitted rain/light sensor
    Euro switch
    Problematic retrofit of OEM Xenons:
    Installed 10-12 pin adapter from Kufatec
    Enabled appropriate settings in central electronics 9
    Lights turn on and high beams function properly via shutter.
    LED DRLs do not turn on (one setting for byte 18 turned them on as parking lights so I know they are getting power)
    No parking/side lights error warning, parking/side lights do not activate
    I have not installed the leveling sensor or other external components. At this time I want to just get the lights functioning normally and may install level sensor later.
    Here is my latest scan after clearing out old errors:
    Friday,08,September,2017,16:20:53:48450
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
    VCDS Version 17.8.0.1
    VIN: 3VW4A7AJ3CM048038   License Plate: SEPT8-2
    Mileage: 110870km-68891mi   Repair Order:
              72 77
    VIN: 3VW4A7AJ3CM048038   Mileage: 110870km-68891miles
       VCID: 3957C43E70E4D08E8D-806D
    Readiness: 1110 1101
       VCID: 181121BA2B2EE98652-804D
       Revision: 00H31001
       VCID: 7BDB1E36FA58229EDF-802F
       Revision: BJ011001
       Coding: 2F200ABAE02F06C480080000250009A8456C008841A08D22F48C00040040
       VCID: 3D5FD02EA4CCECAEA1-8069
       Coding: 0330AD
                        Reset counter: 179
                        Mileage: 110872 km
                        Date: 2012.01.30
                        Time: 16:10:48
                        Voltage: 13.65 V
                        Reset counter: 179
                        Mileage: 110872 km
                        Date: 2012.01.30
                        Time: 16:10:48
                        Voltage: 13.55 V
                        Reset counter: 179
                        Mileage: 110872 km
                        Date: 2012.01.30
                        Time: 16:10:48
                        Voltage: 13.55 V
    Address 15: Airbags
       Coding: 271E01
       VCID: 2C79ED6A47B6752606-8079
       Coding: 351002
       VCID: 3851C13A8BEEC98672-806D
       VCID: 63EB4656A2E8FA5EF7-8037
    Address 25: Immobilizer
       VCID: 2977147E4044600EFD-807D
       Revision: 00H20000
       VCID: 3449F50A57862DE65E-8061
       Component: KonzernAmp10K H06 0362
       VCID: 3041F91A6B9E11C63A-8065
       Coding: 01030100
       VCID: 6FC33A66BE204E3E63-803B
       Coding: 180000
       Coding: 0004B4
       VCID: 5C997DAA5796C5A6B6-8009
       Slave Passenger:
       Coding: 000490
       Coding: 0102000001
       VCID: 62E543527DF2F356FC-8037
                        Reset counter: 179
                        Mileage: 110872 km
                        Date: 2012.01.30
                        Time: 16:10:44
    End-------------------------(Elapsed Time: 01:52)--------------------------
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C008841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C208841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C208841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C978841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C978841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C048841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C048841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C068841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C068841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456CA08841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456CA08841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C028841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C028841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C038841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C038841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C548841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C548841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C558841A08D22F48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C558841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8456C008841A08D22F48C00040040,(64979/001/104857),
    Address 09: DTCs cleared
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456C008841A08D22F48C00040040,to,2F200ABAE02F06C480080000250009A8457C008841A08D22E48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8457C008841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009E8457C008841A08D22E48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009E8457C008841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009E8457D008841A08D22E48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009E8457D008841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D008841A08D22E48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D008841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D218841A08D22E48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D218841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D1F8841A08D22E48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D1F8841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D438841A08D22E48C00040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D438841A08D22E48C00040040,to,2F200ABAE02F06C480080000250009A8456D438841A08D22E48C08040040,(64979/001/104857),
    Address 09,5K0 937 086 L,recoded (Long Coding),from,2F200ABAE02F06C480080000250009A8456D438841A08D22E48C08040040,to,2F200ABAE02F06C480080000250009A8456D068841A08D22E48C00040040,(64979/001/104857),
    I have been unable to locate a list of hex settings for byte 18 to help find the right combination. Does such a list exist anywhere? Anyone have any other suggestions on coding changes?
    Thanks for any help!
  7. #7
    Jan 2015
    try byte 18: 88
    also you could try 53, 55, 8C and report
  8. #8
    Apr 2015
    Great thanks for the suggestions! I'll go try them shortly.
  9. #9
    Apr 2015
    None of those worked properly, unfortunately. When I do Eos ROW I can get the LEDs to come on as parking lights but not as DRLs/automatic via light sensor and the parking/side/corner lights also don't come on and I get error warnings.
    try byte 18: 88
  10. #10
    Jan 2015
    which hex value?
    also try 14, 2B, 40, 4C, 8D
